1752
    ADAFRUIT
    EVAL BOARD FOR MAX9744
1752 数据手册
19-4078; Rev 1; 9/08 KIT ATION EVALU E L B AVAILA 20W Stereo Class D Speaker Amplifier with Volume Control Applications Features ♦ Wide 4.5V to 14V Power-Supply Voltage Range ♦ Filterless Spread-Spectrum Modulation Lowers Radiated RF Emissions from Speaker Cables ♦ 20W Stereo Output (4Ω, VDD = 12V, THD+N = 10%) ♦ Integrated Volume Control (I2C or Analog) ♦ Low 0.04% THD+N ♦ High 75dB PSRR ♦ High 93% Efficiency ♦ Integrated Click-and-Pop Suppression ♦ Low-Power Shutdown Mode ♦ Short-Circuit and Thermal-Overload Protection ♦ Available in a 44-Pin Thin QFN-EP (7mm x 7mm x 0.8mm) Ordering Information PART MAX9744ETH+ TEMP RANGE PIN-PACKAGE -40°C to +85°C 44 TQFN-EP* +Denotes a lead-free/RoHS-compliant package. *EP = Exposed pad. Flat-Panel Televisions PC Speaker Systems Multimedia Docking Stations Pin Configuration appears at end of data sheet. Simplified Block Diagram 4.5V TO 14V 40 35 VOLUME CONTROL CLASS D MODULATOR BIAS MAX9744 EMI WITH FERRITE BEAD FILTERS (VDD = 12V, 1m CABLE, 8Ω LOAD) CLASS D MODULATOR MAX9744 OUTPUT MAGNITUDE (dBV) 3V TO 3.6V MUTE SHUTDOWN CONTROL I2C SYNC EN5022 B LIMIT 30 25 20 15 10 ANALOG CONTROL 5 OSCILLATOR SYNCOUT 30 100 60 80 140 180 220 260 300 120 160 200 240 280 FREQUENCY (MHz) ________________________________________________________________ Maxim Integrated Products For pricing, delivery, and ordering information, please contact Maxim Direct at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com. 1 MAX9744 General Description The MAX9744 20W stereo Class D audio power amplifier provides Class AB amplifier performance with Class D efficiency, conserving board space and eliminating the need for a bulky heatsink. This device features single-supply operation, adjustable gain, shutdown mode, a SYNC output, speaker mute, and industry-leading click-and-pop suppression. The MAX9744 features a 64-step dual-mode (analog or digital), programmable volume control and mute function. The MAX9744 operates from a 4.5V to 14V single supply and can deliver up to 20W per channel into a 4Ω speaker with a 14V supply. The MAX9744 offers two modulation schemes: a fixedfrequency modulation mode that allows one of several preset switching frequencies to be selected, and a spread-spectrum modulation mode that helps to reduce EMI-radiated emissions. The MAX9744 features high 75dB PSRR, low 0.04% THD+N, and SNR in excess of 90dB. Robust short-circuit and thermal-overload protection prevent device damage during a fault condition. The MAX9744 is available in a 44-pin thin QFN-EP (7mm x 7mm x 0.8mm) package and is specified over the extended -40°C to +85°C temperature range. MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control ABSOLUTE MAXIMUM RATINGS PVDD to PGND ....................................................................+16V VDD to GND ...........................................................................+4V FB_, SYNCOUT, SYNC, SDA/VOL, ADDR1, ADDR2 to GND........................................-0.3V to (VDD + 0.3V) BOOT_ to VDD ..........................................................-0.3V to +6V BOOT_ to OUT_........................................................-0.3V to +6V OUT_ to GND ..........................................-0.3V to (PVDD + 0.3V) PGND to GND .......................................................-0.3V to +0.3V Any Other Pin to GND ..............................................-0.3V to +4V OUT_, Short-Circuit Duration......................................Continuous Continuous Power Dissipation (TA = +70°C) 44-Pin Thin QFN (derate 27mW/°C above +70°C, single-layer board) ...................................................2162mW 44-Pin Thin QFN (derate 37mW/°C above +70°C, multilayer board) ......................................................2963mW θJA, Single-Layer Board................................................37°C/W θJA, Multilayer Board ................................................….27°C/W Continuous Input Current (PVDD, PGND).............................6.4A Continuous Output Current (OUT_) ......................................3.2A Continuous Input Current (except OUT_).........................±20mA Junction Temperature ......................................................+150°C Operating Temperature Range ...........................-40°C to +85°C Storage Temperature Range .............................-65°C to +150°C Lead Temperature (soldering, 10s) .................................+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_-, RL = ∞, unless otherwise stated, CBOOT_ = 0.1µF, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spreadspectrum mode, filterless modulation mode, see the Functional Diagrams/Typical Application Circuits. TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS 14 V 3.6 V GENERAL Speaker Amplifier Supply Voltage Range Supply Voltage Range Quiescent Current Shutdown Current Turn-On Time Common-Mode Bias Voltage PVDD Inferred from PSRR test 4.5 VDD Inferred from PSRR test 2.7 IDD 20 35 IPVDD 10 20 IVDDSHDN TA = +25°C 0.1 1 IPVDDSHDN TA = +25°C 0.1 1 mA µA tON 200 ms VBIAS 1.5 V Input Amplifier Output-Voltage Swing High VOH Specified as VDD – VOH, RL = 2kΩ connected to 1.5V 20 mV Input Amplifier Output-Voltage Swing Low VOL Specified as VOL – GND, RL = 2kΩ connected to 1.5V 20 mV ±60 mA 1.8 MHz Input Amplifier Output ShortCircuit Current Limit Input Amplifier Gain-Bandwidth Product GBW SPEAKER AMPLIFIERS Gain Output Offset 2 AVMAX VOS Maximum volume setting TA = 25°C Output stage gain 29.5 Total gain (Note 2) 29.5 ±2 _______________________________________________________________________________________ dB ±15 mV 20W Stereo Class D Speaker Amplifier with Volume Control (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_-, RL = ∞, unless otherwise stated, CBOOT_ = 0.1µF, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spreadspectrum mode, filterless modulation mode, see the Functional Diagrams/Typical Application Circuits. TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETER SYMBOL CONDITIONS Filterless modulation Efficiency (Note 3) η PWM MIN POUT = 10W, fIN = 1kHz, 8Ω load POUT = 15W, fIN = 1kHz, 4Ω load POUT = 10W, fIN = 1kHz, 8Ω load POUT = 15W, fIN = 1kHz, 4Ω load Output Power POUT VPVDD = 12V, fIN = 1kHz VPVDD = 14V, fIN = 1kHz % 92 % 88 1.4 RL = 8Ω, THD+N = 10% 1.8 RL = 4Ω, THD+N = 1% 2.6 RL = 4Ω, THD+N = 10% 3.6 RL = 8Ω, THD+N = 1% 8 RL = 8Ω, THD+N = 10% 10 RL = 4Ω, THD+N = 1% 14 RL = 4Ω, THD+N = 10% 17 RL = 8Ω, THD+N = 1% 10 RL = 8Ω, THD+N = 10% 13 RL = 4Ω, THD+N = 1% 17.5 Total Harmonic Distortion Plus Noise ISC THD+N POUT = 10W, RL = 8Ω, filterless modulation mode, BW = 22Hz to 22kHz Signal-to-Noise Ratio SNR POUT = 10W, RL = 8Ω, PWM mode, BW = 22Hz to 22kHz W 22.5 3.9 f = 1kHz, RL = 8Ω, POUT = 5W, fIN = 1kHz UNITS 87 RL = 4Ω, THD+N = 10% Hard Output Current Limit MAX 93 RL = 8Ω, THD+N = 1% VPVDD = 5V, fIN = 1kHz TYP 5.5 Filterless modulation 0.04 PWM 0.04 Fixed-frequency modulation, unweighted 91 Spread-spectrum, unweighted 90 Fixed-frequency modulation, A-weighted 94 Spread-spectrum, A-weighted 94 Fixed-frequency modulation, unweighted 91 Spread-spectrum, unweighted 81 Fixed-frequency modulation, A-weighted 94 Spread-spectrum, A-weighted 89 A % dB dB _______________________________________________________________________________________ 3 MAX9744 ELECTRICAL CHARACTERISTICS (continued) MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control ELECTRICAL CHARACTERISTICS (continued) (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_-, RL = ∞, unless otherwise stated, CBOOT_ = 0.1µF, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spreadspectrum mode, filterless modulation mode, see the Functional Diagrams/Typical Application Circuits. TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETER SYMBOL Crosstalk Power-Supply Rejection Ratio PSRR CONDITIONS MIN TYP 1kHz 85 20Hz to 20kHz 68 VDD = 2.7V to 3.6V, TA = 25°C, MUTE = high 68 PVDD = 4.5V to 14V 50 75 SYNC = GND 1020 1200 1355 SYNC = unconnected 1280 1440 1640 fSW SYNC = GND 255 300 338 SYNC = unconnected 320 360 410 kHz 300 ±6 SYNC = VDD (spread-spectrum mode) SYNC Frequency Lock Range kHz 1200 ±30 SYNC = VDD (spread-spectrum mode) Class D Switching Frequency dB 70 f = 1kHz, VRIPPLE = 200mVP-P on PVDD fSYNC UNITS dB 83 f = 1kHz, VRIPPLE = 100mVP-P on VDD SYNC Frequency MAX 1000 1600 kHz Minimum SYNC Frequency Lock Duty Cycle 40 % Maximum SYNC Frequency Lock Duty Cycle 60 % 0.2 dB Gain Matching Full volume (ideal matching for RIN and RF) Into shutdown Click-and-Pop Level KCP Peak voltage, 32 samples/second, A-weighted (Note 4) -43 Out of shutdown -43 Into mute -46 Out of mute -57 dBV VOLUME CONTROL VOL Input Leakage Current ±5 µA Input Hysteresis DC volume control mode 11 mV 9.5dB Gain Voltage DC volume control mode 0.1 x VDD V Full Mute Voltage DC volume control mode 0.9 x VDD V Full Mute Attenuation f = 1kHz, relative to 9.5dB setting -115 dB DIGITAL INPUTS/OUTPUT (SHDN, MUTE, ADDR1, ADDR2, SCLK, SDA/VOL) Input-Voltage High VIH Input-Voltage Low VIL Input Leakage Current ILK Input Hysteresis CIN Output-Voltage Low VIL V 0.3 x VDD TA = +25°C SCLK, SDA/VOL Input Capacitance 4 0.7 x VDD ±1 0.1 x VDD V 5 IOL = 3mA _______________________________________________________________________________________ V µA pF 0.4 V 20W Stereo Class D Speaker Amplifier with Volume Control (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_-, RL = ∞, unless otherwise stated, CBOOT_ = 0.1µF, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spreadspectrum mode, filterless modulation mode, see the Functional Diagrams/Typical Application Circuits. TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS DIGITAL INPUT (SYNC) Input-Voltage High VSYNCIH Input-Voltage Low VSYNCIL SYNC Input Leakage ISYNCIN 2.3 TA = +25°C V ±7.5 0.8 V ±13 µA DIGITAL OUTPUT (SYNCOUT) Output-Voltage High VSYNCOUTIH ISOURCE = 1mA Output-Voltage Low VSYNCOUTIL ISINK = 1mA Rise/Fall Time VDD 0.3 V 0.3 CL = 10pF 50 V V/µs THERMAL PROTECTION Thermal-Shutdown Threshold +165 °C Thermal-Shutdown Hysteresis 15 °C I2C TIMING CHARACTERISTICS (Figure 3) Serial Clock fSCL Bus Free Time Between a STOP and a START Condition tBUF 400 kHz 1.3 µs 0.6 µs Hold Time (Repeated) START Condition tHD, STA Repeated START Condition Setup Time tSU, STA 0.6 µs STOP Condition Setup Time tSU, STO 0.6 µs Data Hold Time tHD,DAT 0 Data Setup Time tSU,DAT 100 ns SCL Clock Low Period tLOW 1.3 µs SCL Clock High Period µs (Note 5) 0.9 µs tHIGH 0.6 Rise Time of SDA and SCL, Receiving tR (Note 6) 20 + 0.1CB 300 ns Fall Time of SDA and SCL, Receiving tF (Note 6) 20 + 0.1CB 300 ns 0 50 ns 400 pF Pulse Width of Spike Suppressed tSP Capacitive Load for Each Bus Line CB All devices are 100% production tested at +25°C. All temperature limits are guaranteed by design. See the Gain-Setting Resistors section. Measured on the MAX9744 Evaluation Kit. Testing performed with an 8Ω resistive load connected across BTL output. Mode transitions are controlled by SHDN or MUTE pin, respectively. Note 5: A master device must provide a hold time of at least 300ns for the SDA signal in order to bridge the undefined region of the SCL’s falling edge. Note 6: CB = total capacitance of one bus line in pF. Note 1: Note 2: Note 3: Note 4: _______________________________________________________________________________________ 5 MAX9744 ELECTRICAL CHARACTERISTICS (continued) Typical Operating Characteristics (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_- with an inductor in series, 8Ω load, L = 68µH, 4Ω load, L= 33µH. RL = ∞, unless otherwise stated, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spread-spectrum mode, TA = +25°C, unless otherwise noted.) 0.1 fIN = 1kHz 0.01 1 0.1 fIN = 1kHz 0.01 fIN = 100Hz 4 6 8 10 12 14 16 18 20 MAX9744 toc03 fIN = 1kHz fIN = 100Hz 0.001 4 0 8 12 16 3 0 20 6 9 12 OUTPUT POWER (W) OUTPUT POWER (W) TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER fIN = 1kHz 0.01 0.1 0.01 fIN = 100Hz fIN = 100Hz 0.001 3 6 9 12 fIN = 100Hz 0 1 2 1 1 FFM 0.1 3 TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER 100 MAX9744 toc07 PVDD = 12V RL = 4Ω fIN = 1kHz FILTERLESS MODULATION 2 OUTPUT POWER (W) PVDD = 12V RL = 8Ω fIN = 1kHz FILTERLESS MODULATION 10 THD+N (%) THD+N (%) 0 4 3 OUTPUT POWER (W) TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER 10 fIN = 1kHz 0.001 OUTPUT POWER (W) 100 0.1 0.01 fIN = 1kHz 0.001 0 1 MAX9744 toc08 0.1 fIN = 6kHz fIN = 6kHz 1 PVDD = 5V RL = 4Ω PWM MODE 10 THD+N (%) THD+N (%) fIN = 6kHz 1 PVDD = 5V RL = 4Ω FILTERLESS MODULATION 10 100 MAX9744 toc05 10 100 MAX9744 toc04 PVDD = 12V RL = 8Ω PWM MODE MAX9744 toc06 OUTPUT POWER (W) 100 1 FFM 0.1 SSM 0.01 0.01 0.001 SSM 0.001 0 4 8 12 OUTPUT POWER (W) 6 0.1 0.01 0.001 2 fIN = 6kHz 1 fIN = 100Hz 0.001 0 PVDD = 12V RL = 8Ω FILTERLESS MODULATION 10 THD+N (%) THD+N (%) THD+N (%) fIN = 6kHz fIN = 6kHz 1 PVDD = 12V RL = 4Ω PWM MODE 10 100 MAX9744 toc02 PVDD = 12V RL = 4Ω FILTERLESS MODULATION 10 100 MAX9744 toc01 100 TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER THD+N (%) MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control 16 20 0 2 4 6 8 10 OUTPUT POWER (W) _______________________________________________________________________________________ 12 4 20W Stereo Class D Speaker Amplifier with Volume Control 0.01 MAX9744 toc10 OUTPUT POWER = 10W 0.1 OUTPUT POWER = 5W 0.01 0.001 8 12 16 PVDD = 12V RL = 4Ω PWM MODE 1 OUTPUT POWER = 10W 0.1 0.01 OUTPUT POWER = 5W 0.001 0.001 4 0 20 10 100 1k 10k 10 100k 100 1k 10k 100k FREQUENCY (Hz) FREQUENCY (Hz) TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY 1 OUTPUT POWER = 6W 0.1 0.01 1 OUTPUT POWER = 6W 0.1 0.01 OUTPUT POWER = 3W 0.001 100 1k 100k 10k 100 1k 10k 0.1 OUTPUT POWER = 500mW 10 100k 100 OUTPUT POWER = 500mW 0.1 100 10 PVDD = 12V RL = 4Ω FILTERLESS MODULATION POUT = 5W 0.001 100k 1 SSM 0.1 0.01 OUTPUT POWER = 1.5W 10k TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY MAX9744 toc15 1 1k FREQUENCY (Hz) THD+N (%) THD+N (%) PVDD = 5V RL = 4Ω PWM MODE 0.01 OUTPUT POWER = 1.5W FREQUENCY (Hz) TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY 10 1 0.001 10 FREQUENCY (Hz) 100 10 PVDD = 5V RL = 4Ω FILTERLESS MODULATION 0.01 OUTPUT POWER = 3W 0.001 10 100 MAX9744 toc16 THD+N (%) 10 PVDD = 12V RL = 8Ω PWM MODE THD+N (%) 100 MAX9744 toc12 10 PVDD = 12V RL = 8Ω FILTERLESS MODULATION MAX9744 toc14 OUTPUT POWER (W) 100 THD+N (%) 1 SSM 10 THD+N (%) FFM 100 MAX9744 toc13 THD+N (%) 1 0.1 PVDD = 12V RL = 4Ω FILTERLESS MODULATION 10 THD+N (%) PVDD = 12V RL = 4Ω fIN = 1kHz PWM MODE 10 100 MAX9744 toc09 100 TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY MAX9744 toc11 TOTAL HARMONIC DISTORTION PLUS NOISE vs. OUTPUT POWER FFM 0.001 10 100 1k FREQUENCY (Hz) 10k 100k 10 100 1k 10k 100k FREQUENCY (Hz) _______________________________________________________________________________________ 7 MAX9744 Typical Operating Characteristics (continued) (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_- with an inductor in series, 8Ω load, L = 68µH, 4Ω load, L= 33µH. RL = ∞, unless otherwise stated, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spread-spectrum mode, TA = +25°C, unless otherwise noted.) 20W Stereo Class D Speaker Amplifier with Volume Control MAX9744 Typical Operating Characteristics (continued) (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_- with an inductor in series, 8Ω load, L = 68µH, 4Ω load, L= 33µH. RL = ∞, unless otherwise stated, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spread-spectrum mode, TA = +25°C, unless otherwise noted.) SSM 1k 10k 5 40 4 30 3 20 2 20 1 10 0 0 0 100k 4 EFFICIENCY vs. OUTPUT POWER 2W 40 30 PVDD = 5V fIN = 1kHz RL = 4Ω 10 0W 2.5 MAX9744 toc21 THD+N = 1% 85 80 6 8 10 12 6 8 10 SUPPLY VOLTAGE (V) MAX9744 toc23 24 80 fIN = 1kHz RL = 4Ω PWM MODE 20 OUTPUT POWER (W) EFFICIENCY (%) THD+N = 1% 75 16 THD+N = 10% 12 8 THD+N = 1% 4 70 0 4 6 8 10 SUPPLY VOLTAGE (V) 8 fIN = 1kHz RL = 8Ω FILTERLESS MODULATION OUTPUT POWER vs. SUPPLY VOLTAGE THD+N = 10% 85 80 4 14 EFFICIENCY vs. SUPPLY VOLTAGE 90 85 SUPPLY VOLTAGE (V) fIN = 1kHz RL = 4Ω PWM MODE 12 10 70 4 OUTPUT POWER (W) 95 8 THD+N = 1% 90 75 70 3.0 6 THD+N = 10% 95 fIN = 1kHz RL = 4Ω FILTERLESS MODULATION 75 0 2.0 THD+N = 10% 90 4 MAX9744 toc24 20 100 2 100 EFFICIENCY (%) 50 EFFICIENCY (%) POWER DISSIPATION 60 1.5 0W 0 EFFICIENCY vs. SUPPLY VOLTAGE 95 70 1.0 PVDD = 12V fIN = 1kHz RL = 8Ω OUTPUT POWER (W) (PER CHANNEL) 100 PWM MODE 0.5 30 16 12 FILTERLESS MODULATION 0 40 EFFICIENCY vs. SUPPLY VOLTAGE MAX9744 toc20 80 50 OUTPUT POWER (W) 100 EFFICIENCY (%) 8 PWM MODE 60 6 PVDD = 12V, fIN = 1kHz, RL = 4Ω 5W 70 50 FREQUENCY (Hz) 90 80 7 0 100 10 8 60 10 0.001 90 FILTERLESS MODULATION POWER DISSIPATION FFM 0.1 PWM MODE 70 9 EFFICIENCY (%) 80 1 0.01 FILTERLESS MODULATION MAX9744 toc19 100 10 POWER DISSIPATION (mW) THD+N (%) 10 MAX9744 toc18 90 EFFICIENCY (%) PVDD = 12V RL = 8Ω FILTERLESS MODULATION POUT = 3W EFFICIENCY vs. OUTPUT POWER EFFICIENCY vs. OUTPUT POWER 100 MAX9744 toc17 100 MAX9744 toc22 TOTAL HARMONIC DISTORTION PLUS NOISE vs. FREQUENCY 14 4 6 8 10 12 SUPPLY VOLTAGE (V) _______________________________________________________________________________________ 14 12 14 20W Stereo Class D Speaker Amplifier with Volume Control THD+N = 10% 8 4 THD+N = 1% 3 THD+N = 10% 12 8 THD+N = 1% 0 0 8 12 10 10 15 20 0 30 25 10 15 20 25 30 SUPPLY VOLTAGE (V) LOAD RESISTANCE (Ω) CASE TEMPERATURE vs. OUTPUT POWER CASE TEMPERATURE vs. OUTPUT POWER POWER-SUPPLY REJECTION RATIO (PVDD) vs. FREQUENCY 50 PVDD = 12V FILTERLESS MODULATION 25 0 PVDD = 14V PWM MODE -20 PVDD = 12V PWM MODE 50 -30 PVDD = 12V FILTERLESS MODULATION 25 9 12 15 2 4 6 8 10 PSRR (dB) -30 PWM MODE -50 -60 -70 FILTERLESS MODULATION 10k 100k 40 MAX9744 toc32 -20 1k EMI WITH FERRITE BEAD FILTERS (VDD = 12V, 1m CABLE, 8Ω LOAD) 35 OUTPUT MAGNITUDE (dBV) MAX9744 toc31 VDD = 3.3V VRIPPLE = 100mVP-P 100 FREQUENCY (Hz) OUTPUT POWER (W) 0 -80 10 12 POWER-SUPPLY REJECTION RATIO (VDD) vs. FREQUENCY -40 FILTERLESS MODULATION -100 0 18 OUTPUT POWER (W) -10 -60 -80 0 6 PWM MODE -50 -90 0 3 -40 -70 PVDD = 14V FILTERLESS MODULATION PVDD = 14V FILTERLESS MODULATION PVDD = 12V VRIPPLE = 200mVP-P -10 PSRR (dB) PVDD = 12V PWM MODE fIN = 1kHz RL = 8Ω MAX9744 toc30 75 MAX9744 toc29 PVDD = 14V PWM MODE 100 0 5 LOAD RESISTANCE (Ω) fIN = 1kHz RL = 4Ω 75 5 0 14 CASE TEMPERATURE (°C) 125 6 MAX9744 toc28 4 THD+N = 10% 2 1 THD+N = 1% 4 PVDD = 5V f = 1kHz PWM MODE MAX9744 toc27 16 0 CASE TEMPERATURE (°C) PVDD = 12V f = 1kHz FILTERLESS MODULATION OUTPUT POWER (W) 12 4 MAX9744 toc26 MAX9744 toc25 20 OUTPUT POWER (W) OUTPUT POWER (W) RL = 8Ω fIN = 1kHz PWM MODE OUTPUT POWER vs. LOAD RESISTANCE OUTPUT POWER vs. LOAD RESISTANCE OUTPUT POWER vs. SUPPLY VOLTAGE 16 EN5022 B LIMIT 30 25 20 15 10 -90 5 -100 10 100 1k FREQUENCY (Hz) 10k 100k 30 100 60 80 140 180 220 260 300 120 160 200 240 280 FREQUENCY (MHz) _______________________________________________________________________________________ 9 MAX9744 Typical Operating Characteristics (continued) (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_- with an inductor in series, 8Ω load, L = 68µH, 4Ω load, L= 33µH. RL = ∞, unless otherwise stated, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spread-spectrum mode, TA = +25°C, unless otherwise noted.) 20W Stereo Class D Speaker Amplifier with Volume Control MAX9744 Typical Operating Characteristics (continued) (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_- with an inductor in series, 8Ω load, L = 68µH, 4Ω load, L= 33µH. RL = ∞, unless otherwise stated, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spread-spectrum mode, TA = +25°C, unless otherwise noted.) OUTPUT WAVEFORM (PWM) OUTPUT FREQUENCY SPECTRUM MAX9744 toc34 0 2V/div 2V/div 2V/div 2V/div FFM MODE VIN = -60dBV f = 1kHz RL = 4Ω UNWEIGHTED -20 OUTPUT MAGNITUDE (dBV) MAX9744 toc33 -40 MAX9744 toc35 OUTPUT WAVEFORM (FILTERLESS MODULATION) -60 LEFT -80 -100 -120 RIGHT -140 0 -60 LEFT -100 -40 -60 -80 5 10 15 20 1 -60 -80 0 100 10 1 WIDEBAND OUTPUT SPECTRUM (SPREAD-SPECTRUM MODULATION MODE) 20 MAX9744 toc39 -20 -40 -60 -80 RBW = 1kHz INPUT AC GROUNDED PWM MODE 0 OUTPUT AMPLITUDE (dBV) RBW = 1kHz INPUT AC GROUNDED FILTERLESS MODULATION 10 FREQUENCY (MHz) FREQUENCY (MHz) WIDEBAND OUTPUT SPECTRUM (SPREAD-SPECTRUM MODULATION MODE) 0 -40 -120 0 FREQUENCY (kHz) 20 -20 -100 -120 0 -20 -40 -60 -80 -100 -100 -120 -120 0 1 10 FREQUENCY (MHz) 20 MAX9744 toc38 MAX9744 toc37 -20 RBW = 1kHz INPUT AC GROUNDED PWM MODE 0 -100 RIGHT -140 10 20 MAX9744 toc40 -120 RBW = 1kHz INPUT AC GROUNDED FILTERLESS MODULATION 0 15 WIDEBAND OUTPUT SPECTRUM (FIXED-FREQUENCY MODULATION MODE) OUTPUT AMPLITUDE (dBV) -40 OUTPUT AMPLITUDE (dBV) OUTPUT MAGNITUDE (dBV) -20 20 OUTPUT AMPLITUDE (dBV) SSM MODE VIN = -60dBV f = 1kHz RL = 4Ω UNWEIGHTED MAX9744 toc36 0 10 FREQUENCY (kHz) WIDEBAND OUTPUT SPECTRUM (FIXED-FREQUENCY MODULATION MODE) OUTPUT FREQUENCY SPECTRUM -80 5 1μs/div 1μs/div 100 0 1 10 FREQUENCY (MHz) ______________________________________________________________________________________ 100 100 20W Stereo Class D Speaker Amplifier with Volume Control CROSSTALK vs. FREQUENCY CROSSTALK vs. AMPLITUDE RL = 8Ω f = 1kHz -10 -20 CROSSTALK (dB) -40 -60 LEFT TO RIGHT -80 SHDN 2V/div -30 -40 -50 RIGHT TO LEFT LEFT TO RIGHT -60 -70 -100 OUTPUT -80 RIGHT TO LEFT -90 -120 -100 100 1k 100k 10k -60 FREQUENCY (Hz) -50 -40 -30 -20 -10 0 20 10 100ms/div AMPLITUDE (dBV) VOLUME CONTROL LEVEL vs. VOLUME CONTROL VOLTAGE 14 SUPPLY CURRENT (mA) VOLUME CONTROL LEVEL 16 -20 -40 -60 -80 MAX9744 toc45 0 SUPPLY CURRENT (PVDD) vs. SUPPLY VOLTAGE MAX9744 toc44 20 12 PWM MODE 10 8 6 FILTERLESS MODULATION 4 -100 2 -120 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4 6 8 10 12 VVOL (V) SUPPLY VOLTAGE (V) SUPPLY CURRENT (VDD) vs. SUPPLY VOLTAGE SHUTDOWN CURRENT vs. SUPPLY VOLTAGE 0.8 MAX9744 toc46 30 FILTERLESS MODULATION 20 PWM MODE 15 SHUTDOWN CURRENT = IPVDD + IDD VDD = 3.3V SHUTDOWN CURRENT (μA) 25 14 MAX9744 toc47 VOLUME LEVEL (dB) 10 SUPPLY CURRENT (mA) CROSSTALK (dB) -20 MAX9744 toc43 MAX9744 toc42 VIN = 200mVRMS TURN-ON/OFF RESPONSE 0 MAX9744 toc41 0 0.7 0.6 0.5 10 5 0.4 3.0 3.2 3.4 3.6 SUPPLY VOLTAGE (V) 3.8 4.0 4 6 8 10 12 14 SUPPLY VOLTAGE (V) ______________________________________________________________________________________ 11 MAX9744 Typical Operating Characteristics (continued) (VPVDD = 12V, VDD = 3.3V, VGND = VPGND = 0V, VMUTE = 0V; max volume setting; all speaker load resistors connected between OUT_+ and OUT_- with an inductor in series, 8Ω load, L = 68µH, 4Ω load, L= 33µH. RL = ∞, unless otherwise stated, CBIAS = 2.2µF, CIN = 0.47µF, RIN = 20kΩ, RF_ = 20kΩ, spread-spectrum mode, TA = +25°C, unless otherwise noted.) 20W Stereo Class D Speaker Amplifier with Volume Control MAX9744 Pin Description PIN NAME 1 BOOTL+ 2, 3 OUTL+ 4, 5, 29, 30 PVDD 6, 10, 21, 28 VDD Power-Supply Input. Bypass each with a 1µF capacitor to GND. 7, 11, 12, 15, 27 GND Ground 8 SDA/VOL 9 Left-Channel Positive Speaker Output Boost Flying-Capacitor Connection. Connect a 0.1µF ceramic capacitor between BOOTL+ and OUTL+. Left-Channel Speaker Output, Positive Phase Speaker Amplifier Power-Supply Input. Bypass each with a 1µF capacitor to PGND. I2C Serial Data I/O and Analog Volume Control Input I2C Serial Clock Input and Modulation Scheme Select. In I2C mode (ADDR1 and ADDR2 ≠ GND), SCLK/PWM acts as I2C serial clock input. When ADDR1 and ADDR2 = GND, set SCLK = 1 for standard PWM output scheme, or set SCLK = 0 for filterless modulation output scheme. 13 ADDR1 Address Select Input 1. Sets device address for I2C address option. Connect ADDR1 and ADDR2 to GND to select analog volume control mode. 14 ADDR2 Address Select Input 2. Sets device address for I2C address option. Connect ADDR1 and ADDR2 to GND to select Analog Volume Control mode. 16 INL Left-Channel Audio Input 17 FBL Left-Channel Feedback. Connect feedback resistor between FBL and INL to set amplifier gain. See the Gain-Setting Resistors section. 18 FBR Right-Channel Feedback. Connect feedback resistor between FBR and INR to set amplifier gain. See the Gain-Setting Resistors section. 19 INR Right-Channel Input 20 BIAS Common-Mode Bias Voltage. Bypass with a 2.2µF capacitor to GND. 22 SHDN Shutdown Input. Drive SHDN low to disable the audio amplifiers. Connect SHDN to VDD or drive high for normal operation. 23 N.C. 24 MUTE Mute Input. Drive MUTE high to mute the speaker outputs. Connect MUTE to GND for normal operation (mute function controls speaker outputs only). SYNC Frequency Select and External Clock Input. SYNC = GND: Fixed-frequency mode with fSYNC = 1200kHz SYNC = Unconnected: Fixed-frequency mode with fSYNC = 1440kHz SYNC = VDD: Spread-spectrum mode with fSYNC = 1200kHz ±30kHz SYNC = Clocked: Fixed-frequency mode with fSYNC = external clock frequency. fSW = 1/4 the value of fSYNC. 25 12 FUNCTION No Connection. Not internally connected. ______________________________________________________________________________________ 20W Stereo Class D Speaker Amplifier with Volume Control PIN NAME 26 SYNCOUT 31, 32 OUTR+ 33 BOOTR+ 34, 35, 39, 43, 44 PGND 36, 37 OUTR- FUNCTION SYNC Signal Output Right-Channel Positive Speaker Output Right-Channel Positive Speaker Output Boost Flying-Capacitor Connection. Connect a 0.1µF ceramic capacitor between BOOTR+ and OUTR+. Power Ground Right-Channel Negative Speaker Output 38 BOOTR- Right-Channel Negative Speaker Output Boost Flying-Capacitor Connection. Connect a 0.1µF ceramic capacitor between BOOTR- and OUTR-. 40 BOOTL- Left-Channel Negative Speaker Output Boost Flying-Capacitor Connection. Connect a 0.1µF ceramic capacitor between BOOTL- and OUTL-. 41, 42 OUTL- — EP Left-Channel Negative Speaker Output Exposed Pad. The external pad lowers the package’s thermal impedance by providing a direct heat conduction path from the die to the PCB. Connect the exposed thermal pad to PGND. Detailed Description The MAX9744 20W filterless, stereo Class D audio power amplifier offers Class AB performance with Class D efficiency with a minimal board space solution. The MAX9744 features a spread-spectrum modulation scheme offering significant improvements to switchmode amplifier technology. This device features analog or digitally adjustable volume control, externally set input gain, shutdown mode, SYNC input and output, mute, and industry-leading click-and-pop suppression. The MAX9744 features extensive click-and-pop suppression circuitry that eliminates audible clicks-andpops at startup and shutdown. The MAX9744 features a 64-step, dual-mode (analog or I2C) volume control and mute function. In analog volume control mode, the voltage applied to SDA/VOL sets the volume level. Two address inputs (ADDR1, ADDR2) set the volume control function between analog and I2C mode and set the slave address. In I2C mode, there are three selectable slave addresses allowing for multiple devices on a single bus. The MAX9744 offers spread-spectrum and fixed-frequency modes of operation with classic PWM or filterless modulation output schemes. The filterless modulation scheme uses minimum pulse outputs when the audio inputs are at the zero crossing. As the input voltage increases or decreases, the duration of the pulse at one output increases while the other output pulse duration remains the same. This causes the net voltage across the speaker (VOUT+ - VOUT-) to change. The minimum-width pulse topology reduces EMI and increases efficiency. Operating Modes Fixed-Frequency Modulation Mode The MAX9744 features two fixed-frequency modes: 300kHz and 360kHz. Connect SYNC to GND to select 300kHz switching frequency; leave SYNC unconnected to select the 360kHz switching frequency. The MAX9744 frequency spectrum consists of the fundamental switching frequency and its associated harmonics (see the Wideband Output Spectrum graphs in the Typical Operating Characteristics). For applications where exact spectrum placement of the switching fundamental is important, program the switching frequency so that the harmonics do not fall within a sensitive frequency band (Table 1). Audio reproduction is not affected by changing the switching frequency. ______________________________________________________________________________________ 13 MAX9744 Pin Description (continued) MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control Spread-Spectrum Modulation Mode The MAX9744 features a unique spread-spectrum mode that flattens the wideband spectral components, improving EMI emissions that may be radiated by the speaker and cables. This mode is enabled by setting SYNC = VDD (Table 1). In spread-spectrum mode, the switching frequency varies randomly by ±7.5kHz around the center frequency (300kHz). The modulation scheme remains the same, but the period of the triangle waveform changes from cycle to cycle. Instead of a large amount of spectral energy present at multiples of the switching frequency, the energy is now spread over a bandwidth that increases with frequency. Above a few megahertz, the wideband spectrum looks like white noise for EMI purposes. A proprietary amplifier topology ensures this does not corrupt the noise floor in the audio bandwidth. External Clock Mode The SYNC input allows the MAX9744 to be synchronized to an external clock or another Maxim Class D amplifier, creating a fully synchronous system. This minimizes clock intermodulation and allocates spectral components of the switching harmonics to insensitive frequency bands. Applying a clock signal between 1MHz and 1.6MHz to SYNC synchronizes the MAX9744. The MAX9744 Class D amplifier operates at 1/4 of the SYNC frequency. For example, if SYNC is 1.6MHz, the Class D amplifier operates at 400kHz. The external SYNC signal can be any CMOS clock source with a 40% to 60% duty cycle. Spread-spectrum clocks work well to reduce EMI; therefore, the SYNCOUT signal from another MAX9744 in spreadspectrum mode is an excellent SYNC input. Table 1. Operating Modes SYNC MODE Fixed-frequency modulation 1200 300 Unconnected Fixed-frequency modulation 1440 360 VDD Spread-spectrum modulation 1200 ±30 300 ±7.5 1000 to 1600 250 to 400 EXT Filterless Modulation/PWM Modulation The MAX9744 features two output modulation schemes: filterless modulation or classic PWM. The MAX9744 output modulation schemes are selectable through SCLK/PWM when the device is in analog mode (ADDR1 and ADDR2 = GND, Table 2) or through the I2C interface (Table 8). Maxim’s unique, filterless modulation scheme eliminates the LC filter required by traditional Class D amplifiers, reducing component count and conserving board space and system cost. Although the MAX9744 meets FCC and other EMI limits with a lowcost ferrite bead filter, many applications still may want to use a full LC-filtered output. If using a full LC filter, audio performance is best with the MAX9744 configured for classic PWM output. Switching between schemes, the output is not click-andpop protected. To have click-and-pop protection when switching between output schemes, the device must enter shutdown mode and be configured to the new output scheme before the startup sequence is finished. MAX9744 SYNC INPUT OUTL+ OUTL- SYNC OUTR+ OUTR- fSYNC (kHz) fSW (kHz) GND Clocked SYNCOUT allows several Maxim amplifiers to be cascaded (Figure 1). The synchronized output minimizes interference due to clock intermodulation caused by the switching spread between single devices. Using SYNCOUT and SYNC does not affect the audio performance of the MAX9744. SYNCOUT MAX9709 SYNC OUT+ OUT- Figure 1. Cascading Two Amplifiers’ External Clock Mode 14 ______________________________________________________________________________________ 20W Stereo Class D Speaker Amplifier with Volume Control ADDR2 ADDR1 SDA/VOL SCLK/PWM 0 0 Analog volume control 0 Filterless modulation FUNCTION 0 0 Analog volume control 1 Classic PWM (50% duty cycle) Efficiency Thermal Shutdown The high efficiency of a Class D amplifier is due to the switching operation of the output stage transistors. In a Class D amplifier, the output transistors act as currentsteering switches and consume negligible additional power. Any power loss associated with the Class D output stage is mostly due to the I2R loss of the MOSFET on-resistance, and quiescent current overhead. The theoretical best efficiency of a linear amplifier is 78% at peak output power. Under normal operating levels (typical music reproduction levels), the efficiency falls below 30%, whereas the MAX9744 exhibits > 80% efficiency under the same conditions (Figure 2). When the die temperature exceeds the thermal-shutdown threshold, +165°C (typ), the MAX9744 outputs are disabled. Normal operation resumes when the die temperature decreases by a factor equal to the thermal-shutdown threshold minus the thermal-shutdown hysteresis, (typically below +150°C). The effect of thermal shutdown is an output signal turning off for approximately 3s in most applications, depending on the thermal time constant of the audio system. Most applications should never enter thermal shutdown. Some of the possible causes of thermal shutdown are too low of a load impedance, bad thermal contact between the MAX9744’s exposed pad and PCB, high ambient temperature, poor PCB layout and assembly, or excessive output overdrive. Current Limit When the output current exceeds the current limit, 5.5A (typ), the MAX9744 disables the outputs and initiates a 220µs startup sequence. The shutdown and startup sequence is repeated until the output fault is removed. Since the retry repetition is slow, the average supply current is low. Most applications do not enter currentlimit mode unless the output is short circuited or incorrectly connected. EFFICIENCY vs. OUTPUT POWER MAX9744/45 fig02 100 90 EFFICIENCY (%) 80 70 MAX9744 60 50 40 30 CLASS AB 20 PVDD = 12V fIN = 1kHz RL = 4Ω 10 Shutdown The MAX9744 features a shutdown mode that reduces power consumption and extends battery life. Driving SHDN low places the device in low-power shutdown mode. Connect SHDN to digital high for normal operation. In shutdown mode, the outputs are high impedance, SYNCOUT is pulled high, BIAS voltage decays to zero, and the common-mode input voltage decays to zero. The I2C register does not retain its contents during shutdown (MAX9744). Mute Function The MAX9744 features a clickless-and-popless mute mode. When the device is muted, the outputs do not stop switching; only the volume level is muted to the speaker. Mute only affects the output stage and does not shut down the device. To mute the MAX9744, drive MUTE to logic-high. MUTE should be held high during system power-up and power-down to ensure that pops caused by circuits before the MAX9744 are eliminated. To reduce clicks and pops, the device enters or exits mute at zero crossing. 0 0 2 4 6 8 10 OUTPUT POWER (W) Figure 2. MAX9744 Efficiency vs. Class AB Efficiency ______________________________________________________________________________________ 15 MAX9744 Table 2. Modulation Scheme Selection MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control Volume Control For maximum flexibility, the MAX9744 features volume control operation using an analog voltage input or through the I2C interface. To set the device to analog mode, connect ADDR1 and ADDR2 to GND. In analog mode, SDA/VOL is an analog input for volume control. The analog input range is ratiometric between 0.9 x VDD and 0.1 x VDD where 0.9 x VDD = full mute and 0.1 x VDD = full volume (Table 7). Use ADDR1 and ADDR2 to select I2C mode. There are three addresses that can be chosen, allowing for multiple devices on a single bus (Table 4). In I2C mode, volume is controlled by choosing the speaker volume control register in the command byte (Table 5). There are 64 volume settings, where the lowest setting is full mute (Table 6). See the Write Byte section for more information on formatting data and tables to set volume levels. The default volume after power-up is position 40 (-7.1dB) (see Table 7). I2C Interface The MAX9744 features an I2C 2-wire serial interface consisting of a serial-data line (SDA) and a serial-clock line (SCL). SDA and SCL facilitate communication between the MAX9744 and the master at clock rates up to 400kHz. Figure 3 shows the 2-wire interface timing diagram. The MAX9744 is a receive-only slave device, relying on the master to generate the SCL signal. The MAX9744 cannot write to the SDA bus except to acknowledge the receipt of data from the master. The master, typically a microcontroller, generates SCL and initiates data transfer on the bus. A master device communicates to the MAX9744 by transmitting the proper address followed by the data word. Each transmit sequence is framed by a START (S) or Repeated START (Sr) condition and a STOP (P) condition. Each word transmitted over the bus is 8 bits long and is always followed by an acknowledge clock pulse. The MAX9744 SDA line operates as both an input and an open-drain output. A pullup resistor, greater than 500Ω, is required on the SDA bus. The MAX9744 SCL line operates as an input only. A pullup resistor, greater than 500Ω, is required on SCL if there are multiple masters on the bus, or if the master in a single-master system has an open-drain SCL output. Series resistors in line with SDA and SCL are optional. The SCL and SDA inputs have Schmitt trigger and filter circuits that suppress noise spikes to assure proper device operation even on a noisy bus. SDA tBUF tSU, STA tSU, DAT tHD, STA tHD, DAT tLOW tSP tSU, STO SCL tHIGH tHD, STA tR tF START CONDITION REPEATED START CONDITION STOP CONDITION Figure 3. 2-Wire Serial-Interface Timing Diagram 16 ______________________________________________________________________________________ START CONDITION 20W Stereo Class D Speaker Amplifier with Volume Control START and STOP Conditions A master device initiates communication by issuing a START condition. A START condition is a high to low transition on SDA with SCL high. A STOP condition is a low to high transition on SDA while SCL is high (Figure 4). A START (S) condition from the master signals the beginning of a transmission to the MAX9744. The master terminates transmission, and frees the bus, by issuing a STOP (P) condition. The bus remains active if a Repeated START (Sr) condition is generated instead of a STOP condition. S Sr P SCL SDA Early STOP Conditions The MAX9744 recognizes a STOP condition at any point during data transmission except if the STOP condition occurs in the same high pulse as a START condition. Slave Address The slave address of the MAX9744 is 8 bits and consists of 3 fields: the first field is 5 bits wide and is fixed (10010), the second is a 2 bit field which is set through ADDR1 and ADDR2 (externally connected as logic-high or logic-low), and the third field is a R/W flag bit. Set R/W = 0 to write to the slave. A representation of the slave address is shown in Table 3. When ADDR1 and ADDR2 are connected to GND, serial interface communication is disabled. Table 4 summarizes the slave address of the device as a function of ADDR1 and ADDR2. Acknowledge The acknowledge bit (ACK) is a clocked 9th bit that the MAX9744 uses to handshake receipt of each byte of data (see Figure 5). The MAX9744 pulls down SDA during the master-generated 9th clock pulse. The SDA line must remain stable and low during the high period of the acknowledge clock pulse. Monitoring ACK allows for detection of unsuccessful data transfers. An unsuccessful data transfer occurs if a receiving device is busy or if a system fault has occurred. In the event of an unsuccessful data transfer, the bus master may reattempt communication. Figure 4. START, STOP, and Repeated START Conditions Table 3. Slave Address Block SA7 (MSB) SA6 SA5 SA4 SA3 SA2 SA1 SA0 (LSB) 1 0 0 1 0 ADDR2 ADDR1 R/W Table 4. Slave Address ADDR2 ADDR1 SLAVE ADDRESS 0 0 I2C disabled 0 1 1001001_ 1 0 1001010_ 1 1 1001011_ CLOCK PULSE FOR ACKNOWLEDGMENT START CONDITION SCL 1 2 8 9 NOT ACKNOWLEDGE SDA ACKNOWLEDGE Figure 5. Acknowledge ______________________________________________________________________________________ 17 MAX9744 Bit Transfer One data bit is transferred during each SCL cycle. The data on SDA must remain stable during the high period of the SCL pulse. Changes in SDA while SCL is high are control signals (see the START and STOP Conditions section). SDA and SCL idle high when the I2C bus is not busy. MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control Write Byte A write to the MAX9744 includes transmission of a START condition, the slave address with the R/W bit set to 0 (see Table 3), one byte of data to the command register, and a STOP condition. Figure 6 illustrates the proper format for one frame. A write to the MAX9744 consists of a 6-step sequence as seen below: 1) The master sends a START condition. 2) The master sends the 7 bits slave ID plus a write bit (low). 3) The addressed slave asserts an ACK on the data line. 4) The master sends 8 data bits. 5) The active slave asserts an ACK (or NACK) on the data line. 6) The master generates a stop condition. Speaker Volume Control The command register is used to control the volume level of the speaker amplifier. The two MSBs (A1 and A0) are set to 00, while V5–V0 is the data that is written into the addresses register to set the volume level (Tables 5 and 6). WRITE BYTE FORMAT S SLAVE ADDRESS 7 BITS WR ACK DATA P 8 BITS 0 SLAVE ADDRESS: EQUIVALENT TO CHIPSELECT LINE OF A 3-WIRE INTERFACE. ACK DATA BYTE: GIVES A COMMAND. Figure 6. Write Byte Format Example Filterless Modulation/PWM The MAX9744 features two output modulation schemes: filterless modulation or classic PWM, selectable through the I2C interface. Table 6 shows the register command to set the output scheme. When switching between schemes, the output is not click-and-pop protected. To have click-and-pop protection when switching between output schemes, the device must enter shutdown mode and be configured to the new output scheme before the 220ms startup sequence is terminated. Table 5. Data Byte Format D7 (MSB) D6 D5 D4 D3 D2 D1 D0 (LSB) A1 A0 V5 V4 V3 V2 V1 V0 Table 6. Command Register Programming A0 A1 18 V5–V0 SETTING A0 A1 V5–V0 XXXXXX Reserved SETTING 00 XXXXXX Volume level (Table 7) 10 01 000000 Filterless modulation 11 000100 Increased volume 01 000001 Classic PWM 11 000101 Decreased volume ______________________________________________________________________________________ 20W Stereo Class D Speaker Amplifier with Volume Control MAX9744 Table 7. Speaker Volume Levels V5 V4 V3 V2 V1 V0 VOLUME POSITION SDA/VOL VOLUME VOLUME INPUT VOLTAGE (V) ATTENUATION (dB) 1 1 1 1 1 1 63 0.100 x VDD 9.5 1 1 1 1 1 0 62 0.113 x VDD 8.8 1 1 1 1 0 1 61 0.125 x VDD 8.2 1 1 1 1 0 0 60 0.138 x VDD 7.6 1 1 1 0 1 1 59 0.151 x VDD 7.0 1 1 1 0 1 0 58 0.163 x VDD 6.5 1 1 1 0 0 1 57 0.176 x VDD 5.9 1 1 1 0 0 0 56 0.189 x VDD 5.4 1 1 0 1 1 1 55 0.202 x VDD 4.9 1 1 0 1 1 0 54 0.214 x VDD 4.4 1 1 0 1 0 1 53 0.227 x VDD 3.9 1 1 0 1 0 0 52 0.240 x VDD 3.4 1 1 0 0 1 1 51 0.252 x VDD 2.9 1 1 0 0 1 0 50 0.265 x VDD 2.4 1 1 0 0 0 1 49 0.278 x VDD 2.0 1 1 0 0 0 0 48 0.290 x VDD 1.6 1 0 1 1 1 1 47 0.303 x VDD 1.2 1 0 1 1 1 0 46 0.316 x VDD 0.5 1 0 1 1 0 1 45 0.329 x VDD -0.5 1 0 1 1 0 0 44 0.341 x VDD -1.9 1 0 1 0 1 1 43 0.354 x VDD -3.4 1 0 1 0 1 0 42 0.367 x VDD -5.0 1 0 1 0 0 1 41 0.379 x VDD -6.0 1 0 1 0 0 0 40 0.392 x VDD -7.1 1 0 0 1 1 1 39 0.405 x VDD -8.9 1 0 0 1 1 0 38 0.417 x VDD -9.9 1 0 0 1 0 1 37 0.430 x VDD -10.9 1 0 0 1 0 0 36 0.443 x VDD -12.0 1 0 0 0 1 1 35 0.456 x VDD -13.1 1 0 0 0 1 0 34 0.468 x VDD -14.4 1 0 0 0 0 1 33 0.481 x VDD -15.4 1 0 0 0 0 0 32 0.494 x VDD -16.4 ______________________________________________________________________________________ 19 MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control Table 7. Speaker Volume Levels (continued) 20 V5 V4 V3 V2 V1 V0 VOLUME POSITION SDA/VOL VOLUME VOLUME INPUT VOLTAGE (V) ATTENUATION (dB) 0 1 1 1 1 1 31 0.506 x VDD -17.5 0 1 1 1 1 0 30 0.519 x VDD -19.7 0 1 1 1 0 1 29 0.532 x VDD -21.6 0 1 1 1 0 0 28 0.544 x VDD -23.5 0 1 1 0 1 1 27 0.557 x VDD -25.2 0 1 1 0 1 0 26 0.570 x VDD -27.2 0 1 1 0 0 1 25 0.583 x VDD -29.8 0 1 1 0 0 0 24 0.595 x VDD -31.5 0 1 0 1 1 1 23 0.608 x VDD -33.4 0 1 0 1 1 0 22 0.621 x VDD -36.0 0 1 0 1 0 1 21 0.633 x VDD -37.6 0 1 0 1 0 0 20 0.646 x VDD -39.6 0 1 0 0 1 1 19 0.659 x VDD -42.1 0 1 0 0 1 0 18 0.671 x VDD -43.7 0 1 0 0 0 1 17 0.684 x VDD -45.6 0 1 0 0 0 0 16 0.697 x VDD -48.1 0 0 1 1 1 1 15 0.710 x VDD -50.6 0 0 1 1 1 0 14 0.722 x VDD -54.2 0 0 1 1 0 1 13 0.735 x VDD -56.7 0 0 1 1 0 0 12 0.748 x VDD -60.2 0 0 1 0 1 1 11 0.760 x VDD -62.7 0 0 1 0 1 0 10 0.773 x VDD -66.2 0 0 1 0 0 1 9 0.786 x VDD -68.7 0 0 1 0 0 0 8 0.798 x VDD -72.2 0 0 0 1 1` 1 7 0.811 x VDD -74.7 0 0 0 1 1 0 6 0.824 x VDD -78.3 0 0 0 1 0 1 5 0.837 x VDD -80.8 0 0 0 1 0 0 4 0.849 x VDD -84.3 0 0 0 0 1 1 3 0.862 x VDD -86.8 0 0 0 0 1 0 2 0.875 x VDD -90.3 0 0 0 0 0 1 1 0.887 x VDD -92.8 0 0 0 0 0 0 0 0.900 x VDD MUTE ______________________________________________________________________________________ 20W Stereo Class D Speaker Amplifier with Volume Control Filterless Class D Operation The MAX9744 meets common EMC radiation limits without a filter when the speaker leads are less than approximately 10cm. Using lengths beyond 10cm is possible verifying against the appropriate EMC standard. For longer speaker wire lengths, up to approximately 1m, use a simple ferrite bead and capacitor filter to meet EMC limits. Select a ferrite bead with 100Ω to 600Ω impedance, and rated for at least 3A. The capacitor value varies based on the ferrite bead chosen and the actual speaker lead length. Select the capacitor value based on EMC performance. See Figure 7 for the correct connections of these components. When evaluating the device without a filter or a ferrite bead filter, include a series inductor (68µH for 8Ω load and 33µH for 4Ω load) to model the actual loudspeaker’s behavior. Omitting this inductor reduces the efficiency, the THD+N performance, and the output power of the MAX9744. Inductor-Based Output Filters Some applications use the MAX9744 with a full inductor/capacitor-based (LC) output filter. This is common for longer speaker lead lengths and to gain increased margin to EMC limits. Select the PWM output mode and use fixed-frequency modulation mode for best audio performance. See Figure 8 for the correct connections of these components. The component selection is based on the load impedance of the speaker. Table 8 lists suggested values for a variety of load impedances. Inductors L1 and L2 and capacitor C1 form the primary output filter. In addition to these primary filter components, other components in the filter improve its functionality. Capacitors C4 and C5 plus resistors R1 and R2 form a Zobel at the output. A Zobel corrects the output loading to compensate for the rising impedance of the loudspeaker. Without a Zobel, the filter has a peak in its response near the cutoff frequency. Capacitors C2 and C3 provide common-mode noise suppression to reduce radiated emissions. Table 8. Suggested Values for LC filter BOOT_+ OUT_+ CBOOT 0.1μF MAX9744 CFILT 470pF RL (Ω) L1, L2 (µH) C1 (µF) C2, C3 (µF) R1, R2 (Ω) C4, C5 (µF) 4 10 0.47 0.47 10 0.47 6 15 0.33 0.22 15 0.33 8 22 0.22 0.22 22 0.22 OUT_- BOOT_- CFILT 470pF CBOOT 0.1μF Figure 7. Ferrite Bead Filter 4 1, 2 BOOT+ OUT+ CBOOT 0.1μF L1 MAX9744 C2 C4 R1 RL C1 14, 18 15 L2 OUT- BOOT- CBOOT 0.1μF C3 C5 R2 Figure 8. Output Filter for PWM Mode ______________________________________________________________________________________ 21 MAX9744 Applications Information Component Selection Gain-Setting Resistors External feedback resistors set the gain of the MAX9744. The output stage has an internal 20dB gain in addition to the externally set input stage gain. Set the maximum gain by using resistors RF and RIN (Figure 9) as follows: ⎛R ⎞ A V = −30 ⎜ F ⎟ V / V ⎝ RIN ⎠ Choose R F between 10kΩ and 50kΩ. Note that the actual gain of the amplifier is dependent on the volume level setting. For example, with the volume set to +9.5dB, the amplifier gain would be 9.5dB plus 20dB, assuming RIN = RF. The input amplifier can be configured into a variety of circuits. The FB terminal is an actual operational amplifier output, allowing the MAX9744 to be configured as a summing amplifier, a filter, or an equalizer, for example. Input Capacitor An input capacitor (CIN) in conjunction with the input impedance of the MAX9744 form a highpass filter that removes the DC bias from an incoming signal. The ACcoupling capacitor allows the amplifier to automatically bias the signal to an optimum DC level. Assuming zero source impedance, the -3dB point of the highpass filter is given by: f−3dB = 1 2πRINCIN Choose CIN that f-3dB is well below the lowest frequency of interest. Use capacitors whose dielectrics have low-voltage coefficients, such as tantalum or aluminum electrolytic. Capacitors with high-voltage coefficients, such as ceramics, may result in increased distortion at low frequencies. DC-Coupled Input The input amplifier can accept DC-coupled inputs that are biased to the amplifier’s bias voltage. DC-coupling eliminates input-coupling capacitors, reducing component count to potentially one external component. In this configuration the highpass filtering effect of the capacitors is lost, allowing low-frequency signals to be amplified. Power Supplies The MAX9744 features separate supplies for each portion of the device, allowing for the optimum combination of headroom power dissipation and noise immunity. The speaker amplifier is powered from PVDD and can range from 4.5V to 14V. The remainder of the device is powered by VDD. Power supplies are independent of each other so sequencing is not necessary. Power may be supplied by separate sources or derived from a single higher source using a linear regulator (Figure 10). BIAS Capacitor BIAS is the output of the internally generated DC bias voltage. The BIAS bypass capacitor, CBIAS, improves PSRR and THD+N by reducing power supply and other noise sources at the common-mode bias node, and also generates the clickless/popless, startup/shutdown, DC bias waveforms for the speaker amplifiers. Bypass BIAS with a 2.2µF capacitor to GND. 4.5V TO 14.5V MAX9744 AUDIO CIN INPUT BOOT+ IN IN RF FB OUT+ VOLUME CONTROL 9.5dB (max) PVDD 1μF 1μF RIN CLASS D 20dB MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control OUT 3.3V SHDN VDD MAX1615 MAX9744 OUT- GND BOOT- GND Figure 9. Setting Gain 22 Figure 10. Using a Linear Regulator to Produce 3.3V from a Higher Power Supply ______________________________________________________________________________________ 20W Stereo Class D Speaker Amplifier with Volume Control Use large, low-resistance output traces. Current drawn from the outputs increase as load impedance decreases. High output trace resistance decreases the power delivered to the load. Large output, supply, and GND traces allow more heat to move from the MAX9744 to the air, decreasing the thermal impedance of the circuit. The MAX9744 thin QFN package features an exposed thermal pad on its underside. This pad lowers the package’s thermal resistance by providing a direct heat conduction path from the die to the PCB. Connect the exposed thermal pad to PGND by using a large pad and multiple vias to the PGND plane. The exposed pad must be connected to PGND for proper device operation. Proper layout and grounding are essential for optimum performance. Use large traces for the power-supply inputs and amplifier outputs to minimize losses due to parasitic trace resistance. Large traces also aid in moving heat away from the package. Proper grounding improves audio performance, minimizes crosstalk between channels, and prevents any switching noise from coupling into the audio signal. Connect PGND and GND together at a single point on the PCB. Route all traces that carry switching transients away from GND and the traces/components in the audio signal path. Connect all PVDD power supplies together and bypass with a 1µF capacitor to PGND. Connect all VDD power supplies together and bypass with a 1µF capacitor to GND. Place a bulk capacitor between PVDD and PGND if needed. N.C. MUTE SYNC SYNCOUT GND VDD PVDD PVDD OUTR+ BOOTR+ TOP VIEW OUTR+ Pin Configuration 33 32 31 30 29 28 27 26 25 24 23 PGND 34 22 SHDN PGND 35 21 VDD OUTR- 36 20 BIAS OUTR- 37 19 INR BOOTR- 38 18 FBR PGND 39 17 FBL INL MAX9744 BOOTL- 40 16 OUTL- 41 15 GND OUTL- 42 14 ADDR2 PGND 43 13 ADDR1 PGND 44 12 GND OUTL+ PVDD PVDD 7 8 9 10 11 GND OUTL+ 6 VDD 5 SCLK/PWM 4 SDA/VOL 3 VDD 2 GND 1 BOOTL+ + TQFN (7mm x 7mm) ______________________________________________________________________________________ 23 MAX9744 Supply Bypassing, Layout, and Grounding 20W Stereo Class D Speaker Amplifier with Volume Control MAX9744 Functional Diagrams/Typical Application Circuits I2C MODE 3V TO 3.6V 4.5V TO 14V VDD PVDD 1μF 6, 10, 21, 28 RF 20kΩ RIN 20kΩ 4, 5, 29, 30 1 BOOTL+ FBL 17 MAX9744 CLASS D CIN 0.47μF 100μF 1μF INL 16 CBOOT 0.1μF 2, 3 OUTL+ 41, 42 OUTL- CBOOT 0.1μF 40 BOOTLBIAS CIN 0.47μF RIN 20kΩ VOLUME CONTROL INR 19 PVDD 33 BOOTR+ RF 20kΩ MUTE 24 SHDN 22 SDA/VOL 8 TO μC VDD VDD CLASS D FBR 18 MUTE CBOOT 0.1μF 31, 32 OUTR+ 36, 37 OUTR- CBOOT 0.1μF 38 BOOTR- SHUTDOWN CONTROL SCLK 9 ADDR1 13 I2C ADDR2 14 ANALOG CONTROL SYNC 25 N.C. 26 OSCILLATOR BIAS 23 7, 11, 12, 15, 27 GND SYNCOUT 20 BIAS 34, 35, 39, 43, 44 PGND (SHOWN IN I2C MODE, AV = 29.5dB, f-3dB = 17Hz, SPREAD-SPECTRUM MODE, MUTE OFF, SLAVE ADDRESS = 1001011_) 24 ______________________________________________________________________________________ CBIAS 2.2μF 20W Stereo Class D Speaker Amplifier with Volume Control ANALOG MODE 3V TO 3.6V 4.5V TO 14V VDD PVDD 1μF 6, 10, 21, 28 RF 20kΩ RIN 20kΩ 4, 5, 29, 30 1 BOOTL+ FBL 17 MAX9744 CLASS D CIN 0.47μF INL 16 2, 3 OUTL+ BIAS RIN 20kΩ VOLUME CONTROL INR 19 CBOOT 0.1μF 41, 42 OUTL40 BOOTL- CIN 0.47μF 100μF 1μF CBOOT 0.1μF PVDD 33 BOOTR+ RF 20kΩ MUTE 24 SHDN 22 VDD SDA/VOL 8 SCLK/PWM 9 ADDR1 13 ADDR2 14 VDD SYNC 25 N.C. CLASS D FBR 18 MUTE SHUTDOWN CONTROL 31, 32 OUTR+ CBOOT 0.1μF 36, 37 OUTR38 BOOTR- CBOOT 0.1μF I2C OUTPUT MODULATION ANALOG CONTROL 26 OSCILLATOR BIAS 23 7, 11, 12, 15, 27 GND 34, 35, 39, 43, 44 SYNCOUT 20 BIAS CBIAS 2.2μF PGND (SHOWN IN ANALOG MODE, AV = 29.5dB, f-3dB = 17Hz, SPREAD-SPECTRUM MODE, MUTE OFF, SLAVE ADDRESS = 1001011_) ______________________________________________________________________________________ 25 MAX9744 Functional Diagrams/Typical Application Circuits (continued) Package Information For the latest package outline information and land patterns, go to www.maxim-ic.com/packages. E DETAIL A 32, 44, 48L QFN.EPS MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control (NE-1) X e E/2 k e D/2 C L (ND-1) X e D D2 D2/2 b L E2/2 C L k E2 C L C L L L e A1 A2 e A PACKAGE OUTLINE, 32, 44, 48, 56L THIN QFN, 7x7x0.8mm 21-0144 26 ______________________________________________________________________________________ G 1 2 20W Stereo Class D Speaker Amplifier with Volume Control PACKAGE OUTLINE, 32, 44, 48, 56L THIN QFN, 7x7x0.8mm 21-0144 Chip Information PROCESS: BICMOS G 2 2 PACKAGE TYPE PACKAGE CODE DOCUMENT NO. 44 TQFN-EP T4477-3 21-0144 ______________________________________________________________________________________ 27 MAX9744 Package Information (continued) For the latest package outline information and land patterns, go to www.maxim-ic.com/packages. MAX9744 20W Stereo Class D Speaker Amplifier with Volume Control Revision History REVISION NUMBER REVISION DATE 0 3/08 Initial release 1 9/08 Updated EC table for single pass flow DESCRIPTION PAGES CHANGED — 2, 4, 5 Maxim cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Maxim product. No circuit patent licenses are implied. Maxim reserves the right to change the circuitry and specifications without notice at any time. 28 ____________________Maxim Integrated Products, 120 San Gabriel Drive, Sunnyvale, CA 94086 408-737-7600 © 2008 Maxim Integrated Products is a registered trademark of Maxim Integrated Products, Inc.
很抱歉,暂时无法提供与“1752”相匹配的价格&库存,您可以联系我们找货
