PIR Motion Sensor V1.0 SKU:SEN0171
Contents
1 Introduction
2 Specification
3 Application
4 PinOut
4.1 Diagram
4.2 Overview of the Detector
4.3 Output Characteristic
5 Tutorial
5.1 Connection Diagram
5.2 Sample Code
5.3 Result
6 Trouble shooting
Introduction
Pyroelectric infrared motion sensor can detect the infrared signals from the person or animals which
are moving, and can output the switching signals. So it can be applied to a variety of occasions
which need to detect the movement of the human body. Conventional pyroelectric infrared sensors
require body pyroelectric infrared detector, professional chip, complex peripheral circuit, so the
volume is slightly big, circuit is complex, and reliability is slightly lower. Now we launch this new
pyroelectric infrared motion sensor, especially designed for Arduino. An integrated digital body
pyroelectric infrared sensor is used, with small size, high reliability, low power consumption, simple
peripheral circuit.
Specification
Input Voltage: 3.3 ~ 5V, 6V Maximum
Working Current: 15uA
Working Temperature: -20 ~ 85
Output Voltage: High 3V, low 0V
Output Delay Time(High Level): About 2.3 to 3 Seconds
Detection angle: 100 °
Detection distance: 7 meters
Output Indicator LED(When output HIGH,it will be ON)
Pin limit current: 100mA
Connection Interface: PH2.0-3
Module size: 30mm × 22mm
Application
Intrusion Alarm
Non-contact infrared automatic switch
PinOut
Diagram
The pyroelectric infrared motion sensor integrates a digital integrated body pyroelectric infrared
detector whose model is AM412.
This detector is a digital intelligent PIR sensor. It interfaces directly with up to two conventional PIR
sensors via a high impedance differential input. The PIR signal is converted to a 15 bit digital value
on chip. A LED indicates whenever the PIR signal is above the selected threshold. All signal
processing is performed digitally.
When the pyroelectric infrared motion sensor detects the movement of the life body within the
detection range, the output pin will output high level(3V) and the output led is ON; Without an
infrared Pyroelectric signal, the output pin will output low level(0V) and the output led is OFF. Pay
attention: Once the IR signal disappears, the output pin will output low level delay roughly 2.3~3
seconds. So we can quickly establish a body motion detection application according to this feature.
Note:When the sensor just on power, there will be unstable for a short time. The output level is
jittered.
Tutorial
Connection Diagram
Sample Code
Just download the sample code. Move your body to play with the tiny motion sensor.
// # Editor
: Youyou from DFRobot
// # Date
: 04.06.2014
// # E-Mail
: youyou.yu@dfrobot.com
// # Product name: PIR (Motion) Sensor
// # Product SKU : SEN0171
// # Version
: 1.0
// # Description:
// # The sketch for using the PIR Motion sensor with Arduino/Raspberry Pi con
troller to achieve the human detection feature.
// # Hardware Connection:
PIR Sensor
-> Digital pin 2
Indicator LED -> Digital pin 13
byte sensorPin = 2;
byte indicator = 13;
void setup()
pinMode(sensorPin,INPUT);
pinMode(indicator,OUTPUT);
Serial.begin(9600);
void loop()
byte state = digitalRead(sensorPin);
digitalWrite(indicator,state);
if(state == 1)Serial.println("Somebody is in this area!");
else if(state == 0)Serial.println("No one!");
delay(500);
Result
When the sensor detects the living movement body within detection range, the output pin will output
high voltage of 3V, while the output indicator is lighted.Otherwise,after 2~3s,the output pin will output
high voltage of 0V, while the output indicator is extinguished.
Note: When the sensor just on electricity, there will be unstable for a short
time, the output terminal will be level shake!
Trouble shooting
More question and cool idea,visit DFRobot Forum
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0171”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+55.475101+6.70801
