R2-56X5/16 2701
R2-56X5/16 2701
    APMHEXSEAL
R2-56X5/16 2701 数据手册
Proudly manufacturing in the From Telecommunication Towers To Wind Turbines... for 70 years. CATALOG # HEX-SC-01 Rev. C APM HEXSEAL was founded in 1947 with the mission to develop and manufacture environmental sealing solutions to protect and prolong the life of electromechanical switches and circuit breakers in hostile environmental conditions around the globe. This focused effort resulted in the development of an extensive line of standard silicone sealing boots that are compatible with the vast majority of switches, breakers, encoders, potentiometers and rotary devices used throughout the world today. Complimentary sealing products were soon developed and patented, including a complete line of reusable, self-sealing fasteners, and silicone colorizing incandescent lamp filters that transmit colors for instrument panels and lighted pushbutton switches. From Medical and Pharmaceuticals To Food and Farming... Sealing Boots & Bushings  Switch and Potentiometer Boots  Circuit Breaker Boots  Specialty Bushing Seals  Custom Elastomeric Sealing Solutions Drawing upon our experience with precision transfer and compression molding using a wide range of elastomers, rubber-to-metal From Solar To Submarine… bonding and coating treatments, APM Hexseal’s Custom Design Department offers an efficient method to develop your custom sealing needs, from concept all the way to From Construction To Material Handling... production. Self-Sealing Hardware  SEELSKREW® Self-Sealing Screws  SEELBOLT® Self-Sealing Bolts  SEELNUT® Molded Self-Sealing Nuts  SEELOC® Molded Sealing Washers From one Extreme Environment To the Other... “APM Hexseal has a solution looking for your problem.” ISO 9001:2015 Registered (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C APM Hexseal Boots for Toggle, Pushbutton & Rotary Switches Any unsealed electrical devices mounted to a control panel or piece of electrical equipment can fall victim to the impacts of hostile environmental factors if not properly protected. In this context, “environmental” is a very broad term, encompassing any number of possible factors, including weather conditions like rain, snow or prolonged wind and sun exposure, pressure changes from submersion in fluids or changes in altitude, contaminants such as water, ice, salt, air, dust, dirt, grease, chemicals, and even spilled beverages. APM Hexseal's Sealing Boots are designed to protect the vulnerable areas of a device, and create a seal against the mounting panel, providing strong protection for the device itself, and for the overall function of the system. MATERIAL SPECIFICATIONS For APM Hexseal® Standard Threaded Toggle, Pushbutton & Rotary Boots Elastomer: Silicone † conforms to A-A-59588, Class 3A, GR50, Gray ‡ Mounting Nut: Brass, Nickel Plated Temperature Range: -103° F to +400° F ( -75° C to +204° C) Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most acids and lubricating oils. Shelf Life: Excess of 25 years. Enclosure Protection: IEC IP66 / IP68 • † Alternative elastomers options are available by request. (See table on page 7 for options.) ‡ Additional durometer and color options available. Please contact us for details. • A dual IP code rating indicates that both ratings apply. APM Hexseal’s UL and ULC Recognized Components conform to UL Standard 50. Contact us for a complete list of our Recognized Components and ratings. Full Toggle Boots with Secondary Inner Seal Full Toggle Boot with Secondary Inner Seal APM Hexseal Part # Military Part # Thread Size C1131/27 N1030 N5030 M5423/01-01 M5423/04-01 15/32-32 UNS-2B 15/32-32 UNS-2B 1/4-40 UNS-2B Maximum Bat Height (Above Bushing) 0.710" 0.660" 0.310" See Figure 1 Internal Diameter (A) in 0.219 0.219 0.104 mm 5.56 5.56 2.64 DIMENSIONS Hex Size/Outer Diameter (C) Height (B) in 0.937 0.844 0.422 mm 23.80 21.44 10.72 in 0.625 0.625 0.375 mm 15.88 15.88 9.53 Full Toggle Boots with Constant Internal Diameter APM Hexseal Part # Figure 1 Full Toggle Boot with Constant Internal Diameter Military Part # 1131/26 50154 C1131/28 IN1030 IQ1030  N5030L M5423/05-01 N5030S 1131/26 M12x.75 1131/26 M12x1 1131/31 M12 1131/40 C1131/41 IN1030 RFI  M5423/01-02 Thread Size 15/32-32 UNS-2B 15/32-32 UNS-2B 15/32-32 UNS-2B 15/32-32 UNS-2B 15/32-32 UNS-2B 1/4-40 UNS-2B 1/4-40 UNS-2B M12 x 0.75 6H M12 x 1 6H M12 x 1 6H M12 x 1 6H M12 x 0.75 6H 15/32-32 UNS-2B Maximum Bat Height (Above Bushing) 0.900" 0.925" 0.710" 0.660" 0.735" 0.370" 0.500" 22.86mm 22.86mm 16.97mm 16.97mm 16.08mm 0.660" Imperial Imperial Imperial See Figure 2 Internal Diameter (A) in 0.212 0.300 0.219 0.219 0.250 0.062 0.062 0.225 0.225 0.256 0.234 0.210 0.219 System of Measurement mm 5.38 7.62 5.56 5.56 6.35 1.57 1.57 5.72 5.72 6.50 5.95 5.30 5.56 DIMENSIONS Hex Size/Outer Diameter (C) Height (B) in 1.093 1.110 0.937 0.844 0.975 0.500 0.594 1.093 1.093 0.844 0.859 0.850 0.844 mm 27.76 28.19 23.80 21.44 24.77 12.70 15.08 27.76 27.76 21.44 21.83 21.60 21.44 in 0.625 0.625 0.625 0.625 0.875 0.375 0.375 0.625 0.625 0.625 0.625 0.625 0.625 mm 15.88 15.88 15.88 15.88 22.22 9.53 9.53 15.88 15.88 15.88 15.88 15.88 15.88 System of Measurement Imperial Imperial Imperial Imperial Imperial Imperial Imperial Metric Metric Metric Metric Metric Imperial  IQ Toggle Boots “Install Quickly” over pre-installed switches (not shown). Insert is aluminum with a brass washer. Contact us for images and information.  Toggle Boot with EMI/RFI Shielding (not shown). Contact us for images and information. Figure 2 Half & Open Toggle Boots with Exposed Actuator Half Toggle Boot with Exposed Actuator Figure 3 APM Hexseal Part # Military Part # Thread Size 1132/60  C1132/20 C1132/26 ◊ N1030B N5032B 1132/17 M5x0.5 1132/33 M12x1 1132/60 M12  M5423-02-01 M5423/11-01 - 15/32-32 UNS-2B 15/32-32 UNS-2B 15/32-32 UNS-2B 15/32-32 UNS-2B 1/4-40 UNS-2B M5 x 0.5 6H M12 x 1 6H M12 x 1 6H Throat Diameter (A) in 0.160 0.109 0.210 0.109 0.047 0.043 0.093 0.160 mm 4.06 2.77 5.33 2.77 1.19 1.10 2.36 4.06 See Figure 3 DIMENSIONS Height (B) in 0.310 0.437 0.848 0.437 0.250 0.225 0.437 0.310 mm 7.87 11.10 21.54 11.10 6.35 5.70 11.10 7.87 Flat/Hex Size (C) in 0.625 0.625 0.625 0.625 0.375 0.315 0.625 0.625 mm 15.88 15.88 15.88 15.88 9.53 8.00 15.88 15.88 Toggle Bat Diameter (Min. - Max.) in mm 0.170-0.200 4.32-5.08 0.115-0.240 2.92-6.10 0.270-0.285 6.86-7.24 0.115-0.240 2.92-6.10 0.062-0.188 1.57-4.78 0.062-0.188 1.57-4.78 0.115-0.240 2.92-6.10 0.170-0.200 4.32-5.08 System of Measurement Imperial Imperial Imperial Imperial Imperial Metric Metric Metric  “Ultra Flex” Half-Toggle Boot with patented inverted bellows design for use with sensitive switches (not shown). Contact us for images and information. ◊ Open Toggle Boot for lever lock switches (not shown). Contact us for images and information. This catalog is a partial representation of APM Hexseal’s many product lines. Please contact us directly for additional product options, as well as to request a Quote or place an Order. 2 (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C Pushbutton Boots with Hex-shaped Insert Pushbutton Boot with Hex-shaped Insert Figure 4 Pushbutton Boot with Round Insert See Figure 4 Maximum Plunger Height DIMENSIONS APM Hexseal Part # Military Part # Thread Size 1231/8 - 3/8-27 UNS-2B in 0.397 mm 10.08 in 0.300 mm 7.62 in 0.653 mm 16.59 in 0.500 mm 12.70 1231/35 1231/51 - 3/8-32 UNEF-2B 3/8-27 UNS-2B 0.418 0.665 10.62 16.88 0.300 0.313 7.62 7.95 0.670 0.875 17.20 22.23 0.500 0.500 12.70 12.70 Imperial Imperial 1238/1 SS  N3030 M5423/07-01 15/32-32 UNS-2B 15/32-32 UNS-2B 0.306 0.281 7.77 7.14 0.422 0.422 10.72 10.72 1.008 0.547 25.60 13.89 0.750 0.625 19.05 15.88 Imperial Imperial N3030 RFI  N3040 M5423/07-06 M5423/07-04 15/32-32 UNS-2B 5/8-24 UNEF-2B 0.281 0.281 7.14 7.14 0.422 0.515 10.72 13.08 0.547 0.609 13.89 15.47 0.625 0.750 15.88 19.05 Imperial Imperial N5040 N5040G N5040R M5423/10-03 M5423/10-01 M5423/10-02 1/4-40 UNS-2B 1/4-32 UNEF-2B 1/4-40 UNS-2B 0.141 0.203 0.203 3.58 5.16 5.16 0.188 0.188 0.188 4.78 4.78 4.78 0.313 0.313 0.313 7.95 7.95 7.95 0.375 0.375 0.375 9.53 9.53 9.53 Imperial Imperial Imperial Internal Diameter (A) (Above Bushing) Hex Size/Outer Diameter (C) Height (B) System of Measurement Imperial N5045 - 8-40 UNS-2B 0.188 4.78 0.120 3.05 0.297 7.54 0.250 6.35 Imperial NC3030 M5423/07-02 15/32-32 UNS-2B 0.438 11.13 0.422 10.72 0.719 18.26 0.625 15.88 Imperial NC3030 7/16-28 - 7/16-28 UNEF-2B 0.438 11.13 0.422 10.72 0.719 18.26 0.625 15.88 Imperial NH3030 NC3030FL  NC3030H M12x1 M5423/07-03 - 1/2-32 UN-2B 15/32-32 UNS-2B M12 x 1 6H 0.281 0.520 0.469 7.14 13.21 11.90 0.422 0.344 0.422 10.72 8.74 10.72 0.547 0.797 0.734 13.89 20.24 18.64 0.625 0.625 0.625 15.88 15.88 15.88 Imperial Imperial Metric  Armored Pushbutton Boot (not shown). Contact us for images and information.  Pushbutton Boot with EMI/RFI Shielding (not shown). Contact us for images and information.  Flat Top Pushbutton Boot (not shown). Contact us for images and information. Pushbutton Boots with Round Insert (Aluminum) APM Hexseal Part # Military Part # Thread Size C1221/22 C1221/24 ◊ C1221/25 C1221/21 M10 C1221/27 - 3/8-24 UNF-2B 3/8-27 UNS-2B 3/8-27 UNS-2B M10 x 1 6H M11 x 1 6H Maximum Plunger Height Internal Diameter (A) (Above Bushing) in 0.330 0.419 0.419 0.330 0.267 mm 8.40 10.64 10.64 8.40 6.78 See Figure 5 in 0.320 0.300 0.300 0.320 0.320 mm 8.13 7.62 7.62 8.13 8.13 DIMENSIONS Height (B) in 0.609 0.609 0.609 0.609 0.609 mm 15.47 15.47 15.47 15.47 15.47 Hex Size/Outer Diameter (C) in 0.640 0.640 0.640 0.640 0.720 mm 16.26 16.26 16.26 16.26 18.29 System of Measurement Imperial Imperial Imperial Metric Metric ◊ Boot is made from APM Hexseal’s clear RUBRGLAS®. Figure 5 Rotary Boots Rotary Boot Figure 6 See Figure 6 APM Hexseal Part # Military Part # Thread Size N9030x1/4 N9040x1/8 M5423/09-02 M5423/09-03 3/8-32 UNEF-2B 1/4-32 UNEF-2B Shaft Size (A) in 0.250 0.125 mm 6.35 3.18 DIMENSIONS Height (B) in 0.219 0.219 mm 5.56 5.56 Hex Size (C) in 0.500 0.375 mm 12.70 9.53 N9042x1/8 - 1/4-28 UNF-2B 0.125 3.18 0.219 5.56 0.375 9.53 N9060x1/4 1332/39 1332/45 1332/46 C1332/41 M5423/09-04 - 15/32-32 UNS-2B M7x.75 6H M10x1 6H M10x.75 6H M9x.75 6H 0.250 0.196 0.236 0.236 0.250 6.35 5.00 6.00 6.00 6.35 0.219 0.200 0.236 0.236 0.219 5.56 5.50 5.90 5.90 5.56 0.625 0.500 0.500 0.500 0.500 15.88 12.70 12.70 12.70 12.70 APM Hexseal Bushing Seals For Switch Panel Cut-Outs Bushing Seals pack all the sealing power of a boot, but focus on the mounting hole as opposed to the switch itself. Installed before a switch locking nut, the bushing seal fits snugly against the mounting panel, sealing the mounting hole from any possible intrusion. Bushing Seals are small, inconspicuous and perfect for already sealed toggle, push button and rotary switches. Imperial Imperial Imperial Imperial Metric Metric Metric Metric MATERIAL SPECIFICATIONS For APM Hexseal® Standard Bushing Seals Elastomer: Silicone conforms to A-A-59588, Class 3A, GR50 †, Gray ‡ Mounting Nut: 18/8 Stainless Steel Temperature Range: -103° F to +400° F ( -75° C to +204° C) Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most acids and lubricating oils. Shelf Life: Excess of 25 years. Enclosure Protection: IEC IP66 / IP68 • † Durometer options available. Please contact us for details. ‡ Additional colors available. Please contact us for details. • A dual IP code rating indicates that both ratings apply. APM Hexseal’s UL and ULC Recognized Components conform to UL Standard 50. Contact us for a complete list of our Recognized Components and ratings. Bushing Seals Figure 7 System of Measurement See Figure 7 APM Hexseal Part # Military Part # 60064 M5423/17-01 DIMENSIONS Bushing Size (A) Height (B) in mm in mm 0.469 11.91 0.120 3.03 60065 - 0.375 9.53 0.120 3.03 60225 M5423/16-01 0.469 11.91 0.120 3.03 Seal Diameter (C) in mm 0.610 15.49 0.610 15.49 Top: Top: Top: Bottom: Top: Bottom: Outer Diameter (D) Seal Style in mm 0.662 16.81 Double-Side Seal 0.500 12.70 0.522 13.26 Bottom: 0.572 14.53 Double-Side Seal 0.610 15.49 0.662 16.81 Single-Side Seal Bottom: This catalog is a partial representation of APM Hexseal’s many product lines. Please contact us directly for additional product options, as well as to request a Quote or place an Order. 3 (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C APM Hexseal Boots for Circuit Breakers & Rocker Switches Circuit breakers perform a very valuable role in all sorts of control systems, protecting equipment from short circuits and electrical overloads. APM Hexseal’s leveractuated circuit breaker boots are designed to protect these critical devices, extending breaker life-spans and in turn helping to ensure long-term security of the system as a whole. Molded from APM Hexseal’s transparent silicone RUBRGLAS®, which is specially formulated to maintain clarity and prevent yellowing over time, these boots allow for easy device operation and status recognition while maintaining APM Hexseal’s exceptional environmental protection from weather exposure, wash downs, salt water, lubricants, solvents, dust, dirt, grease and any number of other environmental elements that could potentially threaten electrical components. Our two distinct boot styles are Back-of-Panel, secured behind the breaker mounting panel, and Front-of-Panel, mounted to the outside of a panel using a sturdy metal frame. Both styles are secured using APM Hexseal’s self-sealing Seelskrews. Much like our Circuit Breaker Boots, APM Hexseal’s Rocker Boots are often molded from transparent silicone RUBRGLAS® which makes for easy viewing of the switch position. The majority of our Rocker Boots do not include an insert or frame, and are designed to install on the switch prior to the switch installation. MATERIAL SPECIFICATIONS For APM Hexseal® Standard Rocker and Lever-Actuated Circuit Breaker Boots Elastomer: APM HEXSEAL RUBRGLAS® (transparent Silicone) conforms to A-A-59588, Class 3A, GR50 † Frame (Front-of-Panel Mounted Only): Low Carbon Steel ‡ with Zinc-Chromate Plating • Temperature Range: -103° F to +400° F ( -75° C to +204° C) Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most acids and lubricating oils. Shelf Life: Excess of 25 years. Enclosure Protection: Rocker Boots— IEC IP55; Front-of-Panel Mounted— IEC IP66 / IP68 ◊; Back-of-Panel Mounted— IEC IP66 / IP68 ◊ † Durometer options available. Please contact us for details. ‡ Frames are also available in Stainless Steel for extremely aggressive environments. • Contact us for details on our standard 3-step frame finish. ◊ A dual IP code rating indicates that both ratings apply. APM Hexseal’s UL and ULC Recognized Components conform to UL Standard 50. Contact us for a complete list of our Recognized Components and ratings. Front-of-Panel Mounting Figure 8 Circuit Breaker Boots, Front-of-Panel Mounting See Figure 8 DIMENSIONS APM Hexseal Part # Military Part # Poles Marks HE1015 M5423/14-05 1-Pole ON HE1020 M5423/14-06 2-Pole ON 0.875 22.22 1.875 47.63 2.656 67.46 2.062 52.37 2.219 56.36 1.594 40.49 HE1045 - 1-Pole - 0.450 11.43 1.300 33.02 1.900 48.26 1.660 42.16 0.800 20.32 1.200 30.48 HE1050 M5423/14-07 3-Pole ON 0.875 22.22 1.875 47.63 2.656 67.46 2.062 52.37 2.969 75.41 2.344 59.54 HE1070 M5423/14-03 3-Pole ON 0.922 23.42 2.000 50.80 3.719 94.46 2.750 69.85 3.656 92.86 3.156 80.16 Height (H) in mm Length 1 (L1) in mm Length 2 (L2) in mm Length 3 (L3) in mm Width 1 (W1) in mm Width 2 (W2) in mm 0.875 22.22 1.875 47.63 2.625 66.66 2.062 52.37 1.375 34.93 0.875 22.22 Standard Seelskrews® Included  S6-32x3/8" 2701 2 Count S6-32x3/8" 2701 4 Count S6-32x3/8" 2701 2 Count S6-32x3/8" 2701 6 Count S6-32x3/8" 2701 6 Count  Metric Seelskrews are also available by request. Back-of-Panel Mounting Circuit Breaker Boots, Back-of-Panel Mounting APM Hexseal Part # Military Part # 1113/40 - 1113/42 - 1113/43 - See Figure 9 DIMENSIONS Poles Marks Height (H) in mm Length 1 (L1) in mm Length 2 (L2) in mm Length 3 (L3) in mm Width 1 (W1) in mm Width 2 (W2) in mm Standard Seelskrews® Included  S6-32x5/16" 2701 2 Count S6-32x5/16" 2701 2-Pole ON/OFF 0.813 20.65 1.188 30.18 2.000 50.80 1.660 42.16 1.500 38.10 1.406 35.71 4 Count S6-32x5/16" 2701 3-Pole ON/OFF 0.813 20.65 1.188 30.18 2.000 50.80 1.660 42.16 2.250 57.15 2.156 54.76 6 Count 1-Pole ON/OFF 0.813 20.65 1.188 30.18 2.000 50.80 1.660 42.16 0.750 19.50 0.656 16.66  Metric Seelskrews are also available by request. Figure 9 Rocker Boot Figure 10 Rocker Boots See Figure 10 APM Hexseal Part # Military Part # 1113/62 DIMENSIONS Length 1 (C) Compatible Switches (Partial List) Height (A) Width 1 (B) Length 2 (D) Width 2 (E) in mm in mm in mm in mm in mm - 0.297 7.54 0.797 20.24 0.687 17.45 1.093 27.76 0.968 24.61 Eaton/Arrow Hart 2600 Series 1113/66 - 0.228 5.79 0.348 8.84 0.531 13.49 0.750 19.05 0.531 13.49 Carling 611/621-Series 1113/70 - 0.297 7.54 0.437 11.10 0.875 22.23 1.218 30.94 0.640 16.27 Carling RSC-Series 1113/71 - 0.413 10.49 0.687 17.45 1.046 26.57 1.327 33.71 0.703 17.86 Carling M Series Sensata/Airpax R11 Eaton/Heinemann LC-1 This catalog is a partial representation of APM Hexseal’s many product lines. Please contact us directly for additional product options, as well as to request a Quote or place an Order. 4 (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C APM Hexseal’s High-Pressure Self-Sealing Fasteners MATERIAL SPECIFICATIONS For APM Hexseal® Standard Seelskrews® & Seelbolts® Screw/Bolt Material: 18/8 Stainless Steel, passivated (other materials available) Thread Class: Imperial— Class 2A ; Metric— Class 6g O-Ring Elastomer: Silicone conforms to A-A-59588, Class 2, GR60 or GR70, Red  Temperature Range: -80° F to +425° F ( -62° C to +219° C) Pressure Range: Up to 20,000 psig internal and external (subject to clearance hole dimensions). Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most acids and lubricating oils. Shelf Life: Excess of 25 years. Enclosure Protection: IEC IP66 / IP68  APM Hexseal holds the notable distinction of having designed and patented the very first self-sealing fasteners, which became our trademarked Seelskrews® and Seelbolts®. In addition to fastening, our self-sealing screws and bolts offer a reliable and reusable seal, preventing (or containing!) contamination from dust, air, water, lubricants and other liquid or gaseous substances. They are also vibration resistant, making them a great choice for applications that encounter day-to-day jarring, or repetitive movement. Should you need a more serious level of vibration resistance, our screws and bolts are available with locking features such as self-locking pellets, strips and patches. Some additional customizations include specialty threadforming variations, tamper-resistant drives, thread captivation, as well as paint and finish options. Contact us for additional thread size and o-ring elastomer options.  Standard for stock screws and bolts.  Alternative o-ring elastomers are available by request. (See table on page 7 for options.)  A dual IP code rating indicates that both ratings apply. APM Hexseal’s UL and ULC Recognized Components conform to UL Standard 50. Contact us for a complete list of our Recognized Components and ratings. SEELSKREWS® See Figure 11 STANDARD FLAT HEAD † with CROSS RECESS DRIVE (PHILLIPS) – Type Code SFR Recommended Clearance Hole Thread Size Drive Size Available Lengths (L) ‡ Max. Head Diameter (C) Min. Diameter Max. Diameter Min. Depth Max. Depth 2-56 UNC-2A 4-40 UNC-2A 6-32 UNC-2A 8-32 UNC-2A 10-24 UNC-2A 10-32 UNF-2A 1/4-20 UNC-2A #1 #1 #2 #2 #2 #2 #3 1/4" to 1" 1/4" to 1" 1/4" to 1" 1/4” to 1" 5/16" to 1" 5/16" to 1" 3/8" to 1-1/4" 0.172" 0.225" 0.279" 0.332" 0.385" 0.385" 0.507" 0.091" 0.125" 0.147" 0.173" 0.199" 0.199" 0.265" 0.950" 0.129" 0.152" 0.179" 0.204" 0.204" 0.269" 0.036" 0.050" 0.063" 0.063" 0.083" 0.063" 0.100" 0.054" 0.075" 0.094" 0.094" 0.125" 0.094" 0.150" See Figure 12 Figure 11 STANDARD PAN HEAD with SLOTTED DRIVE – Type Code S Thread Size Available Lengths (L) ‡ Max. Head Diameter (C) Max. Head Height (D) 2-56 UNC-2A 4-40 UNC-2A 6-32 UNC-2A 8-32 UNC-2A 10-32 UNF-2A 10-24 UNC-2A 1/4-20 UNC-2A 1/4-28 UNF-2A 1/4" to 5/8" 1/4" to 1" 1/4" to 1" 1/4" to 1" 1/4" to 1" 1/4" to 1" 5/16" to 1-1/4" 5/16" to 1-1/4" 0.168" 0.220" 0.271" 0.323" 0.374" 0.374" 0.493" 0.493" 0.055" 0.069" 0.083" 0.097" 0.113" 0.113" 0.148" 0.148" Thread Size Available Lengths (L) ◊ Max. Head Diameter (C) Max. Head Height (D) M2 x 0.40 6g M2.5 x 0.45 6g M3 x 0.50 6g M4 x 0.70 6g M5 x 0.80 6g M6 x 1 6g M8 x 1.25 6g 4mm to 12mm 4mm to 12mm 4mm to 40mm 4mm to 40mm 6mm to 40mm 6mm to 50mm 6mm to 50mm 4.24mm 5.56mm 6.22mm 8.17mm 9.70mm 12.49mm 15.62mm 1.37mm 1.73mm 1.90mm 2.43mm 3.05mm 3.73mm 4.52mm Recommended Clearance Hole Min. Diameter Max. Diameter Min. Depth Max. Depth 0.091" 0.125" 0.147" 0.173" 0.199" 0.199" 0.265" 0.265” 0.950" 0.129" 0.152" 0.179" 0.204" 0.204" 0.269" 0.269" 0.036" 0.050" 0.063" 0.063" 0.063" 0.083" 0.100" 0.071" 0.054" 0.075" 0.094" 0.094" 0.094" 0.125" 0.150" 0.107" METRIC PAN HEAD with SLOTTED DRIVE – Type Code SM Figure 12 Recommended Clearance Hole Min. Diameter Max. Diameter Min. Depth Max. Depth 2.31mm 2.67mm 3.55mm 4.39mm 5.56mm 6.73mm 8.45mm 2.41mm 2.84mm 3.65mm 4.54mm 5.66mm 6.83mm 8.55mm 0.80mm 0.90mm 1.00mm 1.40mm 1.60mm 2.00mm 2.50mm 1.20mm 1.35mm 1.50mm 2.10mm 2.40mm 3.00mm 3.75mm See Figure 13 STANDARD PAN HEAD with CROSS RECESS DRIVE (PHILLIPS) – Type Code R Thread Size Drive Size Available Lengths (L) ‡ Max. Head Diameter (C) Max. Head Height (D) 2-56 UNC-2A 4-40 UNC-2A 6-32 UNC-2A 8-32 UNC-2A 10-32 UNF-2A 10-24 UNC-2A 1/4-20 UNC-2A 1/4-28 UNF-2A #1 #1 #2 #2 #2 #2 #3 #3 1/4" to 1" 1/4" to 1" 1/4" to 1" 1/4" to 1" 3/8" to 1" 3/8" to 1" 3/8" to 1-1/4" 3/8" to 1-1/4" 0.181" 0.238" 0.294" 0.347" 0.403" 0.403" 0.517" 0.517" 0.062" 0.080" 0.097" 0.115" 0.133" 0.133" 0.175" 0.175" Recommended Clearance Hole Min. Diameter Max. Diameter Min. Depth Max. Depth 0.091" 0.125" 0.147" 0.173" 0.199" 0.199" 0.265" 0.265" 0.950" 0.129" 0.152" 0.179" 0.204" 0.204" 0.269" 0.269" 0.036" 0.050" 0.063" 0.063" 0.063" 0.083" 0.100" 0.071" 0.054" 0.075" 0.094" 0.094" 0.094" 0.125" 0.150" 0.107" METRIC PAN HEAD with CROSS RECESS DRIVE (PHILLIPS) – Type Code RM Thread Size Drive Size Available Lengths (L) ◊ Max. Head Diameter (C) Max. Head Height (D) M2 X 0.40 6g M2.5 X 0.45 6g M3 X 0.50 6g M4 X 0.70 6g M5 X 0.80 6g M6 X 1 6g #1 #1 #2 #2 #2 #3 4mm to 12mm 4mm to 12mm 4mm to 40mm 4mm to 40mm 6mm to 40mm 6mm to 50mm 4.24mm 5.46mm 6.70mm 8.69mm 9.90mm 12.58mm 1.60mm 2.10mm 2.40mm 3.05mm 3.70mm 4.60mm Figure 13 Tamper-Resistant Drive Styles STYLE VIEW Recommended Clearance Hole Min. Diameter Max. Diameter Min. Depth Max. Depth 2.31mm 2.67mm 3.55mm 4.39mm 5.56mm 6.73mm 2.41mm 2.84mm 3.65mm 4.54mm 5.66mm 6.83mm 0.80mm 0.90mm 1.00mm 1.40mm 1.60mm 2.00mm 1.20mm 1.35mm 1.50mm 2.10mm 2.40mm 3.00mm † Standard APM Hexseal Flat Head Seelskrews have a 100° head angle. ‡ Available in increments of 1/16” up to 5/8” length, and 1/8” from 5/8” length up. Tolerance for lengths up to 1” is +0 -1/32”. Tolerance above 1” is +0 -1/16”. ◊ Available in increments of 2mm. Tolerance for lengths up to 25mm is +0 -0.8mm. Tolerance above 25mm is +0 -1.6mm. STYLE NAME 6-Lobe Drive with Pin Hex Drive with Pin Spanner Drive TYPE CODE LBP HP SS Contact us for more information on these, and other, drive options. This catalog is a partial representation of APM Hexseal’s many product lines. Please contact us directly for additional product options, as well as to request a Quote or place an Order. 5 (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C SEELBOLTS® See Figure 14 STANDARD HEXAGONAL HEAD BOLT – Type Code ST Thread Size 1/4-28 UNF-2A 1/4-20 UNC-2A 5/16-24 UNF-2A 5/16-18 UNC-2A 3/8-24 UNF-2A 3/8-16 UNC-2A 1/2-20 UNF-2A 1/2-13 UNC-2A Recommended Clearance Hole Min. Length Distance Between Distance Between Max. Head Available (L) Flats (C) Points (P)  Height (D) Min. Diameter Max. Diameter Min. Depth Max. Depth 3/8" 0.440" 0.510" 0.163" 0.265" 0.269" 0.071" 0.107" 3/8" 0.440" 0.510" 0.163" 0.265" 0.269" 0.100" 0.150" 1/2" 0.502" 0.580" 0.211" 0.332" 0.336" 0.083" 0.125" 3/8" 0.502" 0.580" 0.211" 0.332" 0.336" 0.111" 0.167" 5/8" 0.565" 0.650" 0.243" 0.395" 0.399" 0.083" 0.125" 1/2" 0.565" 0.650" 0.243" 0.395" 0.399" 0.125" 0.188" 1/2" 0.752" 0.870" 0.323" 0.530" 0.534" 0.100" 0.150" 3/4" 0.752" 0.870" 0.323" 0.530" 0.534" 0.154" 0.231" Figure 14 METRIC HEXAGONAL HEAD BOLT – Type Code STM Thread Size M6 X 1 6g M8 X 1.25 6g M10 X 1.5 6g M12 X 1.75 6g M16 X 2 6g Recommended Clearance Hole Min. Length Distance Between Distance Between Max. Head Available (L) Flats (C) Points (P)  Height (D) Min. Diameter Max. Diameter Min. Depth Max. Depth 8mm 10mm 11.28mm 4.15mm 6.73mm 6.83mm 2.00mm 3.00mm 12mm 13mm 14.69mm 5.65mm 8.45mm 8.55mm 2.50mm 3.75mm 12mm 17mm 19.25mm 7.18mm 10.53mm 10.64mm 3.00mm 4.50mm 20mm 19mm 21.50mm 8.18mm 12.79mm 12.9mm 3.50mm 5.25mm 20mm 24mm 27.23mm 10.18mm 17.52mm 17.63mm 4.00mm 6.00mm  The “Distance Between Points” values are for reference only. APM Hexseal’s High-Pressure Self-Sealing Nuts APM Hexseal's Seelnuts® are made from high quality rubber, molded into a specially shaped cavity in the nut itself. With threads molded directly into the rubber, these self-sealing nuts form a positive seal along the threaded section of the Seelnut, as well as with the contact surface, removing the need for gaskets, sealing compounds or extra surface preparation. Seelnuts install just like conventional nuts, and are designed for use with ordinary screws, bolts and studs, making them a quick and easy sealing option for all sorts of applications, especially where there is a need to withstand high internal or external pressures. Seelnuts are also reusable, meaning that they can be easily removed and reapplied, reestablishing the same reliable seal when torqued. Our Seelnuts are available in all standard thread sizes as well as a variety of different elastomers to suit your application needs. For applications where excessive vibration is an issue, Seelnuts can be supplied with self-locking pellets. MATERIAL SPECIFICATIONS For APM Hexseal® Standard Seelnuts® SEELNUTS® See Figure 15 STANDARD NUTS – Type Code AJ JAM NUTS – Type Code AJ MC Nut Material: Low Carbon Steel with Zinc-Chromate Plating † Height of Thread Size Distance Max. Head Distance Max. Head Threads: Imperial— Class 2B ‡; Metric— Class 6H Sealing Rib (R) Between Flats (C) Height (D) Between Flats (C) Height (D) Elastomer: Silicone conforms to A-A-59588, Class 3A, GR60, Red ◊ 6-32 UNC-2B 1/64" 5/16" 9/64" 1/2" 7/32" Temperature Range: -103° F to +400° F ( -75° C to +204° C) 8-32 UNC-2B 1/64" 3/8" 5/32" 1/2" 7/32" Pressure Range: Up to 20,000 psig internal and external (subject to clearance 10-24 UNC-2B 1/64" 3/8" 5/32" 1/2" 7/32" hole dimensions). 10-32 UNF-2B 1/64" 3/8" 5/32" 1/2" 7/32" Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most 1/4-20 UNC-2B 1/64" 7/16" 7/32" 5/8" 7/32" acids and lubricating oils. 1/4-28 UNF-2B 1/64" 7/16" 7/32" 5/8" 7/32" Shelf Life: Excess of 25 years. 5/16-18 UNC-2B 1/64" 1/2" 17/64" 5/8" 7/32" Enclosure Protection: IEC IP66 / IP68 • 5/16-24 UNF-2B  1/64" 1/2" 17/64" 5/8" 7/32" 3/8-16 UNC-2B 3/8-24 UNF-2B 7/16-20 UNF-2B 1/2-13 UNC-2B 1/2-20 UNF-2B 5/8-18 UNF-2B 1/64" 1/64" 1/32" 1/32" 1/32" 1/32" 9/16" 9/16" 11/16" 3/4" 3/4" 15/16" 21/64" 21/64" 3/8" 27/64" 27/64" 35/64" 5/8" 5/8" N/A 3/4" 3/4" N/A 7/32" 7/32" N/A 7/32" 7/32" N/A † Standard Jam Nut material is Brass with Nickel Plating. ‡ Standard for stock nuts. ◊ Alternative elastomers are available by special order. • A dual IP code rating indicates that both ratings apply. APM Hexseal’s UL and ULC Recognized Components conform to UL Standard 50. Contact us for a complete list of our Recognized Components and ratings.  The Jam Nut material used for this thread size is Low Carbon Steel with Zinc-Chromate plating. Thread Size M3 x 0.5 6H METRIC NUTS  – Type Code AJ Height of Distance Sealing Rib (R) Between Flats (C) 0.2mm 5.5mm Max. Head Height (D) 2.2mm M4 x 0.7 6H M5 x 0.8 6H M6 x 1 6H 0.3mm 0.4mm 0.5mm 7.0mm 8.0mm 10.0mm 3.0mm 3.8mm 4.8mm M8 x 1.25 6H M10 x 1.5 6H M12 x 1.75 6H M14 x 2 6H 0.6mm 0.6mm 0.8mm 1.0mm 13.0mm 17.0mm 19.0mm 22.0mm 6.3mm 7.8mm 9.3mm 10.8mm  APM Hexseal’s standard material for metric nuts is Stainless-Steel. Figure 15 Ordering Instructions for Products with Type Codes – Seelskrews®, Seelbolts® & Seelnuts® The following information is required in order for our Sales Team to process any kind of Purchase Order or Request for Quote: ① Indicate the desired Type Code (Type Codes are short series’ of letters that can be found in corresponding parts tables) ② Specify the desired Thread Size as listed in the parts table ③ Specify the Length, if applicable ④ Specify the desired O-Ring Material, if applicable (Please see Elastomer Options for APM Hexseal® O-Rings on page 7) Any additions, such as alternate materials, finish options and locking features, should be discussed with a Sales Associate at the time of order. This catalog is a partial representation of APM Hexseal’s many product lines. Please contact us directly for additional product options, as well as to request a Quote or place an Order. 6 (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C APM Hexseal Air-Tight Sealing Washers APM Hexseal’s Seeloc® Washers consist of molded silicone rubber bonded to specially formed stainless steel washers. Designed to be used in conjunction with conventional screws, bolts or studs, Seeloc Washers are a simple sealing solution that is ideal for all sorts of applications, especially where spray, vapors or wash-downs are present, or where there is concern of contamination from dust, oils or salt build-up. The silicone contact surface features a continuous ridge which, upon compression, creates a 360° sealing barrier around the periphery of the washer face. The silicone rubber also forms a seal under the head of the associated fastener and makes full vertical contact with the threads/shank, making for a complete, high-pressure seal unlike any other. Seeloc Washers can be used over conventional mounting holes, extra-large holes, or even oddly shaped adjustment slots. Their reusability make them perfect for applications that might require periodic maintenance or adjustments. MATERIAL SPECIFICATIONS For APM Hexseal® Standard Seeloc® Washers Washer Material: 18/8 Stainless Steel Elastomer: Silicone † conforms to A-A-59588, Class 3A, GR50, Green ‡ Temperature Range: -103° F to +400° F ( -75° C to +204° C) Pressure Range: Up to 100 psig internal and external. Resistant to: Splash, salt spray, sunlight, ozone, weather, fungus, dust, and most acids and lubricating oils. Shelf Life: Excess of 25 years. Enclosure Protection: IEC IP66 / IP68 ◊ STANDARD SEELOC® WASHERS See Figure 16 APM Hexseal Part # Compatible Thread Size Outer Diameter (C) Max. Mounting Hole Diameter 75601 75801 75101 75602 75802 75102 75082 75107 75122 75142 75162 75603 75803 75103 75083 75108 75123 75143 75163 #6 #8 #10 #6 #8 #10 1/4" 5/16" 3/8" 7/16" 1/2" #6 #8 #10 1/4" 5/16" 3/8" 7/16" 1/2" 1/2" (0.550”) 1/2" (0.550”) 1/2" (0.550”) 1" 1" 1" 1" 1" 1" 1" 1" 1-1/2" 1-1/2" 1-1/2" 1-1/2" 1-1/2" 1-1/2" 1-1/2" 1-1/2" 1/4" (6.35mm) 1/4" (6.35mm) 1/4" (6.35mm) 3/8" (9.53mm) 3/8" (9.53mm) 3/8" (9.53mm) 3/8" (9.53mm) 1/2" (12.70mm) 5/8" (15.87mm) 5/8" (15.87mm) 5/8" (15.87mm) 5/8" (15.87mm) 5/8" (15.87mm) 5/8" (15.87mm) 5/8" (15.87mm) 5/8" (15.87mm) 3/4" (19.05mm) 3/4" (19.05mm) 3/4" (19.05mm) † Alternative materials are available. Consult Elastomer Options table below. ‡ Standard color for Metric Seeloc Washers is red. Alternative colors are available by special order. ◊ A dual IP code rating indicates that both ratings apply. APM Hexseal’s UL and ULC Recognized Components conform to UL Standard 50. Contact us for a complete list of our Recognized Components and ratings. Can’t find the fastener you need? ASK US! METRIC SEELOC® WASHERS If we do not already have what you are looking for, we can MAKE IT! Contact us for more information. See Figure 16 APM Hexseal Part # Compatible Thread Size Outer Diameter (C) Max. Mounting Hole Diameter 75031 75041 75051 75032 75042 75052 75062 75312 75392 75472 M3 M4 M5 M3 M4 M5 M6 M8 M10 M12 14.0mm 14.0mm 14.0mm 25.4mm 25.4mm 25.4mm 25.4mm 25.4mm 25.4mm 25.4mm 6.35mm 6.35mm 6.35mm 9.53mm 9.53mm 9.53mm 12.70mm 12.70mm 15.87mm 15.87mm Figure 16 APM Hexseal’s Available Elastomers Cautionary Note: These tables are to be used as a guide ONLY. The information provided does not take into account the possible variations that can, and do, exist from one application to another, and thus cannot be relied upon as definite. APM Hexseal strongly recommends that the material you select be rigorously tested in the actual application in order to independently verify that the material is well suited for your particular installation or use. Elastomer Options for APM Hexseal® Sealing Boots, Bushings, Seelnuts® & Seeloc® Washers KEY Compound Letter & Code A → Recommended B → Fair / Satisfactory C → Acceptable / Poor U → Unsatisfactory S 2701 L 2615 N 4601 E 3601 F 7601 Material Name Relevant Specifications Silicone A-A-59588, Class 3A, GR30, GR50, GR60  -103° to +400° FluoroSilicone MIL-DTL-25988 (B), Type 2, Class 1, GR60 Buna N ASTM D2000 60 Durometer Neoprene ASTM D2000 60 Durometer EPDM ASTM D2000 70 Durometer (Nitrile) (Ethylene Propylene) Service Service Temp. in °F Temp. in °C RESISTANCE TYPICAL PROPERTIES Ozone Chemicals Petroleum Oil Soap Solutions Tensile PSI Elongation % Abrasion Resistance Compression Set -75° to +204° A B U A 500-1800 100-800 A A -70° to +392° -57° to +200° A B A A 600-1400 100-700 C A -22° to +212° -30° to +100° C C A A 1500-3000 400-600 A B -40° to +257° -40° to +121° B C B A 1500-4000 100-700 B C -60° to +300° -51° to +149° A U U A 1400-1600 500-600 B A  Various durometer and color options available. Please contact us for more information. Elastomer Options for APM Hexseal® O-Rings Compound Letter & Code S 2701 L 2615 V 5701 N 4601 E 3601 F 7601 Material Name Relevant Specifications Silicone A-A-59588, Class 2, GR60 or GR70 -80° to +425° Fluoro-Silicone MIL-DTL-25988C, Type 1, Class 1, GR60 or GR70 -70° to +392° Viton® A  ASTM D2000 75 Durometer -15° to +400° -26° to +205° Buna N ASTM D2000 70 Durometer -30° to +250° -34° to +121° Neoprene ASTM D2000 70 Durometer -35° to +225° -37° to +107° EPDM ASTM D2000 70 Durometer -70° to +250° -57° to +121° (Nitrile) (Ethylene Propylene) Service Service Temp. in °F Temp. in °C RESISTANCE TYPICAL PROPERTIES Ozone Chemicals Petroleum Oil Soap Solutions Tensile PSI Elongation % Abrasion Resistance Compression Set -62° to +219° A B U A 500-1800 100-800 A A -57° to +200° A B A A 600-1400 100-700 B A A A A A 2000-2200 300-400 C B C C A A 1500-3000 400-600 A B B C B A 1500-4000 100-700 B C A U U A 1400-1600 500-600 B A  Viton® is a registered trademark of DuPont Performance Elastomers. This catalog is a partial representation of APM Hexseal’s many product lines. Please contact us directly for additional product options, as well as to request a Quote or place an Order. 7 (800) 498-9034 www.apmhexseal.com CATALOG # HEX-SC-01 Rev. C Suitability of APM Hexseal® Products to Customer Application The information contained in APM Hexseal literature, website, drawings, etc., is offered in good faith and is believed to be accurate. Since APM Hexseal cannot foresee or control the varied conditions under which this information and/or APM Hexseal products may be used, APM Hexseal does not guarantee the applicability of this information, or the suitability of APM Hexseal products. Customers are expected to perform their own evaluation to determine the suitability of APM Hexseal products for their specific purposes and applications. ALL NEW PRODUCTS FROM APM HEXSEAL® SNAPSEEL® BOOT for PUSHBUTTON SWITCHES Compatible with Cole Hersee Momentary Switches Part # 1211/71 12 Kit Kit includes Snapseel® boot and 5/8-32 UN-2B shouldered mounting nut. HEAVY DUTY SEELOC® WASHERS Capable of withstanding at LEAST 50% higher torque values than our original Seeloc® Washers. Part # Series 75XXX HD Currently available in 1/2” and 1” Outer Diameter sizes. Contact us for size options and availability. ISO 9001:2015 Registered (800) 498-9034 www.apmhexseal.com
R2-56X5/16 2701 价格&库存
很抱歉,暂时无法提供与“R2-56X5/16 2701”相匹配的价格&库存,您可以联系我们找货
