Page 2
Design Overview
LPC3154 Powering and Unused parts
LPC-LINK
LPC1347 Target
Page 3
LPC3154 Digital I/O
External powering (+5V)
External powering (+3.3V)
LPC3154 internal powering
Page 4
JTAG Interface
3.3V
USB
powering
LPC1347
USB mini-B
LPC3154 implementing
JTAG interface
Superset of
mbed connector
Can be disconnected
LED on
GPIO2
Page 5
LED on
PIO0_7
External JTAG
connector
LPC1347
Schematic page 2-3
Expansion
connector
JTAG interface
Schematic page 4
Page 6
Expansion connector
UL = UnLoaded = normally not mounted component.
Default jumper settings are indicated in the schematic.
However, always check jumper positions on actual boards
since there is no guarantee that all jumpers are in default place.
Schematic page 5-6
TP_GND TP_1V8 TP_3V3 TP_1V2
VDIG_1V8
VIO_3V3
VDIG_1V2
Power supply parts of LPC3154
C1
C2
10u
100n
USB_VBUS
GND
GND
PSU_VOUT1
PSU_VOUT2
PSU_VOUT3
PSU_VBAT
E16
H17
F17
PSU_VBAT
PSU_VBAT1
PSU_VBAT2
PSU_PLAY
PSU_STOP
C17
D15
D17
PSU_PLAY
PSU_STOP
PSU_VSSA_CLEAN
H15
G17
J16
G16
H16
D16
PSU_LX1
PSU_LX2
PSU_VBUS
PSU_VIN1
PSU_VSS1
PSU_VSSA
Starpoint at ball D16 on U1
D3
PMEG3005EJ
EXT_POW
PSU_VBUS
C5
C6
22u
22u
22u
GND
GND
FSLOW_IN
FSLOW_OUT
L17
L16
RTC_INT
RTC_BACKUP
RTC_CLOCK_OUT
RTC_VDD36
RTC_VSS
M16
K14
U17
L15
M17
CHARGE_VBUS
CHARGE_VBAT
CHARGE_BAT_SENSE
CHARGE_VNTC
CHARGE_CC_REF
CHARGE_VSS
J14
K16
K17
J17
K15
J15
GND
P16
P15
N17
P17
R17
GND GND
VDIG_1V2
VDIG_1V8
C13
68n
GND
100n
GND
C14
100n
GND
VIO_3V3
GND
Q1P
SI1016X
GND
Q1N
SI1016X
VPP
UOS_VBAT
UOS_VBUS
UOS_VSS
UOS_CX2
UOS_CX1
GND
C12
GND
C3
470n
OTP
R53
0R
GND
100K
100K
R6
R5
PSU_PLAY
PSU_STOP
C4
J1
C15
J1
U13
A6
M14
VDDI_0
VDDI_1
VDDI_2
VDDI_3
H1
U14
A7
M15
VSSI_0
VSSI_1
VSSI_2
VSSI_3
100n
GND
C9
VDIG_1V2
VDDE_0
VDDE_1
VDDE_2
VDDE_3
VDDE_4
VDDE_5
VDDE_6
VDDE_7
D1
M1
L1
U7
U15
A15
A4
G15
VSSE_0
VSSE_1
VSSE_2
VSSE_3
VSSE_4
VSSE_5
VSSE_6
VSSE_7
E1
N1
K1
U8
U16
A14
A5
L14
VIO_3V3
C7
C8
22n
GND
22n
GND
C9
100n
GND
C10
C11
100n
GND
10u
GND
GND
GND
Analog parts of LPC3154
Not used parts of LPC3154
U1-4
LPC3154
U1-3
LPC3154
VIO_3V3
GND
VIO_3V3
C16
C17
UL
100n
GND
GND
VIO_3V3
VDIG_1V8
GND
GND
I2S_DATA_RX
B13
A13
ADC10B_VDDA33
ADC10B_GNDA
B12
C13
C12
ADC10B_GPA0
ADC10B_GPA1
ADC10B_GPA2
R15
P13
P14
T15
R14
ADC_MIC
ADC_TINL
ADC_TINR
ADC_VINL
ADC_VINR
T17
R16
T16
ADC_VREFP
ADC_VREFN
ADC_VREF
N14
N15
N16
T9
R9
P9
ADC_VDDA33
ADC_VDDA18
ADC_GNDA
DAI_BCK0
DAI_WS0
DAI_DATA0
DAC_VREFP
DAC_VREFN
DAC_VDDA33
F16
F15
C14
HP_OUTR
HP_FCR
C15
B15
HP_OUTL
HP_FCL
B17
C16
HP_VDDA33
NC
A16
D13
HP_OUTC
HP_VREF
HP_GNDA
D14
E14
B16
VIO_3V3
GND
MDAO_CLK0
MDAO_BCK0
MDAO_WS0
MDAO_DATA0
C18
C19
T11
100n
UL
T12
R12
T13 GND GND
GND
U1-5
LPC3154
J3
H3
H4
G4
F4
F3
E4
E3
D3
A3
C2
D2
E2
F2
G2
H2
EBI_D0
EBI_D1
EBI_D2
EBI_D3
EBI_D4
EBI_D5
EBI_D6
EBI_D7
EBI_D8
EBI_D9
EBI_D10
EBI_D11
EBI_D12
EBI_D13
EBI_D14
EBI_D15
MLCD_DB0
MLCD_DB1
MLCD_DB2
MLCD_DB3
MLCD_DB4
MLCD_DB5
MLCD_DB6
MLCD_DB7
MLCD_DB8
MLCD_DB9
MLCD_DB10
MLCD_DB11
MLCD_DB12
MLCD_DB13
MLCD_DB14
MLCD_DB15
T7
P8
T6
R6
U6
P6
R5
T5
U5
P5
P4
U4
T4
U3
U2
R4
K3
EBI_DQM0_NOE
EBI_A0_ALE
EBI_A1_CLE
C4
A2
K4
EBI_NWE
R7
T8
P7
R8
L2
L3
L4
M2
B5
C5
D5
D4
MLCD_RS
MLCD_RW_WR
MLCD_E_RD
MLCD_CSB
NAND_NCS0
NAND_NCS1
NAND_NCS2
NAND_NCS3
MNAND_RYBN0
MNAND_RYBN1
MNAND_RYBN2
MNAND_RYBN3
EBI_NCAS_BLOUT0
EBI_NRAS_BLOUT1
J2
J4
VIO_3V3
1
2
3
4
5
6
7
EXT_POW
OTP
N-RESET-IN
VIO_3V3
VDIG_1V8
VDIG_1V2
15K
H14
G14
E17
D1
PMBD7000
D2
PMEG3005EJ
Production test connector
U1-1
LPC3154
0R
R3
0R
R2
0R
R1
GND
R4
Note: 1V8 rail is actually 1.4V
since internal regulator in default
PWM_DATA
D10
CLOCK_OUT
M4
A1
B1
C1
F1
G1
P1
U1
B2
K2
B3
NC1
NC2
NC3
NC4
NC5
NC6
NC7
NC8
NC9
NC10
NC11
NC12
NC13
NC14
NC15
NC16
NC17
NC18
NC19
C3
G3
M3
B4
B9
A11
A12
B14
A17
Boot mode - USB via DFU class
VIO_3V3
GND
VDIG_1V2
GND
L1
USB_VBUS
R16
R17
USB_ID
R3
T3
N2
USB_VDDA33
USB_VDDA33_DRV
USB_VDDA12_PLL
N3
R1
T1
P3
N4
USB_VBUS
USB_DM
USB_DP
USB_ID
USB_RREF
P2
R2
T2
GND
D5
PRTR5V0U2X
GND
GND
SPI_CS_OUT0
SPI_SCK
SPI_MISO
SPI_MOSI
UART_RXD
C10
A9
VDDA12
VSSA12
B11
C11
RSTIN_N
E15
GPIO0
GPIO1
GPIO2
GPIO3
GPIO4
MGPIO5
MGPIO6
MGPIO7
MGPIO8
MGPIO9
MGPIO10
R13
T14
P12
D12
D11
D7
B7
C7
D6
B6
C6
I2C_SDA0
I2C_SCL0
D8
C8
A8
D9
B8
SPI_CS_OUT0
SPI_SCK
SPI_MISO
SPI_CS_IN
SPI_MOSI
R10
P10
P11
R11
UART_RXD
UART_TXD
MUART_CTS_N
MUART_RTS_N
UL
J2
JTAG-LPC3154-TRSTY
JTAG-LPC3154-TDIY
JTAG-LPC3154-TMSY
JTAG-LPC3154-TCKY
JTAG-LPC3154-TDOY
N_RESET-INY
1
3
5
7
9
11
13
15
17
19
2
4
6
8
10
12
14
16
18
Y1
12MHz
Placed on breakout section of pcb
VIO_3V3
C30
100n
USB_VSSA_REF
USB_VSSA_TERM
USB_GNDA
VCC
RESET#
GND
R15
N-RESET-IN
GND
GND
N-RESET-IN
C31
18p
C32
18p
TP_RST
GND
SPI-FLASH
GND
Starpoint at ball C11 on U1
VIO_3V3
LED
GPIO5_SWD_TX
GPIO6_CLOCK
GPIO7_TMS
GPIO8_RESET_IN
GPIO9_RESET_OUT
GPIO10_RESET_CNTRL
GND
Q2
BSH111
GND
C34
N-RESET-IN
U3
AT45DB321D-SU
SPI_MOSI
SPI_MISO
SPI_SCK
SPI_CS_OUT0
Not mounted
VIO_3V3
VIO_3V3
GPIO2_BOOT2
GPIO0_BOOT0
GPIO1_BOOT1
GPIO2_BOOT2
GPIO3_JTAG_SWD
R48
GND GND GND
FFAST_IN
FFAST_OUT
A10
B10
JTAG-LPC3154-TRST
JTAG-LPC3154-TDI
JTAG-LPC3154-TMS
JTAG-LPC3154-TCK
JTAG-LPC3154-TDO
JTAG-LPC3154-DBGEN
0R
0R
0R
0R
0R
0R
0R
VDIG_1V2
R22
100n
TRST_N
TDI
TMS
TCK
TDO
JTAGSEL_ARM
U11
T10
U9
U12
F14
U10
12K
C29
3u3
R18
1M
1M
R20
R19
LINE2
VCC
C28
C33
1M
R21
LINE1
0R
GND
UL
U1-2
LPC3154
BLM15HG601SN1D 100R
USB-DM
USB-DP
R40
R41
R42
R43
R44
R45
R47
4K7
GND
15K
220p
R52
1n
15K
R51
10u
45 ohm impedance routing, 90 ohm differential
No tracks within 10 times trace width
No via's and no sharp angles
10n/500V
U2
STM1816R
3
2
1
15K
R50
C27
15K
R49
C26
LED1 2K
RED
C25
GND
GND
D4
BAT54C
GND GND GND
USB 2.0 OTG Interface
1
2
3
4
5
GND
GND
4K7
3n3
LPC3154-JTAG
VIO_3V3Y
GNDY
4K7
R11
C24
10u
R39 0R
R46 0R
VIO_3V3
GPIO0_BOOT0
GPIO1_BOOT1
GPIO2_BOOT2
R10
C23
15K
R9
39n
GND
UL
R14
GND
R12
GND
UL
R8
100n
R7
10u
VIO_3V3
C22
15K
C21
15K
R13
C20
1
8
2
4
SI
SO
SCK
CS#
VCC
RESET#
WP#
GND
10n
6
3
5
7
GND
GND
1
SWD/JTAG Interface
GPIO5_SWD_TX
SPI_MOSI
SWDIO input cntrl
SWDIO input
GPIO3_JTAG_SWD
SPI_MISO
2
11
GPIO3_JTAG_SWD
GPIO7_TMS
U6D
74LVC125APW
12
1
TMS output cntrl
TMS output
U4A
74LVC125APW
3
13
SWDIO/TMS output cntrl
SWDIO/TMS output
2
J4
U5A
74LVC126APW
R23
3
VIO_3V3
4
100R
SWCLK/TCK output cntrl
SWCLK/TCK output
GPIO6_CLOCK
SPI_SCK
5
1
3
5
7
9
11
13
15
C48
U4B
74LVC125APW
4u7
R24
6
GND
2
4
6
8
10
12
14
16
J4 not mounted, but
can be if bridge wires
below are cut.
C49
10n
GND
R25
5
GND
SWV input
10
100R
JTAG_TCLK_SWCLK
JTAG_TDO_SWO
JTAG_TDI
8
UART_RXD
U6C
74LVC125APW
JTAG_TMS_SWDIO
9
JTAG_RESET
10
JTAG_RTCK
TDI output cntrl
TDI output
GPIO3_JTAG_SWD
SPI_MOSI
9
U5C
74LVC126APW
EXT_POW
R66
0R
R65
0R
R64
0R
R63
0R
R62
0R
R61
0R
R60
0R
R59
0R
R26
8
GPIO10_RESET_CNTRL
GPIO9_RESET_OUT
12
U4D
74LVC125APW
11
2
4
6
8
10
14
VCC
14
U6P U4P U5P
GND
13
RESET output cntrl
RESET output
J5
1
3
5
7
9
VCC
UL
100R
GND
GPIO8_RESET_IN
4
GND GND GND
I2S_DATA_RX
GND
6
GND
U6B
74LVC125APW
R30
5
RTCK input
GND
10
13
100R
12
U5D
74LVC126APW
11
9
GND
JTAG_TMS_SWDIOX
JTAG_TCLK_SWCLKX
JTAG_TDO_SWOX
JTAG_TDIX
JTAG_RESETX
EXT_POWX
GNDX
0R
R29
R28
2
7
RESET input
3
7
1
R27
GND
VIO_3V3X
Bridge wires can be cut on pcb
by removing solder paste.
GND
100R
U6A
74LVC125APW
14
6
VCC
GPIO3_JTAG_SWD
SPI_MISO
GND
TDO input cntrl
TDO input
D6
PMEG1020EA
VIO_3V3
7
4
100R
U5B
74LVC126APW
U4C
74LVC125APW
8
J5 can connect to external SWD/JTAG
interface if LPCXpresso target
side (LPC1347) is disconnected.
C35
C36
100n
10n
GND
GND
LPC1347 Target Side
From LPC-LINK Side
LPC1347_3V3
JTAG_TMS_SWDIOX
JTAG_TCLK_SWCLKX
JTAG_TDO_SWOX
JTAG_RESETX
R31
12K
R36
0R
R35
0R
R33
0R
R32
0R
EXT_POWX
GND
GNDX
U7
LPC1347
2
8
LPC1347_3V3
J7
C39
C40
100n
10n
GNDX
36
37
43
48
2
13
26
38
18
21
1
11
12
24
31
25
PIO1_13
PIO1_14
PIO1_15
PIO1_16
PIO1_19
PIO1_20
PIO1_21
PIO1_22
PIO1_23
PIO1_24
PIO1_25
PIO1_26
PIO1_27
PIO1_28
PIO1_29
PIO1_31
GNDX
44
C41
C42
100n
10n
GNDX
PIO1_13/DTR/CT16B0_MAT0/TXD
PIO1_14/DSR/CT16B0_MAT1/RXD
PIO1_15/DCD/CT16B0_MAT2/SCK1
PIO1_16/RI/CT16B0_CAP0
PIO1_19/DTR/SSEL1
PIO1_20/DSR/SCK1
PIO1_21/DCD/MISO1
PIO1_22/RI/MOSI1
PIO1_23/CT16B1_MAT1/SSEL1
PIO1_24/CT32B0_MAT0
PIO1_25/CT32B0_MAT1
PIO1_26/CT32B0_MAT2/RXD
PIO1_27/CT32B0_MAT3/TXD
PIO1_28/CT32B0_CAP0/SCLK
PIO1_29/SCK0/CT32B0_CAP1
PIO1_31
VDD
GNDX
5
41
VSS
VSS
GNDX
Q3
BC857BSMD
R57
PIO0_6
3k
SJ1 - short to power LPCXpresso board from target side USB VBUS (J8).
SJ1 - must be open when LPCXpresso Base board is used.
EXT_POWX 1
2
SJ1
PIO0_3
R54
1.5k
VIO_3V3X 1
33R
33R
R55
R38
R37
USB-DPX
USB-DMX
LPC1347_3V3
24k
GNDX
R56
GNDX
LED
2K
C38
18pF
PIO0_0
PIO0_1
PIO0_2
PIO0_3
PIO0_4
PIO0_5
PIO0_6
PIO0_7
PIO0_8
PIO0_9
PIO0_10
PIO0_11
PIO0_12
PIO0_13
PIO0_14
PIO0_15
PIO0_16
PIO0_17
PIO0_18
PIO0_19
PIO0_20
PIO0_21
PIO0_22
PIO0_23
R34
C37
18pF
3
4
10
14
15
16
22
23
27
28
29
32
33
34
35
39
40
45
46
47
9
17
30
42
LED2
RED
6
7
Y2 12MHz
RESET/PIO0_0
PIO0_1/CLKOUT/CT32B0_MAT2/USB_FTOGGLE
PIO0_2/SSEL0/CT16B0_CAP0
PIO0_3/USB_VBUS
PIO0_4/SCL
PIO0_5/SDA
PIO0_6/USB_CONNECT/SCK0
XTALIN
PIO0_7/CTS
XTALOUT
PIO0_8/MISO0/CT16B0_MAT0
PIO0_9/MOSI0/CT16B0_MAT1/SWO
SWCLK/PIO0_10/SCK0/CT16B0_MAT2
TDI/PIO0_11/AD0/CT32B0_MAT3
TMS/PIO0_12/AD1/CT32B1_CAP0
TDO/PIO0_13/AD2/CT32B1_MAT0
TRST/PIO0_14/AD3/CT32B1_MAT1
SWDIO/PIO0_15/AD4/CT32B1_MAT2
PIO0_16/AD5/CT32B1_MAT3/WAKEUP
PIO0_17/RTS/CT32B0_CAP0/SCLK
USB_DP
PIO0_18/RXD/CT32B0_MAT0
USB_DM
PIO0_19/TXD/CT32B0_MAT1
PIO0_20/CT16B1_CAP0
PIO0_21/CT16B1_MAT0/MOSI1
PIO0_22/AD6/CT16B1_MAT1/MISO1
VDD
PIO0_23/AD7
USB_VBUSX
100R
1
2
3
4
5
C43
10n
C44
GNDX
1M
R58
GNDX
10n/500V
LPC-LINK side
Expansion Connector
(superset of mbed pinning)
mbed
LPCXpresso
GND
GND
GNDX
J6-1
J6-28
VIN (4.5-5.5V)
EXT_POWX
J6-2
J6-29
VOUT (+3.3V out) if self
powered, else +3.3V input
not used
VOUT (3.3V out)
VIN (4.5-14V)
VB (battery supply)
not used
J6-3
J6-30
not used
IF+
nR (reset)
PIO0_0
RESET
PIO0_0
J6-4
J6-31
not used
IF-
SPI1-MOSI
PIO0_9
MOSI0/SWO
PIO0_9
J6-5
J6-32
not used
RD- (Ethernet)
SPI1-MISO
PIO0_8
MISO0
PIO0_8
J6-6
J6-33
not used
RD+ (Ethernet)
SPI1-SCK
PIO1_29
SCK0
PIO1_29
J6-7
J6-34
not used
TD- (Ethernet)
GPIO
PIO0_2
SSEL0
PIO0_2
J6-8
J6-35
not used
TD+ (Ethernet)
UART1-TX / I2C1-SDA
PIO0_19
TXD
PIO0_19
J6-9
J6-36
USB-DMX
USB-DM
D- (USB)
UART1-RX / I2C1-SCL
PIO0_18
RXD
PIO0_18
J6-10
J6-37
USB-DPX
USB-DP
D+ (USB)
SPI2-MOSI
PIO0_7
PIO0_7
J6-11
J6-38
PIO0_1
PIO0_1
SPI2-MISO
PIO1_19
PIO1_19
J6-12
J6-39
PIO0_3
PIO0_3
USB-VBUS
CAN-TD
SPI2-SCL / UART2-TX
PIO1_20
PIO1_20
J6-13
J6-40
PIO0_5
PIO0_5
I2C-SDA
UART3-TX / I2C2-SDA
UART2-RX
PIO1_21
PIO1_21
J6-14
J6-41
PIO0_4
PIO0_4
I2C-SCL
UART3-RX / I2C2-SCL
AIN0
PIO0_11
AD0
PIO0_11
J6-15
J6-42
PIO0_21
PIO0_21
MAT=PWM
PWMOUT0
AIN1
PIO0_12
AD1
PIO0_12
J6-16
J6-43
PIO0_22
PIO0_22
MAT=PWM
PWMOUT1
AIN2
PIO0_13
AD2
PIO0_13
J6-17
J6-44
PIO0_23
PIO0_23
PWMOUT2
AIN3 / AOUT
PIO0_14
AD3
PIO0_14
J6-18
J6-45
PIO1_22
PIO1_22
PWMOUT3
AIN4
PIO0_15
AD4/SWDIO
PIO0_15
J6-19
J6-46
PIO1_23
PIO1_23
PWMOUT4
AIN5
PIO0_16
AD5
PIO0_16
J6-20
J6-47
PIO1_24
PIO1_24
PWMOUT5
PIO0_17
PIO0_17
J6-21
J6-48
PIO1_25
PIO1_25
PIO0_20
PIO0_20
J6-22
J6-49
PIO1_26
PIO1_26
PIO0_6 USB_SOFT_CONN
PIO0_6
J6-23
J6-50
PIO1_27
PIO1_27
PIO0_10
PIO0_10
J6-24
J6-51
PIO1_28
PIO1_28
PIO1_13
PIO1_13
J6-25
J6-52
PIO1_31
PIO1_31
PIO1_14
PIO1_14
J6-26
J6-53
PIO1_16
PIO1_16
PIO1_15
PIO1_15
J6-27
J6-54
GNDX
SWCLK
LPCXpresso mbed
Dual row holes (2x27), 100 mil spacing
GNDX
PAD1
PAD2
PAD3
VIO_3V3X
PAD8
PAD9
PAD10
PAD15
PAD16
PAD17
GNDX
PAD22
PAD23
PAD24
PAD29
PAD30
PAD31
PAD36
PAD37
PAD38
VIO_3V3X
GND
VU (5.0V USB out)
CAN-RD
很抱歉,暂时无法提供与“EA-XPR-011”相匹配的价格&库存,您可以联系我们找货
