Solar Charger SKU:DFR0264
Contents
1 Introduction
2 Specification
3 Diagram
4 FAQ
5 Application
Introduction
This solar charger is designed for single lithium battery (3.7V) for intelligent charging, with input
reverse polarity protection. The maximum charging current is 500 milliamperes and the connection is
simple and convenient. Used with the solar battery and lithium battery, you can quickly build a solar
power system.
Specification
Input Voltage: 4.4~6V
Charging Current: 500mA Max (Depending on the solar battery supply capability)
Charging Cutoff Voltage: 4.2V
Operating Temperature:-40~85
Module Size: 33mm*33mm*12mm
Requisite battery: 3.7V lithium battery (Please note the maximum permissible charging current of the
lithium battery)
Charging Indicator: Charging:Red LED Done:Green LED No Battery:Red LED Flashing
Diagram
Port Description:
PWR IN:4.4~6V power input terminal. You should connect it to a solar battery. The maximum output
voltage of the solar battery should be in the range of 4.4V to 6V.
BAT: Connect a 3.7V lithium battery, for storing electricity.
VOUT: Lithium-ion battery output. Connect your electrical equipment to it.
Charging Indicator: When there are no battery, the green LED is ON and the red LED is flashing.
When charging, only the red LED is ON. After the charging is completed, only the green LED is ON.
FAQ
Q. Can I charge my lipo with a battery, and charge an arduino at the same time?
A. Not recommanded! For the Solar cannot produce a steady current generally. If you supply
the not steady power to an Arduino card, it may cause unexpected result or get the
bootloader lost.
Application
Material:
Solar Panel (5v 260mA)
[Solar Charger]
3.7V Polymer Lithium Ion Battery - 1000mAh
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0264”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+38.34375
- 5+36.29223
- 10+34.33442
- 国内价格
- 1+73.11539
- 3+67.75477
- 6+59.05474
- 国内价格 香港价格
- 1+50.344971+6.07964
