XC-3 LED Tile Control Kit Quick Start Guide
Version 1.1
Publication Date: 2010/05/10
Copyright © 2010 XMOS Ltd. All Rights Reserved.
XC-3 LED Tile Control Kit Quick Start Guide (1.1)
1
2/7
Introduction
The XC-3 LED Tile Control Kit is an ideal starting point for prototyping LED scan
board designs using XMOS XCore processors. It provides a complete software
programmable solution for controlling LED arrays and strings.
The XC-3 LED Tile Control Kit includes:
• XC-3 Development Board
• XTAG Connector that provides a JTAG interface between the board and XMOS
Tools
• USB Cable to connect the XTAG to your development system
• External 5V power supply
Further information on the XC-3 is available from the XMOS web site. Download the
hardware manual, schematics and design files from: www.xmos.com/xc3.
2
Getting Started
The XC-3 board includes an implementation of the XMOS LED Reference Design
software which provides native support for the MBI5026 and MBI5030 Macroblock
LED Driver IC. The application is designed to interface to an SMD-32X16-1R1G1G-F-P6,
a 32x16 pixel LED module using 12 x MBI5026 or MBI5030 on a 1/8 scan rate with a
16-way 2mm IDC connection. The reference design software is pre-loaded on the
XC-3. The latest version is available from: www.xmos.com
www.xmos.com
16-WAY IDC HEADER
2mm
5V PSU SOCKET
3/7
SURFACE MOUNT
PUSHBUTTON
LED MODULE IIN
MOUNTING HOLES
3mm dia.
LED MODULE OUT
ETH
PHY
ETH
PHY
XS1-G4
144BGA
SPI
RJ45
0.1” IDC HEADER
20MHz
XTAL OSC
ETHERNET
TRANSCEIVER
SPI FLASH
5V PSU
PSU
XSYS CONNECTOR
www.xmos.com
25MHz
XTAL OSC
RJ45
2.1
4/7
Driving LEDs with the XC-3 Board
The LED application can be used out-of-the-box as a demonstration. A PC can be
directly connected to the Ethernet daisychain, and a standard video player, such as
the open-source mplayer application, can be used to broadcast video
Ethernet
100 Mbps
XC-3
XC-3
XC-3
XC-3
For large video wall systems a separate distribution or tiling unit is required, which
inputs DVI, HDMI or VGA video at HD resolutions, separates the data for each of the
tiles in the system, packetizes it and distributes over one or more gigabit Ethernet
streams.
RJ45
RJ45
RJ45
RJ45
SPI * n
Up to
8K pixels
Up to
8K pixels
RJ45
RJ45
RJ45
LED
XC3
LED
XC3
LED
XC3
RJ45
RJ45
RJ45
www.xmos.com
RJ45
RJ45
Up to
8K pixels
LED
XC3
LED
XC3
LED
XC3
RJ45
RJ45
SPI * n
Up to
8K pixels
RJ45
RJ45
RJ45
RJ45
LED
XC3
LED
XC3
LED
XC3
RJ45
LED
XC3
LED
XC3
LED
XC3
RJ45
RJ45
Setup and
Diagnostics
100 Mbps
RJ45
DVI/HDMI/VGA
Video
Ethernet
RJ45
1Gbps
Ethernet
Switch
RJ45
Processor
(Tiling
Engine)
2.2
5/7
Configuring a single board demonstration
The following instructions provide details on how to confi gure the software supplied
with the XC-3 board when connected to a single SMD-32X16-1R1G1G-F-P6 LED module
using MBI5030 drivers. Please refer to the LED Reference Kit Application Note for
information on using MBI5026 drivers:
1. Plug-in the XC-3 using the 5V power supply.
The PLL LED on the bottom of the board lights up to indicate that the board
has been powered up.
2. Connect the XC-3 board to the LED module.
The text “XMOS” is displayed.
3. Set the PC to use a static Ethernet IP address, with an IP of 192.168.0.1, and a
subnet mask of 255.255.0.0.
4. Connect the PC to the XC-3 using an Ethernet cable (not supplied in kit).
5. Test connectivity by pinging the default IP address of the XC-3: 192.168.0.254.
6. Use the mplayer application, supplied with the LED Reference Design software,
to stream video to the tiles, with the following command:
mplayer - vf scale =16:32 - loop 0 - vo xudp : noinit :
tilewidth =16: tileheight =32 videofile . avi
Ethernet
10/100 Mbps
16x32 Pixel Array
XC-3
6 x SPI
RJ45
www.xmos.com
XMOS
RJ45
2.3
6/7
Configuring a dual board demonstration
1. Follow Step 1 and Step 2 from the single-board demonstration.
2. Run the LED Tile Confi guration Application with the following command:
ledconfig . exe -- prefix =192.168 -- port =306
3. In the application, run the command:
ac
The application acknowledges this with “Autoconfigure packets sent” message.
4. Quit the application by typing:
quit
The IP addresses for the LED modules are automatically configured.
5. Test connectivity with both tiles by pinging 192.168.1.1 and192.168.1.2.
mplayer - vf scale =32:32 - loop 0 - vo xudp :
tilewidth =16: tileheight =32: chainstart =0 _0 :
chainpoint =1 _0 videofile . avi
32x32 Pixel Array
www.xmos.com
6 x SPI
XC-3
XC-3
6 x SPI
RJ45
XMOS
RJ45
XMOS
RJ45
RJ45
3
7/7
XMOS Tools Support
The XMOS tools are provide in a single platform-specific downloadable file from
http://www.xmos.com/tools
Instructions on installing and using the XMOS Tools can be found in the XMOS
Tools User Guide http://www.xmos.com/published/xtools_en. The following table
provides a summary tools support for the XC-3 development board.
Minimum tools version required
Board support file
USB-to-JTAG adaptor
USB-to-JTAG driver
9.7
XC-3.xn
XTAG
FTDI
Hardware Guide
http://www.xmos.com/published/xc3hw
4
Document History
Date
Release
Comment
2009-07-08
1.0
First release
2010-05-10
1.1
Added tools support section
Disclaimer
XMOS Ltd. is the owner or licensee of this design, code, or Information (collectively, the
“Information”) and is providing it to you “AS IS” with no warranty of any kind, express or
implied and shall have no liability in relation to its use. XMOS Ltd. makes no representation
that the Information, or any particular implementation thereof, is or will be free from any
claims of infringement and again, shall have no liability in relation to any such claims.
Copyright © 2010 XMOS Ltd. All Rights Reserved. XMOS and the XMOS logo are registered
trademarks of XMOS Ltd in the United Kingdom and other countries, and may not be used
without written permission. Company and product names mentioned in this document are the
trademarks or registered trademarks of their respective owners. Where those designations
appear in this document, and XMOS was aware of a trademark claim, the designations have
been printed with initial capital letters or in all capitals.
www.xmos.com
很抱歉,暂时无法提供与“XCARDXC-3”相匹配的价格&库存,您可以联系我们找货
