Page 1 of 2
SparkFun Shift-In Breakout - SN74HC165
B OB-11 733 ROH S
1
images are CC BY-NC-SA 3.0
3D Download: Sketchup, STL, Blender
Description: The SN74HC165N is a neat little IC that will take an input of up to 8
parallel lines and produce a single, serial output. It’s a great way to increase the
number of inputs on a microcontroller.
This breakout makes it easy to prototype using the 74HC165 by breaking out all of the
pins you need to standard 0.1" spaced headers. We’ve also lined up the data and
power pins so that you can easily make chains of them and expand the number of
outputs under your control!
This chip works with a voltage supply anywhere in the range of 2-6VDC, and at clock
frequencies of up to 29MHz (@6VDC).
Page 2 of 2
Features:
Wide Operating Voltage Range of 2 V to 6 V
Parallel-to-Serial Data Conversion
Outputs Can Drive Up To 10 LSTTL Loads
Low Power Consumption, 80-μA Max ICC
±4mA Output Drive at 5 V
Low Input Current of 1 μA Max
Complementary Outputs
Direct Overriding Load (Data) Inputs
Gated Clock Inputs
0.1" Spaced Headers
https://www.sparkfun.com/products/11733
11/16/2015
很抱歉,暂时无法提供与“BOB-11733”相匹配的价格&库存,您可以联系我们找货
