SparkFun XBee Shield - WRL-12847 - SparkFun Electronics
Page 1 of 1
images are CC BY-NC-SA 3.0
Description: Xbee radios are an awesome way to add wireless capability to your
Arduino project and now it’s even easier with the SparkFun XBee Shield. The shield
form-factor mates directly with any dev board that has an Arduino standard footprint
and equips it with wireless communication capabilities using the popular XBee
module. This unit works with all XBee modules including the Series 1 and 2, standard
and Pro versions.
The serial pins (DIN and DOUT) of the XBee are connected through an SPDT switch,
which allows you to select a connection to either the UART pins (D0, D1) or any
digital pins on the Arduino (D2 and D3 default). Power is taken from the 5V pin of the
Arduino and regulated on-board to 3.3VDC before being supplied to the XBee. The
shield also takes care of level shifting on the DIN and DOUT pins of the XBee. In the
latest revision the diode level shifter is replaced with a more robust MOSFET level
shifter.
The board also includes LEDs to indicate power and activity on DIN, DOUT, RSSI,
and DIO5 pins of the XBee. The Arduino’s reset button is brought out on the shield,
and a 9x11 grid of 0.1" holes are available for prototyping. The shield does not come
with headers installed; we recommend the Arduino Stackable Header Kit. The XBee
module is also not included.
Features:
• Mounts directly onto your Arduino
• DIN and DOUT pins of XBee can be connected to either the UART pins or any
digital pin on the Arduino (D2 and D3 default)
• 3.3V power regulation and MOSFET level shifting on-board
• 9x11 grid of 0.1" spaced prototyping holes
• Reset button brought out to shield
• Power, DIN, DOUT, RSSI and DIO5 indicator LEDs
https://www.sparkfun.com/products/12847
4/16/2015
很抱歉,暂时无法提供与“WRL-12847”相匹配的价格&库存,您可以联系我们找货
