MIKROE-2516
MIKROE-2516
    MIKRO
    POLLUTIONCLICK
MIKROE-2516 数据手册
Pollution click PID: MIKROE-2516 Weight: 23 g Pollution click has high sensitivity to organic gases such as methanal (also known as formaldehyde), benzene, alcohol, toluene, etc. The click carries the WSP2110 VOC gas sensor with the detection range of 1~50ppm (parts per million). Pollution click is designed to run on a 5V power supply. It communicates with the target MCU over AN and RST pin on the mikroBUS™ line. WSP2110 VOC gas sensor WSP2110 VOC gas sensor is a MOS type (metal oxide semiconductor) sensor that detects volatile organic compounds such as methanal, benzene, alcohol and other types of gases that can be harmful to one’s health in high concentrations. The concentration of the target gas affects the conductivity of the sensor. Higher concentration of the gas means the conductivity of the sensor gets higher as well. For precise calibration, the sensor needs to preheat (once powered up, it takes 120h to reach the right temperature). Sensor’s sensitivity P1 potentiometer onboard is used for trimming the sensor’s sensitivity. Enable the pin drive gate of heaters MOSFET switch to reduce power consumption when the click is not in use. Detection range The detection range of the sensor is 1~50ppm (part per million). Parts per million is the numbers of parts of a component in 1 million parts of the gas mixture, it's the ratio of one gas to another. Volatile organic compounds Volatile organic compounds or VOCs are organic chemicals. They have very high vapor pressure at room temperature, and some of them can be harmful to human health. As most people spend a lot of time indoors it’s important to know if the quality of the air is good. With Pollution click you could always know if your indoor environment is healthy enough. Key features    WSP2110 VOC gas sensor   o Detection range 1~50ppm (parts per milion)  o Sensitivity: Rs(in air)/Rs(in 10ppm toluene)≥3  Interface: AN and RST pin  5V power supply    SPECIFICATION  Product Type Gas Applications Automatic exhaust devices, air cleaners, harmful gas detection devices, etc. On-board modules WSP2110 VOC gas sensor Key Features Detection range 1~50ppm, Sensitivity S Rs(in air)/Rs(in 10ppm toluene)≥3 Key Benefits Interface Power Supply Compatibility Click board size High sensitivity to organic gases AN, RST 5V mikroBUS M (42.9 x 25.4 mm) Pinout diagram This table shows how the pinout on Pollution click corresponds to the pinout on the mikroBUS™ socket (the latter shown in the two middle columns). Notes    Pin  Pin Notes  mikroBUStm  Analog out pin  AN  1  AN  PWM  16 NC Not connected Enable sensor  RST  2  RST  INT  15 NC Not connected Not connected  NC  3  CS  RX  14 NC Not connected Not connected  NC  4  SCK  TX  13 NC Not connected Not connected  NC  5  MISO  SCL  12 NC Not connected Not connected  NC  6  MOSI  SDA  11 NC Not connected Not connected  NC  7  3.3V  5V  10 +5V Power supply  Ground  GND  8  GND  GND  9 GND Ground  Programming The demo first enters in calibration procedure, before measuring pollution. In order to show accurate results, calibration must be done in clean air. Because the sensor has slow response time, it needs time to stabilize and to achieve working temperature. It also measures load resistance, and shows value on the display so the user can set the desired sensitivity. After the calibration is done, the demo enters in the measuring procedure. Calibration procedure:      1) Put the sensor in clean air and adjust the click board potentiometer to max value.  2) Wait for the measured value on the load resistor to stabilize.  3) Press the continue button.  4) Adjust the potentiometer to define the sensitivity.  5) Press the continue button.  Detection range: 1ppm ~ 50ppm (parts per million). Code snippet The function calculates the ppm value from the RS/R0 ratio. Where R0 is resistance in clean air, and RS is resistance in target gas, with different concentration. The constants are extracted from the sensitivity curve, for the sensitivity curve of alcohol given in the sensor datasheet. 01: float ratio_to_ppm(float ratio) 02: { 03: if (0.84 > ratio && ratio >= 0.53) // I segment 04: return pow((ratio/C1), (1/M1)); 05: 06: else if (0.53 > ratio && ratio >= 0.39) // II segment 07: return pow((ratio/C2), (1/M2)); 08: 09: else if (0.39 > ratio && ratio >= 0.1) // III segment 10: return pow((ratio/C3), (1/M3)); 11: 12: else if (ratio < 0.148) 13: return 50.0; 14: 15: return 1.0; 16: } https://shop.mikroe.com/click/sensors/pollution 2/24/2017
MIKROE-2516 价格&库存
很抱歉,暂时无法提供与“MIKROE-2516”相匹配的价格&库存,您可以联系我们找货
MIKROE-2516
    • 1+640.98239
    • 5+615.33734
    库存:5
    MIKROE-2516
      • 1+592.32611
      • 5+568.62775
      库存:5
      MIKROE-2516
        • 1+198.05815
        库存:3
        MIKROE-2516
        • 1+434.32334
        • 5+425.63416
        库存:6
