SUPERPRO6000
SUPERPRO6000
    XELTEK(南京西尔特)
    HIGH SPEED SUPERPRO PROGRAMMER
SUPERPRO6000 数据手册
Xeltek, Inc. 1296 Kifer Rd. Suite #605 Sunnyvale, CA 94086 United States SuperPro®6000 High-speed Universal Programmer. Tel: 14085308080 Fax: 408.530.0096 Email: info@xeltek.com Features: • Supports 301 IC manufacturer, 85,000+ IC devices. (Device support as of December 2012, check • SuperPro6000 device list for current device support). 30% faster programming speed compared to SuperPro5000 with ARM9 MCU Processor. • Supports eMMC / NAND files up to 256 GB. • Improved universal 144 pin-driver technology provides a cleaner signal, wider voltage range and more accurate clock frequency. • Two operating modes: 1. PC mode via USB2.0 port and PC communication. 2. Stand-Alone mode (no PC required).Operates via built-in keyboard, LCD display and removable memory (standard Compact Flash card). Setup is flexible and simple to expand (1-15 units) for large volume production on the factory floor. Projects files (limited only by Compact Flash card capacity limit) • are created online and downloaded into the Compact Flash card. Cluster 1-15 units for volume production. • • Supports devices with Vcc from 1.2V to 5V. In-circuit programming capability available via ISP/ICP adaptor. • Only IC manufacturer approved programming algorithms are used for high reliability. (+5%~-5%) and • Powerful yet user-friendly software features streamline operations, improve efficiency and reduce user (10%~-10%) Vcc verification enhances programming reliability. mistakes during programming procedures. Production mode start chip operation upon proper chip is insertion. Project function simplifies processes such as Device Selection, File Loading, Device Configuration Setting, Program Option, and Batch File Setting into one step. Password can be set for project files for volume production control Batch command combines device operations like Program, Verify, and Security into a single command at any sequence. Serial number generator is available as standard or customer-specific functions. Log file is useful for quality tracking. • • Overvoltage / overcurrent and ESD protection to avoid programmer damage. Supports Windows XP / Vista / Win7 / Win8. Price: $2295 Device Updates: • XELTEK updates software and device algorithm regularly. • XELTEK adds devices upon customer's request. General algorithm upgrades completed within a week. Warranty Support: • Programmer is warranted to be free of manufacturing or workmanship defects for two years from the date of purchase. • Same day Phone/Email/Chat support. • Large inventory allow same day shipping for majority of items. Hardware & Electrical Specifications: • Supported devices include (but not limited to)EPROM, Paged EPROM, Parallel and Serial EEPROM, FPGA Configuration PROM, FLASH memory (NOR & NAND)n, BPROM, NVRAM, SPLD, CPLD, EPLD, Firmware HUB, Microcontroller, MCU. • Packages supported (but not limited to)DIP, SDIP, PLCC, JLCC, SOIC, QFP, TQFP, PQFP, VQFP, TSOP, SOP, TSOPII, PSOP, TSSOP, SON, EBGA, FBGA, VFBGA, uBGA, CSP, SCSP. • NAND Flash library supports dozens of major platforms such as Samsung (XSR1.0/1.6), QualComm, HYNIX (HIFFS), MTK (Solution V1.1), ICERA (v1.0/2.0), ST (7162 , 7141, etc.), AMLOGIC (the IF2 / 0), REALTEK PICOCHIP DataLight (Flash FX Pro), Marvell (310/303/920/935 ...), Broadcom, ZTE, Intel (CE4100), UBI, Leadcore LEADCORE The (L1809OG), MSATR. • PC communication interface: USB2.0 (high speed). • Memory storage: Compact Flash card. • Electrical spec. of the AC adapter: AC input 90V to 250V, 50/60Hz, DC output 12V/2A; power:15W • • Programmer size: Size: 148 x 216 x 94 mm; Weight: 1.6Kg. Package size: 301 x 252 x 145 mm; Weight: 2.8 Kg. Accessories: • Main unit with a DIP48 adaptor, AC adaptor, USB2.0 cable, user manual, software CD and registration • Optional accessories: adaptor in varies packages, Compact Flash card for stand-alone operation. card.
SUPERPRO6000 价格&库存
很抱歉,暂时无法提供与“SUPERPRO6000”相匹配的价格&库存,您可以联系我们找货
