Page 1 of 2
3G click
From MikroElektonika Documentation
3G click is a mikroBUS™ add-on board with Quectel’s UG95 3G UMTS/HSPA module. The board
has a rich set of components to simplify development: an SMA connector, earphone/microphone jack,
MicroUSB port, as well as a SIM card slot. The network protocol stack includes support for TCP,
UDP, PPP, MMS, FTP, SMTP, SMTPS, HTTP, HTTPS, PING, and SSL. 3G click communicates
with the target MCU through the mikroBUS™ UART interface (RX, TX), with additional
functionality provided by STAT, PWRKEY, RTS, R1, and CTS pins. The board is designed to use
either a 3.3V or a 5V power supply.
3G click
Features and usage notes
Due to the nature of the protocol, 3G click comes
in two different versions. The Europe and
Australia version operates on the
900/2100@UMTS, 900/1800@GSM frequency
band, while the USA version works on
850/1900@UMTS frequency band.
The boards are otherwise identical.
An onboard jumper allows you to choose the I/O
voltage levels between 3.3V and 5V. Signal LEDs
show the status of the data transmission.
Schematic also available in PDF (http://cdndocs.mikroe.com/images/d/d6/3g_click_schematic_v
The following are data rates the UG95 module
can achieve using various supported protocols:
- HSPA: 7.2 Mbps (DL)/ 5.76 Mbps (UL) - UMTS: 384 Kbps (DL)/ 384 Kbps (UL) - GPRS: 85.6
Kbps (DL)/ 85.6 Kbps (UL) - EDGE: 236.8 Kbps (DL)
Programming
This code snippet shows how easy it is to establish a connection with 3G click, and answer or hangup
an incoming call.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
#include "3G_click_lib.h"
#include "resources.h"
// TFT module connections
unsigned int TFT_DataPort at GPIOE_ODR;
sbit TFT_RST at GPIOE_ODR.B8;
sbit TFT_RS at GPIOE_ODR.B12;
sbit TFT_CS at GPIOE_ODR.B15;
sbit TFT_RD at GPIOE_ODR.B10;
sbit TFT_WR at GPIOE_ODR.B11;
sbit TFT_BLED at GPIOE_ODR.B9;
sbit GSM_PWR at GPIOC_ODR.B2;
sbit GSM_CTS at GPIOD_ODR.B13;
sbit GSM_RTS at GPIOD_IDR.B10;
bool answer_call = false;
bool hangup_call = false;
void system_init( void );
void main()
system_init();
display_init();
click_3g_api_init();
while( 1 )
click_3g_process();
if( Button( &GPIOC_IDR, 9, 80, 1 ) )
answer_call = true;
if( Button( &GPIOC_IDR, 8, 80, 1 ) )
hangup_call = true;
if( answer_call )
click_3g_call_answer();
if( hangup_call )
click_3g_call_hangup();
3G click
IC/Module Quectel UG95
(http://www.quectel.com/product/prodetail.aspx?
id=78)
Interface
UART, STAT, PWRKEY, RTS, RI, CTS
Power
supply
3.3V, 5V
Website
www.mikroe.com/click/3g-aa
(http://www.mikroe.com/click/3g-aa)
www.mikroe.com/click/3g-ea
(http://www.mikroe.com/click/3g-ea)
Page 2 of 2
48
49
50 }
Code examples that demonstrate the usage of 3G click with MikroElektronika hardware, written for mikroC for ARM, AVR, FT90x, PIC and PIC32 are
available on [TK].
Resources
- 3G click example on Libstock (http://libstock.mikroe.com/projects/view/1802/3g-click)
- Quectel’s M2M brochure with more info about UG95 (http://www.quectel.com/UploadFile/Brochure/Quectel_Brochure_EN_V4.3.pdf)
- Quectel’s UG95 landing page with links to relevant documentation (http://www.quectel.com/product/prodetail.aspx?id=78)
- 2G sunset is near, article about 3G click on learn.mikroe.com (http://learn.mikroe.com/2g-sunset-near/)
Retrieved from "http://docs.mikroe.com/index.php?title=3G_click&oldid=352"
◾ This page was last modified on 3 June 2016, at 16:39.
◾ Content is available under Creative Commons Attribution unless otherwise noted.
http://docs.mikroe.com/index.php?title=3G_click&printable=yes
6/15/2016
很抱歉,暂时无法提供与“MIKROE-2296”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1364.67806
- 3+1303.44251
- 国内价格
- 1+1132.50670
- 3+1087.27363
- 国内价格
- 1+1075.88157
- 3+1032.91015
- 国内价格 香港价格
- 1+947.729551+114.97041
- 2+943.300812+114.43316
- 3+943.279953+114.43063
- 4+943.259114+114.42810
- 5+943.238255+114.42557
