1381
    ADAFRUIT
    VS1053 CODEC + MICROSD BREAKOUT
1381 数据手册
VS1053b Datasheet VS1053b Ogg Vorbis/MP3/AAC/WMA/FLAC/ MIDI AUDIO CODEC CIRCUIT Features Description VS1053b is an Ogg Vorbis/MP3/AAC/WMA/ • Decodes FLAC/WAVMIDI audio decoder as well as an Ogg Vorbis; PCM/IMA ADPCM/Ogg Vorbis encoder on a MP3 = MPEG 1 & 2 audio layer III (CBR single chip. It contains a high-performance, +VBR +ABR); proprietary low-power DSP processor core MP1/MP2 = layers I & II optional; VS_DSP4 , data memory, 16 KiB instruction MPEG4 / 2 AAC-LC(+PNS), RAM and 0.5+ KiB data RAM for user appliHE-AAC v2 (Level 3) (SBR + PS); WMA 4.0/4.1/7/8/9 all profiles (5-384 kbps); cations running simultaneously with any builtin decoder, serial control and input data inGeneral MIDI 1 / SP-MIDI format 0 files; terfaces, upto 8 general purpose I/O pins, an FLAC with software plugin; UART, as well as a high-quality variable-sampleWAV (PCM + IMA ADPCM) rate stereo ADC (mic, line, line + mic or 2×line) • Encodes Ogg Vorbis w/ software plugin and stereo DAC, followed by an earphone am• Encodes stereo IMA ADPCM / PCM plifier and a common voltage buffer. • Streaming support for MP3 and WAV • EarSpeaker Spatial Processing VS1053b receives its input bitstream through • Bass and treble controls a serial input bus, which it listens to as a • Operates with a single 12..13 MHz clock system slave. The input stream is decoded • Can also be used with a 24..26 MHz clock and passed through a digital volume control to an 18-bit oversampling, multi-bit, sigma• Internal PLL clock multiplier delta DAC. The decoding is controlled via a • Low-power operation serial control bus. In addition to the basic de• High-quality on-chip stereo DAC with no coding, it is possible to add application spephase error between channels cific features, like DSP effects, to the user • Zero-cross detection for smooth volume RAM memory. change • Stereo earphone driver capable of drivOptional factory-programmable unique chip ing a 30 Ω load ID provides basis for digital rights manage• Quiet power-on and power-off ment or unit identification features. • I2S interface for external DAC • Separate voltages for analog, digital, I/O • On-chip RAM for user code and data • Serial control and data interfaces • Can be used as a slave co-processor • SPI flash boot for special applications • UART for debugging purposes • New functions may be added with software and upto 8 GPIO pins • Lead-free RoHS-compliant package (Green) Version: 1.20, 2012-12-03 1 VS1053b Datasheet CONTENTS Contents VS1053 1 Table of Contents 2 List of Figures 5 1 Licenses 6 2 Disclaimer 6 3 Definitions 6 4 Characteristics & Specifications 4.1 Absolute Maximum Ratings . . . . . . . . . 4.2 Recommended Operating Conditions . . . . 4.3 Analog Characteristics . . . . . . . . . . . . 4.4 Power Consumption . . . . . . . . . . . . . 4.5 Digital Characteristics . . . . . . . . . . . . . 4.6 Switching Characteristics - Boot Initialization . . . . . . 7 7 7 8 9 9 9 5 Packages and Pin Descriptions 5.1 Packages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.1.1 LQFP-48 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 10 10 6 Connection Diagram, LQFP-48 13 7 SPI Buses 7.1 SPI Bus Pin Descriptions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1.1 VS10xx Native Modes (New Mode, recommended) . . . . . . . . . . 7.1.2 VS1001 Compatibility Mode (deprecated, do not use in new designs) 7.2 Data Request Pin DREQ . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.3 Serial Protocol for Serial Data Interface (SPI / SDI) . . . . . . . . . . . . . . . . 7.3.1 SDI in VS10xx Native Modes (New Mode, recommended) . . . . . . 7.3.2 SDI Timing Diagram in VS10xx Native Modes (New Mode) . . . . . . 7.3.3 SDI in VS1001 Compatibility Mode (deprecated, do not use in new designs) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.3.4 Passive SDI Mode (deprecated, do not use in new designs) . . . . . 7.4 Serial Protocol for Serial Command Interface (SPI / SCI) . . . . . . . . . . . . . 7.4.1 SCI Read . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.4.2 SCI Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.4.3 SCI Multiple Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.4.4 SCI Timing Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.5 SPI Examples with SM_SDINEW and SM_SDISHARED set . . . . . . . . . . . 7.5.1 Two SCI Writes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.5.2 Two SDI Bytes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.5.3 SCI Operation in Middle of Two SDI Bytes . . . . . . . . . . . . . . . 15 15 15 15 16 17 17 18 8 Supported Audio Decoder Formats 8.1 Supported MP3 (MPEG layer III) Formats . . . . . . . . . . . . . . . . . . . . . 8.2 Supported MP2 (MPEG layer II) Formats . . . . . . . . . . . . . . . . . . . . . . 25 25 26 Version: 1.20, 2012-12-03 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 19 20 20 21 21 22 23 23 23 24 2 VS1053b Datasheet 8.3 8.4 8.5 8.6 8.7 8.8 8.9 Supported MP1 (MPEG layer I) Formats . . . . . . . . . . . . . . . Supported Ogg Vorbis Formats . . . . . . . . . . . . . . . . . . . . Supported AAC (ISO/IEC 13818-7 and ISO/IEC 14496-3) Formats Supported WMA Formats . . . . . . . . . . . . . . . . . . . . . . . Supported FLAC Formats . . . . . . . . . . . . . . . . . . . . . . . Supported RIFF WAV Formats . . . . . . . . . . . . . . . . . . . . . Supported MIDI Formats . . . . . . . . . . . . . . . . . . . . . . . . 9 Functional Description 9.1 Main Features . . . . . . . . . . . . . . . . . 9.2 Data Flow of VS1053b . . . . . . . . . . . . 9.3 EarSpeaker Spatial Processing . . . . . . . 9.4 Serial Data Interface (SDI) . . . . . . . . . . 9.5 Serial Control Interface (SCI) . . . . . . . . 9.6 SCI Registers . . . . . . . . . . . . . . . . . 9.6.1 SCI_MODE (RW) . . . . . . . . . 9.6.2 SCI_STATUS (RW) . . . . . . . . 9.6.3 SCI_BASS (RW) . . . . . . . . . 9.6.4 SCI_CLOCKF (RW) . . . . . . . . 9.6.5 SCI_DECODE_TIME (RW) . . . 9.6.6 SCI_AUDATA (RW) . . . . . . . . 9.6.7 SCI_WRAM (RW) . . . . . . . . . 9.6.8 SCI_WRAMADDR (W) . . . . . . 9.6.9 SCI_HDAT0 and SCI_HDAT1 (R) 9.6.10 SCI_AIADDR (RW) . . . . . . . . 9.6.11 SCI_VOL (RW) . . . . . . . . . . 9.6.12 SCI_AICTRL[x] (RW) . . . . . . . CONTENTS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 26 27 29 30 30 31 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 33 34 35 36 36 37 38 40 41 42 43 43 43 43 44 46 47 47 10 Operation 10.1 Clocking . . . . . . . . . . . . . . . . . . . . . . . . 10.2 Hardware Reset . . . . . . . . . . . . . . . . . . . . 10.3 Software Reset . . . . . . . . . . . . . . . . . . . . 10.4 Low Power Mode . . . . . . . . . . . . . . . . . . . 10.5 Play and Decode . . . . . . . . . . . . . . . . . . . 10.5.1 Playing a Whole File . . . . . . . . . . . 10.5.2 Cancelling Playback . . . . . . . . . . . 10.5.3 Fast Play . . . . . . . . . . . . . . . . . . 10.5.4 Fast Forward and Rewind without Audio 10.5.5 Maintaining Correct Decode Time . . . . 10.6 Feeding PCM data . . . . . . . . . . . . . . . . . . 10.7 Ogg Vorbis Recording . . . . . . . . . . . . . . . . 10.8 PCM/ADPCM Recording . . . . . . . . . . . . . . . 10.8.1 Activating ADPCM Mode . . . . . . . . . 10.8.2 Reading PCM / IMA ADPCM Data . . . . 10.8.3 Adding a PCM RIFF Header . . . . . . . 10.8.4 Adding an IMA ADPCM RIFF Header . . 10.8.5 Playing ADPCM Data . . . . . . . . . . . 10.8.6 Sample Rate Considerations . . . . . . . 10.8.7 Record Monitoring Volume . . . . . . . . 10.9 SPI Boot . . . . . . . . . . . . . . . . . . . . . . . . 10.10 Real-Time MIDI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 48 48 48 48 49 49 50 50 50 51 51 52 52 53 53 54 55 56 57 57 57 59 59 Version: 1.20, 2012-12-03 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 VS1053b Datasheet 10.11 Extra Parameters . . . . . . . . . . . . 10.11.1 Common Parameters . . . . 10.11.2 WMA . . . . . . . . . . . . . 10.11.3 AAC . . . . . . . . . . . . . 10.11.4 Midi . . . . . . . . . . . . . . 10.11.5 Ogg Vorbis . . . . . . . . . . 10.12 SDI Tests . . . . . . . . . . . . . . . . 10.12.1 Sine Test . . . . . . . . . . . 10.12.2 Pin Test . . . . . . . . . . . 10.12.3 SCI Test . . . . . . . . . . . 10.12.4 Memory Test . . . . . . . . . 10.12.5 New Sine and Sweep Tests . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 61 62 63 64 64 66 66 66 66 67 67 11 VS1053b Registers 11.1 Who Needs to Read This Chapter . . . . . . . . 11.2 The Processor Core . . . . . . . . . . . . . . . 11.3 VS1053b Hardware DAC Audio Paths . . . . . . 11.4 VS1053b Hardware ADC Audio Paths . . . . . . 11.5 VS1053b Memory Map . . . . . . . . . . . . . . 11.6 SCI Hardware Registers . . . . . . . . . . . . . 11.7 Serial Data Interface (SDI) Registers . . . . . . 11.8 DAC Registers . . . . . . . . . . . . . . . . . . . 11.9 PLL Controller . . . . . . . . . . . . . . . . . . . 11.10 GPIO . . . . . . . . . . . . . . . . . . . . . . . . 11.11 Interrupt Control . . . . . . . . . . . . . . . . . . 11.12 UART . . . . . . . . . . . . . . . . . . . . . . . . 11.12.1 UART Registers . . . . . . . . . . . . 11.12.2 Status UART_STATUS . . . . . . . . 11.12.3 Data UART_DATA . . . . . . . . . . . 11.12.4 Data High UART_DATAH . . . . . . . 11.12.5 Divider UART_DIV . . . . . . . . . . 11.12.6 UART Interrupts and Operation . . . 11.13 Timers . . . . . . . . . . . . . . . . . . . . . . . 11.13.1 Timer Registers . . . . . . . . . . . . 11.13.2 Configuration TIMER_CONFIG . . . 11.13.3 Configuration TIMER_ENABLE . . . 11.13.4 Timer X Startvalue TIMER_Tx[L/H] . 11.13.5 Timer X Counter TIMER_TxCNT[L/H] 11.13.6 Timer Interrupts . . . . . . . . . . . . 11.14 I2S DAC Interface . . . . . . . . . . . . . . . . . 11.15 Analog-to-Digital Converter (ADC) . . . . . . . . 11.16 Resampler SampleRate Converter (SRC) . . . 11.17 Sidestream Sigma-Delta Modulator (SDM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69 69 69 70 71 72 72 72 73 73 75 76 77 77 77 78 78 78 79 80 80 80 81 81 81 81 82 83 84 85 12 Version Changes 12.1 Changes Between VS1033c and VS1053a/b Firmware, 2007-03-08 . . . . . . . 86 86 13 Document Version Changes 88 14 Contact Information 89 Version: 1.20, 2012-12-03 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . CONTENTS 4 VS1053b Datasheet LIST OF FIGURES List of Figures 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Pin configuration, LQFP-48. . . . . . . . . . . . . . . . . . . . . . . . . . . . VS1053b in LQFP-48 packaging. . . . . . . . . . . . . . . . . . . . . . . . . Typical connection diagram using LQFP-48. . . . . . . . . . . . . . . . . . . SDI in VS10xx Native Mode, single-byte transfer . . . . . . . . . . . . . . . SDI in VS10xx Native Mode, multi-byte transfer, X ≥ 1 . . . . . . . . . . . . SDI timing diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SDI in VS1001 Mode - one byte transfer. Do not use in new designs! . . . . SDI in VS1001 Mode - two byte transfer. Do not use in new designs! . . . . SCI word read . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SCI word write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SCI multiple word write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SPI timing diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Two SCI operations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Two SDI bytes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Two SDI bytes separated by an SCI operation . . . . . . . . . . . . . . . . . Data flow of VS1053b. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . EarSpeaker externalized sound sources vs. normal inside-the-head sound VS1053b ADC and DAC data paths with some data registers . . . . . . . . VS1053b ADC and DAC data paths with some data registers . . . . . . . . RS232 serial interface protocol . . . . . . . . . . . . . . . . . . . . . . . . . I2S interface, 192 kHz. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Version: 1.20, 2012-12-03 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 10 13 17 17 18 19 19 20 21 21 22 23 23 24 34 35 70 71 77 82 5 VS1053b Datasheet 1 3 DEFINITIONS Licenses MPEG Layer-3 audio decoding technology licensed from Fraunhofer IIS and Thomson. Note: If you enable Layer I and Layer II decoding, you are liable for any patent issues that may arise from using these formats. Joint licensing of MPEG 1.0 / 2.0 Layer III does not cover all patents pertaining to layers I and II. VS1053b contains WMA decoding technology from Microsoft. This product is protected by certain intellectual property rights of Microsoft and cannot be used or further distributed without a license from Microsoft. VS1053b contains AAC technology (ISO/IEC 13818-7 and ISO/IEC 14496-3) which cannot be used without a proper license from Via Licensing Corporation or individual patent holders. VS1053b contains spectral band replication (SBR) and parametric stereo (PS) technologies developed by Coding Technologies. Licensing of SBR is handled within MPEG4 through Via Licensing Corporation. Licensing of PS is handled with Coding Technologies. See http://www.codingtechnologies.com/licensing/aacplus.htm for more information. To the best of our knowledge, if the end product does not play a specific format that otherwise would require a customer license: MPEG 1.0/2.0 layers I and II, WMA, or AAC, the respective license should not be required. Decoding of MPEG layers I and II are disabled by default, and WMA and AAC format exclusion can be easily performed based on the contents of the SCI_HDAT1 register. Also PS and SBR decoding can be separately disabled. 2 Disclaimer All properties and figures are subject to change. 3 Definitions B Byte, 8 bits. b Bit. Ki “Kibi” = 210 = 1024 (IEC 60027-2). Mi “Mebi” = 220 = 1048576 (IEC 60027-2). VS_DSP VLSI Solution’s DSP core. W Word. In VS_DSP, instruction words are 32-bit and data words are 16-bit wide. Version: 1.20, 2012-12-03 6 VS1053b Datasheet 4 4 4.1 Characteristics & Specifications Absolute Maximum Ratings Parameter Analog Positive Supply Digital Positive Supply I/O Positive Supply Current at Any Non-Power Pin1 Voltage at Any Digital Input Operating Temperature Storage Temperature 1 2 CHARACTERISTICS & SPECIFICATIONS Symbol AVDD CVDD IOVDD Min -0.3 -0.3 -0.3 -0.3 -30 -65 Max 3.6 1.85 3.6 ±50 IOVDD+0.32 +85 +150 Unit V V V mA V ◦C ◦C Higher current can cause latch-up. Must not exceed 3.6 V 4.2 Recommended Operating Conditions Parameter Ambient Operating Temperature Analog and Digital Ground 1 Positive Analog, REF=1.23V Positive Analog, REF=1.65V 2 Positive Digital I/O Voltage Input Clock Frequency 3 Internal Clock Frequency Internal Clock Multiplier 4 Master Clock Duty Cycle Symbol AGND DGND AVDD AVDD CVDD IOVDD XTALI CLKI Min -30 2.5 3.3 1.7 1.8 12 12 1.0× 40 Typ 0.0 2.8 3.3 1.8 2.8 12.288 36.864 3.0× 50 Max +85 3.6 3.6 1.85 3.6 13 55.3 4.5× 60 Unit ◦C V V V V V MHz MHz % 1 Must be connected together as close the device as possible for latch-up immunity. Reference voltage can be internally selected between 1.23V and 1.65V, see section 9.6.2. 3 The maximum sample rate that can be played with correct speed is XTALI/256 (or XTALI/512 if SM_CLK_RANGE is set). Thus, XTALI must be at least 12.288 MHz (24.576 MHz) to be able to play 48 kHz at correct speed. 4 Reset value is 1.0×. Recommended SC_MULT=3.5×, SC_ADD=1.0× (SCI_CLOCKF=0x8800). Do not exceed maximum specification for CLKI. 2 Version: 1.20, 2012-12-03 7 VS1053b Datasheet 4 4.3 CHARACTERISTICS & SPECIFICATIONS Analog Characteristics Unless otherwise noted: AVDD=3.3V, CVDD=1.8V, IOVDD=2.8V, REF=1.65V, TA=-30..+85◦ C, XTALI=12..13MHz, Internal Clock Multiplier 3.5×. DAC tested with 1307.894 Hz full-scale output sinewave, measurement bandwidth 20..20000 Hz, analog output load: LEFT to GBUF 30 Ω, RIGHT to GBUF 30 Ω. Microphone test amplitude 48 mVpp, fs =1 kHz, Line input test amplitude 1.26 V, fs =1 kHz. Parameter DAC Resolution Total Harmonic Distortion Third Harmonic Distortion Dynamic Range (DAC unmuted, A-weighted) S/N Ratio (full scale signal) Interchannel Isolation (Cross Talk), 600Ω + GBUF Interchannel Isolation (Cross Talk), 30Ω + GBUF Interchannel Gain Mismatch Frequency Response Full Scale Output Voltage (Peak-to-peak) Deviation from Linear Phase Analog Output Load Resistance Analog Output Load Capacitance Microphone input amplifier gain Microphone input amplitude Microphone Total Harmonic Distortion Microphone S/N Ratio Microphone input impedances, per pin Line input amplitude Line input Total Harmonic Distortion Line input S/N Ratio Line input impedance 1 2 3 Symbol Min Typ 18 THD 0.07 0.02 IDR SNR 100 94 80 53 -0.5 -0.1 1.64 AOLR Max 16 1.851 0.5 0.1 2.06 5 302 100 MICG MTHD MSNR LTHD LSNR 60 85 26 48 0.03 70 45 2500 0.005 90 80 1403 0.07 28003 0.014 Unit bits % % dB dB dB dB dB dB Vpp ◦ Ω pF dB mVpp AC % dB kΩ mVpp AC % dB kΩ 3.0 volts can be achieved with +-to-+ wiring for mono difference sound. AOLR may be much lower, but below Typical distortion performance may be compromised. Above typical amplitude the Harmonic Distortion increases. Version: 1.20, 2012-12-03 8 VS1053b Datasheet 4 4.4 CHARACTERISTICS & SPECIFICATIONS Power Consumption Tested with an Ogg Vorbis 128 kbps sample and generated sine. Output at full volume. Internal clock multiplier 3.0×. TA=+25◦ C. Parameter Power Supply Consumption AVDD, Reset Power Supply Consumption CVDD = 1.8V, Reset Power Supply Consumption AVDD, sine test, 30 Ω + GBUF Power Supply Consumption CVDD = 1.8V, sine test Power Supply Consumption AVDD, no load Power Supply Consumption AVDD, output load 30 Ω Power Supply Consumption AVDD, 30 Ω + GBUF Power Supply Consumption CVDD = 1.8V 4.5 High-Level Output Voltage at XTALO = -0.1 mA Low-Level Output Voltage at XTALO = 0.1 mA High-Level Output Voltage at IO = -1.0 mA Low-Level Output Voltage at IO = 1.0 mA Input Leakage Current SPI Input Clock Frequency 2 Rise time of all output pins, load = 50 pF 2 Must not exceed 3.6V Value for SCI reads. SCI and SDI writes allow 4.6 30 8 Typ 0.6 12 36.9 10 5 11 11 11 Max 5.0 20.0 60 15 Unit µA µA mA mA mA mA mA mA Digital Characteristics Parameter High-Level Input Voltage (xRESET, XTALI, XTALO) High-Level Input Voltage (other input pins) Low-Level Input Voltage 1 Min Min 0.7×IOVDD 0.7×CVDD -0.2 0.7×IOVDD Max IOVDD+0.31 IOVDD+0.31 0.3×CVDD 0.3×IOVDD 0.7×IOVDD -1.0 0.3×IOVDD 1.0 CLKI 7 50 Unit V V V V V V V µA MHz ns CLKI 4 . Switching Characteristics - Boot Initialization Parameter XRESET active time XRESET inactive to software ready Power on reset, rise time to CVDD Symbol Min 2 22000 10 Max 500001 Unit XTALI XTALI V/s 1 DREQ rises when initialization is complete. You should not send any data or commands before that. Version: 1.20, 2012-12-03 9 VS1053b Datasheet 5 5 PACKAGES AND PIN DESCRIPTIONS Packages and Pin Descriptions 5.1 Packages LPQFP-48 is a lead (Pb) free and also RoHS compliant package. RoHS is a short name of Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment. 5.1.1 LQFP-48 48 1 Figure 1: Pin configuration, LQFP-48. LQFP-48 package dimensions are at http://www.vlsi.fi/ . Figure 2: VS1053b in LQFP-48 packaging. Version: 1.20, 2012-12-03 10 VS1053b Datasheet 5 Pad Name MICP / LINE1 MICN XRESET DGND0 CVDD0 IOVDD0 CVDD1 DREQ GPIO2 / DCLK1 GPIO3 / SDATA1 GPIO6 / I2S_SCLK3 GPIO7 / I2S_SDATA3 XDCS / BSYNC1 IOVDD1 VCO DGND1 XTALO XTALI IOVDD2 DGND2 DGND3 DGND4 XCS CVDD2 GPIO5 / I2S_MCLK3 RX TX SCLK SI SO CVDD3 XTEST GPIO0 GPIO1 GND GPIO4 I2S_LROUT3 AGND0 AVDD0 RIGHT AGND1 AGND2 GBUF AVDD1 RCAP AVDD2 LEFT AGND3 LINE2 / PACKAGES AND PIN DESCRIPTIONS LQFP Pin 1 2 3 4 5 6 7 8 9 10 11 12 Pin Type AI AI DI DGND CPWR IOPWR CPWR DO DIO DIO DIO DIO Function 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 DI IOPWR DO DGND AO AI IOPWR DGND DGND DGND DI CPWR DIO DI DO DI DI DO3 CPWR DI DIO 34 35 36 DIO DGND DIO Data chip select / byte sync I/O power supply For testing only (Clock VCO output) Core & I/O ground Crystal output Crystal input I/O power supply Core & I/O ground Core & I/O ground Core & I/O ground Chip select input (active low) Core power supply General purpose IO 5 / I2S_MCLK UART receive, connect to IOVDD if not used UART transmit Clock for serial bus Serial input Serial output Core power supply Reserved for test, connect to IOVDD Gen. purp. IO 0 (SPIBOOT), use 100 kΩ pull-down resistor2 General purpose IO 1 I/O Ground General purpose IO 4 / I2S_LROUT 37 38 39 40 41 42 APWR APWR AO APWR APWR AO 43 44 45 46 47 48 APWR AIO APWR AO APWR AI Version: 1.20, 2012-12-03 Positive differential mic input, self-biasing / Line-in 1 Negative differential mic input, self-biasing Active low asynchronous reset, schmitt-trigger input Core & I/O ground Core power supply I/O power supply Core power supply Data request, input bus General purpose IO 2 / serial input data bus clock General purpose IO 3 / serial data input General purpose IO 6 / I2S_SCLK General purpose IO 7 / I2S_SDATA Analog ground, low-noise reference Analog power supply Right channel output Analog ground Analog ground Common buffer for headphones, do NOT connect to ground! Analog power supply Filtering capacitance for reference Analog power supply Left channel output Analog ground Line-in 2 (right channel) 11 VS1053b Datasheet 5 PACKAGES AND PIN DESCRIPTIONS 1 First pin function is active in New Mode, latter in Compatibility Mode. 2 Unless pull-down resistor is used, SPI Boot is tried. See Chapter 10.9 for details. 3 If I2S_CF_ENA is ’0’ the pins are used for GPIO. See Chapter 11.14 for details. Pin types: Type DI DO DIO DO3 AI Description Digital input, CMOS Input Pad Digital output, CMOS Input Pad Digital input/output Digital output, CMOS Tri-stated Output Pad Analog input Version: 1.20, 2012-12-03 Type AO AIO APWR DGND CPWR IOPWR Description Analog output Analog input/output Analog power supply pin Core or I/O ground pin Core power supply pin I/O power supply pin 12 VS1053b Datasheet 6 6 CONNECTION DIAGRAM, LQFP-48 Connection Diagram, LQFP-48 Figure 3: Typical connection diagram using LQFP-48. Figure 3 shows a typical connection diagram for VS1053. Figure Note 1: Connect either Microphone In or Line In, but not both at the same time. Note: This connection assumes SM_SDINEW is active (see Chapter 9.6.1). If also SM_SDISHARE is used, xDCS should be tied low or high (see Chapter 7.1.1). Version: 1.20, 2012-12-03 13 VS1053b Datasheet 6 CONNECTION DIAGRAM, LQFP-48 The common buffer GBUF can be used for common voltage (1.23 V) for earphones. This will eliminate the need for large isolation capacitors on line outputs, and thus the audio output pins from VS1053b may be connected directly to the earphone connector. GBUF must NOT be connected to ground under any circumstances. If GBUF is not used, LEFT and RIGHT must be provided with coupling capacitors. To keep GBUF stable, you should always have the resistor and capacitor even when GBUF is not used. See application notes for details. Unused GPIO pins should have a pull-down resistor. Unused line and microphone inputs should not be connected. If UART is not used, RX should be connected to IOVDD and TX be unconnected. Do not connect any external load to XTALO. Version: 1.20, 2012-12-03 14 VS1053b Datasheet 7 7 SPI BUSES SPI Buses The SPI Bus - which was originally used in some Motorola devices - has been used for both VS1053b’s Serial Data Interface SDI (Chapters 7.3 and 9.4) and Serial Control Interface SCI (Chapters 7.4 and 9.5). 7.1 SPI Bus Pin Descriptions 7.1.1 VS10xx Native Modes (New Mode, recommended) These modes are active on VS1053b when SM_SDINEW is set to 1 (default at startup). DCLK and SDATA are not used for data transfer and they can be used as general-purpose I/O pins (GPIO2 and GPIO3). BSYNC function changes to data interface chip select (XDCS). SDI Pin XDCS SCI Pin XCS SCK SI - 7.1.2 SO Description Active low chip select input. A high level forces the serial interface into standby mode, ending the current operation. A high level also forces serial output (SO) to high impedance state. If SM_SDISHARE is 1, pin XDCS is not used, but the signal is generated internally by inverting XCS. Serial clock input. The serial clock is also used internally as the master clock for the register interface. SCK can be gated or continuous. In either case, the first rising clock edge after XCS has gone low marks the first bit to be written. Serial input. If a chip select is active, SI is sampled on the rising CLK edge. Serial output. In reads, data is shifted out on the falling SCK edge. In writes SO is at a high impedance state. VS1001 Compatibility Mode (deprecated, do not use in new designs) This mode is active when SM_SDINEW is set to 0. In this mode, DCLK, SDATA and BSYNC are active. SDI Pin - SCI Pin XCS BSYNC DCLK SCK SDATA - SI SO Description Active low chip select input. A high level forces the serial interface into standby mode, ending the current operation. A high level also forces serial output (SO) to high impedance state. SDI data is synchronized with a rising edge of BSYNC. Serial clock input. The serial clock is also used internally as the master clock for the register interface. SCK can be gated or continuous. In either case, the first rising clock edge after XCS has gone low marks the first bit to be written. Serial input. SI is sampled on the rising SCK edge, if XCS is low. Serial output. In reads, data is shifted out on the falling SCK edge. In writes SO is at a high impedance state. Version: 1.20, 2012-12-03 15 VS1053b Datasheet 7.2 7 SPI BUSES Data Request Pin DREQ The DREQ pin/signal is used to signal if VS1053b’s 2048-byte FIFO is capable of receiving data. If DREQ is high, VS1053b can take at least 32 bytes of SDI data or one SCI command. DREQ is turned low when the stream buffer is too full and for the duration of an SCI command. Because of the 32-byte safety area, the sender may send upto 32 bytes of SDI data at a time without checking the status of DREQ, making controlling VS1053b easier for low-speed microcontrollers. Note: DREQ may turn low or high at any time, even during a byte transmission. Thus, DREQ should only be used to decide whether to send more bytes. A transmission that has already started doesn’t need to be aborted. Note: In VS1053b DREQ also goes down while an SCI operation is in progress. There are cases when you still want to send SCI commands when DREQ is low. Because DREQ is shared between SDI and SCI, you can not determine if an SCI command has been executed if SDI is not ready to receive data. In this case you need a long enough delay after every SCI command to make certain none of them are missed. The SCI Registers table in Chapter 9.6 gives the worst-case handling time for each SCI register write. Note: The status of DREQ can also be read through SCI with the following code. For details on SCI registers, see Chapter 7.4. // This example reads status of DREQ pin through the SPI/SCI register // interface. #define SCI_WRAMADDR 7 #define SCI_WRAM 6 while (!endOfFile) { int dreq; WriteSciReg(SCI_WRAMADDR, 0xC012); // Send address of DREQ register dreq = ReadSciReg(SCI_WRAM) & 1; // Read value of DREQ (in bit 0) if (dreq) { // DREQ high: send 1-32 bytes audio data } else { // DREQ low: wait 5 milliseconds (so that VS10xx doesn't get // continuous SCI operations) } } /* while (!endOfFile) */ Version: 1.20, 2012-12-03 16 VS1053b Datasheet 7.3 7 SPI BUSES Serial Protocol for Serial Data Interface (SPI / SDI) The serial data interface operates in slave mode so DCLK signal must be generated by an external circuit. Data (SDATA signal) can be clocked in at either the rising or falling edge of DCLK (Chapter 9.6). VS1053b assumes its data input to be byte-sychronized. SDI bytes may be transmitted either MSb or LSb first, depending of register SCI_MODE bit SM_SDIORD (Chapter 9.6.1). The firmware is able to accept the maximum bitrate the SDI supports. 7.3.1 SDI in VS10xx Native Modes (New Mode, recommended) XDCS SDATA D7 D6 D5 D4 D3 D2 D1 D0 DCLK Figure 4: SDI in VS10xx Native Mode, single-byte transfer In VS10xx native modes (SM_NEWMODE is 1), byte synchronization is achieved by XDCS, as shown in Figure 4. The state of XDCS may not change while a data byte transfer is in progress. XDCS does not need to be deactivated and reactivated for every byte transfer, as shown in Figure 5. However, to maintain data synchronization even if there are occasional clock glitches, it is recommended to deactivate and reactivate XDCS every now and then, for example after each 32 bytes of data. Note that when sending data through SDI you have to check the Data Request Pin DREQ at least after every 32 bytes (Chapter 7.2). XDCS Byte 1 SDATA D7 D6 D5 D4 D3 Byte 2 D2 D1 D0 D7 D6 Byte X D5 ... D3 D2 D1 D0 ... DCLK Figure 5: SDI in VS10xx Native Mode, multi-byte transfer, X ≥ 1 If SM_SDISHARE is 1, the XDCS signal is internally generated by inverting the XCS input. Version: 1.20, 2012-12-03 17 VS1053b Datasheet 7.3.2 7 SPI BUSES SDI Timing Diagram in VS10xx Native Modes (New Mode) tWL tXCSS tWH tXCSH xDCS D7 D6 D5 D4 D3 D2 tXCS D1 D0 SCK SI tH tSU Figure 6: SDI timing diagram Figure 6 presents SDI bus timing. Symbol tXCSS tSU tH tWL tWH tXCSH tXCS Min 5 0 2 2 2 1 0 Max Unit ns ns CLKI cycles CLKI cycles CLKI cycles CLKI cycles CLKI cycles Note: xDCS is not required to go high between bytes, so tXCS is 0. Note: Although the timing is derived from the internal clock CLKI, the system always starts up in 1.0× mode, thus CLKI=XTALI. After you have configured a higher clock through SCI_CLOCKF and waited for DREQ to rise, you can use a higher SPI speed as well. Version: 1.20, 2012-12-03 18 VS1053b Datasheet 7.3.3 7 SPI BUSES SDI in VS1001 Compatibility Mode (deprecated, do not use in new designs) BSYNC SDATA D7 D6 D5 D4 D3 D2 D1 D0 DCLK Figure 7: SDI in VS1001 Mode - one byte transfer. Do not use in new designs! When VS1053b is running in VS1001 compatibility mode, a BSYNC signal must be generated to ensure correct bit-alignment of the input bitstream, as shown in Figures 7 and 8. The first DCLK sampling edge (rising or falling, depending on selected polarity), during which the BSYNC is high, marks the first bit of a byte (LSB, if LSB-first order is used, MSB, if MSB-first order is used). If BSYNC is ’1’ when the last bit is received, the receiver stays active and next 8 bits are also received. BSYNC SDATA D7 D6 D5 D4 D3 D2 D1 D0 D7 D6 D5 D4 D3 D2 D1 D0 DCLK Figure 8: SDI in VS1001 Mode - two byte transfer. Do not use in new designs! 7.3.4 Passive SDI Mode (deprecated, do not use in new designs) If SM_NEWMODE is 0 and SM_SDISHARE is 1, the operation is otherwise like the VS1001 compatibility mode, but bits are only received while the BSYNC signal is ’1’. Rising edge of BSYNC is still used for synchronization. Version: 1.20, 2012-12-03 19 VS1053b Datasheet 7.4 7 SPI BUSES Serial Protocol for Serial Command Interface (SPI / SCI) The serial bus protocol for the Serial Command Interface SCI (Chapter 9.5) consists of an instruction byte, address byte and one 16-bit data word. Each read or write operation can read or write a single register. Data bits are read at the rising edge, so the user should update data at the falling edge. Bytes are always send MSb first. XCS should be low for the full duration of the operation, but you can have pauses between bits if needed. The operation is specified by an 8-bit instruction opcode. The supported instructions are read and write. See table below. Instruction Opcode 0b0000 0011 0b0000 0010 Name READ WRITE Operation Read data Write data Note: VS1053b sets DREQ low after each SCI operation. The duration depends on the operation. It is not allowed to finish a new SCI/SDI operation before DREQ is high again. 7.4.1 SCI Read XCS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 0 0 0 0 0 0 1 1 0 0 0 30 31 SCK 3 SI instruction (read) 2 1 0 don’t care 0 data out address 15 14 SO 0 0 0 0 0 0 0 0 0 0 0 0 0 don’t care 0 0 0 1 0 X execution DREQ Figure 9: SCI word read VS1053b registers are read from using the following sequence, as shown in Figure 9. First, XCS line is pulled low to select the device. Then the READ opcode (0x3) is transmitted via the SI line followed by an 8-bit word address. After the address has been read in, any further data on SI is ignored by the chip. The 16-bit data corresponding to the received address will be shifted out onto the SO line. XCS should be driven high after data has been shifted out. DREQ is driven low for a short while when in a read operation by the chip. This is a very short time and doesn’t require special user attention. Version: 1.20, 2012-12-03 20 VS1053b Datasheet 7.4.2 7 SPI BUSES SCI Write XCS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 0 0 0 0 0 0 1 0 0 0 0 30 31 SCK 3 SI instruction (write) SO 0 0 0 0 0 0 2 1 15 14 0 0 0 0 0 X data out address 0 1 0 0 0 0 0 0 0 0 0 0 X 0 execution DREQ Figure 10: SCI word write VS1053b registers are written from using the following sequence, as shown in Figure 10. First, XCS line is pulled low to select the device. Then the WRITE opcode (0x2) is transmitted via the SI line followed by an 8-bit word address. After the word has been shifted in and the last clock has been sent, XCS should be pulled high to end the WRITE sequence. After the last bit has been sent, DREQ is driven low for the duration of the register update, marked “execution” in the figure. The time varies depending on the register and its contents (see table in Chapter 9.6 for details). If the maximum time is longer than what it takes from the microcontroller to feed the next SCI command or SDI byte, status of DREQ must be checked before finishing the next SCI/SDI operation. 7.4.3 SCI Multiple Write XCS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 SI 0 0 0 0 0 0 1 0 0 0 0 SO 0 0 0 0 0 0 0 29 30 31 32 33 m−2m−1 SCK 3 instruction (write) 0 0 0 0 2 1 0 15 14 1 0 data out 1 address 0 15 14 1 0 X X 0 0 0 0 0 0 0 data out 2 d.out n 0 0 0 execution 0 0 0 X execution DREQ Figure 11: SCI multiple word write VS1053b allows for the user to send multiple words to the same SCI register, which allows fast SCI uploads, shown in Figure 11. The main difference to a single write is that instead of Version: 1.20, 2012-12-03 21 VS1053b Datasheet 7 SPI BUSES bringing XCS up after sending the last bit of a data word, the next data word is sent immediately. After the last data word, XCS is driven high as with a single word write. After the last bit of a word has been sent, DREQ is driven low for the duration of the register update, marked “execution” in the figure. The time varies depending on the register and its contents (see table in Chapter 9.6 for details). If the maximum time is longer than what it takes from the microcontroller to feed the next SCI command or SDI byte, status of DREQ must be checked before finishing the next SCI/SDI operation. 7.4.4 SCI Timing Diagram tWL tXCSS tWH tXCSH XCS tXCS 0 1 14 15 30 16 31 SCK SI tH tSU SO tZ tV tDIS Figure 12: SPI timing diagram The SCI timing diagram is presented in Figure 12. Symbol tXCSS tSU tH tZ tWL tWH tV tXCSH tXCS tDIS 1 Min 5 0 2 0 2 2 1 2 (+ 25 ns ) 1 2 Max 10 Unit ns ns CLKI cycles ns CLKI cycles CLKI cycles CLKI cycles CLKI cycles CLKI cycles ns 25 ns is when pin loaded with 100 pF capacitance. The time is shorter with lower capacitance. Note: Although the timing is derived from the internal clock CLKI, the system always starts up in 1.0× mode, thus CLKI=XTALI. After you have configured a higher clock through SCI_CLOCKF and waited for DREQ to rise, you can use a higher SPI speed as well. Note: Because tWL + tWH + tH is 6×CLKI + 25 ns, the maximum speed for SCI reads is CLKI/7. Version: 1.20, 2012-12-03 22 VS1053b Datasheet 7.5 7.5.1 7 SPI BUSES SPI Examples with SM_SDINEW and SM_SDISHARED set Two SCI Writes SCI Write 1 SCI Write 2 XCS 0 1 2 3 30 31 1 0 32 33 61 62 63 2 1 0 SCK SI 0 0 0 X 0 0 X 0 DREQ up before finishing next SCI write DREQ Figure 13: Two SCI operations Figure 13 shows two consecutive SCI operations. Note that xCS must be raised to inactive state between the writes. Also DREQ must be respected as shown in the figure. 7.5.2 Two SDI Bytes SDI Byte 1 SDI Byte 2 XCS 0 1 2 3 7 6 5 4 6 7 8 9 1 0 7 6 13 14 15 2 1 0 SCK 3 SI 5 X DREQ Figure 14: Two SDI bytes SDI data is synchronized with a raising edge of xCS as shown in Figure 14. However, every byte doesn’t need separate synchronization. Version: 1.20, 2012-12-03 23 VS1053b Datasheet 7.5.3 7 SPI BUSES SCI Operation in Middle of Two SDI Bytes SDI Byte SDI Byte SCI Operation XCS 0 7 1 8 9 39 40 41 7 6 46 47 1 0 SCK 7 6 5 1 0 0 SI 5 X 0 DREQ high before end of next transfer DREQ Figure 15: Two SDI bytes separated by an SCI operation Figure 15 shows how an SCI operation is embedded in between SDI operations. xCS edges are used to synchronize both SDI and SCI. Remember to respect DREQ as shown in the figure. Version: 1.20, 2012-12-03 24 VS1053b Datasheet 8 8 Supported Audio Decoder Formats Mark + ? - 8.1 SUPPORTED AUDIO DECODER FORMATS Conventions Description Format is supported Format is supported but not thoroughly tested Format exists but is not supported Format doesn’t exist Supported MP3 (MPEG layer III) Formats MPEG 1.01 : Samplerate / Hz 48000 44100 32000 32 + + + 40 + + + 48 + + + 56 + + + 64 + + + 80 + + + Bitrate / kbit/s 96 112 128 + + + + + + + + + 160 + + + 192 + + + 224 + + + 256 + + + 320 + + + 8 + + + 16 + + + 24 + + + 32 + + + 40 + + + 48 + + + Bitrate / kbit/s 56 64 80 + + + + + + + + + 96 + + + 112 + + + 128 + + + 144 + + + 160 + + + 8 + + + 16 + + + 24 + + + 32 + + + 40 + + + 48 + + + Bitrate / kbit/s 56 64 80 + + + + + + + + + 96 + + + 112 + + + 128 + + + 144 + + + 160 + + + MPEG 2.01 : Samplerate / Hz 24000 22050 16000 MPEG 2.51 : Samplerate / Hz 12000 11025 8000 1 Also all variable bitrate (VBR) formats are supported. Version: 1.20, 2012-12-03 25 VS1053b Datasheet 8 8.2 SUPPORTED AUDIO DECODER FORMATS Supported MP2 (MPEG layer II) Formats Note: Layer I / II decoding must be specifically enabled from register SCI_MODE. MPEG 1.0: Samplerate / Hz 48000 44100 32000 32 + + + 48 + + + 56 + + + 64 + + + 80 + + + 96 + + + Bitrate / kbit/s 112 128 160 + + + + + + + + + 192 + + + 224 + + + 256 + + + 320 + + + 384 + + + 8 + + + 16 + + + 24 + + + 32 + + + 40 + + + 48 + + + Bitrate / kbit/s 56 64 80 + + + + + + + + + 96 + + + 112 + + + 128 + + + 144 + + + 160 + + + MPEG 2.0: Samplerate / Hz 24000 22050 16000 8.3 Supported MP1 (MPEG layer I) Formats Note: Layer I / II decoding must be specifically enabled from register SCI_MODE. MPEG 1.0: Samplerate / Hz 48000 44100 32000 32 + + + 64 + + + 96 + + + 128 + + + 160 + + + Bitrate / kbit/s 192 224 256 288 + + + + + + + + + + + + 320 + + + 352 + + + 384 + + + 416 + + + 448 + + + 32 ? ? ? 48 ? ? ? 56 ? ? ? 64 ? ? ? 80 ? ? ? 96 ? ? ? Bitrate / kbit/s 112 128 144 ? ? ? ? ? ? ? ? ? 160 ? ? ? 176 ? ? ? 192 ? ? ? 224 ? ? ? 256 ? ? ? MPEG 2.0: Samplerate / Hz 24000 22050 16000 8.4 Supported Ogg Vorbis Formats Parameter Channels Window size Samplerate Bitrate Min 64 Max 2 4096 48000 500 Unit samples Hz kbit/sec Only floor 1 is supported. No known current encoder uses floor 0. All one- and two-channel Ogg Vorbis files should be playable with this decoder. Version: 1.20, 2012-12-03 26 VS1053b Datasheet 8 8.5 SUPPORTED AUDIO DECODER FORMATS Supported AAC (ISO/IEC 13818-7 and ISO/IEC 14496-3) Formats VS1053b decodes MPEG2-AAC-LC-2.0.0.0 and MPEG4-AAC-LC-2.0.0.0 streams, i.e. the low complexity profile with maximum of two channels can be decoded. If a stream contains more than one element and/or element type, you can select which one to decode from the 16 singlechannel, 16 channel-pair, and 16 low-frequency elements. The default is to select the first one that appears in the stream. Dynamic range control (DRC) is supported and can be controlled by the user to limit or enhance the dynamic range of the material that contains DRC information. Both Sine window and Kaiser-Bessel-derived window are supported. For MPEG4 pseudorandom noise substitution (PNS) is supported. Short frames (120 and 960 samples) are not supported. Spectral Band Replication (SBR) level 3, and Parametric Stereo (PS) level 3 are supported (HEAAC v2). Level 3 means that maximum of 2 channels, samplerates upto and including 48 kHz without and with SBR (with or without PS) are supported. Also, both mixing modes (Ra and Rb ), IPD/OPD synthesis and 34 frequency bands resolution are implemented. The downsampled synthesis mode (core coder rates > 24 kHz and 0 for automatic m4a, ADIF, WMA resyncs */ union { struct { u_int32 curPacketSize; u_int32 packetSize; } wma; struct { u_int16 sceFoundMask; /*1e2a SCE's found since last clear */ u_int16 cpeFoundMask; /*1e2b CPE's found since last clear */ u_int16 lfeFoundMask; /*1e2c LFE's found since last clear */ u_int16 playSelect; /*1e2d 0 = first any, initialized at aac init */ s_int16 dynCompress; /*1e2e -8192=1.0, initialized at aac init */ s_int16 dynBoost; /*1e2f 8192=1.0, initialized at aac init */ u_int16 sbrAndPsStatus; /*0x1e30 1=SBR, 2=upsample, 4=PS, 8=PS active */ } aac; struct { u_int32 bytesLeft; } midi; struct { s_int16 gain; /* 0x1e2a proposed gain offset in 0.5dB steps, default = -12 */ } vorbis; } i; }; Notice that reading two-word variables through the SCI_WRAMADDR and SCI_WRAM interface is not protected in any way. The variable can be updated between the read of the low and high parts. The problem arises when both the low and high parts change values. To determine if the value is correct, you should read the value twice and compare the results. The following example shows what happens when bytesLeft is decreased from 0x10000 to 0xffff and the update happens between low and high part reads or after high part read. Address 0x1e2a 0x1e2b 0x1e2a 0x1e2b Read Invalid Value 0x0000 change after this 0x0000 0xffff 0x0000 Version: 1.20, 2012-12-03 Address 0x1e2a 0x1e2b 0x1e2a 0x1e2b Read Valid Value 0x0000 0x0001 change after this 0xffff 0x0000 No Update Address Value 0x1e2a 0x0000 0x1e2b 0x0001 0x1e2a 0x0000 0x1e2b 0x0001 60 VS1053b Datasheet 10 OPERATION You can see that in the invalid read the low part wraps from 0x0000 to 0xffff while the high part stays the same. In this case the second read gives a valid answer, otherwise always use the value of the first read. The second read is needed when it is possible that the low part wraps around, changing the high part, i.e. when the low part is small. bytesLeft is only decreased by one at a time, so a reread is needed only if the low part is 0. 10.11.1 Common Parameters These parameters are common for all codecs. Other fields are only valid when the corresponding codec is active. The currently active codec can be determined from SCI_HDAT1. Parameter version config1 playSpeed byteRate endFillByte jumpPoints[8] latestJump positionMsec resync Address 0x1e02 0x1e03 0x1e04 0x1e05 0x1e06 0x1e16-25 0x1e26 0x1e27-28 0x1e29 Usage Structure version – 0x0003 Miscellaneous configuration 0,1 = normal speed, 2 = twice, 3 = three times etc. average byterate byte to send after file Packet offsets for WMA and AAC Index to latest jumpPoint File position in milliseconds, if available Automatic resync selector The fuse-programmed ID is read at startup and copied into the chipID field. If not available, the value will be all zeros. The version field can be used to determine the layout of the rest of the structure. The version number is changed when the structure is changed. For VS1053b the structure version is 3. config1 controls MIDI Reverb and AAC’s SBR and PS settings. playSpeed makes it possible to fast forward songs. Decoding of the bitstream is performed, but only each playSpeed frames are played. For example by writing 4 to playSpeed will play the song four times as fast as normal, if you are able to feed the data with that speed. Write 0 or 1 to return to normal speed. SCI_DECODE_TIME will also count faster. All current codecs support the playSpeed configuration. byteRate contains the average bitrate in bytes per second for every code. The value is updated once per second and it can be used to calculate an estimate of the remaining playtime. This value is also available in SCI_HDAT0 for all codecs except MP3, MP2, and MP1. endFillByte indicates what byte value to send after file is sent before SM_CANCEL. jumpPoints contain 32-bit file offsets. Each valid (non-zero) entry indicates a start of a packet for WMA or start of a raw data block for AAC (ADIF, .mp4 / .m4a). latestJump contains the index of the entry that was updated last. If you only read entry pointed to by latestJump you do not need to read the entry twice to ensure validity. Jump point information can be used to Version: 1.20, 2012-12-03 61 VS1053b Datasheet 10 OPERATION implement perfect fast forward and rewind for WMA and AAC (ADIF, .mp4 / .m4a). positionMsec is a field that gives the current play position in a file in milliseconds, regardless of rewind and fast forward operations. The value is only available in codecs that can determine the play position from the stream itself. Currently WMA and Ogg Vorbis provide this information. If the position is unknown, this field contains -1. resync field is used to force a resynchronization to the stream for WMA and AAC (ADIF, .mp4 / .m4a) instead of ending the decode at first error. This field can be used to implement almost perfect fast forward and rewind for WMA and AAC (ADIF, .mp4 / .m4a). The user should set this field before performing data seeks if they are not in packet or data block boundaries. The field value tells how many tries are allowed before giving up. The value 32767 gives infinite tries. The resync field is set to 32767 after a reset to make resynchronization the default action, but it can be cleared after reset to restore the old action. When resync is set, every file decode should always end as described in Chapter 10.5.1. Seek fields no longer exist. When resync is required, WMA and AAC codecs now enter broadcast/stream mode where file size information is ignored. Also, the file size and sample size information of WAV files are ignored when resync is non-zero. The user must use SM_CANCEL or software reset to end decoding. Note: WAV, WMA, ADIF, and .mp4 / .m4a files begin with a metadata or header section, which must be fully processed before any fast forward or rewind operation. SS_DO_NOT_JUMP (in SCI_STATUS) is clear when the header information has been processed and jumps are allowed. 10.11.2 WMA Parameter curPacketSize packetSize Address 0x1e2a/2b 0x1e2c/2d Usage The size of the packet being processed The packet size in ASF header The ASF header packet size is available in packetSize. With this information and a packet start offset from jumpPoints you can parse the packet headers and skip packets in ASF files. WMA decoder can also increase the internal clock automatically when it detects that a file can not be decoded correctly with the current clock. The maximum allowed clock is configured with the SCI_CLOCKF register. Version: 1.20, 2012-12-03 62 VS1053b Datasheet 10.11.3 10 OPERATION AAC Parameter config1 sceFoundMask cpeFoundMask lfeFoundMask playSelect dynCompress dynBoost sbrAndPsStatus Address 0x1e03(7:4) 0x1e2a 0x1e2b 0x1e2c 0x1e2d 0x1e2e 0x1e2f 0x1e30 Usage SBR and PS select Single channel elements found Channel pair elements found Low frequency elements found Play element selection Compress coefficient for DRC, -8192=1.0 Boost coefficient for DRC, 8192=1.0 SBR and PS available flags playSelect determines which element to decode if a stream has multiple elements. The value is set to 0 each time AAC decoding starts, which causes the first element that appears in the stream to be selected for decoding. Other values are: 0x01 - select first single channel element (SCE), 0x02 - select first channel pair element (CPE), 0x03 - select first low frequency element (LFE), S ∗ 16 + 5 - select SCE number S, P ∗ 16 + 6 - select CPE number P, L ∗ 16 + 7 select LFE number L. When automatic selection has been performed, playSelect reflects the selected element. sceFoundMask, cpeFoundMask, and lfeFoundMask indicate which elements have been found in an AAC stream since the variables have last been cleared. The values can be used to present an element selection menu with only the available elements. dynCompress and dynBoost change the behavior of the dynamic range control (DRC) that is present in some AAC streams. These are also initialized when AAC decoding starts. sbrAndPsStatus indicates spectral band replication (SBR) and parametric stereo (PS) status. Bit 0 1 2 3 Usage SBR present upsampling active PS present PS active Bits 7 to 4 in config1 can be used to control the SBR and PS decoding. Bits 5 and 4 select SBR mode and bits 7 and 6 select PS mode. These configuration bits are useful if your AAC license does not cover SBR and/or PS. config1(5:4) ’00’ ’01’ ’10’ ’11’ Usage normal mode, upsample
很抱歉,暂时无法提供与“1381”相匹配的价格&库存,您可以联系我们找货
