SAMXON ELECTRONIC
COMPONENTS LIMITED
ELECTRIC DOUBLE LAYER
CAPACITORS
SPECIFICATION
DRL SERIES
CONTENTS
Sheet
1.
2.
3.
Application
Part Number System
Characteristics
3
3
4~10
3.1 Rated voltage & Surge voltage
3.2 Capacitance (Tolerance)
3.3 ESR
3.4 Leakage Current
3.5 Temperature characteristic
3.6 Load life test
3.7 Damp heat test
3.8 Lead strength
3.9 Resistance to vibration
3.10 Solderability
3.11 R esistance to soldering h eat
4. Product Dimensions
5. Notice item
Issued-date: 2016-07-14
Version
11
12
Name
Specification Sheet – DRL
01
Page
STANDARD MANUAL
2
CAPACITORS
SPECIFICATION
DRL SERIES
SAMXON ELECTRONIC
COMPONENTS LIMITED
1.
Application
The specification applies to electric double layer capacitors used in electronic equipment.
2.
Part Number System
DRL 105 S 0T
Series
2.1
F 12 RR
Type (2.3)
Case Length (2.6)
Diameter (2.5)
Voltage (2.2)
Tolerance (2.4)
Capacitance (2.1)
Capacitance code
Code
105
Capacitance (F)
2.2
2.3
2.4
2.5
2.6
1
Rated voltage code
Code
Voltage (W.V.)
0T
2.7
Type
Code
Type
RR
Bulk
Capacitance tolerance
“S” stands for -20% ~ +50%
Diameter
Code
Diameter
F
8
Case length
12=12mm
Version
Name
01
Page
STANDARD MANUAL
3
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
3. Characteristics
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests is
as follows:
Ambient temperature: 15C to 35C
Relative humidity : 25% to75%
Air Pressure
: 86kPa to 106kPa
If there is any doubt about the results, measurement shall be made within the following conditions:
Ambient temperature: 20C 2C
Relative humidity : 60% to 70%
Air Pressure
: 86kPa to 106kPa
Operating temperature range
The ambient temperature range at which the capacitor can be operated continuously at rated voltage
is -40C to 70C.
Version
Name
01
Page
STANDARD MANUAL
4
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
ITEM
PERFORMANCE
Rated voltage
(WV)
3.1
Surge voltage
(SV)
WV (V.DC)
2.7
SV (V.DC)
2.8
Constant current discharge method:
Measuring circuit:
A
S
Constant current /
constant voltage
power supply
V Cx
Constant Current
Discharger
Key
A
3.2
Nominal
capacitance
(Tolerance)
V
S
Cx
d.c. ammeter
d.c. voltmeter
changeover switch
capacitor under test
Figure 1- Circuit for constant current discharge method
Measuring method
a) Set the d.c.voltage at the rated voltage (UR)
b) Set the constant current value of the constant current discharger to the discharge
current specified in Table 1.
c) Turn the switch S to the d.c.power supply ,apply voltage and charge for 30 min
after the constant current / constant voltage power supply has achieved the rated
voltage.
d) After a charge for 30 min has finished ,change over the switch S to the constant
current discharger ,and discharge with a constant current.
e) Measure the time t1 and t2 where the voltage between capacitor terminals at the
time of discharge reduces from U1 to U2 as shown in Figure 2 ,and calculate the
capacitance value by the following formula:
Version
Name
01
Page
STANDARD MANUAL
5
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
UR
△U3
U1
△U3:IR drop
Voltage (V)
U2
30 min
t1
t2
Time (s)
Figure 2- Voltage characteristic between capacitor terminals
C=
3.2
Nominal
capacitance
(Tolerance)
Ix(t2-t1)
U1-U2
Where
C is the capacitance(F);
I
is the discharge current (A);
U1 is the measurement starting voltage (V);
U2 is the measurement end voltage (V);
t1 is the time from discharge start to reach U1 (s);
t2 is the time from discharge start to reach U2 (s).
f) The discharge current I and the voltages U1 and U2 at the time of discharge voltage
drop shall be as per Table 1 .The method classification shall be in accordance with
the individual standards.
Table 1 – Discharge conditions
Charge time 30 min
I(mA)
4 x CUR
U1
The value to be 80% of the charging voltage (0.8xUR)
U2
The value to be 40% of the charging voltage (0.4xUR)
NOTE CR is the rated capacitance in F(Farad),and UR is the rated voltage in V (Volt)
Version
Name
01
Page
STANDARD MANUAL
6
CAPACITORS
SPECIFICATION
DRL SERIES
SAMXON ELECTRONIC
COMPONENTS LIMITED
3.3
Measuring frequency :1kHz
Measuring temperature:20±2℃
Measuring point
: 2mm max from the surface of a sealing resin on the lead wire.
(20℃)Less than the initial limit:
ESR≤400mΩ
ESR
1. Ambient temperature: 25C 2C.
2.The electrification time:72H
Leakage
current
3.4
3. Desistance value of protective resistor less than 1Ω .
Less than the initial limit(25C 2C):
I≤0.008mA
I is the Leakage current
STEP
Temperature(℃)
1
20±2
Item
Capacitance、
ESR
△ C/C
2
-40+3
ESR
3.5
Temperature
characteristic
Keep at 15 to 35℃ for
15 minutes or more
3
--------△ C/C
4
70±2
ESR
Characteristics
----------Within ±30% of
initial capacitance
Less than or equal to
4 times of the value of
item 3.3
initial capacitance
The limit specified in
3.3
a. ESR -40℃/ ESR 20℃: ESR ratio at 1kHz;
b. ΔC/C 20℃: Capacitance change ;
Version
Name
01
Page
STANDARD MANUAL
7
CAPACITORS
SPECIFICATION
DRL SERIES
SAMXON ELECTRONIC
COMPONENTS LIMITED
The Capacitor is stored at a temperature of 70 ±2 °C with rated
voltage for 1000 +48/0 hours .The result should meet the following table:
Item
Performance
Capacitance Change
3.6
Load
life
test
ESR
Appearance
Within ±30% of initial capacitance
Less than or equal to 4 times of the value of item
3.3
No visible damage and no leakage of electrolyte
Humidity Test:
The capacitor shall be exposed for 240±48 hours in an atmosphere of 90~95%RH at
40±2℃, the characteristic change shall meet the following requirement.
Item
3.7
Damp
heat
test
Capacitance Change
ESR
Less than or equal to 4 times of the value of item 3.3
Appearance
Version
Performance
Name
01
Page
STANDARD MANUAL
8
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
a) Lead pull strength
A static load force shall be applied to the terminal in the axial direction and acting
in a direction away from the body for 10±1 s.
Lead wire diameter (mm)
Load force (N)
d ≤0.5
5
3.8
Lead strength
b) Lead be
one lead and then the capacitor is slowly rotated 900 to a horizontal position and then
returned to a vertical position thus completing bends for 2~3seconds. nding
When the capacitor is placed in a vertical position and the weight specified in the
table above is applied to
The additional bends are made in the opposite direction
Load force (N)
d ≤0.5
2.5
Performance: The characteristic shall meet the following value after a) or b) test.
Item
Performance
Capacitance Change
No visible damage Legible marking and no
Appearance
Frequency: 10 to 55 Hz (1minute interval / 10 → 55 → 10Hz
Amplitude: 0.75mm(Total excursion 1.5mm)
Direction :X、 Y、 Z (3 axes)
Duration: 2hours/ axial (Total 6 hours)
The capacitors are supported as the following Fig2
3.9
Resistance to
vibration
≤0.3mm
Fig2
Performance: Capacitance value shall not show drastic change compared to the initial
capacitance when the value is measured within 30 minutes. Prior to the completion of
exam, Capacitance difference shall be within ±10% compared to the initial value the
exam.
Version
Name
01
Page
STANDARD MANUAL
9
SAMXON ELECTRONIC
COMPONENTS LIMITED
T
3.10
Solderability
CAPACITORS
SPECIFICATION
DRL SERIES
The capacitor shall be tested under the following conditions:
Solder
: Sn-3Ag-0.5Cu
Soldering temperature: 2453C
Immersing time
: 2.00.5s
Immersing depth
: 1.5~ 2.0mm from the root.
Flux
: Approx .25% rosin
Performance: At least 75% of the dipped portion of the terminal shall be covered with
new solder.
A) Solder bath method
Lead terminals of a capacitor are placed on the heat isolation board with thickness of
1.60.5mm. It will dip into the flux of isopropylaehol solution of colophony.
Then it will be immersed at the surface of the solder with the following condition:
Solder
: Sn-3Ag-0.5Cu
Soldering temperature : 260 5C
Immersing time
: 50.5s
Heat protector: t=1.6mm glass –epoxy board
3.11
Resistance
to soldering
heat
B) Soldering iron method
Bit temperature
: 350 10C
Application time
: 3.5 0.5 s
For both methods, after the capacitor at thermal stability, the following items shall be
measured:
Item
Performance
Capacitance Change
Within ±10% of initial capacitance
No visible damage legible marking and no leakage
Appearance
of electrolyte
Version
Name
01
Page
STANDARD MANUAL
10
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
Capacitors cycles between specified voltage and half rated voltage under constant current
at +25 C(500,000 cycles)
3.12
Capacitance Change
±30% of initial measured value
Internal Resistance
2 times of initial specified value
Cycles
Version
Name
01
Page
STANDARD MANUAL
11
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
Unit: mm
Safety vent for≥φ6.3
ф d±0.05
F±0.5
L +1.5
-1.0
Version
15 min
4 min
Φ D±0.5
φD
8
L
12
F
3.5
φd
0.5
Name
01
Page
STANDARD MANUAL
12
SAMXON ELECTRONIC
COMPONENTS LIMITED
CAPACITORS
SPECIFICATION
DRL SERIES
5 . Notice item
(1)The capacitor has fixed polarity.
(2)The capacitor should be used under rated voltage.
(3)The capacitor should not be used in the charge and discharge circuit with high frequency.
(4)The ambient temperature affects the super capacitor life.
(5)Voltage reduction ΔV=IR will happen at the moment of discharge.
(6)The capacitor cannot be stored on the place with humidity over 85%RH or place with toxic gas.
(7)The capacitor should stored in the environment within -30℃~50℃ temperature and less than 60% relative humidity.
(8)If the capacitor is applied on the double-side PCB, the connection should not be around the place on which the super capacitor
can contact.
(9)Don't twist capacitor or make it slanting after installing.
(10)Need avoid over heat on the capacitor during soldering (The temperature should be 260℃ with the time less than 5s during
soldering on 1.6mm printed PCB.)
(11)There is voltage balance problem between each capacitor unit during series connection between super capacitor.
Version
Name
01
Page
STANDARD MANUAL
13
很抱歉,暂时无法提供与“DRL105S0TF12RR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.98080
- 10+2.45160
- 30+2.23560
