Adafruit Perma-Proto HAT for Pi Mini Kit With EEPROM
PRODUCT ID: 2314
DESCRIPTION
Design your own Pi HAT, attach custom circuitry and otherwise dress your Pi
A+, B+, or Pi 2 with this jaunty prototyping HAT kit with EEPROM
To kick off the Adafruit HAT party, we have this Perma-Proto inspired plug in
daughter board. It has a grid of 0.1" prototyping soldering holes for attaching
chips, resistors, LED, potentiometers and more. The holes are connected
underneath with traces to mimic the solderless breadboards you're familiar. There's
also long power strips for +3V, +5V and Ground connections to the Pi. Near the
top we break out nearly every pin you could want to connect to the Pi (#26 didnt
quite make the cut).
This is the fancier version of our Perma-Proto HAT. It comes with a printed circuit
board and a single 2x20 GPIO Header for Raspberry Pi to put your Perma-Proto on
top of your Raspberry Pi (like a nice little hat...) This version comes with a blank
24C32 I2C EEPROM soldered on and connected to the EEDAT/EECLK lines so you
cannot 'stack' it with other HATs. However, you can program in the EEPROM to
make a self-identifying setup using the Pi Foundations' HAT specs - please note
the specifications are still under development.
You can customize your Perma-Proto setup using a standard 2x20 stacking header
or extra tall 2x20 stacking header. You can also swap out the 2x20 header with a
slim 2x20 type if you want it to sit closer to the Pi, or an extra tall one if you want
it to sit above the USB/Ethernet ports.
A bit of light soldering is required to attach the header to the PCB but it's easy
work.
This hat is only compatible with the Raspberry Pi A+, B+, or Pi 2! It will not work
with the Raspberry Pi Model A or B.
Our initial version has the +3V and +5V markings in blue, and the GND markings
in red, future orders will have these colors swapped to better match a solderless
breadboard
http://www.adafruit.com/products/2314
10/5/2015
Technical Details
Header Dimensions: 5mm x 51mm x 12mm / 0.2" x 2" x 0.5"
PCB Dimensions: 66mm x 57mm x 2mm / 2.6" x 2.2" x 0.1"
很抱歉,暂时无法提供与“2314”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+84.706411+10.26735
