PROTO-SHIELD
PROTO-SHIELD
    OLIMEX
    ARDUINIO PROTOTYPING BOARD
PROTO-SHIELD 数据手册
PROTO-SHIELD development board Users Manual All boards produced by Olimex are ROHS compliant Revision Initial, June 2011 Copyright(c) 2011, OLIMEX Ltd, All rights reserved Page 1 INTRODUCTION: PROTO-SHIELD is prototype board compatible with all of Olimex's ARDUINO compatible boards – like OLIMEXINO-328, OLIMEXINO-STM32 and PIC32-PINGUINO. The board comes without mounted connectors on it, but it is shipped with one 6x1 connector and three 8x1 connectors, which can be mounted by the customer. The prototype area gives user the opportunity to solder different extensions for ARDUINO compatible boards. All this allows you to build a diversity of applications. BOARD FEATURES: • one 6x1 connector – not mounted • three 8x1 connectors – not mounted • two status leds • two user buttons • prototype area • FR-4, 1.5 mm, soldermask, component print • Dimensions: 68.58 x 53.34mm (2.71 x 2.11") ELECTROSTATIC WARNING: The PROTO-SHIELD board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: Hardware: The board can be used with any of our ARDUINO compatible boards: OLIMEXINO-328, OLIMEXINO-STM32, PIC32-PINGUINO, PIC32PINGUINO-OTG. Page 2 2 1 L1_E 1 L2_E C301 C302 C303 C304 C305 C306 C307 C308 C309 C310 C311 C312 C313 C314 C315 C201 C202 C203 C204 C205 C206 C207 C208 C209 C210 C211 C212 C213 C214 C215 1B 2B 3B 4B 5B 6B 7B 8B 9B 10B 11B 12B 13B 14B 15B GREEN Page 3 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 C330 C329 C328 C327 C326 C325 C324 C323 C322 C321 C320 C319 C318 C317 C316 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 C230 C229 C228 C227 C226 C225 C224 C223 C222 C221 C220 C219 C218 C217 C216 PROTOSHIELD_0.65MM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 CON-B PROTOSHIELD_1.27MM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 CON-A 30B 29B 28B 27B 26B 25B 24B 23B 22B 21B 20B 19B 18B 17B 16B 30A 29A 28A 27A 26A 25A 24A 23A 22A 21A 20A 19A 18A 17A 16A R5 330R 2 C3 100nF B2_E C5 C1 C2 +5V D8 D9 D10 D11 D12 D13 GND_3 AREF http://www.olimex.com/dev COPYRIGHT(C) 2011, OLIMEX Ltd. Rev.A PROTO-SHIELD D8 D9(LED2) D10(#SS) D11(MOSI) D12(MISO) D13(SCK/LED1) GND AREF D0 D1 D2 D3 D4 D5 D6 D7 A6 A6 A7 A7 RESET 3V3 +5V GND_1 GND_2 VIN D0(RXD) D1(TXD) D2 LED1 LED2 D5 BUT1 BUT2 P3 P6 A0 A1 A2 A3 A4 A5 RESET A0 A1 A2 A3 A4(SDA) A5(SCL) VIN 3V3 D8 D9 D10 D11 D12 D13 GND AREF D0 D1 D2 D3 D4 D5 D6 D7 A0 A1 A2 A3 A4 A5 RST 3V3 5V GND GND VIN DIGITAL 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 C4 100nF BUT2 1 BUT1 1 BUT2 3V3 3V3 ANALOG 1A 2A 3A 4A 5A 6A 7A 8A 9A 10A 11A 12A 13A 14A 15A LED2 R6 330R T1107A(6x3.8x2.5mm) RED BUT1 2 B1_E R1 4.7k B2 100nF R4 330R 2 LED2 R2 4.7k B1 POWER LED1 LED1 L2 3V3 100nF R3 330R L1 3V3 SCHEMATIC: ARDUINO: SH PLATFORM DIGITAL 2.2uF/16V T1107A(6x3.8x2.5mm) BOARD LAYOUT: POWER SUPPLY CIRCUIT: PROTO-SHIELD is power supplied via POWER connector from the ARDUINO compatible board with which is used. JUMPER DESCRIPTION: L1_E This jumper, when closed, LED1 is connected to D3 line. This jumper, when opened, LED1 is connected to L1 pad. Default state is closed. L2_E This jumper, when closed, LED2 is connected to D4 line. This jumper, when opened, LED2 is connected to L2 pad. Default state is closed. B1_E This jumper, when closed, BUT1 is connected to D6 line. This jumper, when opened, BUT1 is connected to B1 pad. Default state is closed. Page 4 B2_E This jumper, when closed, BUT2 is connected to D7 line. This jumper, when opened, BUT2 is connected to B2 pad Default state is closed. INPUT/OUTPUT: Status Led with name LED1 (red) connected via jumper L1_E to DIGITAL connector pin D3 – signal LED1. Status Led with name LED2 (green) connected via jumper L2_E to DIGITAL connector pin D4 – signal LED2. User button with name BUT1 connected via jumper B1_E to DIGITAL connector pin D6 – signal BUT1. User button with name BUT2 connected via jumper B2_E to DIGITAL connector pin D7 – signal BUT2. EXTERNAL CONNECTORS DESCRIPTION: POWER: Pin # Signal Name 1 A6 2 A7 3 RESET 4 VCC 5 +5V 6 GND 7 GND 8 +24V (VIN) Note: This connector is not mounted on the board. Page 5 ANALOG: Pin # Signal Name 1 A0 2 A1 3 A2 4 A3 5 A4(SDA) 6 A5(SCL) Note: This connector is not mounted on the board. DIGITAL: Pin # Signal Name 1 D0(RXD) 2 D1(TXD) 3 D2 4 LED1 5 LED2 6 D5 7 BUT1 8 BUT2 Note: This connector is not mounted on the board. Page 6 DIGITAL: Pin # Signal Name 1 D8 2 D9(LED2) 3 D10(#SS) 4 D11(MOSI) 5 D12(MISO) 6 D13(SCK/LED1) 7 GND 8 AREF Note: This connector is not mounted on the board. CON-A: Note: This footprint can be used for mounting of SMD IC with 1.27mm pitch. Each of SMD pads is routed to True Hole pad. SMD Pin # True Hole pin # SMD Pin # True Hole pin # 1 1A 2 2A 3 3A 4 4A 5 5A 6 6A 7 7A 8 8A 9 9A 10 10A 11 11A 12 12A 13 13A 14 14A 15 15A 16 16A 17 17A 18 18A 19 19A 20 20A 21 21A 22 22A 23 23A 24 24A 25 25A 26 26A 27 27A 28 28A 29 29A 30 30A Page 7 CON-B: Note: This footprint can be used for mounting of SMD IC with 0.65mm pitch. Each of SMD pads is routed to True Hole pad. SMD Pin # True Hole pin # SMD Pin # True Hole pin # 1 1B 2 2B 3 3B 4 4B 5 5B 6 6B 7 7B 8 8B 9 9B 10 10B 11 11B 12 12B 13 13B 14 14B 15 15B 16 16B 17 17B 18 18B 19 19B 20 20B 21 21B 22 22B 23 23B 24 24B 25 25B 26 26B 27 27B 28 28B 29 29B 30 30B Page 8 MECHANICAL DIMENSIONS: Page 9 ORDER CODE: PROTO-SHIELD - assembled and tested board How to order? You can order to us directly or by any of our distributors. Check our web www.olimex.com/dev for more info. Revision history: Board's revision Rev. A, May 2011 Manual's revision Rev. Initial, June 2011 Page 10 Disclaimer: © 2011 Olimex Ltd. All rights reserved. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other terms and product names may be trademarks of others. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. Neither the whole nor any part of the information contained in or the product described in this document may be adapted or reproduced in any material from except with the prior written permission of the copyright holder. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. Page 11
PROTO-SHIELD 价格&库存
很抱歉,暂时无法提供与“PROTO-SHIELD”相匹配的价格&库存,您可以联系我们找货
PROTO-SHIELD
    • 1+151.83024
