Adafruit Metro Mini 328 - 5V 16MHz
PRODUCT ID: 2590
Description
We sure love the ATmega328 here at Adafruit, and we use them a lot for our own projects. The
processor has plenty of GPIO, Analog inputs, hardware UART SPI and I2C, timers and PWM galore just enough for most simple projects. When we need to go small, we use a Pro Trinket 3V or 5V,
but if you want to have USB-to-Serial built in, we reach for an Adafruit METRO Mini.
METRO Mini is the culmination of years of playing with AVRs: we wanted to make a tiny,
breadboard-friendly development board that is easy to use and is hacker friendly. Metro Mini can
be programmed with the Arduino IDE (select 'UNO' in the boards dropdown)
ATmega328 brains - This popular chip has 32KB of flash (1/2 K is reserved for the bootloader),
2KB of RAM, clocked at 16MHz
Power the METRO Mini with 6-16V polarity protected on the Vin pin, or plug the micro USB
connector to any 5V USB source.
METRO has 20 GPIO pins, 6 of which are Analog in as well, and 2 of which are reserved for the USBserial converter. There's also 6 PWMs available on 3 timers (1 x 16-bit, 2 x 8-bit). There's a
hardware SPI port, hardware I2C port and hardware UART to USB.
GPIO Logic level is 5V but by cutting and soldering closed a jumper on the bottom, you can easily
convert it to 3.3V logic
5V onboard regulator with 150mA out, 3.3V 50mA available via FTDI chip
USB to Serial converter , there's a genuine SiLabs CP2104 hardware USB to Serial converter that can
be used by any computer to listen/send data to the METRO, and can also be used to launch and
update code via the bootloader
Four indicator LEDs , on the top of the PCB, for easy debugging. One green power LED, two RX/TX
LEDs for the UART, and a red LED connected to pin PB5 / digital #13
Easy reprogramming, comes pre‐loaded with the Optiboot bootloader
Beautiful styling by PaintYourDragon and Bruce Yan, in Adafruit Black with gold plated pads.
The Metro Mini comes as a fully assembled and tested board, with bootloader burned in and also a stick of
0.1" header. Some light soldering is required if you'd like to plug it into a breadboard, or you can solder
wires or header directly to the breakout pads. Once headers are installed they can be fitted into 0.6" wide
sockets
Mac & Windows People! Don't forget to grab & install the FTDI VCP drivers from FTDI and the
SiLabs CP210x drivers from SiLabs to make the COM/Serial port show up right! The default
drivers may not support the interface chip!
Technical Details
Revision History:
As of Nov 8th 2016, we are now shipping with the SiLabs CP2104 - a high quality USB-to-Serial
converter that performs as well or better than the FTDI series
Detailed specifications:
ATmega328 microcontroller with Optiboot (UNO) Bootloader
USB Programming and debugging via the well-supported genuine FTDI FT231X or the SiLabs
CP2104
Input voltage (Vin): 6-16V (a 9VDC power supply is recommended)
5V logic with 3.3V compatible inputs, can be converted to 3.3V logic operation
20 Digital I/O Pins: 6 are also PWM outputs and 6 are also Analog Inputs
32KB Flash Memory - 0.5K for bootloader, 31.5KB available after bootloading
16MHz Clock Speed
Adafruit Black PCB with gold plate on pads
18mm x 44mm x 4mm / 0.7" x 1.7" x 0.2"
Weight: 3g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2590”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+125.525501+15.98730
