Pyxos™ FT EVK Evaluation Kit
Model 11000R-10-1P
Features
• Introduces developers to the Pyxos FT embedded control networking platform
• Includes an example application to demonstrate major features of the Pyxos
FT platform
• Includes source code for the example application and APIs that you can port
to different host
microcontrollers
• Demonstrates easy integration with other control networks such as LonWorks networks
• Includes four evaluation boards, power supply,
and cables for quick plug-and-play setup
Pyxos Network Example HMI Application
• Includes all the tools you need to use in conjunction with your existing development tools to
create new Pyxos FT applications
• RoHS-compliant
Description
Echelon’s Pyxos™ FT EVK Evaluation Kit is a set of hardware and software tools that you
can use to demonstrate the functions and capabilities of Pyxos FT technology and to develop your own devices that incorporate Pyxos FT technology. You can also use the
Pyxos FT EVK to develop devices that integrate a Pyxos network with a control network
based on the LonWorks® platform.
Designed for hardware, software, and firmware engineers, the Pyxos FT EVK Evaluation
Kit includes all the tools you need to use in conjunction with your existing development
tools to create new Pyxos FT applications.
Hardware
The Pyxos FT EVK includes four evaluation boards that you can use with the included example application to quickly build a working Pyxos FT network. You can also use the evaluation boards to create your own Pyxos applications. The evaluation boards incorporate a
Pyxos FT Network Chip and come with schematics so you can see their designs. The following evaluation boards are included:
www.echelon.com
• The Pyxos FT EV-Pilot Evaluation
Board is the controller for the Pyxos
EVK network. It contains an Atmel®
ARM® AT91SAM7S64 host microcontroller that is connected to, and
communicates with,
a Pyxos FT Chip. A Pyxos Pilot is
responsible for configuring, main-
uation Board is a Pyxos Point that
serves as a hosted multi-sensor for
the Pyxos EVK network. It includes
an Atmel AVR® ATtiny13 host microcontroller. The sensors measure
temperature, light level, and DC
voltage.
Pyxos Pilots and Pyxos Points.
The example application simulates a room
controller
network with analog and digital sensors,
analog and digital actuators, and a controller running on a Pyxos Pilot. The example also includes a Performance Demo that
you can use
to demonstrate Pyxos FT network determinism. The example demonstrates several
of the major features of the Pyxos platform,
including:
• Automatic registration of Points
• Manual registration of Points
• Seamless replacement of Points
within the Pyxos FT network
• Determinism within the Pyxos FT
network
• Network security monitoring for the
Pyxos FT network
taining, and communicating with the
Pyxos Points in a Pyxos network.
The EV-Pilot can also optionally
communicate with LonWorks devices using the included FT 3150®
Smart Transceiver.
• The Pyxos FT EV-Actuator Point
Evaluation Board is a Pyxos Point
• The Pyxos FT EV-Nano Point Evaluation Board is a Pyxos Point that
serves as a simple unhosted digital
sensor and actuator for the Pyxos
EVK network. It demonstrates how
a Point can participate in a Pyxos FT
network without a host microcontroller.
The system is powered from a single included power supply that you connect to
the EV-Pilot, which then distributes 24VAC
link power over the included network cable
to the EV Points.
• Free-topology wiring with 24VAC
link power
• Optional connectivity to LonWorks
networks
Development Tools
The Pyxos FT EVK includes software that
you can use in conjunction with your host
microcontroller development tools to develop applications for Pyxos Pilot and
Pyxos Points. The software includes C
source code for a Pyxos FT application
programming interface (API) that you can
The Pyxos FT EVK includes all the cables
you need—network cables to connect all
the evaluation boards, a USB cable to connect the EV-Pilot to a Windows computer,
and an I/O cable to connect the analog
output of the EV-Actuator Point to the analog input of the EV-Sensor Point.
that serves as a hosted analog and
digital actuator for the Pyxos EVK
network. It also includes an Atmel
ARM AT91SAM7S64 host microcontroller.
You can optionally connect the EV-Pilot to
a Windows computer using a LonWorks
network. A LonWorks connection requires
a LonWorks network interface that is not
included with the Pyxos FT EVK—the details of this hardware are listed in the System Specifications section.
• The Pyxos FT EV-Sensor Point Eval-
Example Network
Application
The Pyxos FT EVK comes with example
software that demonstrates a complete
control system using the included evaluation boards, and shows how you can use a
Windows computer to monitor and control
a Pyxos network through a Pyxos Pilot. The
software is preloaded in the evaluation
boards, and is also included as source code
that you can use to learn how to develop
Pyxos Example Network Application
Block Diagram
use with your applications to access a
Pyxos network from a Pyxos Pilot, or to interact with a Pyxos Pilot from a Pyxos
Point. You can also port this software to
www.echelon.com
other microcontrollers if you are using a
microcontroller that is not included with
the Pyxos EVK. The software also includes
the Pyxos FT Interface Developer utility
that simplifies development of Pyxos applications that use the Pyxos API.
The EV-Pilot and the EV-Actuator Point
Evaluation Boards include a header connector that provides external access to the
host microcontroller memory. You can use
the JTAG header connector to load a new
Pyxos application firmware into the host
processor for the EV-Pilot or the EV-Actuator Point. The EV-Sensor Point Evaluation
Board includes a connector that provides
access to the AVR programmed I/O (PIO)
line that you can use to download applications to the Tiny13 processor on the EVSensor Point.
test or debug applications for the Pyxos FT
platform that use host microcontrollers different from the ones used on the evaluation
boards. You can replace the AVR host microcontroller on the EV-Sensor Point Evaluation Board with your own host
microcontroller using the Serial Peripheral
Interface (SPI) header on the evaluation
board.
PC Requirements
Software
Hardware
Windows XP (plus Service Pack 2 or later) or Windows 2000 (plus Service Pack 4 or later)
Minimum: Intel® Pentium® III 500MHz or AMD™ Athlon® 750MHz processor, 128MB
RAM, 65MB hard disk space, CD-ROM drive, 1 available USB port
Recommended: Intel Pentium 4 1.0GHz or AMD Athlon 1.5GHz processor, 256MB RAM,
100MB hard disk space, CD-ROM or DVD-ROM drive, 3 available USB ports
Monitor Display
Minimum screen resolution of 1024 x 768 pixels
LOnWORkS network Interface Hardware LOnWORkS OpenLDV™ compatible TP/FT-10 network interface such as an Echelon
Requirements
U10, PCC-10, PCLTA-20, PCLTA-21, or SLTA-10 interface, or an i.LOn® 10,
i.LOn 100, or i.LOn 600 server
Evaluation Board Specifications
All Pyxos FT Evaluation Boards incorporate a Pyxos FT network Chip.
Pyxos FT EV-Pilot
Pyxos FT EV-nano Point
Link Power Supply (included):
Input Voltage
Output Voltage
Local Power Supply (not included):
Input Voltage
Output Voltage
Hosted Pyxos Pilot with a 47.9 MHz Atmel ARM AT91SAM7S64 as the host microcontroller. Includes five push buttons, eight LEDs, and a pre-loaded demo application. Also includes an Echelon FT 3150 Smart Transceiver with a ShortStack 2 Micro Server that
provides an optional interface to a LOnWORkS network.
Hosted Pyxos Point with a 47.9 MHz Atmel ARM AT91SAM7S64 as the host microcontroller. Includes 0 to +3.0VDC analog output, five push buttons, eight LEDs, and a
Hosted Pyxos Point with a 2.4 MHz Atmel AVR ATtiny13 as the host microcontroller. Includes a temperature sensor, light-level sensor, 0 to +3.0VDC analog input, and a
Unhosted Pyxos Point with four general-purpose digital I/Os, in parallel with two push
buttons and two LEDs.
100 to 120VAC or 200 to 240VAC; 50 or 60Hz (depending on power option).
24V AC nominal unregulated
9V DC nominal unregulated (see below for individual current requirements of each Evaluation Board)
Evaluation Board Input Current*
EV-Pilot
100mA
EV-Actuator Point
50mA
EV-Sensor Point
15mA
EV-nano Point
15mA
* Does not include the application current for user I/O.
www.echelon.com
Temperature
Operating
non-operating
Dimensions (excluding connectors)
EV-Pilot
EV-Actuator Point
EV-Sensor Point
EV-nano Point
EMI Compliance
0 to +40°C
-20 to +65°C
144mm x 122mm x 22mm
127mm x 120mm x 35mm
79mm x 97mm x 20mm
62mm x 70mm x 16mm
FCC Level A; En55022 Level A
Documentation
The following documentation is included with the Pyxos FT EVk. The brief Quick Start Guide provides a quick introduction on
how to install and use the Pyxos FT EVk. It is included in printed and on-line PDF format. All other documents are included only in
on-line PDF format. In addition, the evaluation board schematics are also included with the Pyxos FT EVk.
Document
Pyxos FT EVk Quick Start Guide
Pyxos FT EVk User’s Guide
Pyxos FT Programmer’s Guide
Pyxos FT Chip Datasheet
Pyxos FT Chip Databook
Introduction to the LOnWORkS System
Introduction to Pyxos FT Platform
Echelon Part Number
078-0340-01A
078-0342-01A
078-0339-01A
003-0406-01A
005-0188-01A
078-0183-01A
078-0341-01A
Ordering Information
Product
Pyxos FT EVK Evaluation Kit
Pyxos FT Evaluation kit (US power supply)
Pyxos FT Evaluation kit (Continental Europe power supply)
Pyxos FT Evaluation kit (Uk power supply)
Pyxos FT Evaluation kit (Japan power supply)
Pyxos FT EV-Pilot Evaluation Board (US power supply)
Pyxos FT EV-Pilot Evaluation Board (Cont’l Europe power supply)
Pyxos FT EV-Pilot Evaluation Board (Uk power supply)
Pyxos FT EV-Pilot Evaluation Board (Japan power supply)
Pyxos FT EV-Sensor Point Evaluation Board
Pyxos FT EV-Actuator Point Evaluation Board
Pyxos FT EV-nano Point Evaluation Board
Echelon Model Number
11000R-10-11
11000R-10-12
11000R-10-13
11000R-10-14
11200R-11
11200R-12
11200R-13
11200R-14
11210R
11220R
11230R
Copyright © 2007-2008, Echelon Corporation. Echelon, LON, LonWorks, LonMark, LonBuilder, NodeBuilder, LonManager, LonTalk, LonUsers, LonPoint, Digital Home, Neuron, 3120, 3150, LNS, i.LON, LonWorld, ShortStack, Panoramix, Panoramix Powered by Echelon, LonMaker, the Echelon logo, and the LonUsers
logo are trademarks of Echelon Corporation registered in the United States and other countries. Pyxos, LonLink, LonResponse, LonSupport, LONews, Open
Systems Alliance, OpenLDV, LonBridge, Powered by Echelon, LNS Powered by Echelon, LonWorks Powered by Echelon, Networked Energy Services Powered by Echelon, NES Powered by Echelon, and Thinking Inside the Box are trademarks of Echelon Corporation. Other trademarks belong to their respective holders.
DISCLAIMER
PYXOS FT CHIPS, NEURON CHIPS, FREE TOPOLOGY TWISTED PAIR TRANSCEIVER MODULES, AND OTHER OEM PRODUCTS WERE NOT DESIGNED
FOR USE IN EQUIPMENT OR SYSTEMS INTENDED FOR
SURGICAL IMPLANT INTO THE BODY, OR OTHER APPLICATIONS INTENDED TO SUPPORT OR SUSTAIN LIFE, FOR USE IN FLIGHT CONTROL OR ENGINE CONTROL EQUIPMENT WITHIN AN AIRCRAFT, OR FOR ANY OTHER APPLICATION THAT INVOLVES DANGER TO HUMAN HEALTH OR SAFETY OR
A RISK OF PROPERTY DAMAGE. ECHELON ASSUMES NO RESPONSIBILITY OR LIABILITY FOR USE OF THE PYXOS FT CHIPS, NEURON CHIPS OR FREE
TOPOLOGY TWISTED PAIR TRANSCEIVER MODULES IN SUCH APPLICATIONS. ECHELON SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. ECHELON SHALL NOT BE LIABLE TO ANY USER OF THE PYXOS FT CHIPS, NEURON
CHIPS, OR FREE TOPOLOGY TWISTED PAIR TRANSCEIVER MODULES FOR ANY LOST PROFITS OR OTHER SPECIAL, CONSEQUENTIAL, INDIRECT,
PUNITIVE OR INCIDENTAL DAMAGES, HOWEVER CAUSED ON ANY THEORY OF LIABILITY, ARISING IN ANY WAY OUT OF THE DEVELOPMENT OR DISTRIBUTION OF APPLICATIONS OR SYSTEMS USING SUCH PRODUCTS.
003-0430-01C
www.echelon.com
