DEV-14150
DEV-14150
    SPARKFUNELECTRONICS
    RELAYPLATEPI-PLATE
DEV-14150 数据手册
                                              RELAYplate DEV-14150 RoHS Description: The RELAYplate from Pi‐Plates is the first dedicated relay board for the Raspberry Pi  designed to meet the safety requirements of UL 60950 while being capable of switching 120 volts AC.  Each of the seven relays is UL rated to switch 1 amp at 120volts AC or 30 volts DC. And, like all Pi‐Plates,  you can stack these boards to increase your relay count to 56 using eight plates. The RELAYplate board is  compatible with the DAQCplate and MOTORplate, allowing you to create the perfect stack of boards to  control your project.  Pi-Plates are a family of stackable and interchangeable add-on circuit boards that allow you to interact with the outside world using your Raspberry Pi. Every Pi-Plate is designed to provide a robust set of features at minimal cost while using the fewest pins possible on the RPi header. PiPlates are mechanically and electrically compatible with all revisions of the Raspberry Pi with 40 pin headers (including the Pi 3 Model B and Pi Zero) and are designed to satisfy the needs of hobbyists, experimenters and professionals. Features:           Seven single-pole, single-throw relays Rated at 120 volts AC or 30 volts DC Currents up to 1 amp Convenient screwless terminal blocks Up to eight RELAYplates can be stacked together, providing 56 relays A single RELAYplate will run from the Raspberry Pi 5VDC supply Auxiliary power connectors provided for stacking multiple RELAYplates Includes programmable LED Seven LED annunciators provide visual relay status Designed to meet the stringent safety requirements of UL standard 60950 https://www.sparkfun.com/products/14150 3/14/2017
DEV-14150 价格&库存
很抱歉,暂时无法提供与“DEV-14150”相匹配的价格&库存,您可以联系我们找货
