Application Note: 48V-BMS-AN01 – General Description
48V-BMS
www.ams.com
Revision 1.0 / 06/10/15
page 1/15
48V-BMS-AN01
General Description
Table of Contents
1
General Description ............................................................................................................. 3
1.1
Kit Content ........................................................................................................................... 3
2
Getting Started ..................................................................................................................... 3
3
Hardware Description........................................................................................................... 4
4
Configuration ........................................................................................................................ 5
4.1
Cell connection ..................................................................................................................... 5
4.2
Current path connection ....................................................................................................... 5
5
Software ............................................................................................................................... 6
5.1
Main Tab .............................................................................................................................. 6
6
Board Schematics, Layout and BOM ................................................................................... 9
7
Ordering & Contact Information ......................................................................................... 13
8
RoHS Compliant & ams Green Statement ........................................................................ 14
9
Copyrights & Disclaimer ..................................................................................................... 15
Revision History
Revision
Date
Owner
Description
1.0
06.10.2015
gheh
Initial release
www.ams.com
page 2/15
48V-BMS-AN01
General Description
1
General Description
This document describes the 48V BMS Board.
The 48V-BMS is a demonstrator solution for monitoring and safely operating a 48V battery stack
such as the ones used in modern car supply nets and in many other mobility applications like ebikes and scooters.
The board incorporates:
A cell supervision and balancing portion for up to 14 series connected cells
Pack current and voltage monitoring via a copper shunt on the + terminal of the battery
A N-mosFET disconnect switch on the + side of the battery
A CAN communication interface for status messaging
The board is meant to be used in conjunction with the USB Interface Board and the 48V-PC GUI
however you can connect the CAN Interface to any other CAN compatible device and evaluate the
status messages there.
1.1
Kit Content
The kit consists of the dual layer PCB 48V-BMS and an eSATA Cable which is used to connect to
the USB-Interface Board board.
Figure 1: 48V-BMS Board
2
Getting Started
To operate this Board you should at first download and install the 48V-BMS GUI from here:
http://ams.com/eng/Support/Demoboards/Power-Management/Battery-Stack-MonitorBalancer/AS85xx-Ref-Design-48V
Once the software is installed you can connect the USB Interface Board to the 48V-BMS via the
provided eSATA cable and afterwards connect the USB Interface Board to the PC via the USB
cable.
www.ams.com
page 3/15
48V-BMS-AN01
General Description
3
The 48V-BMS board is powered via the cell
connector J3. A dc-dc converter steps down the
input voltage to 5V which is used to power most of
the circuitry. Current is routed through connectors A
& B. They form a high current sensing path on the +
side of the load circuit. Current is measured through
the small voltage drop across the thin strip of
copper on top of the AS8510 sensing chip. The
copper resistance change is compensated in
software. Balancing is done passively via two
AS8506 chips using discharge resistors.
A
Figure 2: PCB Top Side Diagram
Table 1: Connection Diagram
La
bel
Name
A
+Terminal
+ Connection to
battery
B
+ Switched
Terminal
+ Connection to
load
C
Cell
Connector
J3
Connection for cell
measurement and
balance
D
CAN
J1
Standard CAN
Interface
E
JTAG/SWD
J2
Tag-connect
Adapter for
programming
B
Design
ator
Info
C
E
D
www.ams.com
page 4/15
48V-BMS-AN01
General Description
4
4.1
Configuration
Cell connection
Figure 3: Battery Connector
Cells should be connected according to the pinout of the Battery plug. There are 3 GND (2xGND +
Cell0) 2 Mid-Stack (Cell7 + MID) and 3 VPP (Cell14 + 2xTOP) connections respectively which shall
be tied together directly at the battery.
4.2
The high current path runs through connectors A & B. The maximum current that the board can
handle in this configuration is 100A. The trip current limit can be set via Software and is set to 60A
by default.
www.ams.com
page 5/15
48V-BMS-AN01
General Description
5
Software
The Software Comprises of 4 different Tabs with different functionality which will be subsequently
explained. When the software is started it will automatically connect to the USB Interface Board and
start listening for incoming CAN Messages. A Green USB and CAN Signal in the bottom right
Corner indicate a successful connection to the USB Board.
5.1
Main Tab
Figure 4: GUI Main Tab
This is the default window. It displays all measured battery parameters including cell voltages, pack
voltage before and after the FET switch, temperature and total Current. It also display info
messages like when the balancing is active or if any of the min/max parameters has been reached
and the FET switch has been turned off for safety protection.
www.ams.com
page 6/15
48V-BMS-AN01
General Description
Figure 5: GUI Graph Tab
The graph tab gives a graphical representation of the measured pack current & voltage and allows
you to log these measurements to a file.
www.ams.com
page 7/15
48V-BMS-AN01
General Description
Figure 6: GUI Calibrate Tab
The Calibrate tab allows calibration of the current and voltage measurement. It also allows you to
set the pack as well as the cell voltage limits. These limits are stored in non-volatile memory on the
48V BMS Board.
To redo the calibration apply a known pack voltage and load current to the BMS Board. Type in
these known values in the appropriate fields and click on the calibrate button. The Board will do a
measurement and calculate the required calibration coefficients. These are immediately used and
you can see the effect in the Main Tab.
www.ams.com
page 8/15
48V-BMS-AN01
General Description
6
www.ams.com
page 9/15
48V-BMS-AN01
General Description
Figure 7: Schematics
www.ams.com
page 10/15
48V-BMS-AN01
General Description
Figure 8: Top/Bottom PCB Side
www.ams.com
page 11/15
48V-BMS-AN01
General Description
Figure 9: BOM
www.ams.com
page 12/15
48V-BMS-AN01
General Description
7
SAP number
Ordering Code
Description
#990600868
REFERENCE DESIGN 48V
48V BMS Board
Buy our products or get free samples online at:
www.ams.com/ICdirect
Technical Support is available at:
www.ams.com/Technical-Support
For further information and requests, e-mail us at:
ams_sales@ams.com
For sales offices, distributors and representatives, please visit:
www.ams.com/contact
Headquarters
ams AG
Tobelbaderstrasse 30
8141 Unterpremstaetten
Austria, Europe
Tel: +43 (0) 3136 500 0
Website: www.ams.com
www.ams.com
page 13/15
48V-BMS-AN01
General Description
8
RoHS
The term RoHS compliant means that ams products fully comply with current RoHS directives. Our
semiconductor products do not contain any chemicals for all 6 substance categories, including the
requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be
soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free
processes.
ams Green (RoHS compliant and no Sb/Br)
ams Green defines that additionally to RoHS compliance, our products are free of Bromine (Br) and
Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous
material).
Important Information
The information provided in this statement represents ams knowledge and belief as of the date that
it is provided. ams bases its knowledge and belief on information provided by third parties, and
makes no representation or warranty as to the accuracy of such information. Efforts are underway
to better integrate information from third parties. ams has taken and continues to take reasonable
steps to provide representative and accurate information but may not have conducted destructive
testing or chemical analysis on incoming materials and chemicals. ams and ams suppliers consider
certain information to be proprietary, and thus CAS numbers and other limited information may not
be available for release.
www.ams.com
page 14/15
48V-BMS-AN01
General Description
9
Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks
Registered. All rights reserved. The material herein may not be reproduced, adapted, merged,
translated, stored, or used without the prior written consent of the copyright owner.
Devices sold by ams AG are covered by the warranty and patent indemnification provisions
appearing in its Term of Sale. ams AG makes no warranty, express, statutory, implied, or by
description regarding the information set forth herein. ams AG reserves the right to change
specifications and prices at any time and without notice. Therefore, prior to designing this product
into a system, it is necessary to check with ams AG for current information. This product is intended
for use in commercial applications. Applications requiring extended temperature range, unusual
environmental requirements, or high reliability applications, such as military, medical life-support or
life-sustaining equipment are specifically not recommended without additional processing by ams
AG for each application. This Product is provided by ams “AS IS” and any express or implied
warranties, including, but not limited to the implied warranties of merchantability and fitness for a
particular purpose are disclaimed.
ams AG shall not be liable to recipient or any third party for any damages, including but not limited
to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect,
special, incidental or consequential damages, of any kind, in connection with or arising out of the
furnishing, performance or use of the technical data herein. No obligation or liability to recipient or
any third party shall arise or flow out of ams AG rendering of technical or other services.
www.ams.com
page 15/15
很抱歉,暂时无法提供与“REFERENCEDESIGN48V”相匹配的价格&库存,您可以联系我们找货
