Arduino Motor Shield
The Arduino Motor Shield is based on the L298 (datasheet), which is a dual full-bridge
driver designed to drive inductive loads such as relays, solenoids, DC and stepping motors. It
lets you drive two DC motors with your Arduino board, controlling the speed and direction of
each one independently. You can also measure the current absorption of each motor, among
other features. The shield is TinkerKit compatible, which means you can quickly create
projects by plugging TinkerKit modules to the board.
This shield have two separate channels, called A and B, that each use 4 of the Arduino pins
to choose the rotation direction, vary the speed, fast brake or sense the current that is
flowing through the motor. In total there are 8 pins in use on this shield. You can use each
channel separately to drive two DC motors or combine them to drive one bipolar stepper
motor. The shield can supply 2 amperes per channel, for a total of 4 amperes maximum.
This shield has the 1.0 standard pinout that consist in 4 additional pins: 2 of them placed near
the AREF pin, that are used for TWI communication, and the other 2 are placed near the
RESET pin. The IOREF pin is used to adapt the shield to the board on which is mounted. The
last one is not connected and is reserved for future uses.
Technical Specifications
Operating Voltage
5V to 12V
Motor controller
L298P, Drives 2 DC motors or 1 stepper motor
Max current
2A per channel or 4A max (with external power supply)
Current sensing
1.65V/A
Free running stop and brake function
很抱歉,暂时无法提供与“A000079”相匹配的价格&库存,您可以联系我们找货
