Adafruit 0.54" Quad Alphanumeric
FeatherWing Display - Red
PRODUCT ID: 3130
Description
Display, elegantly, 012345678 or 9! Gaze, hypnotized, at ABCDEFGHIJKLM - well it can display the
whole alphabet. You get the point.
This is the Red Adafruit 0.54" Dual Alphanumeric Display w/ FeatherWing Combo Pack! We also have
these combo packs in Green, White, Yellow-Green, Blue, and Yellow.
This is a nice, bright alphanumeric display that shows letters and numbers in a beautiful hue. It's
super bright and designed for viewing from distances up to 23 feet (7 meters) away. Each of the digit
sets have 14 segments on a dark background and we give you a set of two alphanumeric displays as
well as a Featherwing driver board so you can make a clock or a four letter word.
Works with any and all Feathers!
14-Segment Matrices like these are 'multiplexed' - so to control all the fourteen-segment LEDs you need 18
pins. That's a lot of pins, and there are driver chips like the MAX7219 that can control a matrix for you but
there's a lot of wiring to set up and they take up a ton of space. Wouldn't it be awesome if you could control a
matrix without tons of wiring? That's where these Alphanumeric LED Matrix FeatherWings come in, they
make it really easy to add a 4-digit alphanumeric display with decimal points.
The LEDs themselves do not connect to the Feather. Instead, a matrix driver chip (HT16K33) does the
multiplexing for you. The Feather simply sends i2c commands to the chip to tell it what LEDs to light
up and it is handled for you. This takes a lot of the work and pin-requirements off the Feather. Since
it uses only I2C for control, it works with any Feather and can share the I2C pins for other sensors or
displays
The product kit comes with:
A fully tested and assembled Adafruit 4-Digit 14-Segment Alphanumeric Display FeatherWing
0.54" Ultra-bright dual alphanumeric red display - 2 pack
Two 16-pin headers
Of course, in classic Adafruit fashion, we also have a detailed tutorial showing you how to solder, wire
and control the display. We even wrote a very nice library for the backpacks so you can get running in
under half an hour, displaying images on the matrix or numbers on the 14-segment. If you've been
eyeing matrix displays but hesitated because of the complexity, his is the solution you've been
looking for!
Technical Details
The board/chip uses 12C 7-bit address between 0x70-0x77, selectable with jumpers
FeatherWing Dimensions: 51mm x 23mm x 4.2mm / 2.0" x 0.9" x 0.165"
Backpack Weight: 4.6g
Dual Alphanumeric Display Dimensions: 21mm x 25mm x 7mm / 0.8" x 1" x 0.3"
Dual Alphanumeric Display Height w/ Pins: 14mm / 0.6"
Dual Alphanumeric Display Weight: 4.7g
The Dual Alphanumeric Display is a Common Cathode LED display
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3130”相匹配的价格&库存,您可以联系我们找货
