DEV-12761
DEV-12761
    SPARKFUNELECTRONICS
    Micro SD Connectivity Arduino Platform Evaluation Expansion Board
DEV-12761 数据手册
 SparkFun microSD Shield DE V-12 761 RO HS         4  images are CC BY-NC-SA 3.0 Description: Running out of memory space in your Arduino project? The SparkFun microSD Shield equips your Arduino with mass-storage capability, so you can use it for data-logging or other related projects. Communication with microSD cards is achieved over an SPI interface. The SCK, DI, and DO pins of the microSD socket are broken out to the ATmega168/328’s standard SPI pins (digital 11-13), while the CS pin is broken out to Arduino’s D8 pin. If you decide to use one of the many open source FAT libraries (like FAT16 or SDFat) make sure to change the code to reflect the location of the CS pin. Most libraries assume the CS pin is connected to D10; this will have to be changed to D8. Also for the libraries to work pin D8 will have to be set as an output in the ‘setup()’ section of your sketch. The shield also includes a large prototyping area with a 13x12 grid of 0.1" pitch PTHs. This shield comes populated with a microSD socket, red power indicator LED, and a reset button; but it does not come with headers installed. We recommend the Arduino R3 Stackable Header Kit. https://www.sparkfun.com/products/12761 12/1/2015
DEV-12761 价格&库存
很抱歉,暂时无法提供与“DEV-12761”相匹配的价格&库存,您可以联系我们找货
