PiTFT Plus 320x240 3.2" TFT + Resistive
Touchscreen - Pi 2 and Model A+ / B+
PRODUCT ID: 2616
DESCRIPTION
Is this not the cutest little display for the Raspberry Pi? It features a 3.2" display
with 320x240 16-bit color pixels and a resistive touch overlay. The plate uses the
high speed SPI interface on the Pi and can use the mini display as a console, X
window port, displaying images or video etc. Best of all it plugs right in on top!
This display is functionally the same as our classic PiTFT 2.8" and PiTFT Plus 2.8" same pins used, same resolution, same drivers, but is just a bit bigger. It also has a
26- pins GPIO pins brought out so you can connect a 26-pin Raspberry Pi GPIO
cable underneath. It's the same outline as a Pi 2/B+ it fits well on top of a Pi in our
Raspberry Pi Enclosure base.
The display and touchscreen uses the hardware SPI pins (SCK, MOSI, MISO, CE0,
CE1) as well as GPIO #25 and #24. All other GPIO are unused. Since we had a tiny
bit of space, there's 4 spots for optional slim tactile switches wired to four GPIOs,
that you can use if you want to make a basic user interface. For example, you can
use one as a power on/off button. See below for the link to get the optional tact
switches, they're not included.
Use it for console access or easily pop up X11 onto the PiTFT for a mini monitor,
although its rather small at 320x240. Instead, we recommend using PyGame or
other SDL-drawing programs to write onto the frame buffer.
Raspberry Pi computer and enclosure not included! This display comes fully
assembled, just plug it onto your Raspberry Pi and install our software to rock out.
Check out our detailed tutorial on how to play videos, display images, and
otherwise customize your PiTFT (the tutorial is identical to the 2.8" PiTFT)
http://www.adafruit.com/products/2616
10/7/2015
Technical Details
Screen Dimensions: 50mm x 71mm / 2" x 2.8"
PCB Dimensions: 56mm x 85mm / 2.2" x 3.3"
Height with socket: 19mm / 0.75"
Weight: 50g
很抱歉,暂时无法提供与“2616”相匹配的价格&库存,您可以联系我们找货
