731
    ADAFRUIT
    GROMMET 0.187" RUBBER BLACK
731 数据手册
Teensy++ (AT90USB1286 USB dev board) + header PRODUCT ID: 731 9/26/2014 DESCRIPTION - The Teensy++ is a complete USB-based microcontoller development system, in a very small footprint! All programming is done via the USB port. No special programmer is needed, only a standard "Mini-B" USB cable and a PC or Macintosh with a USB port. Its the big sister version of the popular Teensy board we carry, this board has tons of FLASH, RAM, pins and more. This is the latest version, 2.0. Key Features: • • • • • • • • USB can be any type of device AVR processor, 16 MHz Single pushbutton programming Easy to use Teensy Loader application Free software development tools Works with Mac OS X, Linux & Windows Tiny size, perfect for many projects Comes with headers pins that you can solder on to plug it into any solderless breadboard Comes with assembled Teensy++ board (AT90USB1286 with bootloader preinstalled) and header to allow easy breadboarding. We suggest using AVR-gcc (like WinAVR) with the LUFA library or 'Teensyduino' (http://pjrc.com/teensy/teensyduino.html) Be sure to check out the multiple resources available at PJRC! (http://pjrc.com/teensy/index.html) - MAY WE ALSO SUGGEST... USB cable - A/MiniB (/products/260) Atmega32u4 Breakout Board (/products/296) Teensy (ATmega32u4 USB dev (/products/199) Teensy 3.1 + header (/products/1625) http://www.adafruit.com/product/731 9/26/2014
很抱歉,暂时无法提供与“731”相匹配的价格&库存,您可以联系我们找货
