Precision LM4040 Voltage Reference
Breakout - 2.048V and 4.096V
PRODUCT ID: 2200
DESCRIPTION
How good is your multimeter really? Or maybe your analog converter needs a good
reference? Or lets say you want to test your microcontroller's conversion accuracy &
precision. If only you had a dependable, high precision, rock-solid voltage
reference. Now you know why we made this very cute and useful little breakout
board. It has two very high precision shunt-type voltage references with 750 ohm
biasing resistors. One is 2.048V (great for 3.3V reference systems) and the other is
4.096 (great for 5V). Both are 0.1% accuracy!
Using is easy, just power with about 5V-12V, or 3V if you want only the 2V
reference to work. Then measure the voltage on the output. Note that these are not
regulators - you can't power anything off the output. They are for measurements
only. For more details, check the LM4040 Datasheet for more information.
http://www.adafruit.com/product/2200
11/13/2015
Technical Details
LM4040 Datasheet
PCB Dimensions: 16mm x 12.5mm x 2.5mm / 0.6" x 0.5" x 0.1"
Weight: 0.7g
很抱歉,暂时无法提供与“2200”相匹配的价格&库存,您可以联系我们找货
