Adafruit Audio FX Sound Board - WAV/OGG
Trigger with 16MB Flash
PRODUCT ID: 2220
DESCRIPTION
Would you like to add audio/sound effects to your next project, without an
Arduino+Shield? Or maybe you don't even know how to use microcontrollers, you
just want to make a sound play whenever you press a button. What about
something that has to be small and portable? You are probably feeling a little
frustrated: it's been very hard to find a simple, low cost audio effects trigger that is
easy to use and does not require any programming
UNTIL NOW!
Don't get me wrong, I love the MP3 Music Maker shield, and our Wave Shield is a
dependable classic. But you still need to get an Arduino involved. There's all sorts
of tricks with ISD chips or recordable greeting cards, but they never sound any
good. So after a lot of engineering and tinkering we've come out with the Adafruit
Sound Board, the fastest way to add audio effects to a project! We think this is the
best sound board for props and costumes!
The Sound Board has a lot of amazing features that make it the easiest thing ever:
• No Arduino or other microcontroller required! It is completely stand-alone,
just needs a 3 to 5.5VDC battery
• Small - only 1.9" x 0.85"
• Built in storage - yep! you don't even need an SD card, there's 16MB of
storage on the board itself. Good for ~15 minutes of compressed stereo, and
maybe a couple minutes of uncompressed stereo. Double that if you go with
mono instead of stereo. If you don't need as much space, we also have a 2MB
version.
• Built in Mass Storage USB - Plug any micro USB cable into the Sound Board
and your Windows computer, you can drag and drop your files right on as if it
were a USB key
• Compressed or Uncompressed audio - Go with compressed Ogg Vorbis files
for longer audio files, or uncompressed WAV files
• High Quality Sound - You want 44.1KHz 16 bit stereo? Not a problem! The
decoding hardware can handle any bit/sample rate and mono or stereo
• 11 Triggers - Connect up to 11 buttons or switches, each one can trigger
audio files to play
• Stereo line out - Headphones, powered speakers or even wire up one of our
amplifiers to make loud sounds. We also have a version with built-in stereo
speaker amplifier
• Five different trigger effects - by changing the name of the files, you can
create five different types of triggers which will cover a large range of projects
without any programming
What do we mean by trigger effects? Well, depending on your project you may need
to have audio play in different ways. We thought of the five most common needs
and built it into the Sound Board so you just rename the file to get the effect you
want. See the product tutorial for more details
1. Basic Trigger - name the file Tnn.WAV or Tnn.OGG to have the audio file play
when the matching trigger pin nn is connected to ground momentarily
2. Hold Looping Trigger - name the file TnnHOLDL.WAV or .OGG to have the
audio play only when the trigger pin is held low, it will loop until the pin is
released
3. Latching Loop Trigger - name the file TnnLATCH.WAV or .OGG to have the
audio start playing when the button is pressed momentarily, and repeats until
the button is pressed again
4. Play Next Trigger - have up to 10 files play one after the other by naming
them TnnNEXT0.WAV thru TnnNEXT9.OGG. Will start with #0 and each one on
every momentary button press until it gets through all of them, then go back
to #0
5. Play Random Trigger - just like the Play Next trigger, but will play up to 10
files in random order (TnnRAND0.OGG thru TnnRAND9.OGG) every time the
The sound board is designed to be simple: it does not have polyphonic ability, can't
play MP3's (MP3 is patented and costs $ to license, so this board uses the similar
but not-patented OGG format, there's tons of free converters that will turn an MP3
into OGG), isn't reprogrammable or scriptable, and you can't have any other kind of
trigger type. However, there's a good chance the project you want to make will
work great.
We designed this board specifically for people who wanted to make props,
costumes, toys, and other small portable projects. Check out the tutorial for all the
powering options, you can power from 3-5VDC so a 3xAAA battery pack or a LiPoly
battery will work well. You can even use our LiPoly backpack to fit on top for an allin-one rechargeable effects board
Technical Details
22mm x 48mm x 6mm / 0.9" x 1.9" x 0.2"
Weight: 4.7g
很抱歉,暂时无法提供与“2220”相匹配的价格&库存,您可以联系我们找货
