PA40-44-P64-DP(-PP) Data Sheet
40 pin DIP socket/44 pin PLCC plug
Supported Device/Footprints
Adapter Construction
The PA40-44-P64-DP adapter accepts 40 pin DIP devices and
plugs into 44 pin PLCC production sockets. This allows DIP
devices, or emulators with DIP plugs, to be used during
development of PLCC based products.
The adapter is made up of 2 sub-assemblies. They assemble via
connectors making the adapter modular. This way the subassemblies can be replaced when they wear out.
The PA40P64-DP-PP has a production socket only.
Device
Footprint
Mfgr
Device
Package Device
Plug
Microchip PIC16C64
DIP
PIC16C64
44 pin PLCC
PIC16C64A
PIC16C64A
PIC16C65
PIC16C65
PIC16C65A
PIC16C65A
PIC16C74
PIC16C74
PIC16C74A
PIC16C74A
Adapter Dimensions
When disassembling the adapter take care not to bend the pins.
When reassembling the adapter note the pin 1 indicators to align
the parts correctly.
Test Socket
DIP ZIF test socket:
Aries Part #: 44-6554-11
LSC Part #: 40ADZ
P64-DP
Accepts the test socket and remaps the signals to the PLCC
plug.
Test Points
are available using the DIP socket pins (.020 dia. x .130 high).
Adapter Wiring
The following chart shows the connections from the DIP device
to the adapter’s PLCC plug.
PA40-44-P64-DP
DEVICE
SIGNAL
NC
1
MCLR/Vpp
2
RA0
3
RA1
4
RA2
5
RA3
6
RA4/TOCKI
7
RA5/SS
8
RE0/RD
9
RE1/WR
10
RE2/CS
11
VDO
12
VSS
13
OSC1/CLKIN
14
OSC2/CLKOUT
15
RC0/T1CKI
16
RC1/T1CKO
N/C
17
RC2/CCP1
18
RC3/SCK/SCL
19
RD0/PSP0
RD1/PSP1
PLUG PLUG
1
44
2
43
3
42
4
41
5
40
6
39
7
38
8
37
9
36
10
35
11
34
12
33
13
32
14
31
15
30
16
29
18
28
17
27
19
26
21
24
22
23
SIGNAL
RB 7
RB 6
RB 5
RB 4
RB 3
RB 2
RB 1
RB0/INT
VDO
VSS
RD7/PSP7
RD6/PSP6
RD5/PSP5
RD4/PSP4
RC7
N/C
RC6
RC5/SDO
RC4/SDI/SDA
RD3/PSP3
RD2/PSP2
DEVICE
40
39
38
37
36
35
34
33
32
31
30
29
28
27
26
25
24
23
22
21
PA40-44-P64-DP-PP
Logical Systems Corporation
PO Box 6184, Syracuse, NY 13217-6184 USA
Tel (315) 478-0722, FAX (315) 479-6753
S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com
Doc: 40P64DP.DOC
Rev 5/5/99
Page 1 of 1
很抱歉,暂时无法提供与“PA40-44-P64-DP-PP”相匹配的价格&库存,您可以联系我们找货
