Art. EA-XPR-300
[High Resolution Photos]
LPC800 / LPC812 MAX BOARD
The LPC800 / LPC812 MAX Board (both names are used for this board - it is the same board) combines the features
of the LPCXpresso , mbed , and ArduinoTM environments. The board is designed in partnership with mbed and
developed by Embedded Artists.
The board is is an easy to use ARM Cortex-M0+ rapid prototyping board that bring togther the best of three platforms:
LPCXpresso Support
The LPCXpresso IDE support programming and debugging the board using the on-board CMSIS-DAP
interface, no LPC-Link is needed. The LPCXpresso connector on the board is compatible with existing
baseboards.
mbed Support
When connected to a PC, the board will show up as a mass-storage device. Firmware images placed on it will
be written to the LPC812 after a power cycle, same as todays mbed boards. The board will also show up as a
CMSIS-DAP compatible device allowing users to develop and debug code using any compatible ”off-line”
toolchain, such as the ARM-MDK. The mbed SDK has been ported to the board, and it is suppoorted by the online compiler.
Arduino Support
Arduino is a popular hobbyist platform, with a standardised set of expansion connectors. The Arduino
connectors on the LPC812 MAX board are compatible with the ”Arduino UNO” platform. Several compatible
expansion cards (shields) can be bought from various vendors.
http://www.embeddedartists.com/products/lpcxpresso/lpc812_max.php[12/10/2013 3:19:28 PM]
Introduction Video
To be uploaded...
mbed
The LPC800 / LPC812 MAX Board is
mbed Enabled - meaning that the board
take full advantage of the mbed platform!
What is mbed?
The mbed Software Development Kit (SDK) ,
which is an open source C/C++ microcontroller
software platform designed for a suitable level
of hardware abstraction to simplify
microcontroller programming.
The mbed Compiler is a powerful online IDE
that is tightly integrated with the mbed SDK and
Developer's Website (mbed.org, see below).
The mbed Hardware Development Kit (HDK),
which is an interface design that provides
simple USB drag-n-drop programming and
CMSIS-DAP debug interface for the LPC812
microcontroller.
The mbed.org community, with extensive
documentation in the form of handbooks,
cookbooks, project pages, User Forums for
getting help and advice from other mbed users,
LPC800 / LPC812 MAX Board | Embedded Artists AB
etc.
Some mbed information:
mbed.org website - this is the official mbed
community website. It contains a lot of
documentation with many different topics and
angles on the information.
Explore mbed - a four segment presentation of
the mbed platform: Explore - Getting Started Prototype - Production.
mbed platforms - a list of mbed supported
platforms.
mbed Developers website - an introduction to
the mbed Developers website.
Handbook - gives an overview of the platform
with all features.
Cookbook - a wiki for publishing usercontrobuted libraries and resources.
SPECIFICATION
Processor
NXP's Cortex-M0+ LPC812 microcontroller in TSSOP20 package
Flash Mamory
16 kB
Data Memory
4 kB
Clock Crystal
12.000 MHz crystal for CPU
Dimensions
54 x 78 mm
Power
3.3V external powering, or
5.0V external powering, or
5.0V from USB via mbed HDK debug interface
Connectors
• All relevant LPC812 pins available on LPCXpresso compatible expansion connector (2x27 pin rows, 100 mil pitch, 900 mil between rows)
• Arduino compatible expansion connectors (Arduino shields can be mounted)
• Serial Expansion Connector, 14-pos connector with UART/I2C/SPI/GPIO pins
Other
• RGB-LED
• User push-button
• Supported by the LPCXpresso IDE environment
• Complete on-board mbed HDK
- USB drag-n-drop programming
- CMSIS-DAP interface for Cortex debug interface
- USB virtual serial bort (functional after modifiying soldered jumpers on the board)
• Supported by the mbed SDK and online tools
DOCUMENTATION AND RESOURCES
Further Information
General board information at LPCware.com
General board information at mbed.org
Handbook at mbed.org
Getting Started at mbed.org
Documents
Board Schematics
Embedded Artists' general RoHS 2 declaration
Software
Pre-loaded Demo Application (just import project into the mbed compiler)
RELATED PRODUCTS
Jumper Wires F/M 50 Pack
Order number: EA-ACC-016
Jumper Wires M/M 50 Pack
Order number: EA-ACC-017
14-pos IDC Ribbon Cable 50 mil
Order number: EA-ACC-019
RF Adapter Board
Order number: EA-ACC-021
14-pos Adapter 50 mil to 100 mil
Order number: EA-ACC-024
1.35 inch Memory LCD 96x96 px
Order number: EA-LCD-007
1.5 inch RGB OLED 128x128 px
Order number: EA-LCD-008
2.7 inch E-paper Display
Order number: EA-LCD-009
LPC812 MAX Experiment Kit
Order number: EA-XPR-301
FAQ
How do I get the schematic?
Are your boards RoHS 2 compatible?
What chip revision are your boards using?
Is the design files available (schematic, layout, BOM and Gerber files)?
What is the warranty for your boards?
Where is the serial number?
Do you have high resolution photos of your products?
Do you have a long-term commitment to production and availability of your boards?
I cannot download the manuals or files in general. What to do?
How to erase flash on devices when JTAG/SWD interface accidentally disabled or PLL programmed wrongly by application program that is already in
flash?
Which free graphical libraries exist for NXP's processors?
How do I create an LPC-LINK? ...so that I can use the LPCXpresso IDE in full when developing for my own design.
USEFUL INFORMATION
PARTNERS
We are located in Malmö, Sweden. Get in touch
Useful Links
Embedded Artists AB
Tel +46 (0)40-6110093
Contact Us
Davidshallsgatan 16
Fax +46 (0)40-6110093
Terms & Conditions
211 45 Malmö
Email info@embeddedartists.com Privacy Policy
» More
很抱歉,暂时无法提供与“EA-XPR-300”相匹配的价格&库存,您可以联系我们找货
