PA28-28-DP
PA28-28-DP
    LOGICALSYSTEMS(Logical Systems)
    ADAPTER 28-DIP ZIF TO 28-PLCC
PA28-28-DP 数据手册
PA28-28-DP(-PP) Data Sheet 28 pin DIP ZIF socket/28 pin PLCC plug Supported Device/Footprints Adapter Construction The PA28-28-DP adapter accepts 28 pin DIP devices and plugs into 28 pin PLCC production sockets. This allows DIP devices or emulators with DIP plugs to be used during development of PLCC based products. The adapter is made up of 3 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. The PA28-28-DP-PP has a production socket only. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket Aries Part #: 28-6554-11 LSC Part #: 28ADZ Adapter Dimensions 28-28-1-DIP Accepts the test socket and connects to the the bottom board 28PLUG Accepts the top board and provides the PLCC Plug. Adapter Wiring This adapter is wired 1 to 1. The following chart shows the connections from the DIP device to the adapter’s PLCC plug. PA28-28-DP PA28-28-DP-PP S Y S T E M S Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 www.logicalsys.com, Email: info@logicalsys.com DEVICE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PLUG 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PA28-28-DP(-PP) Data Sheet Doc: 28DP.DOC Rev 1/28/97 Page 1 of 1
PA28-28-DP 价格&库存
很抱歉,暂时无法提供与“PA28-28-DP”相匹配的价格&库存,您可以联系我们找货
