101020087
    SEEED(矽递科技)
    GROVE-TEMPERATURE&HUMIDITY;SEN
101020087 数据手册
Grove Temperature&Humidity Sensor (HDC1000) Release date: 10/27/2015 Version: 1.0 Wiki: http://www.seeedstudio.com/wiki/Grove_-_Temperature&Humidity_Sensor_(HDC1000) Bazaar: http://www.seeedstudio.com/depot/Grove-TemperatureHumidity-Sensor-HDC1000-p2535.html 1 Document Revision History Revision Date Author Description 1.0 Sep 21, 2015 Victor.He Create file 2 Contents Document Revision History ··································································································2 1. Introduction ···················································································································5 2. Features ·························································································································6 3. Specification ··················································································································7 4. Interface Function ·········································································································8 5. Applications ···················································································································9 5.1 5.2 Hardware Installation ········································································································9 Software Part ·····················································································································9 6. Resources·····················································································································11 3 Disclaimer For physical injuries and possessions loss caused by those reasons which are not related to product quality, such as operating without following manual guide, natural disasters or force majeure, we take no responsibility for that. Under the supervision of Seeed Technology Inc., this manual has been compiled and published which covered the latest product description and specification. The content of this manual is subject to change without notice. Copyright The design of this product (including software) and its accessories is under tutelage of laws. Any action to violate relevant right of our product will be penalized through law. Please consciously observe relevant local laws in the use of this product. 4 1. Introduction Grove – Temperature & Humidity Sensor (HDC1000) utilizes a HDC1000 sensor.HDC1000 was designed by Texas Instruments. It is a digital humidity sensor with integrated temperature sensor that provides excellent measurement accuracy at very low power. The device measures humidity based on a novel capacitive sensor. The humidity and temperature sensors are factory calibrated. The innovative WLCSP (Wafer Level Chip Scale Package) simplifies board design with the use of an ultra-compact package. The sensing element of the HDC1000 is placed on the bottom part of the device, which makes the HDC1000 more robust against dirt, dust, and other environmental contaminants. The HDC1000 is functional within the full –40°C to +125°C temperature range, and 0-100% RH range. 5 2. Features  Grove connector compatible  IIC Interface  Low Power  Wide operating voltage range  I2C Serial Bus Address Configuration 6 3. Specification Item Min Typical Max Unit Supply Voltage 3 / 5 VDC Working Current 0.12 / 90 uA Relative Humidity Accuracy (Typ) / ±3 Relative Humidity Operating Range (Typ) 0 / 100 %RH Temperature Accuracy / ±0.2 / ℃ Temperature Range -40 / 125 ℃ Operating Temperature Range -20 / 85 ℃ Dimension 40*20 7 %RH mm 4. Interface Function 1. 2. 3. 4. Grove connector. Ready:Ready for a conversion. Default address: 0x40. ADDR0,ADDR1:I2C Serial Bus Address Configuration(0x40,0x41,0x42,0x43) 8 5. Applications Here is how to use Grove – Temperature & Humidity Sensor (HDC1000) with Seeeduino Lotus. 5.1 Hardware Installation 1. 2. Part lists: Seeeduino Lotus v1.0 or other Microcontroller development board that combination of Seeeduino. Grove – Temperature & Humidity Sensor (HDC1000). Hardware linking is very easy. Grove – Temperature & Humidity Sensor (HDC1000) communicate over I2C.Connecting Grove – Temperature & Humidity Sensor (HDC1000) and Seeeduino Lotus v1.0 by Grove cable, as the following. 5.2 Software Part 1. 2. 3. 4. 5. To download the demo code in Github, click here. To install Arduino Library, please click here. Open the HDC1000 example sketch. In the Tools > Board menu, select right board and serial port. Upload demo code to Seeeduino Lotus v1.0. We can get the temperature and relative humidity information from the serial terminal 9 10 6. Resources  File:Grove - Temperature&Humidity Sensor(HDC1000) v1.0 sch pcb.zip  File:Grove - Temperature&Humidity Sensor(HDC1000) v1.0 sch.pdf  Demo code  HDC1000_DataSheet.pdf 11
101020087 价格&库存
很抱歉,暂时无法提供与“101020087”相匹配的价格&库存,您可以联系我们找货
