All elements marked as C4 and C8
apply only to 8 contact version.
H
15.81±0.20
0.90
0.48
GND
12.63
C1
GND
GND
5.08
Plating:
Contact Terminal:
Contact Area: 3µ” Gold
Solder area: Gold Flash
Underplating: Ni overall 50µ" min.
Shell: Ni overall, 30µ" min.
1.60
C3 C2
5.10
Electrical:
Voltage Rating: 50V max.
Current Rating: 1A max.
Dielectric Withstanding: 500V AC
Insulation Resistance: 1000 MΩ min.
Contact Resistance: 100 mΩ max. (signal)
300 mΩ max. (switch)
7.62
1.35
Recommended PCB Layout
General Tolerance ±0.05
Locating peg holes only applicable to locating peg version
D
12.20
C6 C5
1.70
2.54
Material:
Plastic Housing&Slider:
Thermoplastic, UL94V-0, Black
Contact Terminal & Card Detection Switch :
Phosphor Bronze
Shell,Cam Pin: Stainless Steel
Coil Spring: SWP (steel)
C5 C1
1.40
3.80
17.78
2.54
C3 C6 C2
C8 C7
C4
0.48
C1
CD C8 C4 C7
GND
3.58
C2
2.00
C3
1.00 ref. (Location of card inserted)
C5
3.90 ref. (Location of card ejected)
C6
C1
0.20 ref. (Location of card pushed)
C4
E
C7
C2 C5
12.63
C8
C7 C3 C6
5.14
1.27
Specification:
7.62
16.16
17.08±0.20
F
1.27
CD C8 C4
3.81
1.56
2.61
9x0.40
5.14
17.17±0.20
1.50
0.35
G
6.35
3.94
3.81
1.60
0.30 ref.
(Card Inserted)
18.24
15.81
6.35
9x0.90
Solder Area
2.84
Keep Out Area
Component Outline
Mechanical:
Duration: 1500 cycles
Operating Temperature: -40°C to +85°C
C
Ordering Grid
SIM7100
C4
C3
C2
C1
B
C8
C7
Electric Function
Detect Switch
Without Card
Closed
Card Inserted
Open
GND
CD
Card inserted
CD
GND
Without card
C6 C5
Switch Operation Diagram
A
2
3
4
15
00
Locating Peg
00 = Without
Product Description
Micro SIM Card Connector - Push-Push Type
6 or 8 Pin, SMT, 1.50mm Profile
12th September 2014
Revision
Date
5
CC
Tolerances (Except as Noted)
SIM7100
C PCN
C2
15/06/21
X. ± 0.35
X.° ± 5°
X.X° ± 4°
X.X ± 0.25
X.XX ± 0.15 X.XX° ± 3°
X.XXX ± 0.10 X.XXX° ± 2°
Length
Angle
6
Units:
Metric (mm)
Request Samples
and Quotation
(1,000 per reel)
SIM7100
Drawing Date
A
Packing Options
A = Tape & Reel
Part Number
By
1
1
No. of Contacts
6 or 8
Switch
1 = With (normally closed)
Profile Height
15 = 1.50mm
Detail
16.75±0.20
X
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/3
H
Micro SIM Reference
thickness = 0.76±0.08
G
F
2.19
25.00mm Mini
15.00±0.10
12.30mm Nano
7.62
C1
C5
C2
C6
C3
C7
C4
C
7.62
8x1.70
8.80mm Nano
D
12.00±0.10
15.00mm Mini
E
C8
C1
VCC
C2
RST
C3
CLK
C4
RFU
C5
GND
C6
Vpp
C7
I/O
C8
RFU
2.5C
8x2.00
5xR0.80
B
3.15
Part Number
Product Description
SIM7100
Drawing Date
A
12th September 2014
By
Detail
1
2
3
4
Revision
Date
5
CC
SIM7100
C PCN
C2
15/06/21
X. ± 0.35
X.° ± 5°
X.X ± 0.25
X.X° ± 4°
Length
Angle
6
Units:
Metric (mm)
C
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
2/3
End
H
Start
Products P/N
SIM7100
No
product
200mm min
G
No
product
350mm min
product
2
Pull Out Direction
PCS/Reel Reels/Carton PCS/Carton
8
1000
8000
cover tape
50mm min
32 +- 02
+ 0.05
-0
F
Gross Weight: 0.85kg
Label
Label
Ø330±0.05
Ø80
Cover tape
Reel
E
Carrier Tape
Ø
1.
Carton
0.35±0.05
Net Weight: 4.80kg
Gross Weight: 9.76kg
325mm
2.00±0.10
24.00±0.10
285mm
4.00±0.10
±0
10
17.55
28.40±0.10
32.00
C
set squarex4
Pull Out Direction
14.20±0.10
1.75±0.10
D
m
0m
35
35
0m
m
B
16.15
Part Number
Product Description
SIM7100
Drawing Date
A
1
2
3
2.45
1.95
12th September 2014
By
Detail
4
Revision
Date
5
CC
SIM7100
C PCN
C2
15/06/21
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
3/3
SIM7100-8-1-15-00-A 价格&库存
很抱歉,暂时无法提供与“SIM7100-8-1-15-00-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1000+8.73752
- 2000+8.44591
- 3000+8.15518
- 5000+7.74697
- 10000+7.57196
- 国内价格
- 8+15.27080
- 10+12.74100
- 100+10.99900
- 500+10.17250
- 1000+8.64660
- 2000+8.07440
