867C
867C
    B&K
    UNIVERSALDEVICEPROGRAMMRW/USB
867C 数据手册
Data Sheet Device Programmers Models 844USB, 866C, & 867C Model 844USB Model 866C Model 867C Universal device programmers are powerful, versatile, and simple to use. Our programmers are the ideal solution for programming new chips as well as copying chips for backup or repair purposes. We offer on-going program software updates that extend device libraries and provide continuous improvements for the 844USB, 866C, and 867C programmers. Whether you are working with PLCC, SOIC, TSOP, DIP, TQFP, SSOP, PSOP or QFP packaging, we provide an extensive line of socket adapters that will work in conjunction with our programmers. Specifications 844USB over 32,000 Interface Programming Socket Buffer Features ■ Extensive device libraries ■ Fast and high performance ■ Powerful program software ■ Supports Windows® XP/Vista/7/8.1 867C EPROM, EEPROM/Flash, Serial EPROM, Microcontroller, PLD and Bi-Polar PROM (Bi-Polar PROMs 866C, & 867C) Devices Supported Device libraries 866C Common Features & Benefits over 84,000 over 85,000 USB 2.0 / USB 1.1 Compatible DIL40 pin ZIF Socket, ISP for in-circuit programming DIL48 pin ZIF Socket, ISP for in-circuit programming Erase, Random Data Fill, Fill Block, Copy Block, Move Block, Swap Block, Buffer Print, Find Text, Replace Text, GoTo Address, Checksum Calculator, 8 bit & 16 bit View Modes I.C. Tester No Power Requirements Yes 100-240 VAC, 47-63 Hz Programmer software Weight 1.1 lbs (500 g) 1.98 lbs (0.9 kg) Dimensions (W x H x D) 3.8” x 1.4” x 6.3” (95 x 35 x 160 mm) 5.5” x 2.2” x 7.7” (140 x 56 x 195 mm) One-Year Warranty Windows is a registered trademark of Microsoft Corporation in the United States and other countries. ® Technical data subject to change © B&K Precision Corp. 2015 v072215 www.bkprecision.com
很抱歉,暂时无法提供与“867C”相匹配的价格&库存,您可以联系我们找货
