LM2901
Quad Single Supply Comparator
The LM2901 consists of four independent precision voltage
comparators with an offset voltage specification as low as 2.0 mV max
for four comparators which were designed specifically to operate from
a single power supply over a wide range of voltages.
Application areas include limit comparators, simple analog to digital
converters; pulse, squarewave and time delay generators; wide range
VCO; MOS clock timers; multivibrators and high voltage digital logic
gates.
Single or Split Supply Operation
Low Input Bias Current
Low Input Offset Current
Input Common Mode Voltage Range to Gnd
Low Output Saturation Voltage
TTL and CMOS Compatible
ORDERING INFORMATION
LM2901N Plastic
LM2901D SOIC
TA = 0° to 70° C for all packages.
LOGIC DIAGRAM
PIN ASSIGNMENT
MAXIMUM RATINGS*
PIN 3 = VCC
PIN 12 = GND
Symbol
VCC
Parameter
Value
Unit
36
±18
V
36
V
-0.3 to VCC
V
Power Supply Voltages
Single Supply
Split Supplies
VIDR
Input Differential Voltage Range
VICR
Input Common Mode Voltage Range (1)
http://www.hgsemi.com.cn
1
2014 JUN
LM2901
ISC
Output Short Circuit to Ground
IIN
Input Current, per pin (2)
TJ
Junction Temperature
Continuous
Plastic Packages
Tstg
Storage Temperature
50
mA
150
°C
-65 to +150
°C
TL
Lead Temperature, 1mm from Case for 10 Seconds
260
°C
PD
Power Dissipation @TA=25°C
Plastic Package
Derate above 25°C
1.0
8.0
W
mW/°C
Maximum Ratings are those values beyond which damage to the device may occur.
Functional operation should be restricted to the Recommended Operating Conditions.
Notes:
1. Split Power Supplies.
2. VIN
很抱歉,暂时无法提供与“LM2901M/TR”相匹配的价格&库存,您可以联系我们找货
