1110
    ADAFRUIT
    CORDED FOAM EARPLUGS
1110 数据手册
Adafruit 16x2 Character LCD + Keypad for Raspberry Pi Created by lady ada https://learn.adafruit.com/adafruit-16x2-character-lcd-plus-keypad-for-raspberry-pi Last updated on 2021-11-15 05:53:18 PM EST ©Adafruit Industries Page 1 of 27 Table of Contents Overview 3 Parts List 4 • • • • • • • • • 5 5 5 6 6 6 6 6 6 1) Resistors 2) Potentiometer 3) Pushbuttons 4) i2c Port Expander Chip 5) Male Header Pins 6) Printed Circuit Board 7) Raspberry Pi Plate Header 8) Bumper Additional Assembly 7 • Model B+ Protection 21 Python Usage • Python Installation of CharLCD Library • Python Code • Full Example Code 23 23 24 25 Python Docs 26 Download 26 ©Adafruit Industries Page 2 of 27 Overview This new Adafruit plate makes it easy to use a 16x2 Character LCD. We really like the range of LCDs we stock in the shop, such as our classic blue & white (http://adafru.it/ 181) as well as the fancy RGB negative (http://adafru.it/399) and RGB positive (http:// adafru.it/398). Unfortunately, these LCDs do require quite a few digital pins, 6 to control the LCD and then perhaps another 3 to control the RGB backlight for a total of 9 pins. That's nearly all the GPIO available on a Raspberry Pi! ©Adafruit Industries Page 3 of 27 With this in mind, we wanted to make it easier for people to get these LCD into their projects so we devised a Pi plate that lets you control a 16x2 Character LCD, up to 3 backlight pins AND 5 keypad pins using only the two I2C pins on the Pi! The best part is you don't really lose those two pins either, since you can stick i2c-based sensors, RTCs, etc and have them share the I2C bus. This is a super slick way to add a display without all the wiring hassle. WARNING: The new Raspberry Pi model B+ with 4 USB ports overlaps closely with backlight resistor leads on the char LCD plate. You will need to cover the USB port and back of resistors with electrical tape to protect them from touching. See more details and pictures on the assembly page of this guide. This plate is perfect for when you want to build a stand-alone project with its own user interface. The 4 directional buttons plus select button allows basic control without having to attach a bulky computer.  The kit is designed for any Raspberry Pi - version 1 and 2. If you want plug in a Cobbler or Gertboard at the same time, check out our Stacking Header, you can fit an IDC cable over it if the Plate is assembled with this part. (http:// adafru.it/1112) Parts List Check to make sure your kit comes with the following parts.Sometimes we make mistakes so double check everything and email support@adafruit.com if you need ©Adafruit Industries Page 4 of 27 replacements! We recently adjusted the kit so the buttons are on the RIGHT side instead of the left. The parts list is otherwise the same, its just a little more stable than before 1) Resistors There is a total of 3 resistors in this kit. For resistors labeled RED and BLUE on the PCB, they are 1/4W 5% 220 ohm resistors (Red, Red, Brown, Gold). For the resistor labeled GREEN on the PCB, it is a 1/4W 5% 330 ohm resistor (Orange Orange Brown Gold). 2) Potentiometer There is one 10k trim potentiometer. This part will go in the spot labeled Contrast 3) Pushbuttons There are a total of 5 x 6mm tactile switch pushbuttons. These will be used in the UP, DOWN, LEFT, RIGHT and SELECT locations on the PCB. ©Adafruit Industries Page 5 of 27 4) i2c Port Expander Chip There is one of these MCP23017 i2c (16 input/output) port expander chips in the kit. This is how we are able to only use 2 R-Pi pins to run the entire LCD and buttons. Clic k here for more info on this chip. (http://adafru.it/732) 5) Male Header Pins There is one strip of 36 male header pins in the kit. These will be used to attach the LCD to the PCB. 6) Printed Circuit Board There will be one PCB in the kit as shown above. 7) Raspberry Pi Plate Header There will be one extra-tall 26 pin female header for plugging into the Pi 8) Bumper There will be one rubber bumper as shown above Additional You'll  also need an LCD to place into the shield. Your LCD may have 16 pins (Monochrome) or 18 pins (RGB) and may have 2 rows of connectors or one. This is normal and does not affect the display ©Adafruit Industries Page 6 of 27 You can also use 16x2 LCDs that are the same size that do not have an RGB backlight, or have no backlight at all. We carry Negative type (http://adafru.it/399) or Positive type (http://adafru.it/398) LCDs as well as Blue and White LCDs (http://adafru.it/181) Assembly Check the kit against the parts list to verify you have all the parts necessary We recently adjusted the kit so the buttons are on the right side instead of the left. The parts list is otherwise the same, its just a little more stable than before ©Adafruit Industries Page 7 of 27 Put the printed circuit board into a vise or board holder, heat up your soldering iron and make sure you're ready to go! We'll start with the first resistor GREEN which has orange, orange, brown, gold bands on it. This resistor acts as the backlight control resistor for the green backlight pin. Bend the resistor into a 'staple' and slide it into the slot marked GREEN on the PCB. Resistors do not have a direction so you can put it in 'either way' and it'll work find. ©Adafruit Industries Page 8 of 27 Bend the 'legs' of the resistor out so it sits flat against the PCB and flip it over. This way the resistor won't fall out while soldering. With your soldering iron heated up and ready, solder in both leads of the resistor. To do this, heat up the round ring pad and the wire lead at the same time for 2 or 3 seconds, then dip the end of the solder into the heated joint to melt it in. Then remove the solder and the soldering iron. ©Adafruit Industries Page 9 of 27 Once the soldering is complete, we can clean up by clipping the leads of the resistor. This keeps them from shorting to something else. Use diagonal or flush cutters to clip the wires right above where the solder joint ends. Since you did so great with the first resistor, we'll place all of the rest now at the same time. The two 220 ohm resistors RED and BLUE - named because they are the backlight series resistors for the RGB backlights on the LCDs. These resistors are colored Red Red Brown Gold. ©Adafruit Industries Page 10 of 27 Solder the resistors just like you did with the first one. Clip all the leads. ©Adafruit Industries Page 11 of 27 Next up we will place the buttons. These buttons are useful to send a signal to the Pi (say if you have a basic menu system). We have a 4-way 'direction pad' for up/ down/left/right input and a button to the right called SELECT. These 5 buttons should be able to make 'talking' back to your project easy. These are connected to the I2C port expander chip so they require no extra pins on the Pi, our library does the work of reading whether they are pressed. All the buttons are the same, and they should snap nicely into place. Press down onto each button until it snaps in and sits flat against the PCB. We recently adjusted the kit so the buttons are on the RIGHT side instead of the left. The buttons snap in the same but they're on the right ©Adafruit Industries Page 12 of 27 Flip over the PCB and check that all the legs for the buttons are sticking out. Solder each leg, taking care not to accidentally 'short' two button legs together. The ones for the directional pads are very close! ©Adafruit Industries Page 13 of 27 Next, place the 10K potentiometer (the orange-faced thing with three legs) into the spot above the RESET button. It will only fit one way. This is the contrast potentiometer which will adjust how dark the characters appear. All displays are slightly different so you'll adjust this once the display is soldered in. The kit may come with two potentiometers - a big blue one for breadboarding the LCD and a smaller orange one for the shield kit. You can throw away or recycle the blue one, use only the orange one here! We recently adjusted the kit to have the potentiometer in the center rather than the right, goes in the same way, just in the middle! Flip over the PCB and solder in the three legs of the potentiometer ©Adafruit Industries Page 14 of 27 We're nearly done! Now we will place the I2C port expander chip. Double check that it has the MCP23017-E/SP marking on it. This is a 16-pin expander chip, that uses the i2c bus. That means you can send it commands using the i2c pins on an Pi and control 16 more digital pins! 5 of those pins go to the buttons, 6 go to the LCD control and 3 are used for the backlight (the remaining 2 are unused). Unlike buttons or resistors, chips do have a direction and the must be put in the right way! First, use a flat table to carefully bend the legs of the chip so they are parallel. Then slip it into the silkscreened outline so that the notch at the end of the chip is on the right. Click the image to the left to make absolutely sure you've got it in the right way. Once you are sure, press the chip into place We recently adjusted the kit so the chip is more to the left, its the same alignment, just shifted over ©Adafruit Industries Page 15 of 27 Flip over the PCB and solder in the 28 pins of the port expander. Next we will attach the header, there is a standard 'extra tall' header included in the kit. However, if you want to attach a cobbler or GertBoard, etc to the plate, you may want to opt for one of our stacking headers, they're extra long so you can plug in an IDC cable on top! ©Adafruit Industries Page 16 of 27 Before we solder in the header, remove the bumper from the backing and attach it on the underneath so its right over the Ethernet jack when the PCB is plugged in. On kits where the buttons are on the left, put it right below the contrast pot, as shown. This will keep the pot from touching the Ethernet jack. On kits where the buttons are on the right, put it right next to the buttons (it shouldnt overlap any button legs) sitting flat Place the 2x13 header onto your Pi, and slide the plate on top, it should fit perfectly. ©Adafruit Industries Page 17 of 27 Now we will solder all 26 pins for the plate - this will send power and data between the two boards and also provide a mechanical stability. You may need to hold the plate down with tape to get it sitting flat against the Pi. Solder in one pin, we suggest the top right, then check if the plate is sitting flat. If not, heat up the joint with one hand while stabilizing with the other until its right. Then solder the other 25 pins ©Adafruit Industries Page 18 of 27 Finally, we place the LCD. Break off a piece of 18 or 16 pin header from the stick in the kit. If you have an RGB display, you'll need 18, for a blue&white you'll need 16 Place the header into the remaining slot with the long ends of the pins sticking UP. If you have only 16 pins, leave the two rightmost pads empty ©Adafruit Industries Page 19 of 27 Slide the LCD over the header so that it is perfectly centered over the four holes and the silkscreen. Your LCD may have two rows of connectors or one row. If its a two-rowconnector LCD we do not use the bottom row, just continue using the LCD as it will fit just fine! The LCD should 'snap' in against the buttons Solder all the pins! ©Adafruit Industries Page 20 of 27 Flip over the assembly, carefully. Then solder in the 16 or 18 pins of header WARNING: If you're using the new Raspberry Pi model B+ with 4 USB ports you will need to take some extra steps to ensure the backlight resistor leads do not touch the USB ports and short out. See the steps below for more details. Model B+ Protection With the new Raspberry Pi model B+ and its extra USB ports there's a slight problem with the layout of the character LCD shield. As you can see in the photo below, the three through-hole backlight resistors have their leads right above one of the metal USB ports. Unfortunately these leads are quite close and can potentially short against the metal USB port. ©Adafruit Industries Page 21 of 27 There is current limiting in the resistor circuit so it shouldn't damage the Pi if there is a short, but to be sure it is advised to cover the USB port and resistor leads in a few layers of electrical tape. Be sure to cut the resistor leads as short as possible with flush cutters and try to ensure there are no sharp edges from the cut leads or solder. See the photo below with arrows pointing to the two locations you should place electrical tape. Note that if you are using a Raspberry Pi model A or B (i.e. Pi with only 1 or 2 USB ports) you can skip this step and move on. You only need to add this tape if you're using a Raspberry Pi model B+, the Pi with 4 USB ports. ©Adafruit Industries Page 22 of 27 That's it! You're done soldering, now you just have to run the code in the Usage section next. Python Usage It's easy to use the I2C 16x2 RGB LCD Pi plate with Python and the Adafruit CircuitPython CharLCD (https://adafru.it/C47) library. This library allows you to easily write Python code that controls the RGB character LCD. Assemble the plate as shown in the previous pages and attach to your Pi. You'll need to set up your Raspberry PI to work with I2C before this will work! Check out the CircuitPython on Raspberry Pi guide for details: https:// learn.adafruit.com/circuitpython-on-raspberrypi-linux Python Installation of CharLCD Library You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This will also require enabling I2C on your Raspberry Pi and verifying you are running Python 3. Once that's done, from your command line run the following command: • sudo pip3 install adafruit-circuitpython-charlcd If your default Python is version 3 you may need to run 'pip' instead. Just make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! ©Adafruit Industries Page 23 of 27 Python Code To demonstrate the usage of the character LCD we'll initialize it and display text using CircuitPython code. First, you'll need to import necessary modules, initialize the I2C bus, and create an instance of the character LCD class. Paste the following code into your REPL: import board import busio import adafruit_character_lcd.character_lcd_rgb_i2c as character_lcd lcd_columns = 16 lcd_rows = 2 i2c = busio.I2C(board.SCL, board.SDA) lcd = character_lcd.Character_LCD_RGB_I2C(i2c, lcd_columns, lcd_rows) Now you're ready to start writing text and characters on the display!  The usage of the LCD class is exactly the same as shown in the parallel LCD wiring guide (https:// adafru.it/CVQ).  Be sure to check out that guide (https://adafru.it/CVQ) for a complete discussion of LCD usage. As a quick test though you can run the following code to use the color property to set the backlight to red and the message property to write text to the display: lcd.color = [100, 0, 0] lcd.message = "Hello\nCircuitPython" See the parallel LCD guide for more functions you can call to control the LCD! (https:/ /adafru.it/CVQ) If you don't see anything, adjust the potentiometer on the plate until the message shows up. The potentiometer is located below the LCD on the side opposite the buttons. ©Adafruit Industries Page 24 of 27 That's all there is to using the RGB character LCD Pi Plate with Python and the Adafruit CircuitPython CharLCD library! Full Example Code Save the following file to your Pi and run it to see a demo of some of the different things the character LCD library has to offer! # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT """Simple test for I2C RGB character LCD shield kit""" import time import board import adafruit_character_lcd.character_lcd_rgb_i2c as character_lcd # Modify this if you have a different sized Character LCD lcd_columns = 16 lcd_rows = 2 # Initialise I2C bus. i2c = board.I2C() # uses board.SCL and board.SDA # Initialise the LCD class lcd = character_lcd.Character_LCD_RGB_I2C(i2c, lcd_columns, lcd_rows) lcd.clear() # Set LCD color to red lcd.color = [100, 0, 0] time.sleep(1) # Print two line message lcd.message = "Hello\nCircuitPython" # Wait 5s time.sleep(5) # Set LCD color to blue lcd.color = [0, 100, 0] time.sleep(1) # Set LCD color to green lcd.color = [0, 0, 100] time.sleep(1) # Set LCD color to purple lcd.color = [50, 0, 50] time.sleep(1) lcd.clear() # Print two line message right to left lcd.text_direction = lcd.RIGHT_TO_LEFT lcd.message = "Hello\nCircuitPython" # Wait 5s time.sleep(5) # Return text direction to left to right lcd.text_direction = lcd.LEFT_TO_RIGHT # Display cursor lcd.clear() lcd.cursor = True lcd.message = "Cursor! " # Wait 5s time.sleep(5) # Display blinking cursor lcd.clear() lcd.blink = True lcd.message = "Blinky Cursor!" # Wait 5s ©Adafruit Industries Page 25 of 27 time.sleep(5) lcd.blink = False lcd.clear() # Create message to scroll scroll_msg = "
很抱歉,暂时无法提供与“1110”相匹配的价格&库存,您可以联系我们找货
