OLED Switch click
1
OLED Switch click
OLED Switch click
OLED Switch click
IC/Module
NKI Switch ISC15ANP4
Interface
SPI
Power supply
3.3V
Website
Schematic
[1]
www.mikroe.com/click/oled-switch
OLED Switch click schematic
[2]
[3]
If you are building any type of human machine interface, OLED Switch click can help you keep the design simple,
clear and interactive. It can be used in designing a control panel for an industrial machine… or a DIY arcade.
Features and usage notes
Hardware: a full color OLED built in a button
This board has a module that combines a button and a full color organic LED display, plus input/output screw
terminals for connecting external electronics.
The mechanical button itself is nicely built, with a translucent black housing. When pressed, it gives satisfying tactile
feedback.
The display, built in the button itself, can show 64 by 48 pixel images with up to 65k colors (16-bit depth).
With the screw terminals, you can toggle an external circuit on and off.
The display is big enough to display simple information, whether as icons or words. Small characters are legible and
clear.
The most interesting feature is that the display can be programmed to change the picture when needed (for example,
you can design a reprogrammable keypad that would allow users to switch from latin to cyrillic script or to chinese
characters).
VisualTFT can be used to prepare the bmp images. There is a learn.mikroe.com article that explains how to to take
16 or 24 bit bmp pictures and create C arrays.
OLED Switch click
2
The board communicates with the target MCU through the mikroBUS™ SPI interface. It uses a 3.3V power supply
only.
Software: frame buffering
The internal frame buffer on the OLED display holds 96x64 pixels with 2 bytes of 565 formatted color information
for each. When displaying an image the size of the display, (64x48) the image will be displayed well, unless scrolled.
To scroll an image without having random pixels from unused space in the internal frame buffer, load a 96x64 image
onto the OLED Switch click with your desired image centered like the blue colored area in the picture below.
Programming
This code snippet takes a 565 formatted 16-bit bitmap and displays it on the OLED display, and then scrolls the
image across the display.
#define BIG_IMG_SIZE
12288
void main()
//Local Declarations
scroll_t scroll;
scroll.col_horiz_shift
scroll.row_offset
scroll.row_horiz_shift
doesn't work well, because
scroll.row_vert_shift
scroll.interval
//Used for scroll settings
= 0x01; //Shift left to right
= 0;
//No offset of rows
= 64;
//64: BIG IMAGE, 47:SMALL ( SMALL
of firmware on click side )
= 0;
//No vertical shifting
= 1;
//1: 10 frames between each shift
//Setup
system_setup( BIG ); //Provide size of allocated space for images (
64x48 or 96x64 )
OLED Switch click
3
oled_switch_deactivate_scrolling();
//Scrolling must be absolutely
deactivated first
oled_switch_scrolling_setup( scroll );
//Next, setup scroll settings
oled_switch_draw_565_img( oled_switch_logo_big_bmp, BIG_IMG_SIZE );
//Draw the image to scroll
oled_switch_activate_scrolling();
//Activate scrolling on screen
while( 1 )//Forever
Code examples for OLED Switch click, written for MikroElektronika hardware and compilers are available on
Libstock [4].
Pinout diagram
mikroBUStm
Data/Command
1 AN
—1 PWM 16
2 RST
INT
15
3 CS
RX
14
4 SCK
TX
13
MISO 5 MISO
SCL
12
MOSI 6 MOSI
SDA
11
+3.3V 7 +3.3V
+5V
10
GND 8 GND
GND
9
RST
CS
SCK
D/C
GND
– Data/Command
OLED Switch click
Resources
• Libstock code example [4]
• Vendor's data sheet [5]
• OLED Switch 3D CAD model [6]
• mikroBUS™ standard specifications [7]
References
[1]
[2]
[3]
[4]
[5]
[6]
http:/ / 2t70un3m1d9z1kztamkdrd38. wpengine. netdna-cdn. com/ wp-content/ uploads/ 2016/ 03/ ISC15ANP4. pdf
http:/ / www. mikroe. com/ click/ oled-switch
http:/ / cdn-docs. mikroe. com/ images/ 7/ 72/ Oled_Switch_click_schematic_v100. pdf
http:/ / libstock. mikroe. com/ projects/ view/ 1931/ oled-switch-click
http:/ / www. nkkswitches. com/ pdf/ ISC15ANP4. pdf
http:/ / nkkswitches-embedded. partcommunity. com/ 3d-cad-models/ ?info=nkkswitches/ smart_switch/ oled_smartswitch/
isc15anp4_asmtab. prj
[7] http:/ / download. mikroe. com/ documents/ standards/ mikrobus/ mikrobus-standard-specification-v200. pdf
4
Article Sources and Contributors
OLED Switch click Source: http://docs.mikroe.com/index.php?oldid=1650 Contributors: Srdjan.misic
Image Sources, Licenses and Contributors
File:OLED Switch click 1.jpg Source: http://docs.mikroe.com/index.php?title=File:OLED_Switch_click_1.jpg License: unknown Contributors: Srdjan.misic
File:OLED switch.png Source: http://docs.mikroe.com/index.php?title=File:OLED_switch.png License: unknown Contributors: Srdjan.misic
File:mikrobus logo.png Source: http://docs.mikroe.com/index.php?title=File:Mikrobus_logo.png License: unknown Contributors: Vojislav.gvozdic
License
Creative Commons Attribution
https:/ / creativecommons. org/ licenses/ by/ 4. 0/
5
很抱歉,暂时无法提供与“MIKROE-2449”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1367.74627
- 2+1313.05867
- 国内价格
- 1+1439.73265
- 2+1382.16676
