XT25F64FWOIGT
XT25F64FWOIGT
    XTX(芯天下)
    WSON8_6X5MM
    XT25F64FWOIGT
XT25F64FWOIGT 数据手册
3.3V QUAD IO Serial Flash XT25F64F XT25F64F Quad IO Serial NOR Flash Datasheet * Information furnished is believed to be accurate and reliable. However, XTX Technology Inc. assumes no responsibility for the consequences of use of such information or for any infringement of patents of other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent rights of XTX Technology Inc. Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. XTX Technology Inc. products are not authorized for use as critical components in life support devices or systems without express written approval of XTX Technology Inc. The XTX logo is a registered trademark of XTX Technology Inc. All other names are the property of their respective own. Rev 1.0 Dec 8, 2021 Page 1 XT25F64F 3.3V QUAD IO Serial Flash Serial NOR Flash Memory 3.3V Multi I/O with 4KB, 32KB & 64KB Sector/Block Erase 64M -bit Serial Flash   8192K-byte  256 bytes per programmable page  Support SFDP & Unique ID  Standard, Dual, Quad SPI   Dual SPI: SCLK, CS#, IO0, IO1, WP#, HOLD#  Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3  Flexible Architecture Sector of 4K-byte Block of 32/64k-byte  Advanced security Features 3*1024-Byte Security Registers With OTP Lock Software/Hardware Write Protection Write protect all/portion of memory via software  0.3uA typ. power down current Single Power Supply Voltage   Industrial Level Temperature. (-40℃ to +85℃), MSL3 Power Consumption    2.7~3.6V Endurance and Data Retention  Minimum 100,000 Program/Erase Cycle  20-year Data Retention typical High Speed Clock Frequency  133MHz for fast read with 30pF load  Dual I/O Data transfer up to 266Mbit/s  Quad I/O Data transfer up to 532Mbit/s  Continuous Read With 8/16/32/64-byte Wrap Program/Erase Speed  Enable/Disable protection with WP# Pin  Page Program time: 0.4ms typical  Top or Bottom Block Protection  Sector Erase time: 65ms typical  Block Erase time: 0.15/0.3s typical  Chip Erase time: 30s typical Package Options    Standard SPI: SCLK, CS#, SI, SO, WP#, HOLD#  Temperature Range & Moisture Sensitivity Level        See 1.1 Available Ordering OPN  All Pb-free packages are compliant RoHS, Halogen-Free and REACH. Allows XIP(execute in place)operation  High speed Read reduce overall XiP instruction fetch time  Continuous Read with Wrap further reduce data latency to fill up SoC cache Rev 1.0 Dec 8, 2021 Page 2 3.3V QUAD IO Serial Flash XT25F64F CONTENTS 1. GENERAL DESCRIPTION ............................................................................................................................................. 5 1.1. 1.2. 1.3. 1.4. AVAILABLE ORDERING OPN ............................................................................................................................................ 5 CONNECTION DIAGRAM .................................................................................................................................................. 6 PIN DESCRIPTION........................................................................................................................................................... 6 BLOCK DIAGRAM ........................................................................................................................................................... 7 2. MEMORY ORGANIZATION ......................................................................................................................................... 8 3. DEVICE OPERATION ................................................................................................................................................... 9 4. DATA PROTECTION .................................................................................................................................................. 11 5. STATUS REGISTER .................................................................................................................................................... 14 6. COMMANDS DESCRIPTION ...................................................................................................................................... 17 6.1. 6.2. 6.3. 6.4. 6.5. 6.6. 6.7. 6.8. 6.9. 6.10. 6.11. 6.12. 6.13. 6.14. 6.15. 6.16. 6.17. 6.18. 6.19. 6.20. 6.21. 6.22. 6.23. 6.24. 6.25. 6.26. 6.27. 6.28. 7. WRITE ENABLE (WREN) (06H) ..................................................................................................................................... 20 WRITE ENABLE FOR VOLATILE STATUS REGISTER (50H) ...................................................................................................... 20 WRITE DISABLE (WRDI) (04H) ..................................................................................................................................... 21 READ STATUS REGISTER (RDSR) (05H OR 35H OR 15H) ................................................................................................... 21 WRITE STATUS REGISTER (WRSR) (01H OR 31H OR 11H) ................................................................................................ 22 READ DATA BYTES (READ) (03H).................................................................................................................................. 23 READ DATA BYTES AT HIGHER SPEED (FAST READ) (0BH) .................................................................................................. 23 DUAL OUTPUT FAST READ (3BH) ................................................................................................................................... 24 DUAL I/O FAST READ (BBH) ......................................................................................................................................... 25 QUAD OUTPUT FAST READ (6BH) .................................................................................................................................. 27 QUAD I/O FAST READ (EBH) ........................................................................................................................................ 27 PAGE PROGRAM (PP) (02H) ......................................................................................................................................... 29 QUAD PAGE PROGRAM (QPP) (32H) ............................................................................................................................. 30 SECTOR ERASE (SE) (20H) ............................................................................................................................................ 31 32KB BLOCK ERASE (BE) (52H) .................................................................................................................................... 31 64KB BLOCK ERASE (BE) (D8H).................................................................................................................................... 32 CHIP ERASE (CE) (60/C7H) .......................................................................................................................................... 33 SET BURST WITH WRAP (77H) ...................................................................................................................................... 34 DEEP POWER-DOWN (DP) (B9H) .................................................................................................................................. 35 RELEASE FROM DEEP POWER-DOWN AND READ DEVICE ID (RDI) (ABH) .............................................................................. 36 READ MANUFACTURE ID/ DEVICE ID (REMS) (90H) ........................................................................................................ 37 READ SERIAL FLASH DISCOVERABLE PARAMETER (5AH) ...................................................................................................... 38 READ UNIQUE ID(4BH) ............................................................................................................................................... 39 READ IDENTIFICATION (RDID) (9FH) .............................................................................................................................. 39 ERASE SECURITY REGISTERS (44H) ................................................................................................................................. 40 PROGRAM SECURITY REGISTERS (42H) ............................................................................................................................ 41 READ SECURITY REGISTERS (48H) .................................................................................................................................. 42 ENABLE RESET (66H) AND RESET (99H) .......................................................................................................................... 43 ELECTRICAL CHARACTERISTICS ................................................................................................................................ 44 7.1. 7.2. 7.3. 7.4. Rev 1.0 POWER-ON TIMING ..................................................................................................................................................... 44 INITIAL DELIVERY STATE ................................................................................................................................................ 44 LATCH UP CHARACTERISTICS .......................................................................................................................................... 44 ABSOLUTE MAXIMUM RATINGS...................................................................................................................................... 45 Dec 8, 2021 Page 3 3.3V QUAD IO Serial Flash 7.5. 7.6. 7.7. XT25F64F CAPACITANCE MEASUREMENT CONDITION ....................................................................................................................... 45 DC CHARACTERISTICS ................................................................................................................................................... 46 AC CHARACTERISTICS ................................................................................................................................................... 47 8. ORDERING INFORMATION ....................................................................................................................................... 50 9. PACKAGE INFORMATION ......................................................................................................................................... 51 9.1. 9.2. 9.3. 10. Rev 1.0 PACKAGE SOP8 150MIL............................................................................................................................................... 51 PACKAGE SOP8 208MIL............................................................................................................................................... 52 PACKAGE WSON8 (6X5) MM ....................................................................................................................................... 53 REVISION HISTORY .............................................................................................................................................. 54 Dec 8, 2021 Page 4 XT25F64F 3.3V QUAD IO Serial Flash 1. GENERAL DESCRIPTION The XT25F64F (64M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Dual/Quad SPI: Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2 (WP#), and I/O3 (HOLD#). 1.1. Available Ordering OPN Rev 1.0 OPN Package Type Package Carrier XT25F64FSOIGU SOP8 150mil Tube XT25F64FSOIGT SOP8 150mil Tape & Reel XT25F64FSSIGU SOP8 208mil Tube XT25F64FSSIGT SOP8 208mil Tape & Reel XT25F64FWOIGT WSON8 6x5mm Tape & Reel Dec 8, 2021 Page 5 XT25F64F 3.3V QUAD IO Serial Flash 1.2. Connection Diagram CS# 1 8 VCC SO(IO1) 2 7 HOLD#(IO3) WP#(IO2) 3 6 SCLK VSS 4 5 SI(IO0) Top View 8-PIN SOP 8 VCC CS# 1 SO(IO1) 2 7 HOLD#(IO3) Top View 6 SCLK WP#(IO2) 3 5 SI(IO0) VSS 4 8-PIN WSON 1.3. Pin Description Pin Name I/O CS# I SO (IO1) I/O Data Output (Data Input Output 1) WP# (IO2) I/O Write Protect Input (Data Input Output 2) VSS Rev 1.0 Chip Select Input Ground SI (IO0) I/O SCLK I HOLD# (IO3) I/O VCC Description Data Input (Data Input Output 0) Serial Clock Input Hold Input (Data Input Output 3) Power Supply Dec 8, 2021 Page 6 XT25F64F 3.3V QUAD IO Serial Flash 1.4. Block Diagram Status Register HOLD#(IO3) SCLK CS# SPI Command & Control Logic High Voltage Generators Page Address Latch/Counter Flash Memory Column Decode And 256-Byte Page Buffer SI(IO0) SO(IO1) Rev 1.0 Write Protect Logic And Row Decode WP#(IO2) Write Control Logic Byte Address Latch/Counter Dec 8, 2021 Page 7 XT25F64F 3.3V QUAD IO Serial Flash 2. MEMORY ORGANIZATION XT25F64F Each Device has Each block has Each sector has Each page has Remark 8M 64K/32K 4K 256 bytes 32K 256/128 16 - pages 2K 16/8 - - sectors 128/256 - - - blocks XT25F64F Block / Sector Architecture Block(64K-byte) Block(32K-byte) Sector(4K-byte) 2047 255 …… …… …… 2040 7F8000H 7F8FFFH 2039 7F7000H 7F7FFFH …… …… …… 2032 7F0000H 7F0FFFH 2031 7EF000H 7EFFFFH …… …… …… 2024 7E8000H 7E8FFFH 2023 7E7000H 7E7FFFH …… …… …… 2016 7E0000H 7E0FFFH …… …… …… …… …… …… …… …… …… 31 01F000H 01FFFFH …… …… …… 24 018000H 018FFFH 23 017000H 017FFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 8 008000H 008FFFH 7 007000H 007FFFH …… …… …… 0 000000H 000FFFH 127 254 253 126 252 …… …… 3 1 2 1 0 0 Rev 1.0 Dec 8, 2021 Address Range 7FF000H 7FFFFFH Page 8 3.3V QUAD IO Serial Flash XT25F64F 3. DEVICE OPERATION Standard SPI The device features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Dual SPI The device supports Dual SPI operation when using the “Dual Output Fast Read” and “Dual I/O Fast Read” (3BH and BBH) commands. These commands allow data to be transferred to or from the device at two times the rate of the standard SPI. When using the Dual SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. Quad SPI The device supports Quad SPI operation when using the “Quad Output Fast Read”,” Quad I/O Fast Read”(6BH, EBH) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1, and WP# and HOLD# pins become IO2 and IO3. Quad SPI commands require the non-volatile Quad Enable bit (QE) in Status Register to be set. Hold The HOLD# signal goes low to stop any serial communications with the device, but doesn’t stop the operation of write status register, programming, or erasing in progress. The operation of HOLD, need CS# keep low, and starts on falling edge of the HOLD# signal, with SCLK signal being low (if SCLK is not being low, HOLD operation will not start until SCLK being low). The HOLD condition ends on rising edge of HOLD# signal with SCLK being low (If SCLK is not being low, HOLD operation will not end until SCLK being low). The SO is high impedance, both SI and SCLK don’t care during the HOLD operation, if CS# drives high during HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be at high and then CS# must be at low. Figure1. Hold Condition CS# SCLK HOLD# Rev 1.0 HOLD HOLD Dec 8, 2021 Page 9 XT25F64F 3.3V QUAD IO Serial Flash The Reset Signaling Protocol (JEDEC 252) The protocol consists of two phases: reset request, and completion (a device internal reset). Reset Request 1. CS# is driven active low to select the SPI slave (Note1) 2. Clock (SCK) remains stable in either a high or low state (Note 2) 3. SI / IO0 is driven low by the bus master, simultaneously with CS# going active low, (Note 3) 4. CS# is driven inactive (Note 4). Repeat the steps 1-4 each time alternating the state of SI (Note 5). NOTE 1 This powers up the SPI slave. NOTE 2 This prevents any confusion with a command, as no command bits are transferred (clocked). NOTE 3 No SPI bus slave drives SI during CS# low before a transition of SCK, i.e., slave streaming output active is not allowed until after the first edge of SCK. NOTE 4 The slave captures the state of SI on the rising edge of CS#. NOTE 5 SI is low on the first CS#, high on the second, low on the third, high on the fourth (This provides a 5h pattern, to differentiate it from random noise). Reset Completion After the fourth CS# pulse, the slave triggers its internal reset. Timing Diagram and Timing Parameters Reset Signaling Protocol tCSL tCSH CS# Mode 3 SCLK Mode 0 SI SO High Z 200us Internal Reset Rev 1.0 Device is Ready Dec 8, 2021 Page 10 3.3V QUAD IO Serial Flash XT25F64F 4. DATA PROTECTION The XT25F64F provide the following data protection methods:  Write Enable (WREN) command: The WREN command is set the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation:  Power-Up / Software Reset (66H + 99H)  Write Disable (WRDI)  Write Status Register (WRSR)  Page Program (PP)  Sector Erase (SE) / Block Erase (BE) / Chip Erase (CE)  Erase Security Register / Program Security Register  Software Protection Mode: The Block Protect (BP4, BP3, BP2, BP1, BP0) bits and CMP bit define the section of the memory array that can be read but not change.  Hardware Protection Mode: WP# goes low to prevent writing status register.  Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command (ABH) and software reset (66H+99H). Rev 1.0 Dec 8, 2021 Page 11 XT25F64F 3.3V QUAD IO Serial Flash Table 1.0 XT25F64F Protected area size (CMP=0) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X X 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 126 to 127 7E0000H-7FFFFFH 128KB Upper 1/64 0 0 0 1 0 124 to 127 7C0000H-7FFFFFH 256KB Upper 1/32 0 0 0 1 1 120 to 127 780000H-7FFFFFH 512KB Upper 1/16 0 0 1 0 0 112 to 127 700000H-7FFFFFH 1MB Upper 1/8 0 0 1 0 1 96 to 127 600000H-7FFFFFH 2MB Upper 1/4 0 0 1 1 0 64 to 127 400000H-7FFFFFH 4MB Upper 1/2 0 1 0 0 1 0 to 1 000000H-01FFFFH 128KB Lower 1/64 0 1 0 1 0 0 to 3 000000H-03FFFFH 256KB Lower 1/32 0 1 0 1 1 0 to 7 000000H-07FFFFH 512KB Lower 1/16 0 1 1 0 0 0 to 15 000000H-0FFFFFH 1MB Lower 1/8 0 1 1 0 1 0 to 31 000000H-1FFFFFH 2MB Lower 1/4 0 1 1 1 0 0 to 63 000000H-3FFFFFH 4MB Lower 1/2 X X 1 1 1 0 to 127 000000H-7FFFFFH 8MB ALL 1 0 0 0 1 127 7FF000H-7FFFFFH 4KB Top Block 1 0 0 1 0 127 7FE000H-7FFFFFH 8KB Top Block 1 0 0 1 1 127 7FC000H-7FFFFFH 16KB Top Block 1 0 1 0 X 127 7F8000H-7FFFFFH 32KB Top Block 1 0 1 1 0 127 7F8000H-7FFFFFH 32KB Top Block 1 1 0 0 1 0 000000H-000FFFH 4KB Bottom Block 1 1 0 1 0 0 000000H-001FFFH 8KB Bottom Block 1 1 0 1 1 0 000000H-003FFFH 16KB Bottom Block 1 1 1 0 X 0 000000H-007FFFH 32KB Bottom Block 1 1 1 1 0 0 000000H-007FFFH 32KB Bottom Block Rev 1.0 Dec 8, 2021 Page 12 XT25F64F 3.3V QUAD IO Serial Flash Table 1.1 XT25F64F Protected area size (CMP=1) Status Register Content Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X X 0 0 0 ALL 000000H-7FFFFFH ALL ALL 0 0 0 0 1 0 to 125 000000H-7DFFFFH 8064KB Lower 63/64 0 0 0 1 0 0 to 123 000000H-7BFFFFH 7936KB Lower 31/32 0 0 0 1 1 0 to 119 000000H-77FFFFH 7680KB Lower 15/16 0 0 1 0 0 0 to 111 000000H-6FFFFFH 7MB Lower 7/8 0 0 1 0 1 0 to 95 000000H-5FFFFFH 6MB Lower 3/4 0 0 1 1 0 0 to 63 000000H-3FFFFFH 4MB Lower 1/2 0 1 0 0 1 2 to 127 020000H-7FFFFFH 8064KB Upper 63/64 0 1 0 1 0 4 to 127 040000H-7FFFFFH 7936KB Upper 31/32 0 1 0 1 1 8 to 127 080000H-7FFFFFH 7680KB Upper 15/16 0 1 1 0 0 16 to 127 100000H-7FFFFFH 7MB Upper 7/8 0 1 1 0 1 32 to 127 200000H-7FFFFFH 6MB Upper 3/4 0 1 1 1 0 64 to 127 400000H-7FFFFFH 4MB Upper 1/2 X X 1 1 1 NONE NONE NONE NONE 1 0 0 0 1 0 to 127 000000H-7FEFFFH 8188KB L-2047/2048 1 0 0 1 0 0 to 127 000000H-7FDFFFH 8184KB L-1023/1024 1 0 0 1 1 0 to 127 000000H-7FBFFFH 8176KB L-511/512 1 0 1 0 X 0 to 127 000000H-7F7FFFH 8160KB L-255/256 1 0 1 1 0 0 to 127 000000H-7F7FFFH 8160KB L-255/256 1 1 0 0 1 0 to 127 001000H-7FFFFFH 8188KB U-2047/2048 1 1 0 1 0 0 to 127 002000H-7FFFFFH 8184KB U-1023/1024 1 1 0 1 1 0 to 127 004000H-7FFFFFH 8176KB U-511/512 1 1 1 0 X 0 to 127 008000H-7FFFFFH 8160KB U-255/256 1 1 1 1 0 0 to 127 008000H-7FFFFFH 8160KB U-255/256 Rev 1.0 Dec 8, 2021 Page 13 XT25F64F 3.3V QUAD IO Serial Flash 5. STATUS REGISTER Table2.1 Status Register-1 S7 SRP0 S6 BP4 S5 BP3 S4 BP2 S3 BP1 S2 BP0 S1 WEL S0 WIP Status Block Protect Block Protect Block Protect Block Protect Block Protect Write Enable Erase/Write In Register Bit Bit Bit Bit Bit Latch Progress Protection Bit Non-volatile Non-volatile Non-volatile Non-volatile Non-volatile Non-volatile Volatile, Volatile, Read Only Read Only S10 Reserved S9 QE S8 SRP1 Table2.2 Status Register-2 S15 Reserved S14 CMP S13 LB3 S12 LB2 S11 LB1 Reserved Complement Security Security Security Protect Bit Register Lock Register Lock Register Lock Bit Bit Bit Reserved Quad Enable Status Register Protection Bit Reserved Non-volatile Non-volatile Non-volatile Non-volatile writable (OTP) writable (OTP) writable (OTP) Reserved Non-volatile Non-volatile Table2.3 Status Register-3 S23 Reserved Reserved Reserved S22 DRV1 S21 DRV0 Output Driver Output Driver Strength Strength Non-volatile Non-volatile S20 Reserved S19 Reserved S18 Reserved S17 Reserved S16 DC Reserved Reserved Reserved Reserved Dummy Configuration Bit Reserved Reserved Reserved Reserved Non-volatile The status and control bits of the Status Register are as follows: WIP bit. The Write In Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register progress, when WIP bit sets 0, means the device is not in program/erase/write status register progress. WEL bit. The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write Status Rev 1.0 Dec 8, 2021 Page 14 XT25F64F 3.3V QUAD IO Serial Flash Register, Program or Erase command is accepted. BP4,BP3, BP2, BP1, BP0 bits. The Block Protect (BP4, BP3, BP2, BP1, BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to 1, the relevant memory area (as defined in Table 1.0 & 1.1) becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP4, BP3, BP2, BP1, BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed if the Block Protect (BP2, BP1, BP0) bits are 0 and CMP=0 or the Block Protect (BP2, BP1, BP0) bits are 1 and CMP=1. SRP1, SRP0 The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the status register. The SRP bits control the type of write protection: software protection, hardware protection, power supply lockdown or one-time programmable protection. SRP1 SRP0 WP# Status Register Description 0 0 X Software Protected The Status Register can be written to after a Write Enable command, WEL=1. (Default) 0 1 0 Hardware Protected WP#=0, the Status Register locked and cannot be written to. 0 1 1 Hardware Unprotected WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. 1 0 X Power Supply LockDown Status Register is protected and cannot be written to again Note 1 until the next Power-Down, Power-Up cycle. 1 1 X One-Time Program Note 2 Status Register is protected and cannot be written to. NOTE: 1. When SRP1, SRP0= (1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. This feature is available on special order. Please contact XTX for details. QE bit. The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the WP# pin and HOLD# pin are enable. When the QE pin is set to 1, the Quad IO2 and IO3 pins are enabled. LB3, LB2, LB1 bits. The LB3, LB2, LB1 bit are non-volatile One Time Program (OTP) bits in Status Register (S13,S12,S11) that provide the write protect control and status to the Security Registers. The default state of LB3, LB2,LB1 bits are 0, the security registers are unlocked. LB3,LB2,LB1 can be set to 1 using the Write Register instruction. LB2,LB1 are One Time Programmable, once they are set to 1, the Security Registers will become read-only permanently. CMP bit. The CMP bit is a non-volatile Read/Write bit in the Status Register (S14). It is used in conjunction with the Rev 1.0 Dec 8, 2021 Page 15 XT25F64F 3.3V QUAD IO Serial Flash BP4-BP0 bits to provide more flexibility for the array protection. Please see the Status registers Memory Protection table for details. The default setting is CMP=0. DC bit The Dummy Configuration (DC) bit is non-volatile, which selects the number of dummy cycles between the end of address and the start of read data output. Dummy cycles provide additional latency that is needed to complete the initial read access of the flash array before data can be returned to the host system. Some read commands require additional dummy cycles as the SCLK frequency increases. The following dummy cycle tables provide different dummy cycle settings that are configured. Command DC Bit BBH EBH Dummy Clock Cycles Freq. 0 (Default) 4 104MHz 1 8 133MHz 0 (Default) 6 104MHz 1 10 133MHz DRV1, DRV0 The Output Driver Strength (DRV1 & DRV0) bits are used to determine the output driver strength for the Read operations. Table 2.4 DRV1, DRV0 Driver Strength Table Rev 1.0 DRV1 DRV0 Driver Strength 0 0 25% 0 1 50% 1 0 75% (default) 1 1 100% Dec 8, 2021 Page 16 XT25F64F 3.3V QUAD IO Serial Flash 6. COMMANDS DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-byte command code must be shifted in to the device, most significant bit first on SI, each bit being latched on the rising edges of SCLK. See Table 3, every command sequence starts with a one-byte command code. Depending on the command, this might be followed by address bytes, or by data bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been shifted in. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. CS# can be driven high after any bit of the data-out sequence is being shifted out. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input byte is not a full byte, nothing will happen and WEL will not be reset. Table 3. Commands Command Name Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 n-Bytes Write Enable 06H Write Enable for Volatile Status Register 50H Write Disable 04H Read Status Register-1 05H (S7-S0) (continuous) Read Status Register-2 35H (S15-S8) (continuous) Read Status Register-3 15H (S23-S16) (continuous) Write Status Register-1 01H (S7-S0) Write Status Register-2 31H (S15-S8) Write Status Register-3 11H (S23-S16) Read Data 03H A23-A16 A15-A8 A7-A0 (D7-D0) Fast Read 0BH A23-A16 A15-A8 A7-A0 dummy Dual Output Fast Read 3BH A23-A16 A15-A8 A7-A0 dummy Dual I/O Fast Read BBH A23-A8 Quad Output Fast Read 6BH A23-A16 Quad I/O Fast Read EBH Page Program 02H A23-A16 A15-A8 A7-A0 Quad Page Program 32H A23-A16 A15-A8 A7-A0 Sector Erase 20H A23-A16 A15-A8 A7-A0 Block Erase(32KB) 52H A23-A16 A15-A8 A7-A0 Rev 1.0 (2) (S15-S8) A7-A0 (2) M7-M0 A23-A0 (4) M7-M0 A15-A8 Dummy (5) Dec 8, 2021 (D7-D0) (D7-D0) (D7-D0) (1) (1) A7-A0 (D7-D0) (continuous) (continuous) (continuous) (continuous) dummy (3) (D7-D0) (3) (continuous) (continuous) (D7-D0) (to byte256) (3) (to byte256) (D7-D0) Page 17 XT25F64F 3.3V QUAD IO Serial Flash Block Erase(64KB) D8H Chip Erase A23-A16 A15-A8 A7-A0 dummy dummy dummy W6-W4 dummy dummy dummy (DID7-DID0) C7/60H Set Burst with Wrap 77H Deep Power-Down B9H Release From Deep Power-Down, And Read Device ID Release From Deep ABH (continuous) ABH Power-Down Manufacturer/Device ID 90H A23-A16 A15-A8 A7-A0 (MID7MID0) Read Serial Flash Discoverable Parameters 5AH A23-A16 A15-A8 A7-A0 dummy (D7-D0) (continuous) Read Unique ID 4BH dummy dummy dummy dummy (UID127UID120) (to UID0) Read Identification 9FH (MID7MID0) (JDID15-J (JDID7-JDI DID8) D0) 44H A23-A16 A15-A8 A7-A0 42H A23-A16 A15-A8 A7-A0 (D7-D0) Read Security Register 48H A23-A16 A15-A8 A7-A0 dummy Enable Reset 66H Reset 99H Erase Security Register (6) Program Security Register (6) (6) (DID7-DID0) (continuous) (continuous) (Next byte) (to byte256) (D7-D0) (to byte256) NOTE: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8,A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9,A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 Rev 1.0 Dec 8, 2021 Page 18 XT25F64F 3.3V QUAD IO Serial Flash IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. Quad I/O Fast Read Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 6. Security Registers Address: Security Register1: A23-A16=00H, A15-A8=10H, A7-A0= Byte Address; Security Register2: A23-A16=00H, A15-A8=20H, A7-A0= Byte Address; Security Register3: A23-A16=00H, A15-A8=30H, A7-A0= Byte Address. Table of ID Definitions: XT25F64F Operation Code MID7-MID0 ID15-ID8 9FH 0B 40 90H 0B 17 16 ABH Rev 1.0 ID7-ID0 16 Dec 8, 2021 Page 19 3.3V QUAD IO Serial Flash XT25F64F 6.1. Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE), Erase/Program Security Register and Write Status Register (WRSR) command. The Write Enable (WREN) command sequence: CS# goes low  Sending the Write Enable command CS# goes high. Figure 2. Write Enable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO 06H High-Z 6.2. Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical nonvolatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command and any other commands can't be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Figure 3. Write Enable for Volatile Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI SO Rev 1.0 50H High-Z Dec 8, 2021 Page 20 XT25F64F 3.3V QUAD IO Serial Flash 6.3. Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes low Sending the Write Disable command CS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase commands. Figure 4. Write Disable Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 04H High-Z SO 6.4. Read Status Register (RDSR) (05H or 35H or 15H) The Read Status Register (RDSR) command is for reading the Status Register. The Status Register can be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write In Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. The command code “35H”, the SO will output Status Register bits S15~S8. The command code “15H”, the SO will output Status Register bits S23~S16. Figure 5. Read Status Register Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI SO 05H or 35H or 15H High-Z Register 1/2/3 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 MSB Rev 1.0 Register 1/2/3 Dec 8, 2021 MSB Page 21 XT25F64F 3.3V QUAD IO Serial Flash 6.5. Write Status Register (WRSR) (01H or 31H or 11H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register (WRSR) command has no effect on the volatile bits of the Status Register. CS# must be driven high after the eighth or sixteenth bit of the data byte has been latched in. If not, the Write Status Register (WRSR) command is not executed. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, BP0) bits, to define the size of the area that is to be treated as read-only, as defined in Table 1.0 & 1.1. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP) bit and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. For command code “01H”, the SI will input Status Register bits S7~S0, S15~S8. For the command code “31H”, the SI will input Status Register bits S15~S8. For the command code “11H”, the SI will input Status Register bits S23~S16. Figure 6. Write Status Register Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI 01H Status Register in Status Register in 7 6 5 4 3 2 1 0 15 14 13 12 11 10 9 8 MSB MSB High-Z SO CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI Command Status Register in 01H/31H/11H 7 6 5 4 3 2 1 0 MSB High-Z SO Rev 1.0 Dec 8, 2021 Page 22 XT25F64F 3.3V QUAD IO Serial Flash 6.6. Read Data Bytes (READ) (03H) The Read Data Bytes (READ) command is followed by a 3-byte address (A23-A0), each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fR, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 7. Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI 24-bit address(A23:A0) 03H 23 22 21 20 19 MSB High-Z SO 7 6 5 4 3 2 1 0 Data Out1 MSB Data Out2 7 6 5 4 3 2 1 0 6.7. Read Data Bytes At Higher Speed (Fast Read) (0BH) The Read Data Bytes at Higher Speed (Fast Read) command is for fast reading data out. It is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 8. Read Data Bytes at Higher Speed Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 24-bit address(A23:A0) 0BH 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO 7 6 5 4 3 2 1 MSB Rev 1.0 Dec 8, 2021 Data Out2 0 7 6 5 4 3 2 1 Data Out3 0 MSB Page 23 XT25F64F 3.3V QUAD IO Serial Flash 6.8. Dual Output Fast Read (3BH) The Dual Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure 9. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 9. Dual Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 3BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 6 4 2 0 6 4 2 Data Out1 SO Rev 1.0 0 6 4 2 0 6 4 2 Data Out2 7 5 3 1 7 5 3 MSB MSB Dec 8, 2021 Data Out3 0 6 Data Out4 1 7 5 3 1 7 5 3 MSB MSB 1 7 Page 24 XT25F64F 3.3V QUAD IO Serial Flash 6.9. Dual I/O Fast Read (BBH) The Dual I/O Fast Read command is similar to the Dual Output Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte 2-bit per clock by SI and SO, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 2-bit per clock cycle from SI and SO. The command sequence is shown in Figure 10. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The number of dummy clocks is 4 by default (M7-M0 Byte is considered to be 4 dummy clocks). Also can be set to 8 by the DC bit of Status Register. Dual I/O Fast Read with “Continuous Read Mode” The Dual I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7- 0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5- 4) =(1, 0), then the next Dual I/O Fast Read command (after CS# is raised and then lowered) does not require the BBH command code. The command sequence is shown in figure 10a. If the “Continuous Read Mode” bits (M54) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Figure 10. Dual I/O Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) BBH SO(IO1) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A7-0 A15-8 M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Rev 1.0 Byte2 Byte3 Dec 8, 2021 Byte4 Byte5 Byte6 Page 25 XT25F64F 3.3V QUAD IO Serial Flash Figure 10a. Dual I/O Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 A23-16 A15-8 A7-0 M7-0 CS# 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Rev 1.0 Byte2 Dec 8, 2021 Byte3 Byte4 Page 26 XT25F64F 3.3V QUAD IO Serial Flash 6.10. Quad Output Fast Read (6BH) The Quad Output Fast Read command is followed by 3-byte address (A23-A0) and a dummy byte, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The command sequence is shown in Figure 11. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Figure 11. Quad Output Fast Read Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI(IO0) 6BH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO(IO1) High-Z WP#(IO2) High-Z HOLD#(IO3) CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Byte5 Byte6 Byte7 Byte8 6.11. Quad I/O Fast Read (EBH) The Quad I/O Fast Read command is similar to the Dual I/O Fast Read command but with the capability to input the 3-byte address (A23-0) and a “Continuous Read Mode” byte and 4 dummy clock 4-bit per clock by IO0, IO1, IO3, IO4, each bit being latched in during the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The command sequence is shown in Figure 12. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. The Quad Enable bit (QE) of Status Register (S9) must be set to enable for the Quad I/O Fast read command. The number of dummy clocks is 6 by default (M7-M0 Byte is considered to be 2 dummy clocks). Also can be set to 10 by the DC bit of Status Register. Rev 1.0 Dec 8, 2021 Page 27 XT25F64F 3.3V QUAD IO Serial Flash Figure 12. Quad I/O Fast Read Sequence Diagram (M5-4≠(1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 3 7 3 7 EBH HOLD#(IO3) A23-16 A15-8 A7-0 M7-0 Byte1 Byte2 Dummy Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M54) =(1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH command code. The command sequence is shown in Figure 12a. If the “Continuous Read Mode” (M54) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5- 4) before issuing normal command. Figure 12a. Quad I/O Fast Read Sequence Diagram (M5-4= (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Quad I/O Fast Read with ““8/16/32/64-Byte Wrap Around” in Standard SPI mode The Quad I/O Fast Read command can be used to access a specific portion within a page by issuing “Set Burst with Wrap” (77H) commands prior to EBH. The “Set Burst with Wrap” (77H) command can either enable or disable the “Wrap Around” feature for the following EBH commands. When “Wrap Around” is enabled, the data being accessed can be limited to either an 8/16/32/64-byte section of a 256-byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 8/16/32/64byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. Rev 1.0 Dec 8, 2021 Page 28 XT25F64F 3.3V QUAD IO Serial Flash The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read commands. The “Set Burst with Wrap” command allows three “Wrap Bits” W6-W4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-W5 is used to specify the length of the wrap around section within a page. 6.12. Page Program (PP) (02H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three address bytes and at least one data byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes low Sending Page Program command 3-byte address on SI at least 1 byte data on SI  CS# goes high. The command sequence is shown in Figure 13. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) is not executed. Figure 13. Page Program Sequence Diagram CS# 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 0 1 2 3 4 5 6 7 8 9 10 11 SCLK 24-bit address(A23:A0) Command SI 02H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB Rev 1.0 Data Byte4 Data Byte3 MSB MSB Dec 8, 2021 Data Byte256 7 6 5 4 3 2 1 0 MSB Page 29 XT25F64F 3.3V QUAD IO Serial Flash 6.13. Quad Page Program (QPP) (32H) The Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. To use Quad Page Program the Quad enable in status register Bit 9 must be set (QE=1). A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Quad Page Program command is entered by driving CS# Low, followed by the command code (32H), three address bytes and at least one data byte on IO pins. The command sequence is shown in Figure 14. If more than 256 bytes are sent to the device, previously latched data are discarded and the last 256 data bytes are guaranteed to be programmed correctly within the same page. If less than 256 data bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other bytes of the same page. CS# must be driven high after the eighth bit of the last data byte has been latched in; otherwise the Quad Page Program command is not executed. As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Quad Page Program command applied to a page which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) will not be executed. Figure 14. Quad Page Program Sequence Diagram CS# 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 0 1 2 3 4 5 6 7 8 9 10 11 SCLK 24-bit address(A23:A0) Command SI(IO0) 32H 23 22 21 20 19 7 6 5 4 3 2 1 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 MSB Byte1 Byte2 Byte3 Byte4 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 536 537 538 539 540 541 542 543 CS# SCLK SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 Byte5 Rev 1.0 Byte6 Byte7 Byte8 Byte9 Byte10 Byte11 Byte12 Byte13 Byte14 Byte15 Byte16 Dec 8, 2021 Byte253 Byte254 Byte255 Byte256 Page 30 XT25F64F 3.3V QUAD IO Serial Flash 6.14. Sector Erase (SE) (20H) The Sector Erase (SE) command is for erasing the all data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3-address byte on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. CS# must be driven low for the entire duration of the sequence. The Sector Erase command sequence: CS# goes low  Sending Sector Erase command  3-byte address on SI  CS# goes high. The command sequence is shown in Figure 15. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the Sector Erase (SE) command is not executed. As soon as CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) com-mand applied to a sector which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bit (see Table 1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 15. Sector Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 20H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.15. 32KB Block Erase (BE) (52H) The 32KB Block Erase (BE) command is for erasing the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 32KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI. Any address inside the block is a valid address for the 32KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 32KB Block Erase command sequence: CS# goes low  Sending 32KB Block Erase command  3-byte address on SI CS# goes high. The command sequence is shown in Figure 16. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 32KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table 1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Rev 1.0 Dec 8, 2021 Page 31 XT25F64F 3.3V QUAD IO Serial Flash Figure 16. 32KB Block Erase Sequence Diagram CS 24 25 26 27 28 29 30 31 0 1 2 3 4 5 6 7 8 9 10 11 SCLK Command SI 52H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB 6.16. 64KB Block Erase (BE) (D8H) The 64KB Block Erase (BE) command is for erasing the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 64KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and three address bytes on SI. Any address inside the block is a valid address for the 64KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 64KB Block Erase command sequence: CS# goes low  Sending 64KB Block Erase command  3-byte address on SI  CS# goes high. The command sequence is shown in Figure 17. CS# must be driven high after the eighth bit of the last address byte has been latched in; otherwise the 64KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tBE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase (BE) command applied to a block which is protected by the Block Protect (BP4, BP3, BP2, BP1, BP0) bits (see Table 1.0 & 1.1) will not be executed. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 17. 64KB Block Erase Sequence Diagram CS 24 25 26 27 28 29 30 31 0 1 2 3 4 5 6 7 8 9 10 11 SCLK Command SI D8H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Rev 1.0 Dec 8, 2021 Page 32 3.3V QUAD IO Serial Flash XT25F64F 6.17. Chip Erase (CE) (60/C7H) The Chip Erase (CE) command is for erasing the all data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). CS# must be driven Low for the en-tire duration of the sequence. The Chip Erase command sequence: CS# goes lowSending Chip Erase commandCS# goes high. The command sequence is shown in Figure 18. CS# must be driven high after the eighth bit of the command code has been latched in, otherwise the Chip Erase command is not executed. As soon as CS# is driven high, the selftimed Chip Erase cycle (whose duration is tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect (BP2, BP1, BP0) bits are 0 and CMP=0 or the Block Protect (BP2,BP1,and BP0)bits are 1 and CMP=1. The Chip Erase (CE) command is ignored if one or more sectors are protected. Note: Power disruption during erase operation will cause incomplete erase, thus recommend to perform a re-erase once power resume. Figure 18. Chip Erase Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI Rev 1.0 60H or C7H Dec 8, 2021 Page 33 XT25F64F 3.3V QUAD IO Serial Flash 6.18. Set Burst with Wrap (77H) The Set Burst with Wrap command is used in conjunction with “Quad I/O Fast Read” command to access a fixed length of 8/16/32/64-byte section within a 256-byte page, in standard SPI mode. The Set Burst with Wrap command sequence: CS# goes low Send Set Burst with Wrap command Send 24 dummy bits Send 8 bits “Wrap bits”CS# goes high W4=0 W6,W5 W4=1(default) Wrap Around Wrap Length Wrap Around Wrap Length 0,0 Yes 8-byte No N/A 0,1 Yes 16-byte No N/A 1,0 Yes 32-byte No N/A 1,1 Yes 64-byte No N/A If the W6-W4 bits are set by the Set Burst with Wrap command, all the following “Quad I/O Fast Read” command will use the W6-W4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap command should be issued to set W4=1. Figure 19. Set Burst with Wrap Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 SCLK Command SI(IO0) 77H X X X X X X 4 X SO(IO1) X X X X X X 5 X WP#(IO2) X X X X X X 6 X HOLD#(IO3) X X X X X X X X W6-W4 Rev 1.0 Dec 8, 2021 Page 34 XT25F64F 3.3V QUAD IO Serial Flash 6.19. Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and puts the device in the Standby Mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the device has entered the Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down and Read Device ID command (ABH) and software reset (66H+99H). This releases the device from this mode. The Release from Deep Power-Down and Read Device ID (RDI) command (ABH) also allows the Device ID of the device to be output on SO. The Deep Power-Down Mode automatically stops at Power-Down, and the device always Power-Up in the Standby Mode. The Deep Power-Down (DP) command is entered by driving CS# low, followed by the command code on SI. CS# must be driven low for the entire duration of the sequence. The Deep Power-Down command sequence: CS# goes lowSending Deep Power-Down commandCS# goes high. The command sequence is shown in Figure 20. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command is not executed. As soon as CS# is driven high, it requires a delay of tDP before the supply current is reduced to ICC2 and the Deep Power-Down Mode is entered. Any Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 20. Deep Power-Down Sequence Diagram CS# 0 1 2 3 4 5 6 7 tDP SCLK Command SI Rev 1.0 Standby mode Deep Power-Down mode B9H Dec 8, 2021 Page 35 XT25F64F 3.3V QUAD IO Serial Flash 6.20. Release from Deep Power-Down and Read Device ID (RDI) (ABH) The Release from Power-Down and Read/Device ID command is a multi-purpose command. It can be used to release the device from the Power-Down state or obtain the devices electronic identification (ID) number. To release the device from the Power-Down state, the command is issued by driving the CS# pin low, shifting the instruction code “ABH” and driving CS# high as shown in Figure 21. Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other command are accepted. The CS# pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the Power-Down state, the command is initiated by driving the CS# pin low and shifting the instruction code “ABH” followed by 3-dummy byte. The Device ID bits are then shifted out on the falling edge of SCLK with most significant bit (MSB) first as shown in Figure 21a. The Device ID value for the XT25F64F is listed in Manufacturer and Device Identification table. The Device ID can be read continuously. The command is completed by driving CS# high. When used to release the device from the Power-Down state and obtain the Device ID, the command is the same as previously described, and shown in Figure 21a, except that after CS# is driven high it must remain high for a time duration of tRES2 (See AC Characteristics). After this time duration the device will resume normal operation and other command will be accepted. If the Release from Power-Down/Device ID command is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the command is ignored and will not affect the current cycle. Figure 21. Release Power-Down Sequence Diagram CS 0 1 2 3 4 5 6 7 tRES1 SCLK Command SI ABH Deep Power-Down mode Standby mode Figure 21a. Release Power-Down/Read Device ID Sequence Diagram CS 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 SCLK Command SI SO ABH High-Z tRES2 3 Dummy Bytes 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Device ID MSB 7 6 5 4 3 2 1 0 Deep Power-Down Mode Rev 1.0 Dec 8, 2021 Standby Mode Page 36 XT25F64F 3.3V QUAD IO Serial Flash 6.21. Read Manufacture ID/ Device ID (REMS) (90H) The Read Manufacturer/Device ID command is an alternative to the Release from Power-Down / Device ID command that provides both the JEDEC assigned Manufacturer ID and the specific Device ID. The command is initiated by driving the CS# pin low and shifting the command code “90H” followed by a 24-bit address (A23-A0) of 000000H. After which, the Manufacturer ID and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first is shown in Figure 22. If the 24-bit address is initially set to 000001H, the Device ID will be read first. Figure 22. Read Manufacture ID/ Device ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 90H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK SI Manufacturer ID SO MSB Rev 1.0 Manufacturer ID Device ID 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB MSB Dec 8, 2021 Page 37 XT25F64F 3.3V QUAD IO Serial Flash 6.22. Read Serial Flash Discoverable Parameter (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216. Note: For SFDP Table, please contact XTX. Figure 23. Read Serial Flash Discoverable Parameter command Sequence Diagram CS# 24 25 26 27 28 29 30 31 0 1 2 3 4 5 6 7 8 9 10 11 SCLK Command SI 5AH 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 SO 7 6 5 4 3 2 1 Data Out3 Data Out2 Data Out1 0 7 6 5 4 3 2 1 0 MSB MSB Note: A23-A8 = 0, A7-A0 is the starting byte address for 256-byte SFDP Register. Rev 1.0 Dec 8, 2021 Page 38 XT25F64F 3.3V QUAD IO Serial Flash 6.23. Read Unique ID(4BH) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low  Sending Read Unique ID command 4 dummy bytes 128bit Unique ID Out  CS# goes high. The command sequence is show below. Figure 24. Read Unique ID (RUID) Sequence (Command 4BH) CS# 0 1 2 3 4 5 6 7 8 9 10 11 32 33 34 35 36 37 38 39 SCLK Command SI 4bytes dummy 4BH MSB High-Z SO CS# 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 156 157 158 159 SCLK SI 128 bit unique serial number SO 7 6 5 4 3 2 1 0 127126 125 124 123 122 121 120 MSB 6.24. Read Identification (RDID) (9FH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by two bytes of device identification. The device identification indicates the memory type in the first byte, and the memory capacity of the device in the second byte. Any Read Identification (RDID) command while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# to low. Then, the 8-bit command code for the command is shifted in. This is followed by the 24-bit device identification, stored in the memory, being shifted out on Serial Data Output, each bit being shifted out during the falling edge of Serial Clock. The command sequence is shown in Figure 25. The Read Identification (RDID) command is terminated by driving CS# to high at any time during data output. When CS# is driven high, the device is put in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. Rev 1.0 Dec 8, 2021 Page 39 XT25F64F 3.3V QUAD IO Serial Flash Figure 25. Read Identification ID Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK Command SI 9FH High-Z SO Manufacturer ID 7 6 5 4 3 2 1 Memory Type JDID15-JDID8 0 7 6 5 4 3 2 1 Capacity JDID7-JDID0 0 7 6 5 4 3 2 1 0 High-Z MSB 6.25. Erase Security Registers (44H) The device provides 3x1024-byte Security Registers which only erased each 1024-byte at once. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes low  Sending Erase Security Registers CommandCS# goes high. The command sequence is shown in Figure 26. CS# must be driven high after the eighth bit of the command code has been latched in, otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit (LB1,LB2,LB3) in the Status Register can be used to OTP protect the corresponding security registers (#1, #2, #3). Once the LB bit is set to 1, the corresponding Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address A23-A16 A15-A12 A11-A10 A9-A0 Security Registers #1 00000000 0001b 00b Don’t Care Security Registers #2 00000000 0010b 00b Don’t Care Security Registers #3 00000000 0011b 00b Don’t Care Figure 26. Erase Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 44H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB Rev 1.0 Dec 8, 2021 Page 40 XT25F64F 3.3V QUAD IO Serial Flash 6.26. Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. It allows from 1 to 256 bytes Security Registers data to be programmed. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before Sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address bytes and at least one data byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit (LB1,LB2,LB3) is set to 1, the corresponding Security Registers (#1, #2, #3) will be permanently locked. Program Security Registers command will be ignored. Address A23-A16 A15-A12 A11-A10 A9-A0 Security Registers #1 00000000 0001b 00b Byte Address Security Registers #2 00000000 0010b 00b Byte Address Security Registers #3 00000000 0011b 00b Byte Address Figure 27. Program Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK 24-bit address(A23:A0) Command SI 42H 23 22 21 20 19 Data Byte1 7 6 5 4 3 2 1 MSB 0 7 6 5 4 3 2 1 0 MSB 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 2072 2073 2074 2075 2076 2077 2078 2079 CS# SCLK Data Byte2 SI 7 6 5 4 3 2 1 MSB Rev 1.0 Data Byte3 0 7 6 5 4 3 2 1 MSB Data Byte4 0 7 6 5 4 3 2 1 MSB Dec 8, 2021 Data Byte256 0 7 6 5 4 3 2 1 0 MSB Page 41 XT25F64F 3.3V QUAD IO Serial Flash 6.27. Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next address after each byte of data is shifted out. Once the A9-A0 address reaches the last byte of the register (Byte 3FFH), it will reset to 000H, the command is completed by driving CS# high. Address A23-A16 A15-A12 A11-A10 A9-A0 Security Registers #1 00000000 0001b 00b Byte Address Security Registers #2 00000000 0010b 00b Byte Address Security Registers #3 00000000 0011b 00b Byte Address Figure 28. Read Security Registers command Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 SCLK Command SI 48H 24-bit address(A23:A0) 23 22 21 20 19 7 6 5 4 3 2 1 0 MSB High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 SO 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 Data Out3 0 MSB MSB Rev 1.0 Data Out2 Dec 8, 2021 Page 42 XT25F64F 3.3V QUAD IO Serial Flash 6.28. Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch status (WEL), Read Parameter setting (P7-P0) and Wrap Bit Setting (W6-W4). The “Reset (99H)” command sequence as follow: CS# goes low  Sending Enable Reset command  CS# goes high  CS# goes low  Sending Reset command  CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRST_R to reset. During this period, no command will be accepted. Data corruption may happen if there is an on-going internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the BUSY bit in Status Register before issuing the Reset command sequence. The Enable Reset (66H) command must be issued prior to a Reset (99H) command and any other commands can't be inserted between them. Otherwise, Enable Reset (66H) command will be cleared. Figure 29. Enable Reset and Reset command Sequence Diagram CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK Command SI Rev 1.0 High-Z 66H Command 99H Dec 8, 2021 Page 43 XT25F64F 3.3V QUAD IO Serial Flash 7. ELECTRICAL CHARACTERISTICS 7.1. Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) tVSL Device is fully accessible VWI Time Power-Up Timing and Write Inhibit Threshold Symbol Parameter Min. tVSL VCC(min.) To CS# Low 100 VWI Write Inhibit Voltage 1.5 Max. Unit us 2.5 V 7.2. Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1(each byte contains FFH). All Status Register bits except S22 bits are 0, S22 bit is 1. 7.3. Latch up Characteristics Parameter Min. Input Voltage Respect To VSS On I/O Pins -1.0V VCC Current Rev 1.0 -100mA Dec 8, 2021 Max. VCC+1.0V 100mA Page 44 XT25F64F 3.3V QUAD IO Serial Flash 7.4. Absolute Maximum Ratings Parameter Value Unit Ambient Operating Temperature -40 to 85 °C Storage Temperature -65 to 150 °C Output Short Circuit Current 200 mA Applied Input/Output Voltage -0.5 to 4.0 V -0.5 to 4.0 V VCC Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns 20ns VSS VSS-2.0V 20ns Maximum Positive Overshoot Waveform 20ns VCC+2.0V VCC 20ns 20ns 7.5. Capacitance Measurement Condition Symbol Parameter Min. Typ. Max. Unit Conditions CIN Input Capacitance 6 pF VIN=0V COUT Output Capacitance 8 pF VOUT=0V CL Load Capacitance 30 pF Input Rise And Fall time 5 ns Input Pulse Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.2VCC to 0.7VCC V Output Timing Reference Voltage 0.5VCC V Absolute Maximum Ratings Diagram 0.8VCC Input timing reference level 0.7VCC 0.1VCC 0.2VCC Output timing reference level AC Measurement Level 0.5VCC Note:Input pulse rise and fall time are
XT25F64FWOIGT 价格&库存
很抱歉,暂时无法提供与“XT25F64FWOIGT”相匹配的价格&库存,您可以联系我们找货
