OLIMEXINO-STM32
OLIMEXINO-STM32
    OLIMEX
    STM32F103RBT6 Maple STM32F1 MCU 32-Bit ARM® Cortex®-M3 Embedded Evaluation Board
OLIMEXINO-STM32 数据手册
OLIMEXINO-STM32 development board User's manual All boards manufactured by Olimex are ROHS compliant Document revision G, September 2016 Designed by OLIMEX Ltd, 2012 Page 1 of 19 INTRODUCTION TO DUINO: Arduino is an open-source electronics prototyping platform, designed to make the process of using electronics in multidisciplinary projects easily accessible. The hardware consists of a simple open hardware design for the Arduino board with an Atmel AVR processor and on-board I/O support. The software consists of a standard programming language and the boot loader that runs on the board. Arduino hardware is programmed using a Wiring-based language (syntax + libraries), similar to C++ with some simplifications and modifications, and a Processing-based Integrated Development Environment (IDE). The project began in Ivrea, Italy in 2005 aiming to make a device for controlling student-built interaction design projects less expensively than other prototyping systems available at the time. As of February 2010 more than 120,000 Arduino boards had been shipped. Founders Massimo Banzi and David Cuartielles named the project after a local bar named “Arduino”. The name is an Italian masculine first name, meaning "strong friend". The English pronunciation is "Hardwin", a namesake of Arduino of Ivrea. More information could be found at the creators web page http://arduino.cc/ and in the Arduino Wiki http://en.wikipedia.org/wiki/Arduino To make the story short – Arduino is easy for beginners who lack Electronics knowledge, but also does not restrict professionals as they can program it in C++ or mix of Arduino/C++ language. There are thousands of projects which makes it easy to startup as there is barely no field where Arduino enthusiasts to have not been already. Arduino has inspired two other major derivatives – MAPLE and PINGUINO. Based on 8-bit AVR technology the computational power of Arduino boards is modest, this is why a team from MIT developed the MAPLE project which is based on ARM7 STM32F103RBT6 microcontroller. The board has same friendly IDE as Arduino and offers the same capabilities as hardware and software but runs the Arduino code much faster. Unfortunately, by year 2016, the MAPLE project is now no longer supported and updated. The remaining resources of the Maple project can be found at http://leaflabs.com In parallel with Arduino another project was started called PINGUINO. This project chose its first implementation to be with PIC microcontrollers, as AVRs were hard to find in some parts of the world like South America so it is likely to see lot of PINGUINO developers are from that part of the world. PINGUINO project founders decided to go with Python instead Java for processing language. For the moment PINGUINO is much more flexible than Arduino as it is not limited to 8bit microcontrollers. Currently the IDE, which has GCC in background, can support 8-bit PIC microcontrollers, 32bit PIC32 (MIPS) microcontrollers and ARM7/CORTEXM3 microcontrollers which makes PINGUINO very flexible because once you make your project you can migrate easily through different hardware platforms and not being bound to a single microcontroller manufacturer. The PINGUINO project can be found at: http://www.pinguino.cc. Page 2 of 19 BOARD FEATURES: We entered the Arduino/MAPLE field 5 years after the design was introduced, and this allowed us to see and resolve some of (what we consider) errors made by the Arduino inventors. We had the possibility to read current customer feedback and to implement what they wanted to see in the original Arduino. Original Arduino/MAPLE uses linear power supply, this limits the input voltage range. We designed the power supply to accept power from 9 to 30V DC thus making it possible to take virtually any power supply adapter on the market, also enable application which are in industrial power supply 24VDC. 1. We carefully selected all components to work reliable in INDUSTIRAL temperature range -25+85C so the board can be used in INDUSTIRAL applications while the original design is to Commercial 0 – 70C operating temperature. 2. The original Arduino/MAPLE design is not very reliable for portable applications as consumes it too much power with the linear voltage regulators, we put ULTRA LOW POWER voltage regulators and the consumption is only few microampers, which enables handheld and battery powered applications. 3. We add Li-Ion rechargable battery power supply option with BUILD-IN on board charger, so when you attach battery it is automatically charged and kept in this state until the other power source (USB or external adapter) is removed and it AUTOMATICALLY will power the board – no jumpers, no switches! 4. Our board has UEXT connector which allows many existing modules like RF, ZIGBEE, GSM, GPS to be connected. 5. 6. 7. 8. 9. 10. Our board has micro SD card Our board has CAN driver on board Our design allows RTC – Real Time Clock. We made our design noise immune. We use separate voltage regulator for the Analog part, which allows the ADC to be read correctly without the digital noise pickup. The LEDs and the BUTTONs are on the edge of the board so there is easy access even if the boards have shields on them. 11. 12. 13. All components are LOWER than the connectors, so the shields do not interfere with them. mini USB connector is used which is common and used in most cell phones, so you do not have to buy other cables Original Arduino design had a flaw and the connectors were not spaced at 0.1" thus making breadboarding board use impossible, to keep the compatibility we have the same spacing but we added next to this connector on 0.1" which customer can use with perforated boards. 14. All signals on the connectors are printed on top and on bottom of the board, so when you check with probe you know exactly which port you are measuring. 15. 16. 4 mount holes make board attachment easier Page 3 of 19 ELECTROSTATIC WARNING: The OLIMEXINO-STM32 board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: HARDWARE REQUIREMENTS: - Cables: You'll need a USB cable with mini USB connector for connecting the board to a personal computer and MAPLE IDE. The board also gets powered via this cable. - ARM programing tool (optional but recommended): STM32-compatible programmer/debugger is recommended: 1. if you wish to use a general-purpose approach of programming (not bootloader and USB method) 2. if you wish to change the bootloader with MPIDE bootloader 3. if you managed to overwrite the bootloader program and wish to recover the device You can use any STM32F103 compatible programmer or debugger just notice that the board has a 10-pin mini JTAG/SWD connector (0.05” step) – make sure that you have a suitable adapter. You can use ARMJTAG-20-10 adapter for this task. Our ARM-USB-OCD-H, ARM-USB-TINY-H, ARM-JTAG-COOCOX tools are capable of programming the board (remember the adapter). SOFTWARE REQUIREMENTS: - Environment (recommended) By default the board comes with MAPLE IDE bootloader. It is recommended to use MAPLE IDE initially. - Environment (recommended) Since the MAPLE project is now completely abandoned it is recommended to either use an alternative (MPIDE; Espruino IDE; stm32duino; etc) or use general-purpose method of programming. It is important to notice that the STM32 chip has internal bootloader which can be used to change any code without JTAG debugger. Please find instructions on how to use “STM32 Flash Load Demonstrator” in the wiki article: https://www.olimex.com/wiki/How_to_use_OLIMEXINO-STM32_with_Espruino_IDE Note that usually the general-purpose require a programmer or debugger in order to interact with the board. Page 4 of 19 SCHEMATIC: TRST,TDI,TMS/SWDIO,TCK/SWCLK,TDO/SWO,RESET Serial wire debug (SWD) 3.3V 3.3V_AVCC 3.3V C1 3.3V 13 C2 10uF/6.3V 100nF 12 SWD 1 2 3 4 5 6 7 8 9 TMS/SWDIO TCK/SWCLK TDO/SWO TDI RESET 10 1 32 48 19 64 C3 R-T 2 GPH127SMT-02x05(PIN7-CUT) Open C4 C5 C6 TRST 1 100nF 100nF 31 63 18 3.3V USB_DEVICE RESET 7 BOOT0 60 D2 D3(LED2) D1(TXD2) D0(RXD2) D10(#SS1) D13(SCK1/LED1) D12(MISO1) D11(MOSI1) D6 D7(TXD1) D8(RXD1) USBDM USBDP 14 TMS/SWDIO TCK/SWCLK TDI 46 D5 1N5819S/SS14 USB_P DISC 1 0k R1 DTA114YKA R2 15k T1 22k R5 3.3V 1.5k U6 USB 3 VBUS 4 2 D- 22R USBDM R4 22R USBDP 5 1 D+ R3 6 NA ID GND MINI_USB9SMALLER_CREAM C8 100nF C7 C9 C10 NA(47pF) NA(47pF) 15 16 17 20 21 22 23 41 42 43 44 45 49 50 R34 VDDA PB0/ADC8/TIM3_CH3/TIM1_CH2N 26 D27 PB1/ADC9/TIM3_CH4/TIM1_CH3N 27 D28 VSSA PB2/BOOT1 28 PB3/JTDO/TIM2_CH2/TRACESWO/SPI1_SCK 55 TDO/SWO VBAT PB4/JTRST/TIM3_CH1/SPI1_MISO 56 TRST PB5/I2C1_SMBAI/TIM3_CH2/SPI1_MOSI 57 D4 VDD PB6/I2C1_SCL/TIM4_CH1/USART1_TX D5 58 PB7/I2C1_SDA/TIM4_CH2/USART1_RX 59 D9 VDD U5 NA 3M C32 RESET 1 10nF R35 RESET 2 VCC VDD VDD VSS PA0-WKUP/USART2_CTS/ADC0/TIM2_CH1_ETR PA1/USART2_RTS/ADC1/TIM2_CH2 PA2/USART2_TX/ADC2/TIM2_CH3 PA3/USART2_RX/ADC3/TIM2_CH4 PA4/SPI1_NSS/USART2_CK/ADC4 VIN PA6/SPI1_MISO/ADC6/TIM3_CH1/TIM1_BKIN PA8/USART1_CK/TIM1_CH1/MCO PA10/USART1_RX/TIM1_CH3 1 R33 PA14/JTCK/SWCLK 1k A2 4 A3 5 A4 6 D0(RXD2) D1(TXD2) D2 D3(LED2) D4 D5 D6 D7(TXD1) BOOT0 C11 10pF A5 1 D0 2 D1 3 D2 4 D3 5 D4 6 D5 7 D6 8 D7 Q2 32768Hz/6pF C12 10pF C13 27pF CON4 D8(RXD1) D9 D10(#SS1) D11(MOSI1) D12(MISO1) D13(SCK1/LED1) GN D D23_EXT Open R32 1M PD2/TIM3_ETR 54 D25(MMC_CS) PA15/JTDI/TIM2_CH1_ETR/SPI1_NSS A1 3 NA PD0/OSC_IN 5 PD1/OSC_OUT 6 PA13/JTMS/SWDIO A0 2 CON3 2 D23_E 1 PA12/USART1_RTS/CANTX/USBDP/TIM1_ETR VIN NA PC15/OSC32_OUT 4 D23 PA11/USART1_CTS/CANRX/USBDM/TIM1_CH4 GND CON2 D15(A0) D16(A1) D17(A2) D18(A3) D19(A4) D20(A5) PC13/ANTI_TAMP 2 D21(CAN_CTRL) PC14/OSC32_IN 3 D22 PA9/USART1_TX/TIM1_CH2 GNDA NA PC11/USART3_RX 52 USB_P PC12/USART3_CK DISC 53 PA7/SPI1_MOSI/ADC7/TIM3_CH2/TIM1_CH1N 5V 6 3.3V_AVCC PC9/TIM3_CH4 40 PC10/USART3_TX 51 D26 PA5/SPI1_SCK/ADC5 3V3 5 D15(A0) D16(A1) PC2/ADC12 D17(A2) 10 PC3/ADC13 D18(A3) 11 PC4/ADC14 D19(A4) 24 PC5/ADC15 D20(A5) 25 PC6/TIM3_CH1 D35 37 PC7/TIM3_CH2 38 D36 PC8/TIM3_CH3 D37 39 BOOT0 RST 3 PC0/ADC10 8 PC1/ADC11 9 NRST CON1 1 4 PB14/SPI2_MISO/USART3_RTS/TIM1_CH2N 35 D33(MISO2) PB15/SPI2_MOSI/TIM1_CH3N D34(MOSI2) 36 VSS RESET 2 PB12/SPI2_NSS/I2C2_SMBAL/USART3_CK/TIM1_BKIN D31(#SS2) 33 PB13/SPI2_SCK/USART3_CTS/TIM1_CH1N 34 D32(SCK2) VSS 3.3V 2 PB10/I2C2_SCL/USART3_TX/TIM2_CH3 D29(SCL2) 29 PB11/I2C2_SDA/USART3_RX/TIM2_CH4 D30(SDA2) 30 VSS STM32-MAPLE_PLATFORM +5V GND 1M PB8/TIM4_CH3/I2C1_SCL/CANRX D14(CANRX) 61 PB9/TIM4_CH4/I2C1_SDA/CANTX 62 D24(CANTX) 4.7uF/6.3V 100nF 47 +5V VBAT Designed by Olimex U1 Q1 STM32F103RBT6(LQFP64) D8 2 D9 3 D10 4 D11 5 D12 6 D13 7 C14 10nF 1 27pF D14(CANRX) GND 8 D14 NA HC49/S1 D0(RXD2),D1(TXD2),D2,D3(LED2),D[4..6],D7(TXD1),D8(RXD1),D9,D10(#SS1),D11(MOSI1),D12(MISO1),D13(SCK1/LED1),D14(CANRX) 1 2 SD/MMC 3.3V LEDS LED1_E 3.3V 3.3V D13(SCK1/LED1) 1 Close 2 R7 2k R11 R12 R13 R8 4.7k LED1 SD/MMC UEXT D3(LED2) Close R6 2k 3.3V 3.3V LED2_E UEXT 1 D7(TXD1) 3 D29(SCL2) 5 D12(MISO1) 7 D13(SCK1/LED1) LED2 9 R9 R10 4.7k 10k D10:Open/D4:Close 3 10 D8(RXD1) D30(SDA2) D11(MOSI1) UEXT_#CS R25 D21(CAN_CTRL) 4 6 8 L3 D10/D4 2 100k 100k 100k CL470nH/0805/1.76R/250mA R14 R15 1 D33(MISO2) D32(SCK2) 10k 1M D34(MOSI2) D25(MMC_CS) C15 9 1 DAT2/RES 8 DAT1/RES 7 DAT0/DO 5 CLK/SCLK 4 VDD 6 VSS 3 CMD/DI 2 CD/DAT3/CS EXT D23_EXT 1 D25(MMC_CS) 3 D27 5 D29(SCL2) 7 D31(#SS2) 9 D33(MISO2) 11 D35 13 D37 15 MICRO_SD/TFC-WPAPR-08 C33 22uF/6.3V UEXT_#CS Extension 13 2 4 6 8 10 12 14 D24(CANTX) D26 D28 D30(SDA2) D32(SCK2) D34(MOSI2) D36 16 PN2x8 22uF/6.3V BH10R 3.3V +5V POWER_SUPPLY VIN X1-1 CAN 2 R17 PWR_J D1 R23 120R TB3-3.5MM 0.47R 3.3V VR1 2 VIN L2 VOUT 3 MCP2551-I/SN 8 RS 7 CANH 6 CANL 5 VREF NA D24(CANTX) 1 TXD 2 VSS 3 VDD 4 RXD 1 C24 2.2uF D14(CANRX) R28 10k 3.3V D6 R30 1k 1N4148/mini-melf GND RESET BUT R22 U2 YDJ-1136 BUTTONS 3.3V_AVCC 3.3V MCP1700T-3302E/MB C23 100nF 1N5819S/SS14 RST 0R 9-30VDC C16 X1-2 CAN 0R(boad mounted) U4 1 0.47R 0R R24 10k 3 R16 3.3V 3 TC D3 SC 1 SE 2 FB 5 L1 +5V D4 CL10uH SW68 NA MC33063ADR(SO8) D2 0R(boad mounted) +5V 1N5819S/SS14 Battery Charger C19 R20 2k C20 C21 2.2uF MCP1700T-3302E/MB VDD 2 PROG 5 1 2 C22 15k appr. 70 mA charge current 100nF 3.3V_AVCC VOUT 3 VBAT VSS C31 VIN CE 1 MCP73812T-420I/OT R21 VR2 IRLML6402 VBAT 3 BATTERY CHARGER 2 1N5819S/SS14 FET1 U3 4 BOOT0 R29 330R 2.2uF LIPO_BAT DW02R - C29 2.2uF 1 GND C30 2.2uF OLIMEXINO-STM32 hardware revision F www.OLIMEX.com R31 10k BOARD LAYOUT: Page 6 of 19 POWER SUPPLY CIRCUIT: OLIMEXINO-STM32 can be powered from: – external power supply (9-30) VDC. – + 5V from USB – 3.7 V Li-ion battery – JTAG/SWD programmer/debugger The programmed board power consumption is about 50 mA with all peripherals enabled. RESET CIRCUIT: OLIMEXINO-STM32 reset circuit includes D6 (1N4148), R28 (10kΩ), R29 (330Ω), C31 (100nF), STM32F103RBT6 pin 7 (NRST) and RESET button. CLOCK CIRCUIT: Quartz crystal Q1 8 MHz is connected to STM32F103RBT6 pin 5 (PD0/OSC_IN) and pin 6 (PD1/OSC_OUT). Quartz crystal Q2 32.768 kHz is connected to STM32F103RBT6 pin 3 (PC14/OSC32_IN) and pin 4 (PC15/OSC32_OUT). JUMPER DESCRIPTION: Note that all jumpers on the board are SMD type. You will need to solder/unsoder/cut them in order to reconfigure them. LED1_E This jumper, when is closed, enables LED1. Default state is closed. LED2_E This jumper, when is closed, enables LED2. Default state is closed. D23_E This jumper, when is closed, connects STM32F103RBT6 pin (PC15/OSC32_OUT) – signal D23 to EXT pin 1, and when is opened, D23 is not connected to EXT. Default state is opened. R-T This jumper, when is closed, connects TRST and RESET, and when is opened, TRST and RESET are separated. Default state is opened. Page 7 of 19 CAN_T This jumper, when is closed, CAN termination is enabled, and when is opened, CAN termination is disabled. Default state is opened. D10/D4 This jumper, when is in position D10, UEXT pin 10 (UEXT_#CS) is connected to STM32F103RBT6 pin 20 (PA4/SPI1_NSS/USART2_CK/ADC4) – signal D10, and when is in position D4, UEXT pin 10 (UEXT_#CS) is connected to STM32F103RBT6 pin 57 (PB5/I2C1_SMBAI/TIM3_CH2/SPI1_MOSI) – signal D4. Note that P10_E's effect also is affected by D10/D4. Default state is in position D4. P10_E: When closed the board provides 3.3V to the UEXT_CCS – UEXT pin. Default state is closed. 3V3A/5V This is a new jumper introduced in hardware revision F of the board. It changes the voltage provided to pin #3 of the power shield connector from the default 5V to 3.3VA. IMPORTANT! Hardware revision F introduced changes to the POWER connector of the Arduino shield. Now there are 5V available at pin #3 of the POWER connector by default! It was 3.3V in older revisions. Be careful if you use 3.3V shields! You can revert the voltage of the pin back to 3.3V if you change the position of the 3V3A/5V jumper! Default state is in position 5V. INPUT/OUTPUT: Status Led with name LED1 (green) connected via jumper LED1_E to STM32F103RBT6 pin 21 (PA5/SPI1_SCK/ADC5) – signal D13(SCK/LED1). Status Led with name LED2 (yellow) connected to STM32F103RBT6 pin 15 (PA1/USART2_RTS/ADC1/TIM2_CH2) – signal D3(LED2). Power-on LED (red) with name PWR_LED – this LED shows that the board is power supplied. User button with name BUT connected to STM32F103RBT6 pin 40 (PC9/TIM3_CH4) via R33 (1kΩ) and pin 60 (BOOT0) – signal BOOT0. User button with name RST connected to STM32F103RBT6 pin 7 (NRST). Page 8 of 19 EXTERNAL CONNECTORS DESCRIPTION: SWD: Pin # Signal Name 1 VCC 2 TMS/SWDIO 3 GND 4 TCK/SWCLK 5 GND 6 TDO/SWO 7 Cut off 8 TDI 9 GND 10 RESET Note that pin 7 of SWD connector is cut off. Page 9 of 19 UEXT: Pin # Signal Name 1 VCC 2 GND 3 D7(TXD1) 4 D8(RXD1) 5 D29(SCL2) 6 D30(SDA2) 7 D12(MISO1) 8 D11(MOSI1) 9 D13(SCK/LED1)D13(SCK1/LED1) 10 UEXT_#CS PWR_JACK: Pin # Signal Name 1 Power input 2 GND CON1 – POWER: Pin # Signal Name 1 RESET 2 3.3V OUTPUT 3 5V OUTPUT (3.3VA if you modify jumper 3V3A/5V) 4 GND 5 GND 6 VIN Page 10 of 19 CON2 – ANALOG: Pin # Signal Name 1 D15(A0) 2 D16(A1) 3 D17(A2) 4 D18(A3) 5 D19(A4) 6 D20(A5) CON3 – DIGITAL: Pin # Signal Name 1 D0(RXD2) 2 D1(TXD2) 3 D2 4 D3(LED2) 5 D4 6 D5 7 D6 8 D7(TXD1) CON4 – DIGITAL: Pin # Signal Name 1 D8(RXD1) 2 D9 3 D10(#SS1) 4 D11(MOSI1) 5 D12(MISO1) 6 D13(SCK/LED1) 7 GND 8 D14(CANRX) Page 11 of 19 LI_BAT: Pin # Signal Name 1 VBAT 2 GND USB: Pin # Signal Name 1 +5V_USB 2 D- 3 D+ 4 Not connected 5 GND SD/MMC: Pin # Signal Name 1 MCIDAT2 2 D25(MMC_CS) 3 D34(MOSI2) 4 MMC_PWR 5 D32(SCK2) 6 GND 7 D33(MISO2) 8 MCIDAT1 9 Not connected 10 Not connected 11 Not connected 12 Not connected Page 12 of 19 EXT: Pin # Signal Name Pin # Signal Name 1 D23_EXT 2 D24(CANTX) 3 D25(MMC_CS) 4 D26 5 D27 6 D28 7 D29(SCL2) 8 D30(SDA2) 9 D31(#SS2) 10 D32(SCK2) 11 D33(MISO2) 12 D34(MOSI2) 13 D35 14 D36 15 D37 16 GND CAN: Pin # Signal Name 1 GND 2 CANL 3 CANH Page 13 of 19 MECHANICAL DIMENSIONS: Page 14 of 19 AVAILABLE DEMO SOFTWARE: The board comes with a simple program on-board. To get more projects, examples and ready maple libraries please visit the OLIMEXINO-STM32's page: https://www.olimex.com/Products/Duino/STM32/OLIMEXINO-STM32/ Page 15 of 19 ORDER CODE: OLIMEXINO-STM32 – assembled and tested board How to order? You can order directly from our web-shop or from any of our distributors. Check our web https://www.olimex.com for more info. Board revision history: Revision Notable Changes A - C6 (100n/0603) is changed to 4.7uF/0603. B - Removed the label " 2011". - Logos added: Open Hardware, Designed by OLIMEX and Made in Bulgaria, 2011 logos - Added divider which includes R34, R35 and C32 with aim to measure the battery. - All tracks which were placed close to board's edges were moved as far as possible away from them. - Some changes in the values of some components were made C - Added closed by default SMD jumpers on LED2 and R10(UEXT_CS)lines - The table with the jumper description is now updated - Some logos and print lines have been re-arranged D - Added again the PWR JACK connector for the external supply in the board design and schematic E - R18 is changed from 3k/1% to 3.01k/1% - C15(tantalum 47uF/6.3V) is removed and replaced by 2 (two) 22uF/6.3V0603 capacitors - Wires near the edges of the board were moved to the center - By default the board now provides 5V on the Arduino connector (at the 5V pin). Added 3-pin SMD jumper at the bottom to change to 3.3VA. F - Different SWD connector used now - Placing new and better USB OTG connector - Placing new and better micro SD card connector Page 16 of 19 Document revision history: Revision A B C Changes - At first page “Copyright(c) 2011, OLIMEX Ltd, All rights reserved” is replaces with “Designed by OLIMEX Ltd., 2011” - Updated schematic with board revision A - Updated schematics with board revision B and table - Fixed grammatical errors - Updated schematics with board revision D - Added board revision history - Updated schematics - Added new jumpers description - Updated disclaimer Modified Page# 1 6, 11 All D - Removed misleading feature – there is no precision AREF circuit on the board 4 E - Schematic and revision changes updated to reflect latest board revision 5, 16 F - Updated manual for hardware revision F – the most important change is the 5V output at pin #3 of the Arduino shield connector (it was 3.3VA previously). This can be reverted by modifying the 3V3A/5V jumper. All G - Added a note about the changes to the output pin of the POWER connector 8 Page 17 of 19 DISCLAIMER © 2014 Olimex Ltd. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other product names may be trademarks of others and the rights belong to their respective owners. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. The Hardware project is released under the Creative Commons Attribution-Share Alike 3.0 United States License. You may reproduce it for both your own personal use, and for commercial use. You will have to provide a link to the original creator of the project https://www.olimex.com on any documentation or website. You may also modify the files, but you must then release them as well under the same terms. Credit can be attributed through a link to the creator website: https://www.olimex.com The software is released under GPL. It is possible that the pictures in this manual differ from the latest revision of the board. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. This evaluation board/kit is intended for use for engineering development, demonstration, or evaluation purposes only and is not considered by OLIMEX to be a finished end-product fit for general consumer use. Persons handling the product must have electronics training and observe good engineering practice standards. As such, the goods being provided are not intended to be complete in terms of required design-, marketing-, and/or manufacturing-related protective considerations, including product safety and environmental measures typically found in end products that incorporate such semiconductor components or circuit boards. Olimex currently deals with a variety of customers for products, and therefore our arrangement with the user is not exclusive. Olimex assumes no liability for applications assistance, customer product design, software performance, or infringement of patents or services described herein. THERE IS NO WARRANTY FOR THE DESIGN MATERIALS AND THE COMPONENTS USED TO CREATE OLIMEXINO-STM32. THEY ARE CONSIDERED SUITABLE ONLY FOR OLIMEXINO-STM32. Page 18 of 19 For product support, hardware information and error reports mail to: support@olimex.com. Note that we are primarily a hardware company and our software support is limited. Please consider reading the paragraph below about the warranty of Olimex products. Warranty and returns: Our boards have lifetime warranty against manufacturing defects and components. During development work it is not unlikely that you can burn your programmer or development board. This is normal, we also do development work and we have damaged A LOT of programmers and boards during our daily job so we know how it works. If our board/programmer has worked fine then stopped, please check if you didn't apply over voltage by mistake, or shorted something in your target board where the programmer was connected etc. Sometimes boards might get damaged by ESD shock voltage or if you spill coffee on them during your work when they are powered. Please note that warranty do not cover problems caused by improper use, shorts, over-voltages, ESD shock etc. If the board has warranty label it should be not broken. Broken labels void the warranty, same applies for boards modified by the customer, for instance soldering additional components or removing components – such boards will be not be a subject of our warranty. If you are positive that the problem is due to manufacturing defect or component you can return the board back to us for inspection. When we receive the board we will check and if the problem is caused due to our fault and we will repair/replace the faulty hardware free of charge, otherwise we can quote price of the repair. Note that all shipping back and forth have to be covered by the customer. Before you ship anything back you need to ask for RMA. When you ship back please attach to it your shipping address, phone, e-mail, RMA# and brief description of the problem. All boards should be sent back in antistatic package and well packed to prevent damages during the transport. Page 19 of 19
OLIMEXINO-STM32 价格&库存
很抱歉,暂时无法提供与“OLIMEXINO-STM32”相匹配的价格&库存,您可以联系我们找货
OLIMEXINO-STM32
  • 1+234.693051+28.40820
  • 3+211.167733+25.56060
库存:3
OLIMEXINO-STM32
    • 1+263.01773
    • 3+248.99012
    库存:3
