3201
    ADAFRUIT
    WASHER FLAT #6 FIBRE
3201 数据手册
Adafruit Ethernet FeatherWing Created by lady ada https://learn.adafruit.com/adafruit-wiz5500-wiznet-ethernet-featherwing Last updated on 2021-11-15 06:45:06 PM EST ©Adafruit Industries Page 1 of 18 Table of Contents Overview 3 Pinouts 5 • Power Pins • SPI Data Pins • Other Breakouts 5 6 7 Assembly 8 • Prepare the header strip: • Add the FeatherWing: • And Solder! 8 8 9 Usage • Install Ethernet Library • Connect Cable • Run Example Code 12 12 13 13 Usage with CircuitPython 15 Power over Ethernet 15 • Passive PoE 16 Downloads 17 • Files & Datasheets • Schematic • Fabrication Print 17 18 18 ©Adafruit Industries Page 2 of 18 Overview Wireless is wonderful, but sometimes you want the strong reliability of a wire. If your Feather board is going to be part of a permanent installation, this Ethernet FeatherWing will let you add quick and easy wired Internet. Just plug in a standard Ethernet cable, and run the Ethernet2 library for cross-platform networking. Ethernet is a tried-and-true networking standard. It's supported by every hub and switch, and because there's a physical connection you don't have to noodle around with SSIDs, passwords, authentication schemes or antennas. It works great with any ©Adafruit Industries Page 3 of 18 of our Feathers, the WIZ5500 chip communicates over SPI plus a single CS pin. The Arduino Ethernet2 library works great, and within a few seconds after connecting, will do the DHCP setup for you. As a nice extra, the RJ-45 jack has both link and activity lights that will light/blink to let you know the current connection status. Each order comes with one assembled and tested FeatherWing, plus some header. You will need to solder in the header yourself but its a quick task. ©Adafruit Industries Page 4 of 18 Pinouts The Ethernet FeatherWing plugs into any Feather and adds hard-wired networking. To make it as cross-platform compatible as possible, we use only SPI plus one extra, configurable pin. It's not going to be gigabit (or even multi-megabit) speeds but it will work! Power Pins The WIZ5500 Ethernet chip (and really any ethernet chip) are fairly high current devices, requring about 150mA whether or not actively transmitting. The chip is powered from the 3.3V and GND pins indicated and does not have an internal regulator. ©Adafruit Industries Page 5 of 18 SPI Data Pins Configuration, setup, and data is received/transmitted over SPI. All Feathers have the default SPI port on the same pins, so we use MOSI/MISO/SCK in this location. They are 3.3V logic, 5V tolerant. A Chip Select pin is also required. By default we use this pin: Which is connected to pin #10 on Feather Teensy 3, 32u4, 328p, M4 and M0, pin #15 on ESP8266, and PB4 on WICED. You can also get to the CS pin from the left group of breakouts. To change CS pin, solder this pad to a different pin and cut this jumper: ©Adafruit Industries Page 6 of 18 Other Breakouts You can also connect to and use the IRQ and WIZ ReSeT pins. These are not used in the library and are there for advanced usage. They are 3.3V logic, 5V tolerant. ©Adafruit Industries Page 7 of 18 Assembly Prepare the header strip:   Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down Add the FeatherWing:   Place the featherwing over the pins so that the short pins poke through the two rows of breakout pads ©Adafruit Industries Page 8 of 18 And Solder!   Be sure to solder all pins for reliable electrical contact. (For tips on soldering, be sure to check out ourGuide to Excellent Soldering (https://adafru.it/aTk)). Start by soldering the first row of header ©Adafruit Industries Page 9 of 18 Now flip around and solder the other row completely ©Adafruit Industries Page 10 of 18 You're done ! Attach an ethernet cable, & plug it into your feather of choice! ©Adafruit Industries Page 11 of 18 Usage The Ethernet chipset we are using (Wiz5500) is well supported and works for all Feathers, all you need is a little library support and you will be sending packets in no time! Install Ethernet Library Start by installing the support library for the Wiz5500. We recommend the Arduino Ethernet library (https://adafru.it/Dx7) Start by downloading the library. You can do that by using the library manager ©Adafruit Industries Page 12 of 18 Make sure you're running at least version 2.0.0 (or higher) We also have a great tutorial on Arduino library installation at: http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https:// adafru.it/aYM) Connect Cable Make sure you have the FeatherWing plugged into your Feather, and an Ethernet cable connected to your hub, router or switch. Run Example Code We recommend opening up the WebClient example ©Adafruit Industries Page 13 of 18 At the top of setup() change this section void setup() { // You can use Ethernet.init(pin) to configure the CS pin //Ethernet.init(10); // Most Arduino shields //Ethernet.init(5); // MKR ETH shield //Ethernet.init(0); // Teensy 2.0 //Ethernet.init(20); // Teensy++ 2.0 //Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet //Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet By uncommenting the line that matches your board: • ESP8266 Feather uses CS pin 15 • ESP32 Feather uses CS pin 33 • WICED Feather uses CS pin PB4 • nRF52832 Feather uses CS pin 11 • Teensy, nRF52840, 32u4, 328p, M0 and M4 Feather uses CS pin 10 Change this line char server[] = "www.google.com"; // name address for Google (using DNS) to char server[] = "wifitest.adafruit.com"; // name address for adafruit (using DNS) and these lines ©Adafruit Industries Page 14 of 18 client.println("GET /search?q=arduino HTTP/1.1"); client.println("Host: www.google.com"); to client.println("GET /testwifi/index.html HTTP/1.1"); client.println("Host: wifitest.adafruit.com"); If you're using a LoRa/RFM69 Feather, make sure to add a pinMode(8, INPUT_PULLUP) to disable the LoRa or RFM69 radio Then open up the serial console of your Feather to see the connection and data: If you don't get an IP address, check you have a green link light, and that your Ethernet is going out to an internet connected router. You may also have to set up the MAC address to allow it access, check with your system admin if you're not sure. Usage with CircuitPython Usage with CircuitPython (https://adafru.it/JEp) Power over Ethernet To keep the FeatherWing small, simple and inexpensive, we do not include PoE support. However, it's a common request that some people want to simplify cabling when the device is far away. This all-in-one solution will let you plug an Ethernet cable to a PoE switch/hub then split into data and a Feather-friendly micro USB connector on the other ©Adafruit Industries Page 15 of 18 PoE Splitter with MicroUSB Plug - Isolated 12W - 5V 2.4 Amp Power over Ethernet (PoE) splitters can make your project wiring a breeze - and best of all they work to connect any 802.3af-capable router to any Ethernet device, even if it... https://www.adafruit.com/product/3785 Passive PoE If you don't even have a PoE hub, here's a solution that doesn't even require a PoE hub: passive PoE injectors! (http://adafru.it/435) Passive PoE Injector Cable Set Simplify your Internet of Things with a passive PoE injector cable. These are quite handy for projects that have Ethernet connectivity and also need a power cable. Of course, you can... https://www.adafruit.com/product/435 These cables don't have any active PoE negotation circuitry, intstead, we just use the extra unused wires in the Cat-5+ wires to carry power and ground. They're a simple and afforable solution. On one end, plug in the Ethernet cable to your router, and a 5V wall adapter into the 2.1mm jack (http://adafru.it/276) ©Adafruit Industries Page 16 of 18 5V 2A (2000mA) switching power supply UL Listed This is an FCC/CE certified and UL listed power supply. Need a lot of 5V power? This switching supply gives a clean regulated 5V output at up to 2000mA. 110 or 240 input, so it works... https://www.adafruit.com/product/276 Then run any standard Ethernet cable to the other end where you will use a 2.1mm to microUSB adapter cable (http://adafru.it/2727) MicroUSB Plug to 5.5/2.1mm DC Barrel Jack Adapter The premise of this MicroUSB Plug to 5.5/2.1mm Jack adapter is simple. There's a MicroUSB plug on one end and a 5.5mm/2.1mm DC barrel jack with center... https://www.adafruit.com/product/2727 And plug that directly into the Feather. For long power runs there might be a slight voltage droop but since the regulator on board will reduce the input voltage to 3.3V for the chip and peripherals (all Feathers are 3.3V logic) it should not be noticable Downloads Files & Datasheets • WIZ5500 Datasheet (https://adafru.it/plD) • EagleCAD PCB files on GitHub (https://adafru.it/plE) • Fritzing object in Adafruit Fritzing repo (https://adafru.it/aP3) ©Adafruit Industries Page 17 of 18 Schematic Click to embiggen Fabrication Print dimensions in inches ©Adafruit Industries Page 18 of 18
很抱歉,暂时无法提供与“3201”相匹配的价格&库存,您可以联系我们找货
