Mayhew Labs
Example Use:
Go Between Shield
User’s Guide
1
Determine what pins
conflict on your shields
and decide what pins to
use in their place.
2
For the top shieldʼs pins
that get rearranged, put
solder jumpers where the
pins should switched to on
the bottom shield.
3
Place solder jumpers for
the pins that should pass
directly through from
bottom to top - forming a
diagonal.
4
Modify your code that
interacts with the top
shield to use the new pins
in place of the old pins.
Shield A uses:
•Digital 2,3,4,10
•Analog 0,3
Shield B uses:
•Digital 2,3,5,6
•Analog 0,4
Stack onto Arduino
Tip: solder wick makes removing solder
jumpers easy. Place some between a hot
soldering iron and the jumper you want to
remove and watch it get wicked away!
Shield A now uses:
•Digital 7,8,4,10
•Analog 1,3
Shield B still uses:
•Digital 2,3,5,6
•Analog 0,4
✴Digital 2,3 and Analog 0 will not be accessible from the top
很抱歉,暂时无法提供与“DEV-11002”相匹配的价格&库存,您可以联系我们找货
