3421
    ADAFRUIT
    SPH0645LM4HI2SMICROPHONEBOARD
3421 数据手册
Adafruit I2S MEMS Microphone Breakout Created by lady ada https://learn.adafruit.com/adafruit-i2s-mems-microphone-breakout Last updated on 2022-04-07 07:22:23 PM EDT ©Adafruit Industries Page 1 of 35 Table of Contents Overview 3 Assembly 5 • Prepare the header strip: • Add the breakout board: • And Solder! 5 5 6 Pinouts 6 • Power Pins • I2S Data Pins 7 7 Arduino Wiring & Test 8 • • • • 8 9 11 12 Wiring I2S Library VU Meter Demo ArduinoSound Library Raspberry Pi Wiring & Test 14 • • • • • • • • • • • • Wiring For Mono Mic Wiring For Stereo Mic Install Raspbian on an SD Card Update the Pi Python and Pip Installer Script Run the Script Test & Record! Test Playback Manual Load Rebuilding After System Update Adding Volume Control 15 15 16 16 16 17 17 18 19 20 20 21 Old Kernel Install Method 23 • • • • • • • • • Wiring For Mono Mic Wiring For Stereo Mic Raspberry Pi i2s Configuration Kernel Compiling Prepare to Compile the i2s module Auto-load the module on startup Test & Record! Test Playback Adding Volume control Downloads • Files • Schematic & Fab Print ©Adafruit Industries 24 25 25 27 28 30 31 32 32 34 34 35 Page 2 of 35 Overview For many microcontrollers, adding audio input is easy with one of our analog microphone breakouts (http://adafru.it/1063). But as you get to bigger and better microcontrollers and microcomputers, you'll find that you don't always have an analog input, or maybe you want to avoid the noise that can seep in with an analog mic system. Once you get past 8-bit micros, you will often find an I2S peripheral, that can take digital audio data in! That's where this I2S Microphone Breakout comes in. Instead of an analog output, there are three digital pins: Clock, Data and Word-Select. When connected to your microcontroller/computer, the 'I2S Main' will drive the clock and word-select pins at a high frequency and read out the data from the microphone. No analog conversion required! ©Adafruit Industries Page 3 of 35 The microphone is a single mono element. You can select whether you want it to be on the Left or Right channel by connecting the Select pin to power or ground. If you have two microphones, you can set them up to be stereo by sharing the Clock, WS and Data lines but having one with Select to ground, and one with Select to high voltage. This I2S MEMS microphone is bottom ported, so make sure you have the hole in the bottom facing out towards the sounds you want to read. It's a 1.6-3.3V device only, so not for use with 5V logic (its really unlikely you'd have a 5V-logic device with I2S ©Adafruit Industries Page 4 of 35 anyways). Many beginner microcontroller boards don't have I2S, so make sure its a supported interface before you try to wire it up! This microphone is best used with microcontrollers or computers that have hardware I2S peripheral support such as the Cortex M-series chips like the Arduino Zero, Feather M0, or single-board computers like the Raspberry Pi. Assembly Assembly is really easy, you can use straight or 'right-angle' style headers to attach to the PCB. We'll be using the plain straight headers included The board comes with all surface-mount components pre-soldered. The included header strip can be soldered on for convenient use on a breadboard or with 0.1" connectors. You can also skip this step and solder on wires. Prepare the header strip: Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down Add the breakout board: Place the breakout board over the pins so that the short pins poke through the breakout pads   Make sure the side with the components is face down, as shown in the photos in this guide! ©Adafruit Industries Page 5 of 35 And Solder! Be sure to solder all 5 pins for reliable electrical contact. (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https:// adafru.it/aTk)). You're done! Check your solder joints visually and continue onto the next steps Pinouts Unlike most of our breakouts, this sensor has the detection element on the bottom of the PCB, so we expect you to solder it 'upside down' with the sensor package on the bottom and the port on top! ©Adafruit Industries Page 6 of 35 Power Pins • 3V - this is the power in pin. Technically it can be powered from as low as 1.6V to 3.6V but you'll need to make sure your logic level matches! • GND - power and data ground I2S Data Pins • BCLK - the bit clock, also known as the data clock or just 'clock' - comes from the I2S main to tell the microphone its time to transmit data. This should run at 2-4 MHz but we've found you can often run it a little slower and it'll work fine • DOUT - the data output from the mic! • LRCLK - the left/right clock, also known as WS (word select), this tells the mic when to start transmitting. When the LRCLK is low, the left channel will transmit. When LRCLK is high, the right channel will transmit. • SEL - the channel select pin. By default this pin is low, so that it will transmit on the left channel mono. If you connect this to high logic voltage, the microphone will instantly start transmitting on the right channel. ©Adafruit Industries Page 7 of 35 Arduino Wiring & Test Remember, the I2S microphone requires an I2S peripheral and won't work with chips that don't support it in hardware! For this example we'll use a Feather M0, but you can also use an Arduino Zero. Wiring For Feather M0, Ardruino Zero and friends, use the following wiring: • GND connected GND • 3.3V connected 3.3V (Feather, Zero) or VCC (MKR1000, MKRZero) • LRCLK / WS connected to pin 0 (Feather, Zero) or pin 3 (MKR1000, MKRZero) • BCLK connected to pin 1 (Feather, Zero) or pin 2 (MKR1000, MKRZero) • Data /SD connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero You can leave Select disconnected i2sfeatherm0.fzz https://adafru.it/uya ©Adafruit Industries Page 8 of 35 I2S Library Luckily, there's a nice little I2S library already written for Arduinos based on the SAMD processor. Make sure you have the most recent Arduino IDE and SAMD core. Then select the board you're using (e.g. Adafruit Feather M0) and you'll see the I2S library examples show up in the pulldown menu You could try the InputPlotter demo but this code is higher resolution: /* This example reads audio data from an I2S microphone breakout board, and prints out the samples to the Serial console. The Serial Plotter built into the Arduino IDE can be used to plot the audio data (Tools -> Serial Plotter) Circuit: * Arduino/Genuino Zero, MKRZero or MKR1000 board * GND connected GND * 3.3V connected 3.3V (Zero) or VCC (MKR1000, MKRZero) * WS connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero) * CLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero) * SD connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero) created 17 November 2016 by Sandeep Mistry */ #include <I2S.h> void setup() { // Open serial communications and wait for port to open: // A baud rate of 115200 is used instead of 9600 for a faster data rate // on non-native USB ports Serial.begin(115200); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } // start I2S at 16 kHz with 32-bits per sample if (!I2S.begin(I2S_PHILIPS_MODE, 16000, 32)) { Serial.println("Failed to initialize I2S!"); while (1); // do nothing ©Adafruit Industries Page 9 of 35 } } void loop() { // read a sample int sample = I2S.read(); if ((sample == 0) || (sample == -1) ) { return; } // convert to 18 bit signed sample >>= 14; // if it's non-zero print value to serial Serial.println(sample); } Upload to your Arduino Zero/Feather wired up as above, and open up the Serial Plotter Try blowing or whistling at the sensor to see response in real time ©Adafruit Industries Page 10 of 35 VU Meter Demo Often times you don't want the actual audio data but the overall "sound pressure level". This example will take a bunch of samples, normalize the data to be around 0, then give you the maximum difference between the waveforms for a 'volume graph' /* This example reads audio data from an Invensense's ICS43432 I2S microphone breakout board, and prints out the samples to the Serial console. The Serial Plotter built into the Arduino IDE can be used to plot the audio data (Tools -> Serial Plotter) Circuit: * Arduino/Genuino Zero, MKRZero or MKR1000 board * ICS43432: * GND connected GND * 3.3V connected 3.3V (Zero) or VCC (MKR1000, MKRZero) * WS connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero) * CLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero) * SD connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero) created 17 November 2016 by Sandeep Mistry */ #include <I2S.h> void setup() { // Open serial communications and wait for port to open: // A baud rate of 115200 is used instead of 9600 for a faster data rate // on non-native USB ports Serial.begin(115200); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } // start I2S at 16 kHz with 32-bits per sample if (!I2S.begin(I2S_PHILIPS_MODE, 16000, 32)) { Serial.println("Failed to initialize I2S!"); while (1); // do nothing } } #define SAMPLES 128 // make it a power of two for best DMA performance void loop() { // read a bunch of samples: int samples[SAMPLES]; for (int i=0; i<SAMPLES; i++) { int sample = 0; while ((sample == 0) || (sample == -1) ) { sample = I2S.read(); } // convert to 18 bit signed sample >>= 14; samples[i] = sample; } // ok we hvae the samples, get the mean (avg) float meanval = 0; for (int i=0; i<SAMPLES; i++) { meanval += samples[i]; ©Adafruit Industries Page 11 of 35 } meanval /= SAMPLES; //Serial.print("# average: " ); Serial.println(meanval); // subtract it from all sapmles to get a 'normalized' output for (int i=0; i<SAMPLES; i++) { samples[i] -= meanval; //Serial.println(samples[i]); } // find the 'peak to peak' max float maxsample, minsample; minsample = 100000; maxsample = -100000; for (int i=0; i<SAMPLES; i++) { minsample = min(minsample, samples[i]); maxsample = max(maxsample, samples[i]); } Serial.println(maxsample - minsample); } Open up the serial plotter to see how making noises will create peaks! ArduinoSound Library For most uses, its better to have a higher-level library for managing sound. The ArduinoSound library works with I2S mics and can do filtering, amplitude detection, etc! Install it using the Arduino library manager ©Adafruit Industries Page 12 of 35 Various examples come with the library, check them out in the File->Examples>ArduinoSound sub menu For example, amplitude Serial plotter will do basic amplitude plotting: ©Adafruit Industries Page 13 of 35 You can also do FFT spectral diagramming using SpectrumSerialPlotter. We made a small change to the example so that all 128 bins are plotted: Raspberry Pi Wiring & Test You can add mono or stereo I2S microphones to your Raspberry Pi, too! This will work with any Raspberry with a 2x20 GPIO connector. This guide is largely based on this great git repo (https://adafru.it/KBh), which we forked for use here. Also useful was the information provided in this forum post (https: //adafru.it/fEw). ©Adafruit Industries Page 14 of 35 Wiring For Mono Mic • Mic 3V to Pi 3.3V • Mic GND to Pi GND • Mic SEL to Pi GND (this is used for channel selection, connect to either 3.3V or GND) • Mic BCLK to BCM 18 (pin 12) • Mic DOUT to BCM 20 (pin 38) • Mic LRCL to BCM 19 (pin 35) Wiring For Stereo Mic Connect both mics as above except for the SEL pin. • Left Mic SEL to Pi GND • Right Mic SEL to Pi 3.3V ©Adafruit Industries Page 15 of 35 Be sure to follow all these steps in the order shown to insure the I2S mic module is built against the proper kernel headers. Install Raspbian on an SD Card You'll need to start with Raspbian or Raspbian Lite. Get the latest version from the Ras pberry Pi Download page (https://adafru.it/fQi) and follow these instructions to install the OS image to the SD card (https://adafru.it/jd0). Update the Pi Run these commands: sudo apt-get -y update sudo apt-get -y upgrade and then REBOOT THE PI. Python and Pip Run the following command to make sure you have Python 3 and Pip installed: sudo apt install python3-pip ©Adafruit Industries Page 16 of 35 Installer Script This script will do all the work for you. Here are the commands to run. Make sure your Pi has network access, it needs to download the software! cd ~ sudo pip3 install --upgrade adafruit-python-shell wget https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/ master/i2smic.py sudo python3 i2smic.py Run the Script Once you run the script, you will be presented with options for configuration. ©Adafruit Industries Page 17 of 35 Auto Load at Boot The Pi model should be automatically detected. If you want the I2S mic module support to be loaded at boot, select Yes here. Otherwise you'll have to manually install the module each time you want to use it. Reboot Since the script runs a system update and installs some other needed support software, it may take a while to run. Just let it go. When it's finished, you should be prompted with an option to reboot. You need to reboot for the settings to take effect. Test & Record! OK, that probably took a bit of time, but now you are ready to rock! Use the following command to list the available input devices: arecord -l You should see a card entry with information similar to this: ©Adafruit Industries Page 18 of 35 Note the card number. In the screen shot above it is 0 . You can record a wav file in mono with this command (change the -plughw parameter to match the card number from above): arecord -D plughw:0 -c1 -r 48000 -f S32_LE -t wav -V mono -v file.wav Or, if you have two i2s mics installed, record in stereo with this command: arecord -D plughw:0 -c2 -r 48000 -f S32_LE -t wav -V stereo -v file_stereo.wav If all is working correctly, you should see the VU meter react at the bottom of the terminal window: Test Playback If you have speakers hooked up to the Pi, you can play the file back directly on the device: aplay file.wav Or, you can copy it over to your computer for playback :), make sure SSH is enabled and then: scp pi@raspberrypi:file.wav ~/Desktop/file.wav ©Adafruit Industries Page 19 of 35 Manual Load If you chose not to auto load the module at boot, then you will need to manually load it with the following command: sudo modprobe snd-i2smic-rpi rpi_platform_generation=PI_SEL Replace PI_SEL with the approriate value for your Pi Model: • 0 = Pi Zero or Zero W • 1 = Pi 2 or 3 • 2 = Pi 4 You can use the arecord -l command to verify it loaded. Example on a Pi 3: Rebuilding After System Update If you later run a system update and find that the I2S mic no longer works, you may need to rebuild and reinstall the driver. To do so, simply run the install script again: sudo ./i2smic.sh It may complain about things, like git, already being installed. But you can generally ignore those error messages. If you've deleted the repo directory since the original install, then just reclone it. ©Adafruit Industries Page 20 of 35 Adding Volume Control You can add volume control to your mic via alsamixer and alsa config. (Hat tip to RickTracer (https://adafru.it/doW)). To do so, create and edit a file .asoundrc in your home directory. nano ~/.asoundrc and put the following in: #This section makes a reference to your I2S hardware, adjust the card name # to what is shown in arecord -l after card x: before the name in [] #You may have to adjust channel count also but stick with default first pcm.dmic_hw { type hw card sndrpii2scard channels 2 format S32_LE } #This is the software volume control, it links to the hardware above and after # saving the .asoundrc file you can type alsamixer, press F6 to select # your I2S mic then F4 to set the recording volume and arrow up and down # to adjust the volume # After adjusting the volume - go for 50 percent at first, you can do # something like # arecord -D dmic_sv -c2 -r 48000 -f S32_LE -t wav -V mono -v myfile.wav pcm.dmic_sv { type softvol slave.pcm dmic_hw control { name "Boost Capture Volume" card sndrpii2scard } min_dB -3.0 max_dB 30.0 } ©Adafruit Industries Page 21 of 35 Now before you can change the volume you need to use the device once (this is an alsa thing) Run: arecord -D dmic_sv -c2 -r 44100 -f S32_LE -t wav -V mono -v file.wav And cancel with ^C once it starts recording. Now you can run alsamixer - press F6 and select the I2S sound card ©Adafruit Industries Page 22 of 35 It will complain there are no playback controls (because its for recording only). Press F4 to switch to Capture mode and you should be able to adjust the volume with up/down arrow keys. Then you can record with the i2c mic device using: arecord -D dmic_sv -c2 -r 48000 -f S32_LE -t wav -V mono -v recording.wav and playback with: aplay recording.wav Old Kernel Install Method This technique is not suggested, see previous page for a better working method!!! You can add mono or stereo I2S microphones to your Raspberry Pi, too! This will work with Raspberry Pi B+, 2, 3, Zero and any other 2x20-connector-Pi This guide is largely based on this great git repo https://github.com/nejohnson2/rpii2s (https://adafru.it/vka) ©Adafruit Industries Page 23 of 35 Wiring For Mono Mic • Mic 3V - Pi 3.3v • Mic Gnd - Pi Gnd • Mic SEL - Pi Gnd (this is used for channel selection. Connect to 3.3 or GND) • Mic BCLK - BCM 18 (pin 12) • Mic LRCL - BCM 19 (pin 35) • Mic DOUT - BCM 20 (pin 38) Pi i2s Mono Fritzing File https://adafru.it/vkb ©Adafruit Industries Page 24 of 35 Wiring For Stereo Mic Pi i2s Stereo Fritzing File https://adafru.it/vkc Raspberry Pi i2s Configuration Start by logging into your Raspberry Pi via a terminal, we recommend ssh so you can copy + paste the many commands. Turn on i2s support by editing /boot/config.txt with: sudo nano /boot/config.txt Uncomment #dtparam=i2s=on ©Adafruit Industries Page 25 of 35 Next, we'll make sure sound support is enabled in the kernel with: sudo nano /etc/modules Add snd-bcm2835 on its own line, to the modules file as shown below Now reboot your pi with: sudo reboot ©Adafruit Industries Page 26 of 35 Once rebooted, re-log in. Enter the following to confirm the modules are loaded lsmod | grep snd Kernel Compiling Ok now its time for the fun part! You'll manually compile in i2s support. Start by updating your Pi: sudo apt-get update sudo apt-get install rpi-update sudo rpi-update Then reboot! Install the compilation dependencies: sudo apt-get install git bc libncurses5-dev bison flex libssl-dev Download kernel source & compile: sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O / usr/bin/rpi-source ©Adafruit Industries Page 27 of 35 sudo chmod +x /usr/bin/rpi-source /usr/bin/rpi-source -q --tag-update rpi-source --skip-gcc On a Pi 3 this will take many many minutes, so don't worry if its taking 15 minutes. On a Pi Zero it can take an hour or longer! If the script pauses at this prompt: Code coverage for fuzzing (KCOV) [N/y/?] (NEW) Just press enter to accept the default and continue. Prepare to Compile the i2s module Now you're ready to compile i2s support: sudo mount -t debugfs debugs /sys/kernel/debug This may already be done - mount: debugs is already mounted  - in which case keep going If you are using Pi 3 or Pi 2 - make sure the module name is  3f203000.i2s  If you are using Pi Zero - the module name is 20203000.i2s ©Adafruit Industries Page 28 of 35 Run rpi-i2s-audio Download the module, written by Paul Creaser (https://adafru.it/vkd) git clone https://github.com/PaulCreaser/rpi-i2s-audio cd rpi-i2s-audio Pi Zero Only If you are using a Raspberry Pi Zero, edit my_loader.c with nano my_loader.c and change the two lines .platform = "3f203000.i2s", and .name = "3f203000.i2s", with .platform = "20203000.i2s", and .name = "20203000.i2s", If you aren't using a Pi Zero, continue on! ©Adafruit Industries Page 29 of 35 Compile the module with make -C /lib/modules/$(uname -r )/build M=$(pwd) modules sudo insmod my_loader.ko Verify that the module was loaded: lsmod | grep my_loader dmesg | tail Note that on the Pi 2/3 you'll see asoc-simple-card asoc-simple-card.0: sndsoc-dummy-dai 3F203000.i2s mapping ok on the last line and on Pi Zero you'll see asoc-simple-card asoc-simple-card.0: snd-soc-dummy-dai 20203000.i2s mapping ok Auto-load the module on startup Now you can set it up so the module is loaded every time you boot the Pi sudo echo sudo sudo cp my_loader.ko /lib/modules/$(uname -r) 'my_loader' | sudo tee --append /etc/modules > /dev/null depmod -a modprobe my_loader And reboot! sudo reboot ©Adafruit Industries Page 30 of 35 Test & Record! OK that was a lot of effort but now you are ready to rock! Use the following command to list the available input devices: arecord -l you should see a snd_rpi_simple_card You can record a wav file in mono with this command: arecord -D plughw:1 -c1 -r 48000 -f S32_LE -t wav -V mono -v file.wav Or, if you have two i2s mics installed, record in stereo with this command: arecord -D plughw:1 -c2 -r 48000 -f S32_LE -t wav -V stereo -v file_stereo.wav If all is working correctly, you should see the VU meter react at the bottom of the terminal window ©Adafruit Industries Page 31 of 35 Test Playback If you have speakers hooked up to the Pi, you can play the file back directly on the device: aplay file.wav Or, you can copy it over to your computer for playback :), just insert your Pi's IP address below: scp pi@<local-ip>:/home/pi/file.wav ~/Desktop/file.wav Adding Volume control You can add volume control to your mine via alsamixer and alsa config. (Hat tip to RickTracer (https://adafru.it/doW)) Run sudo nano ~/.asoundrc and put the following in: #This section makes a reference to your I2S hardware, adjust the card name # to what is shown in arecord -l after card x: before the name in [] #You may have to adjust channel count also but stick with default first pcm.dmic_hw { type hw card sndrpisimplecar channels 2 format S32_LE } #This is the software volume control, it links to the hardware above and after # saving the .asoundrc file you can type alsamixer, press F6 to select # your I2S mic then F4 to set the recording volume and arrow up and down # to adjust the volume # After adjusting the volume - go for 50 percent at first, you can do # something like # arecord -D dmic_sv -c2 -r 48000 -f S32_LE -t wav -V mono -v myfile.wav pcm.dmic_sv { type softvol slave.pcm dmic_hw control { name "Boost Capture Volume" card sndrpisimplecar } min_dB -3.0 max_dB 30.0 } ©Adafruit Industries Page 32 of 35 Now before you can change the volume you need to use the device once (this is an alsa thing) Run arecord -D dmic_sv -c2 -r 44100 -f S32_LE -t wav -V mono -v file.wav And cancel with ^C once  it starts recording. Now you can run alsamixer - press F6 and select the I2S simple sound card ©Adafruit Industries Page 33 of 35 It will complain there are no playback controls (because its for recording only). Press F5 to change the volume. Then you can record with the i2c mic device using arecord -D dmic_sv -c2 -r 48000 -f S32_LE -t wav -V mono -v recording.wav and playback with aplay recording.wav Downloads Files • EagleCAD PCB Files on GitHub (https://adafru.it/uyb) • Fritzing object in the Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 34 of 35 Schematic & Fab Print ©Adafruit Industries Page 35 of 35
很抱歉,暂时无法提供与“3421”相匹配的价格&库存,您可以联系我们找货
    • 1+68.03740
