Adafruit 0.8" 8x16 LED Matrix FeatherWing Display Kit - Blue
PRODUCT ID: 3150
Description
You will chirp with delight when you see how easy it is to make your very own 8x16 LED
matrix display for any Feather. This kit combines two of our adorable miniature LED
matrices with a FeatherWing driver board. At 0.8" square, these little 8x8 matrices have
got everything a big LED matrix has, but bite sized! Double them up for 128 total bright
blue LEDs
This is the Blue Adafruit 0.8" 8x16 LED Matrix FeatherWing Display Combo Pack! We
Also have these combo packs in White, Green, Red, Yellow, and Yellow-Green
Normally, wiring up 8x16 matrices would require a breath-taking 24 GPIO pins, which is
way too many pins. That's where this lovely 16x8 LED matrix backpack PCB comes in. It
contains a HT16K33 I2C LED matrix driver that does all the multiplexing work for you,
and is controlled over the two I2C pins. It's easy to use, has a portable library that runs
on any of our Feathers to turn on/off each LED.
The 16x8 backpack is also great for making scrolling displays or small video displays. In
our example, we set it up to display small bitmap emoticons but you can also display
text that moves - kind of like a sign in front of a miniature car dealership.
This kit comes with:
A fully tested and assembled 16x8 0.8" LED FeatherWing
2 x ultra-bright square 8x8 blue matrices
2 x 16-pin header
A bit of soldering is required to attach the two matrices onto the FeatherWing but its
very easy to do and only takes about 15 minutes.
Technical Details
The board/chip uses 12C 7-bit address between 0x70-0x77, selectable with jumpers
FeatherWing Dimensions: 51mm x 23mm x 5mm / 2.0" x 0.9" x 0.2"
FeatherWing Weight: 6.3g
Mini LED Matrix Display Dimensions: 20mm x 20mm x 6mm / 0.8" x 0.8" x 0.2"
Mini LED Matrix Display Height w/ Pins: 13mm / 0.5"
Mini LED Matrix Display Weight: 3g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3150”相匹配的价格&库存,您可以联系我们找货
