TPE4V5KHC
1-Line Bi-directional Diode
www.sot23.com.tw
Features
Mechanical Characteristics
2500W peak pulse power (8/20μs)
Package:SOD-323
Protects one data or power line
Operating voltage: 4.5V
Ultra low leakage: nA level
Ultra low clamping voltage
UL Flammability Classification Rating 94V-0
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (SURGE) 160A (8/20us)
Case Material: “Green” Molding Compound.
IC
Moisture Sensitivity: Level 3 per J-STD-020
Applications
Mobile Phones and Accessories
PU
BL
TPE4V5KHC
Qty per Reel
3000
USB VBus
Power Line Protection
Hand Held Portable Applications
Reel Size
7”
TE
Part Number
Battery Protection
CH
Ordering Information
Dimensions and Pin Configuration
1
2
1
TPE4V5KHC
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
2500
W
Peak Pulse Current (8/20µs)
IPP
160
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
°C
IC
Operating Temperature Range
kV
±30
Storage Temperature Range
Tstg
−55 to +150
°C
Symbol
Reverse Working Voltage
VRWM
VBR
Leakage Current
ILeak
VC
Clamping Voltage
Typ
TE
CJ
Unit
4.5
V
0.8
11
V
Junction Capacitance
Max
4.7
CH
Breakdown Voltage
Clamping Voltage
Min
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
15
320
Test Condition
V
IT=1mA
uA
VRWM=4.5V
V
IPP=100A,Tp=8/20μs
V
I =160A,Tp=8/20μs
pF
VR=0V, f=1MHz
WWW.TPsemi.COM
TPE4V5KHC
www.sot23.com.tw
Characteristic Curves
300
250
200
150
100
50
10
5
2
3
4
VR—Reverse Voltage(V)
Junction Capacitance vs. Reverse Voltage
40
CH
10
0.1
1
TE
1
0.1
80
100 120 140 160
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
10
100
-20
1000
100
100
80
60
40
75
100
125
Ambient Temperature_Ta(℃)
Power Derating Curve
150
Ipp-Peak Pulse Current-%of Ipp
120
25
60
80
100
IEC61000−4−2 Pulse Waveform
Peak Pulse Power vs. Pulse Time
Time (nS)
Tp-Pulse time(us)
% of Rated Power
60
PU
100
BL
Ppp-peak pulse power(W)
15
IC
Vc-Clamping Voltage(V)
Voltage (V)
CJ-Junction Capacitance (pF)
350
80
60
40
-20
T-Time(us)
8 X 20us Pulse Waveform
60
TPE4V5KHC
www.sot23.com.tw
Outline Drawing -SOD323
DIMENSIONS
MILLIMETERS
MIN
INCHES
MAX
MIN
MAX
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
TE
CH
PU
A
BL
IC
SYM
Land Pattern - SOD323
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
很抱歉,暂时无法提供与“TPE4V5KHC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.20250
- 30+0.19575
- 100+0.18225
- 500+0.16875
- 1000+0.16200
