Mini FX Evaluation Kit
A Low-Cost Tool for Evaluating and Developing
LONWORKS® Devices for Control Networks
Designed for control system developers, integrators,
specifying engineers, educators, and students, Mini FX
combines a flexible hardware platform with sample
Neuron® C applications and a Neuron C compiler.
In just a matter of minutes, you can easily set up and demonstrate
twisted pair or power line control networks, as well as write, compile,
and load new applications of your own design.
Features
• Introduces developers to LonWorks control networking using ISO/IEC 14908-1
with a simple evaluation and programming environment.
• Includes example applications for device networking.
• Can be used without any separate network installation tools for running selfinstalled examples or creating self-installed devices.
• Can be used with the LonMaker ® Integration Tool (Standard or Professional
Edition) to develop and test devices for managed networks.
• Speeds development of control networks with the powerful Neuron C
programming language and a compiler that supports up to 32 network variables.
• Downloads compiled Neuron C applications to target hardware over the
control network.
• Provides easy resource and hardware definition and editing with built-in resource
and hardware template editors.
• Includes two evaluation boards, I/O hardware, and USB interface for fast plugand-play setup.
• Provides easy migration to the powerful NodeBuilder® Development Tool.
• Available in free topology twisted pair (FT) and power line (PL) versions.
www.echelon.com
Description
Mini FX makes it affordable for anyone
to understand and harness the power
of the popular LonWorks platform, and
to develop new devices for the rapidly
growing, price-sensitive sensor/actuator
mass market. Use Mini FX standalone to
create devices that install themselves, or
use Mini FX with a network installation
tool such as the LonMaker Integration
Tool to create devices that are installed in
managed networks. If you need a more
full-featured development environment,
upgrade to the NodeBuilder FX
Development Tool, which uses the same
Neuron C programming language, includes
the LonMaker Integration Tool, and also
includes many productivity enhancements
such as a debugger, project manager,
integrated development environment, code
editor, code wizard, plug-in framework,
and network management API.
free topology twisted pair transceiver,
anexternal 10 MHz crystal (you can adjust
the internal system clock speed from
5MHz to 80MHz), an FT-X3 communication
transformer, 64KB external serial EEPROM
and flash memory devices, and a 3.3V
power source. The free topology twisted
pair transceivers implement the ISO/
IEC 14908-2 communication standard for
TP/FT-10 channels and eliminate wiring
topology restrictions for twisted pair
communication, a severe limitation of
older technologies such as RS-485. The FT
5000 EVB features a compact design that
includes the following I/O components,
which you can use to develop prototype
and production devices and test the FT
5000 EVB example applications:
• 4-line x 20-character LCD display
• 4-way joystick with center push
button
• Two push-button inputs
• Two LED outputs
• Light-level sensor
• Temperature sensor
FT 5000 EVB
There are two versions of Mini FX: Mini
FX/FT for developing devices that
communicate using twisted pair cable,
and Mini FX/PL for developing devices
that communicate over existing power
lines. Both versions include two evaluation
boards with example I/O hardware, a USB
network interface for attaching a Windows
PC to the LonWorks network, and power
supplies. The USB network interfaces are
low-cost, high-performance LonWorks
interfaces for USB-enabled computers and
controllers.
Mini FX/FT includes two FT 5000 EVB
Evaluation Boards. The FT 5000 EVB is a
complete Series 5000 LonWorks device
that you can use to evaluate the LonWorks
2.0 platform and create LonWorks 2.0
devices. The FT 5000 EVB includes an FT
5000 Smart Transceiver with an integrated
PL 3150 EVB and MiniGizmo
Mini FX/PL includes one PL 3150 EVB
Evaluation Board, one PL 3170 EVB
Evaluation Board, and two MiniGizmo I/O
Boards for use with the two EVBs. The
PL 3150 EVB includes a PL 3150 Smart
Transceiver with an integrated power line
transceiver, an external 10 MHz crystal (with
an internal system clock speed of 5MHz),
64KB external flash memory, and a 5V
power source. The PL 3170 EVB includes
a PL 3170 Smart Transceiver with an
integrated power line transceiver, onchip ROM with Neuron firmware and selfinstallation support, an external 10MHz
crystal (for an internal system clock
speed of 5MHz), and a 5V power source.
The power line transceivers implement
the ISO/IEC 14908-3 communication
standard for PL-20
C-Band channels and provide network
munication by signaling over any AC or
DC power circuit, eliminating the need
for any new wires for communication.
The plug-in power supplies provided
with the power line evaluation boards
pass the network signals directly into the
AC power lines over the same two wires
that power the evaluation boards. The
power line version of the Mini FX allows a
control network to be created by simply
plugging the evaluation boards into
electrical outlets.
Mini FX PL includes two MiniGizmo I/O
boards that provide I/O components that
you can use to develop prototype and
production devices and test the PL EVB
example applications. The MiniGizmo
I/O boards include eight push buttons,
eight LEDs, a temperature sensor, and a
piezo transducer.
The FT 5000 EVB Evaluation Board
and PL Evaluation Boards also include
an EIA-232/TIA-232/RS-232 interface
that you can use to connect the board
to your development computer and
perform application-level debugging.
The FT 5000 EVB also includes a USB
interface that you can use instead of the
RS-232 interface for a serial interface to
your development computer.
Mini FX/FT also includes a U10 USB
Network Interface. This connects directly
to a TP/FT-10 free topology twisted pair
LonWorks channel through a compact
removable connector.
Mini FX/PL also includes a U20 USB
Network Interface. This connects to a
PL-20 C-Band power line LonWorks
channel through an included power
supply with integrated power line
coupler. The U20 USB Network Interface
can also be connected directly to
10.8-18VDC power systems (such as
those in automobiles, trucks, and buses)
without a coupling circuit, or to virtually
any powered line through a customersupplied coupler/power supply.
Simplify Your Development
Mini FX includes software for Windows
that lets you create and test applications
for LonWorks devices based on an
Echelon Series 5000 or 3100 Neuron
Processor or an Echelon Series 5000
www.echelon.com
or 3100 Smart Transceiver. Using the
Mini FX software, you write your device
applications using the Neuron C Version
2.2 programming language, a high-level
language based on ANSI C with extensions
to simplify network communication,
hardware I/O, and event-driven processing.
For Series 5000 applications, Neuron C
Version 2.2 also introduces support for
application-specific interrupt handlers and
a hardware semaphore that can be used
for interrupt task synchronization. Interrupt
sources include signals on any of the 12
I/O pins (rising edge, falling edge, either
edge, positive or negative level), the highperformance on-chip timer and counter
units, and a dedicated, configurable, highperformance, periodic system timer.
You can use the Neuron C compiler
included with Mini FX to compile
applications with up to 32 network
variables, and that require up to 12K
compiled instructions (resulting in
approximately 32KB of compiled
application code). To develop larger
applications or to develop applications that
require more network variables,
you can upgrade to the NodeBuilder
FX software, which includes support
for up to 254 static network variables,
up to 127 network variable aliases, and no
code limit other than available memory.
If the standard resource files do not
include the resources you need, a
powerful resource editor lets you view
standard types and functional profiles, and
createuser-defined types and profiles.
Built-in Examples Shorten
Design Time
Mini FX includes working example
applications that let you evaluate the
benefits of the LonWorks platform without
writing any code. These applications
demonstrate how control devices can
interact with I/O hardware and exchange
data over a control network. They also
demonstrate how control networks
can be created without the use of any
installation tools through a simple process
called self-installation. The applications
are compatible with standard LonWorks
installation tools such as the LonMaker ®
Integration Tool, letting you evaluate
the capability of devices to be used in
control networks with or without network
installation tools.
All examples are provided in both
executable images and source code.
An example application is pre-loaded into
each Mini EVB Evaluation Board, allowing
new users to get a control network up and
running within minutes.
You can use the Mini FX software to
modify the Neuron C examples, create
new applications based on the Mini FX
examples, or create new examples from
scratch. You can use the powerful selfinstallation library (included with the
examples) in custom applications that do
not require the use of any installation tools,
and yet are fully compatible with standard
LonWorks installation tools such as the
LonMaker Integration Tool.
Specifications
Operating System
Microsoft Windows Vista or Windows XP.
Minimum Hardware
Intel Pentium® III 600MHz processor; 2GB
RAM for Windows Vista, 512MB RAM for
Windows XP; CD-ROM drive; 1024 x 768
display with at least 256 colors; mouse
or other Windows-compatible pointing
device; 120 to 350MB free hard-disk space.
Compatible LNS Network Interfaces
and IP-852 Routers
OpenLDV-compatible local and
remote network interface or IP-852 router.
Compatible local network interfaces
include the U10/U20 USB network
interface (a U10 is included with Mini FX/
FT and a U20 is included with Mini FX/PL);
PCC-10, PCLTA-20, or PCLTA-21 network
interfaces; and the SLTA-10 Serial LonTalk
Adapter. Compatible remote network
interfaces include the i.LON ® SmartServer
and i.LON 600 LonWorks IP Server.
Compatible IP-852 routers include the
i.LON SmartServer with IP-852 routing and
the i.LON 600 LonWorks IP Server. If you
are using an IP-852 router, your computer
must have an IP network interface such
as an Ethernet card or modem with PPP
software. In addition, the i.LON software
must be installed on your computer, and
the IP-852 channel must be configured
using the LonWorks-IP Configuration
Server application software.
Neuron C Version 2.2
Neuron C I/O Objects
Bit, byte, nibble input/output
Bitshift input/output
Dallas Touch input/output
Dual slope input (for low-cost A/D)
Edge divide output
Edgelog input.
Frequency output.
Infrared input
Infrared pattern output
I2C input/output
Level detect input
Magcard bitstream input
Magcard track 1 and 2 input
(for ISO 7811 input)
Muxbus input/output
(multiplexed address/data)
Neurowire input/output
(National Semiconductor Microwire and
Motorola SPI compatible)
Oneshot output, ontime input, period input,
pulsewidth output
Parallel input/output
Pulsecount input/output
Quadrature input
SCI (UART) serial input/output*
SPI serial input/output*
Serial input/output
Total count input
Touch input/output (Maxim/Dallas 1-Wire®
protocol-compatible)
Triac and stretched triac** output
Triggered count output
Wiegand input
Neuron C Network
Communication Extensions
Functional blocks
Network variables
Configuration properties
Application and foreign-frame messages
* For Series 5000 and 3100 Smart
Transceivers and Neuron Chips with
hardware SCI and SPI support only
** For Series 5000 Smart Transceivers
and Neuron Chips with stretched triac
support only
FT 5000 EVB
Processor
FT 5000 Smart Transceiver.
Processor Input Clock
10MHz (5MHz to 80MHz internal
system clock).
Processor Memory
64KB on-chip RAM, 16KB on-chip ROM,
64KB external serial flash memory, and
64KB external serial EEPROM mapped to
64KB Neuron memory space based on
hardware template definition.
Operating Input Voltage
+9 to 12VDC unregulated.
External I/O Power
Combined +5V and +3.3V current not to
exceed 100mA.
External Power Supply
100 to 240VAC; 50 or 60Hz.
Operating Temperature
0 to +45°C
Non-operating Temperature
-20 to +70°C
Dimensions
140mm x 105mm x 30mm
www.echelon.com
EMC Compliance
Documentation
Neuron C Reference Guide
EN 55022 Class A.
FT 5000 EVB Examples Guide
078-0140-02
PL 3150 and PL 3170 EVB
078-0389-01
Neuron Tools Error Guide
Processor
FT 5000 EVB Hardware Guide
078-0402-01
PL 3150 EVB: PL 3150 Smart Transceiver.
PL 3170 EVB: PL 3170 Smart Transceiver.
078-0390-01
NodeBuilder Resource Editor User’s
Guide
I/O Model Reference for Smart
10MHz (5MHz internal system clock).
078-0392-01
Processor Memory
Introduction to the LonWorks Platform
PL 3150 EVB: 56KB flash memory
and 2KB on-chip RAM.
PL 3170 EVB: 4KB on-chip flash memory
078-0183-01
+11 to 17.8VDC unregulated.
Operating Input Current
250mA max, not including external I/O.
External I/O Power
+5V current not to exceed 100mA.
100 to 240VAC; 50 or 60Hz with power
line coupler.
078-0194-01
NodeBuilder Resource Report Generator
User’s Guide
078-0260-01
ISI Programmer’s Guide
PL 3120/PL 3150/PL 3170 Smart
Transceiver Data Book
078-0299-01
ISI Protocol Specification
005-0193-01
078-0300-01
LonWorks USB Interfaces User’s Guide
Series 5000 Chip Data Book
005-0199-01
078-0296-01
Ordering Information
Mini FX/FT Quick Start Guide
Mini FX/FT Evaluation Kit
078-0418-01
10000R-40-24
Mini FX/PL Examples Guide
Mini FX/PL Evaluation Kit
078-0394-01
10000R-40-27
Mini FX/PL Hardware Guide
Both kits include 100-240VAC 50/60Hz
power supplies with both US/Japan and
Europlugs (CEE 7/16).
078-0395-01
0 to +40°C
Mini FX/PL Quick Start Guide
078-0419-01
-20 to +65°C
Mini FX User’s Guide
Dimensions
078-0398-01
114mm x 70mm x 32mm
(excluding connectors)
Neuron Assembly Language Reference
EMC Compliance
Neuron C Programmer’s Guide
EN 55022 Class A.
078-0002-02
078-0399-01
Copyright © 2005-2010, Echelon Corporation. Echelon, LON, LonWorks, LonMark, NodeBuilder, LonTalk, Neuron,
3120, 3150, LNS, i.LON, LonMaker, the Echelon logo, and the LonUsers logo are trademarks of Echelon Corporation
registered in the United States and other countries.
Other trademarks belong to their respective holders. Content subject to change without notice. P/N 003-0472-01C
www.echelon.com
