HighTemperatureSensor SKU:SEN0198
Contents
1 Introduction
2 Specification
o 2.1 Module
o 2.2 PT100 Probe
3 Board Overview
4 Tutorial
o 4.1 Requirements
o 4.2 Connection Diagram
o 4.3 Sample Code
o 4.4 RESUALT
5 FAQ
Introduction
What do you do when you want to measure the temperature?Most of people may be think of
DS18B20 temperature sensor first.But DS18B20 can only measure the temperature within 125
degrees. After more than 125 degrees, you need to use other sensors.In order to measure the high
temperature above 100 degrees,So we choose the PT100 resistance type high temperature probe
which is industry commonly used as our sensor probe.Through our high temperature module,We
can achieve 30-350 degree range of temperature detection.Our modules are compatible with the
input voltage of 3.3V-5.5V, so ARDUINO and STM32 and other MCU are able to use our
modules.
Specification
Module
Working voltage: 3.3V‐5.5V
Analog output voltage: 0.2V‐2.8V
Working temperature range: 30‐350 Centigrade
Relative Error: ±2% F.S.
Interface: PH2.0‐3P
Size: 42mm * 32mm * 18mm
not waterproof
PT100 Probe
Probe working temperature: ‐20 ‐ 400 Centigrade
The highest temperature of the skin: 200 Centigrade
Length: 2m
Precision: 0.5 Centigrade
Waterproof
Board Overview
LABEL
NAME
Function Description
1
PT100‐
PT100‐
2
PT100‐
PT100‐
3
PT100+
PT100+
4
Signal Output
Signal Output
5
VCC
Power Input +(3.3V‐5.5V)
6
GND
GND
Tutorial
This tutorial will describe you how to use the high temperature sensor module and PT100.
Requirements
Hardware
o UNO x1
o PT100 x1
o high temperature sensor module x1
o PH2.0‐3P cable x1
Software
o Arduino IDE V1.6.5 Click to Download Arduino IDE from Arduino®
o HighTemperatureSensor libraries About Library installation.
Connection Diagram
Sample Code
Before downloading the program, you must know the reference voltage of the
analog port.If your board supply voltage is 3.3V, then you need change voltageRef
which is in sample code from 5.000 rto 3.300,If your board supply voltage is
5.0V,then set voltageRef to 5.000。If you want a higher precision,Then you need
to measure the voltage of the IOREF port and set that voltage to as voltageRef .
This example reads HighTemperature Sensor.
Created 2016-1-13
By berinie Chen
GNU Lesser General Public License.
See for details.
All above must be included in any redistribution
/***********Notice and Trouble shooting***************
1.Connection and Diagram can be found here https://www.dfrobot.com/wiki/in
dex.php?title=HighTemperatureSensor_SKU:SEN0198
2.This code is tested on Arduino Uno.
#include
const float voltageRef = 5.000; //Set reference voltage,you need test your I
OREF voltage.
//const float voltageRef = 3.300;
int HighTemperaturePin = A0;
//Setting pin
DFRobotHighTemperature PT100 = DFRobotHighTemperature(voltageRef); //Define
an PT100 object
void setup(void) {
Serial.begin(9600);
void loop(void) {
int temperature = PT100.readTemperature(HighTemperaturePin);
ature
Serial.print("temperature:
//Get temper
Serial.print(temperature);
Serial.println("
^C");
delay(1000); //just here to slow down the output so it is easier to read
RESUALT
FAQ
There are no questions about this product yet. If you have any problems or suggestions, you are
welcome to email us or post on the DFRobot forum!
For any questions/advice/cool ideas to share, please visit the DFRobot Forum or email
techsupport@dfrobot.com
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0198”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 8+157.508898+19.02883
