2x5W AMP click
PID: MIKROE-2477
2x5W AMP click functions as an amplifier and features the TDA7491LP 2x5-watt dual BTL
class-D audio amplifier. The click is designed to run on either 3.3V or 5V power supply. It
communicates with the target MCU over the following pins on the mikroBUS™ line: AN, RST,
CS, PWM, INT.
2x5W AMP click features a 3.5mm input jack and four output screw terminals for connecting
passive speakers.
Note: In order to achieve full 2x5W output power, keep in mind that you need to supply enough
current to the chip.
This is achievable with the EXT PWR header, but you need to switch over the AMP VCC to the
left position.
Note: a 3.5mm stereo cable and wired passive speakers are not included in the offer.
Class‐D audio amplifier
Class-D audio amplifiers (switching amplifiers) are very energy efficient. They reduce power
losses on the output device by operating as an electronic switch, rather than as linear gain
devices, like in A or AB amplifiers.
These kinds of amplifiers are ideal for compact, high power applications.
TDA7491LP audio amplifier
The amplifier has three operating modes:
Standby mode: all circuits are turned off, very low current consumption. The amplifier uses a
maximum of 10uA in standby mode.
Mute mode: inputs are connected to ground and the positive and negative PWM outputs are at
50% duty cycle.
Play mode: the amplifiers are active.
Simple control
The click does not use a standard serial communication, like I2C or SPI - it's controlled by a few
pins on the mikroBUS™ line. The state of these pins can either be HIGH or LOW (mute, gain,
enable). The operating modes and gain are set with input pins.
Key features
o Class‐D audio amplifier
o 2x5W output power
o Short‐circuit protection
o Thermal overload protection
o Standby and mute features
3.5mm audio jack
Screw terminals for speaker output
Interface: AN, RST, CS, PWM, INT
SPECIFICATION
Product Type
Applications
On-board
modules
Amplifier
Mobile phones, portable sound systems, etc.
TDA7491LP 2x5-watt dual BTL class-D audio amplifier
2x5W output power, short-circuit protection, thermal overload protection,
3.5mm audio jack, screw terminals for passive speakers.
Interface
AN, RST, CS, PWM, INT pins
Power Supply 3.3V or 5V
Compatibility mikroBUS
Click board size L (57.15 x 25.4 mm)
Key Features
Pinout diagram
This table shows how the pinout on 2x5W AMP click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Gain 0 pin GN0 1 AN
PWM 16 MUTE Mute control
Gain 1 pin GN1 2 RST
INT 15 DIA Diagnostic pin
Standby control STB 3
CS
TX 14
NC Not connected
Not connected NC 4 SCK
RX 13
NC Not connected
Not coneected NC 5 MISO SCL 12
NC Not connected
Not connected NC 6 MOSI SDA 11
NC Not connected
Power supply +3.3V 7 3.3V
5V 10 +5V Power supply
Ground GND 8 GND GND 9 GND Ground
Jumpers and settings
Designator Name
JP1
AMP
VCC
Default
Position
Right
Default
Option
5V
Description
AMP power supply, can be 5V or external (5V‐
14V)
LEDs, buttons, connectors and switches
Designator Name Type (LED, BUTTON...)
EXT PWR
EXT PWR Connector
Description
two pin non‐populated headerfor the external Amp supply
Programming
The library has two helper functions for setting the gain and the mode via output pins.
Code snippet
The demo shows how to initialize, set the mode and the gain of the click.
01 void main()
02 {
03
system_init();
04
05
click_2x5W_gain(CLICK_2X5W_AMP_20_DB);
06
click_2x5W_mode(CLICK_2X5W_AMP_MODE_PLAY);
07
08
while( 1 )
09
10
if(Button(&GPIOE_IDR, 11, 100, 1))
11
12
click_2x5W_gain((click_2x5w_amp_gain_t)(++gain % 4));
13
14
15 }
https://shop.mikroe.com/click/audio-and-voice/2x5w-amp 2/24/2017
很抱歉,暂时无法提供与“MIKROE-2477”相匹配的价格&库存,您可以联系我们找货
