10020R-40-27
10020R-40-27
    ECHELON
    NODEBUILDER FX/PL DEV TOOL
10020R-40-27 数据手册
The NodeBuilder FX Development Tool is a complete hardware and software platform for creating LONWORKS devices based on the Series 5000 and 3100 Neuron® Processors and the Series 5000 and 3100 Smart Transceivers. NodeBuilder® FX Development Tool A Complete Platform for Developing, Debugging, Testing, and Maintaining LONWORKS® Devices You can use the NodeBuilder tool to create devices such as VAV controllers, thermostats, washing machines, card-access readers, refrigerators, lighting ballasts, blinds, and pumps. These devices can be used in a variety of systems including building and lighting controls, factory automation, energy management, and transportation systems. Whether you’re building large or small control network devices, the NodeBuilder FX tool makes your project faster, easier, and more affordable. FEATURES • Available in free topology (FT), power line (PL), classroom, and softwareonly versions. • FT and PL versions include a hardware platform (PL) or platforms (FT) for initial application development and testing. • FT and PL versions include sample I/O hardware with a 4x20 character LCD display for easy I/O prototyping and testing. • CD version available for use with custom hardware. • Neuron® C Version 2.2 compiler supports up to 254 network variables for Series 5000 and 3100 chips, and supports interrupts for Series 5000 chips. • Resource editor displays available functional profiles, network variable types, and configuration property types, and can be used to create new functional profiles and types. • Code wizard automatically generates Neuron C code to implement an easyto-integrate device interface. DESCRIPTION • Code editor lets you easily edit device There are four NodeBuilder FX products: • Project manager lets you manage NodeBuilder FX/FT Development Tool. Includes development hardware for the FT 5000 Smart Transceiver. • ISI library lets you create devices that NodeBuilder FX/PL Development Tool. Includes development hardware for Power Line Smart Transceivers. application source code. device definitions and build applications. install themselves without the use of an installation tool. • LonMaker® Turbo Integration Tool installs development and production devices into networks, simplifying network integration and testing. • LonScanner® Protocol Analyzer LNS Turbo Edition captures, analyzes, characterizes, and displays network packets so you can pinpoint network or device faults and identify potential solutions. • LNS® Device Plug-in Framework Developer’s Kit lets you create and redistribute LNS plug-ins written in a Microsoft .NET programming language such as C# or Visual Basic.NET, making your devices easier to install and configure. 1 NodeBuilder FX/FT Classroom Edition. Educational use only (includes FT 5000 development hardware). NodeBuilder FX CD. Software-only solution (for those who don’t need development hardware, such as NodeBuilder 3.1 users, or for developers who want to upgrade from the Mini FX Evaluation Kit to the NodeBuilder FX Development Tool). All four products include a complete suite of device development software for Windows Vista or Windows XP. The following table summarizes the components in each product. FX/FT and FX/PL Development Tools FX/FT Classroom Edition FX CD positive or negative level), the highperformance on-chip timer and counter units, and a dedicated, configurable, high-performance periodic system timer. NodeBuilder Development Tool CD ☑ ☑ ☑ The NodeBuilder FX software includes the following tools: Development Platforms* ☑ ☑ LonMaker Integration Tool Professional Edition CD (includes Microsoft Visio 2003 Professional) ☑ Component LonMaker Integration Tool Standard Edition CD (includes Microsoft Visio 2003 Standard) • NodeBuilder Resource Editor. View ☑ ☑ LonScanner Protocol Analyzer LNS Turbo Edition CD ☑ U10/U20 USB Network Interface ☑ ☑ ☑ ☑ * The NodeBuilder FX/FT Development Tool and Classroom Edition include two FT 5000 EVBs. The NodeBuilder FX/PL Development Tool Full Edition includes one LTM10A Hardware Platform, one NodeBuilder Gizmo 4 I/O Board, and one LonWorks Module Application Interface (for development of PL devices). NodeBuilder Software The NodeBuilder software lets you create, debug, test, and maintain applications for LonWorks devices based on an Echelon Series 5000 or 3100 Neuron Processor or an Echelon Series 5000 or 3100 Smart Transceiver. Using the NodeBuilder FX software, you write your device applications using the Neuron C Version 2.2 programming language, a high-level language based on ANSI C with extensions to simplify network communication, hardware I/O, and event-driven processing. Version 2.2 of the Neuron C language supports up to 254 static network variables and 127 network variable aliases per device for devices based on a Series 5000 or 3100 chip with Neuron Firmware version 16 or newer, subject to available memory. For Series 5000 applications, Neuron C Version 2.2 also supports applicationspecific interrupt handlers and a hardware semaphore that can be used for interrupt task synchronization. Interrupt sources include signals on any of the 12 I/O pins (rising edge, falling edge, either edge, standard types and functional profiles, and create user-defined types and profiles if the standard resource files don’t include the resources you need. • NodeBuilder Code Wizard. Use a drag-and-drop interface to create your device’s interface, and then automatically generate Neuron C source code that implements the device interface and creates the framework for your device application. The code wizard saves days of development for every new device. • NodeBuilder Editor. Edit the Neuron C source code generated by the code wizard to create your device’s application. • NodeBuilder Debugger. Debug your application with a source-level view of your application code as it executes. • NodeBuilder Project Manager. Build and download your application image to your development platform or to your own device hardware. • ISI Developer’s Kit. Develop ISI devices that use the Interoperable Self-Installation (ISI) protocol to install and organize themselves into networks automatically or at the push of a button, all without the use of a separate installation tool. client-server architecture with an easyto-use Microsoft Visio user interface. It’s compatible with a number of LNS plug-ins, including the NodeBuilder Project Manager. LonScanner Protocol Analyzer LNS Turbo Edition The LonScanner Protocol Analyzer is a software package that provides network diagnostic tools that you can use to observe, analyze, and diagnose the behavior of installed LonWorks networks, including networks with devices you’ve built with the NodeBuilder tool. You can use the LonScanner tool with the U10 or U20 USB network interface included with the NodeBuilder FX/FT and FX/PL Tools, and you can also use it with other network interfaces including all layer-2 OpenLDV compatible network interfaces or an IP-852 (ISO/IEC 14908-4) network interface. FT 5000 EVB Evaluation Board Two FT 5000 EVB Evaluation Boards are included with the NodeBuilder FX/FT Development Tool and the NodeBuilder FX/FT Classroom Edition. The FT 5000 EVB is a complete Series 5000 LonWorks device that you can use to evaluate the LonWorks 2.0 platform and create LonWorks 2.0 devices. The FT 5000 EVB includes an FT 5000 Smart Transceiver with an external 10MHz crystal (you can adjust the internal system clock speed from 5MHz to 80MHz), an FT-X3 communication transformer, 64KB external serial EEPROM and flash memory devices, and a 3.3V power source. • LNS Device Plug-in Framework Developer’s Kit. Develop and redistribute LNS plug-ins written in a Microsoft .NET programming language such as C# or Visual Basic .NET. Plug-ins make your devices much easier to install and configure. LNS is the standard network operating system for managed LonWorks networks. LonMaker Integration Tool Turbo Edition An integral part of the NodeBuilder FX Development Tool, the LonMaker tool is a software package for designing, installing, and maintaining LonWorks control networks. This single tool manages all phases of a network’s life cycle, from the initial design and commissioning to the ongoing operation. Based on Echelon’s LNS network operating system, the LonMaker tool combines a powerful 2 FT 5000 EVB Evaluation Board The FT 5000 EVB’s compact design includes the following I/O devices, which you can use to develop prototype and production devices, and to test the FT 5000 EVB example applications: • 4-line x 20-character LCD display • 4-way joystick with center push button • Two push-button inputs • Two LED outputs • Light-level sensor • Temperature sensor An FT 5000 EVB I/O library, included with the NodeBuilder software, provides easy-to-use high-level functions for accessing the display, light-level sensor, and temperature sensor. The FT 5000 EVB Evaluation Board also includes an EIA-232/TIA-232/RS-232 interface and a USB interface that you can use to connect the board to your development computer and perform application-level debugging (only one of the two serial interfaces can be used at a time). loaded into the RAM is preserved when the module is reset, but not when it’s powered down. You can use the Neuron C Debugger to debug applications running in the RAM or flash memory; however, you should debug your application running in RAM because extensive debugging in the flash memory can cause the flash memory to fail. The LTM-10A Platform includes an LTM-10A Flash Control Module that you can design into your prototypes and products. The module includes a Neuron 3150 Chip, 64KB flash memory, 32KB static RAM, a 10MHz crystal oscillator (providing a 5MHz internal system clock), and custom Neuron firmware. The firmware allocates the memory to the Neuron Chip 64KB address space and automatically initializes the transceiver interface for standard transceivers. The NodeBuilder tool can load your application image into the RAM or flash memory of the LTM-10A module. An application image loaded into the flash memory is preserved when the module is powered down. An application image A Gizmo 4 I/O library, included with the NodeBuilder software, provides easy-touse high-level functions for accessing the display, analog I/O, piezo transducer, real-time clock, and temperature sensor. NodeBuilder Gizmo 4 I/O Board The NodeBuilder Gizmo 4 I/O Board is included with the NodeBuilder FX/PL Development Tool. You can use this collection of I/O devices with the LTM-10A Platform to develop prototype devices and I/O circuits, develop special-purpose devices for testing, or run the NodeBuilder examples. LonWorks Module Application Interface The LonWorks Module Application Interface (MAI) is included with the NodeBuilder FX/PL Development Tool. This interface board is plug-compatible with the LonWorks TP/FT-10, TP/FT-10F, TP/XF-78, TP/XF-78F, TP/XF-1250, and LTM-10A control modules. The MAI replaces the control module in a custom device so that the LTM-10A Platform can be used to debug the custom hardware. This simplifies testing since the application can be easily downloaded to the LTM-10A Platform during development and testing. Once the application has been debugged, the MAI can be replaced by the control module with the application programmed into the control module’s PROM or flash memory. Gizmo 4 plugged into the LTM-10A Platform U10/U20 USB Network Interface The U10 USB Network Interface is included with the NodeBuilder FX/FT Development Tool and the NodeBuilder FX/FT Classroom Edition. The U20 USB Network Interface is included with the NodeBuilder FX/PL Development Tool. The U10 and U20 USB Network Interfaces are low-cost, high-performance LonWorks interfaces for USB-enabled computers and controllers. The LTM-10A Platform also includes a PLM-22 power line transceiver with external power line coupler for attaching the platform to a LonWorks network. Two power line couplers are included, one for line-to-earth coupling and one for line-to-neutral coupling. Each FT 5000 EVB also features a connector for optional in-circuit programming of the external nonvolatile memory of the FT 5000 Smart Transceiver on the board. This allows fast application downloads to the external non-volatile memory. LTM-10A Platform The LTM-10A Platform is included with the NodeBuilder FX/PL Development Tool. This complete LonWorks device with downloadable flash memory and RAM can be used to test application and prototype I/O hardware. • Temperature sensor You can also plug a TP/FT-10 or TP/FT-10F control module into the Gizmo 4 to create a self-contained LonWorks device. This requires separate purchase of the TP/FT-10 or TP/FT-10F control module. The Gizmo 4 includes the following I/O devices: • 4-line x 20-character LCD display • Two 10-bit resolution analog inputs with screw terminal connector • Two 8-bit resolution analog outputs with screw terminal connector • Two digital inputs with screw terminal connector and push-button inputs • Two digital outputs with screw terminal connector and LED outputs • Digital shaft encoder • Piezoelectric transducer • Real-time clock 3 The U10 USB Network Interface connects directly to a TP/FT-10 Free Topology Twisted Pair (ISO/IEC 14908-2) LonWorks channel through a compact removable connector. The U20 USB Network Interface connects to a PL-20 C-Band Power Line (ISO/IEC 14908-3) LonWorks channel through an included power supply with integrated power line coupler. The U20 USB Network Interface can also be connected directly to 10.8-18VDC power systems (such as those in automobiles, trucks, and buses) without a coupling circuit, or to virtually any powered line through a customersupplied coupler/power supply. The USB Network Interfaces can be used with virtually any computer-based LonWorks application, including all LNS and OpenLDV based applications such as the NodeBuilder tool, LonMaker tool, and LonScanner Protocol Analyzer. SPECIFICATIONS Operating System Microsoft Windows Vista or Windows XP. Minimum Hardware Intel Pentium® III 600MHz processor; 2GB RAM for Windows Vista, 512MB RAM for Windows XP; CD-ROM drive; 1,024 x 768 resolution display with at least 256 colors; mouse or other Windowscompatible pointing device; 300 to 550 MB free hard-disk space. Compatible LNS Network Interfaces and IP-852 Routers OpenLDV-compatible local and remote network interface or IP-852 router. Compatible local network interfaces include the U10/U20 USB network interface (included with the NodeBuilder FX/FT and FX/PL Development Kits and the NodeBuilder FX/FT Classroom Edition); PCC-10, PCLTA-20, or PCLTA-21 network interfaces; and the SLTA-10 Serial LonTalk Adapter. Compatible remote network interfaces include the i.LON® SmartServer, i.LON 100 e3 plus Internet Server, i.LON 600 LonWorks IP Server, and i.LON 10 Ethernet Adapter. Compatible IP-852 routers include the i.LON SmartServer with IP-852 routing, i.LON 100 e3 plus Internet Server with IP-852 routing, and i.LON 600 LonWorks IP Server. If you’re using an IP-852 router, your computer must have an IP network interface such as an Ethernet card or modem with PPP software. In addition, the i.LON software must be installed on your computer, and the IP-852 channel must be configured using the LonWorks-IP Configuration Server application software. Neuron C I/O Objects Bit, byte, nibble input/output Bitshift input/output Dallas Touch input/output Dual slope input (for low-cost A/D) Edge divide output Edgelog input Frequency output Infrared input Infrared pattern output I2C input/output Level detect input Magcard bitstream input Magcard track 1 and 2 input (for ISO 7811 input) Muxbus input/output (multiplexed address/data) Neurowire input/output (National Semiconductor Microwire and Motorola SPI compatible) Oneshot output, ontime input, period input, pulsewidth output Parallel input/output Pulsecount input/output Quadrature input SCI (UART) serial input/output*. SPI serial input/output*. Serial input/output. Total count input. Touch input/output (Maxim/Dallas 1-Wire® protocol-compatible) Triac and stretched triac** output Triggeredcount output Wiegand input Neuron C Network Communication Extensions Functional blocks Network variables Configuration properties Application and foreign-frame messages * For Series 5000 and 3100 Smart Transceivers and Neuron Chips with hardware SCI and SPI support only ** For Series 5000 Smart Transceivers and Neuron Chips with stretched triac support only FT 5000 EVB Processor FT 5000 Smart Transceiver. Non-operating Temperature -20 to +70°C Dimensions 140mm x 105mm x 30mm EMC Compliance EN 55022 Class A. LTM-10A PLATFORM Processor Neuron 3150 Chip. Processor Input Clock 10MHz (5MHz system clock). Processor Memory 64KB flash memory and 32KB RAM mapped to 64KB Neuron memory space in three memory configurations. Power Input +5VDC ±5% regulated 3A minimum (power supply not included). External I/O Power +5VDC @ 100mA typical. Operating Temperature 0 to +55ºC with enclosure. 0 to +70ºC in free air. Non-operating Temperature -20 to +70ºC Dimensions 198mm x 145mm x 53mm EMC Compliance EN 55022 Class A. DOCUMENTATION Processor Input Clock 10MHz (5MHz to 80MHz system clock). FT 5000 EVB Examples Guide 078-0389-01 Processor Memory 64KB on-chip RAM, 16KB on-chip ROM, 64KB external serial flash memory, and 64KB external serial EEPROM mapped to 64KB Neuron memory space based on NodeBuilder hardware template definition. FT 5000 EVB Hardware Guide 078-0390-01 Operating Input Voltage +9 to 12VDC unregulated. External I/O Power Combined +5V and +3.3V current not to exceed 100mA. External Power Supply 100 to 240VAC; 50 or 60Hz. Operating Temperature 0 to +45°C 4 Gizmo 4 User’s Guide 078-0191-01 I/O Model Reference for Smart Transceivers and Neuron Chips 078-0392-01 Introduction to the LonWorks Platform 078-0183-01 LNS Plug-in Programmer’s Guide 078-0393-01 LTM-10A User’s Guide 078-0132-01 LonMaker User’s Guide 078-0168-02 Neuron Assembly Language Reference 078-0399-01 Neuron C Programmer’s Guide*** 078-0002-02 Neuron C Reference Guide*** 078-0140-02 Neuron Tools Errors Guide 078-0402-01 NodeBuilder FX User’s Guide 078-0405-01 NodeBuilder FX/PL Examples Guide 078-0403-01 NodeBuilder Resource Editor User’s Guide 078-0194-01 Series 5000 Chip Data Book 005-0199-01 *** Printed copy shipped upon receipt of product registration. ORDERING INFORMATION NodeBuilder FX/FT Development Tool 10020R-40-24 NodeBuilder FX/PL Development Tool 10020R-40-27 NodeBuilder FX/FT Classroom Edition 10020R-40-34 NodeBuilder FX CD 10050-40 FT 5000 EVB Evaluation Board 28022R LTM-10A/PL-20 Platform 65150R-270 Gizmo 4 I/O Board 28004R Copyright © 2007-2011, Echelon Corporation. Echelon, LON, LonWorks, LNS, i.LON, and LonMaker are trademarks of Echelon Corporation registered in the United States and/or other countries. LonScanner is a trademark of Echelon Corporation. Other trademarks belong to their respective holders. Content subject to change without notice. P/N 003-0460-01B 5
10020R-40-27 价格&库存
很抱歉,暂时无法提供与“10020R-40-27”相匹配的价格&库存,您可以联系我们找货
