A000004
A000004
    ARDUINO
    KIT ARDUINO MINI LIGHT
A000004 数据手册
          A R D U I N O   U S B   H O ST   S H I E L D   Code: A000004    The Arduino USB Host Shield allows you to connect an USB device to  your Arduino.    The Arduino USB Host Shield allows you to connect a USB device to your Arduino  board. The Arduino USB Host Shield is based on the MAX3421E (datasheet), which  is a USB peripheral/host controller containing the digital logic and analog circuitry  necessary to implement a full‐speed USB peripheral or a full‐/low‐speed host  compliant to USB specification rev 2.0. The shield isTinkerKit compatible, which  means you can quickly create projects by plugging TinkerKit modules onto the  board.  The following device classes are supported by the shield:  HID devices: keyboards, mice, joysticks, etc.        Game controllers: Sony PS3, Nintendo Wii, Xbox360.  USB to serial converters: FTDI, PL‐2303, ACM, as well as certain cell phones and  GPS receivers.  ADK‐capable Android phones and tables.  Digital cameras: Canon EOS, Powershot, Nikon DSLRs and P&S, as well as generic  PTP.  Mass storage devices: USB sticks, memory card readers, external hard drives, etc.  Bluetooth dongles.    For information on using the board with the Android OS, see:    ‐ Google's ADK documentation.   http://developer.android.com/guide/topics/usb/adk.html   ‐ Arduino's ADK documentation.  http://arduino.cc/en/Reference/AndroidAccessory    Arduino communicates with the MAX3421E using the SPI bus (through the ICSP  header). This is on digital pins 10, 11, 12, and 13 on the Uno and pins 10, 50, 51,  and 52 on the Mega. On both boards, pin 10 is used to select the MAX3421E. Pins  7, 8 and 9 are used for GPX, INT and RES pins.    TECH SPECS  Operating  5V  Voltage  USB Controller  MAX3421E  500mA when Arduino is powered by a suitable power supply  Max Current  connected to the Arduino power jack  Max Current  400mA when Arduino is powered by its USB port     OSH: Schematics  Arduino USB Host Shield is open‐source hardware! You can build your own board  using the following files:    EAGLE FILES IN .ZIP     https://www.arduino.cc/en/uploads/Main/USBHostShield‐Rev2.zip  SCHEMATICS IN .PDF    https://www.arduino.cc/en/uploads/Main/USBHostShield‐Rev2.pdf  Arduino Library  The Arduino USB Host Shield can be used with the "USB Host Library for Arduino"  hosted by Oleg Mazurov and Alexei Glushchenko from circuits@home, Kristian  Lauszus and Andrew Kroll onGitHub (download).  https://github.com/felis/USB_Host_Shield_2.0/archive/master.zip  Tutorials      With an Arduino HSB Host Shield you can even control an RC car using an XBOX  wireless game controller. Many tutorials are available online, here you can find  some tutorial developed bycircuits@home.  Bluetooth HID devices;  PS4 controller;  Adding a display to a digital scale using Arduino and USB Host shield;  Mass Storage;  Power  The Arduino USB Host Shield has no power jack and is powered only when attached  to an Arduino board.  Input & Output     This shield has a MALE USB port where you can attach your USB device. The shield  features several TinkerKit input/output and communication interfaces.  Connecting TinkerKit modules can simplify the creation of a project or a prototype.  The on‐board connectors are :  2 TinkerKit Inputs: IN2 and IN3 (in white), these connectors are routed to the  Arduino A2 and A3 analog input pins.  2 TinkerKit Outputs: OUT5 and OUT6 (in orange), these connectors are routed to  the Arduino PWM outputs on pins 5 and 6.  2 TinkerKit TWI: these connectors (4‐pin in white) are routed on the Arduino TWI  interface. Both connect to the same TWI interface to allow you to create a chain of  TWI devices.  Physical Characteristics  The maximum length and width of the Motor Shield PCB are 2.7 and 2.1 inches  respectively. Four screw holes allow the board to be attached to a surface or case.  Note that the distance between digital pins 7 and 8 is 160 mil (0.16"), not an even  multiple of the 100 mil spacing of the other pins.        https://store.arduino.cc/usa/arduino‐usb‐host‐shield 12‐7‐17
A000004 价格&库存
很抱歉,暂时无法提供与“A000004”相匹配的价格&库存,您可以联系我们找货
