Adafruit MAX98357 I2S Class-D Mono
Amp
Created by lady ada
https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp
Last updated on 2022-09-13 10:54:48 AM EDT
©Adafruit Industries
Page 1 of 46
Table of Contents
Overview
5
Pinouts
7
Speaker Output
Power Pins
I2S Pins
Other Pins
Gain
SD / MODE
Assembly
12
• Prepare the header strip:
• Add the breakout board:
• And Solder!
Raspberry Pi Wiring
16
Raspberry Pi Setup
17
Fast Install
Detailed Install
Update /etc/modprobe.d (if it exists)
Disable headphone audio (if it's set)
Create asound.conf file
Add Device Tree Overlay
Raspberry Pi Test
25
Speaker Tests!
Simple white noise speaker test
Simple WAV speaker test
Simple MP3 speaker test
Volume adjustment
Pi I2S Tweaks
27
• Reducing popping
• Step 1
• Add software volume control
Play Audio with PyGame
31
• Install PyGame
• Run Demo
Arduino Wiring & Test
33
• Wiring
• Basic Test
• DMA Test
CircuitPython Wiring & Test
37
Wiring
Code Examples
Tone Generation
Wave File
Page 2 of 46
• Where's my I2S?
I2S Audio FAQ
44
Downloads
45
• Schematic
• Fabrication Print
• 3D Model
Page 3 of 46
Page 4 of 46
Overview
If your microcontroller or microcomputer has digital audio capability, this amp is for
you! It takes standard I2S digital audio input and, not only decodes it into analog, but
also amplifies it directly into a speaker. Perfect for adding compact amplified sound, it
takes 2 breakouts (I2S DAC + Amp) and combines them into one.
I2S (not to be confused with I2C) is a digital sound protocol that is used on circuit
boards to pass audio data around. Many high end chips and processors manage all of
the audio in digital I2S format. Then, to input or output data, three or four pins are
used (data in, data out, bit clock and left-right channel select). Usually, for audio
devices, there's a DAC chip that will take I2S in and convert it to analog that can drive
a headphone.
This small mono amplifier is surprisingly powerful - able to deliver 3.2 Watts of power
into a 4 ohm impedance speaker (5V power @ 10% THD). Inside the miniature chip is a
class D controller, able to run from 2.7V-5.5VDC. Since the amp is a class D, it's
incredibly efficient - making it perfect for portable and battery-powered projects. It
has built in thermal and over-current protection but we could barely tell it got hot.
The audio input is I2S standard, you can use 3.3V or 5V logic data. The outputs are
"Bridge Tied" - that means they connect directly to the outputs, no connection to
ground. The output is a ~300KHz square wave PWM that is then 'averaged out' by the
speaker coil - the high frequencies are not heard. All the above means that you can't
connect the output into another amplifier, it should drive the speakers directly.
Page 5 of 46
There's a Gain pin that can be manipulated to change the gain. By default, the amp
will give you 9dB of gain. By connecting a pullup or pull down resistor, or wiring
directly, the Gain pin can be set up to give 3dB, 6dB, 9dB, 12dB or 15dB.
the ShutDown/Mode pin can be used to put the chip in shutdown or set up which I2S
audio channel is piped to the speaker. By default, the amp will output (L+R)/2 stereo
mix into mono out. By adding a resistor, you can change it to be just left or just right
output
Works great with Raspberry Pi, Arduino Zero, and any other microcontroller or
microcomputer with I2S audio outputs
Specs:
• Output Power: 3.2W at 4Ω, 10% THD, 1.8W at 8Ω, 10% THD, with 5V supply
• PSRR: 77 dB typ @ 1KHz
• I2S sample rates from 8kHz to 96kHz
• No MCLK required
• Click + Pop reduction
• Five pin-selectable gains: 3dB, 6dB, 9dB, 12dB, 15dB
• Excellent click-and-pop suppression
• Thermal shutdown protection
Page 6 of 46
Comes as an assembled and tested breakout board, with a small piece of optional
header and 3.5mm terminal block. Some soldering is required to attach the header
and terminal block if those are desired.
Pinouts
The MAX98357A is an I2S amplifier - it does not use analog inputs, it only has digital
audio input support! Don't confuse I2S with I2C, I2S is a sound protocol whereas I2C
is for small amounts of data.
Page 7 of 46
Speaker Output
This amplifier is designed to drive moving coil loudpeakers only. Speaker impedence
must be 4Ω or more. The output signal is a 330KHz PWM square wave with a duty
cycle proportional to the audio signal. The inductance of the speaker coil serves as a
low-pass filter to average out the high-frequency components. Do not try to use this
as a pre-amplifier.
The outputs of each channel are "Bridge-Tied" with no connection to ground. This
means that for each channels, the + and - alternate polarity to create a single channel
amplifier with twice the available power.
Connect your speakers using the 3.5mm screw-terminal blocks.
• 5V into 4Ω @ 10% THD - 3W max
• 5V into 4Ω @ 1% THD - 2.5W max
• 3.3V into 4Ω @ 10% THD - 1.3W max
• 3.3V into 4Ω @ 1% THD - 1.0W max
• 5V into 8Ω @ 10% THD - 1.8W max
• 5V into 8Ω @ 1% THD - 1.4W max
• 3.3V into 8Ω @ 10% THD - 0.8W max
• 3.3V into 8Ω @ 1% THD - 0.6W max
Page 8 of 46
Power Pins
This is the power for the amplifier and logic of the amplifier. You can provide 2.5V up
to 5.5V. Note that at 5V you can end up putting up to 2.8W into your speaker, so
make sure your power supply can easily handle up to 650mA and we recommend a
power supply spec'd for at least 800mA to give yourself some 'room'
If you have a 3.3V logic device, you can still power the amp from 5V, and that's
recommended to get the most power output!
Page 9 of 46
I2S Pins
Three pins are used to receive audio data. These can be 3.3-5V logic
• LRC (Left/Right Clock) - this is the pin that tells the amplifier when the data is for
the left channel and when its for the right channel
• BCLK (Bit Clock) - This is the pin that tells the amplifier when to read data on the
data pin.
• DIN (Data In) - This is the pin that has the actual data coming in, both left and
right data are sent on this pin, the LRC pin indicates when left or right is being
transmitted
Note that this amplifier does not require an MCLK pin, if you have an MCLK output,
you can leave it disconnected!
Page 10 of 46
Other Pins
The other settings are handled by GAIN and SD
Gain
GAIN is, well, the gain setting. You can have a gain of 3dB, 6dB, 9dB, 12dB or 15dB.
• 15dB if a 100K resistor is connected between GAIN and GND
• 12dB if GAIN is connected directly to GND
• 9dB if GAIN is not connected to anything (this is the default)
• 6dB if GAIN is connected directly to Vin
• 3dB if a 100K resistor is connected between GAIN and Vin
This way, the default gain is 9dB but you can easily change it by tweaking the
connection to the GAIN pin. Note you may need to perform a power reset to adjust
the gain.
Page 11 of 46
SD / MODE
This pin is used for shutdown mode but is also used for setting which channel is
output. It's a little confusing but essentially:
• If SD is connected to ground directly (voltage is under 0.16V) then the amp is shu
t down
• If the voltage on SD is between 0.16V and 0.77V then the output is (Left + Right)/
2, that is the stereo average.
• If the voltage on SD is between 0.77V and 1.4V then the output is just the Right
channel
• If the voltage on SD is higher than 1.4V then the output is the Left channel.
This is compounded by an internal 100K pulldown resistor on SD so you need to use a
pullup resistor on SD to balance out the 100K internal pulldown.
For the breakout board, there's a 1Mohm resistor from SD to Vin which, when
powering from 5V will give you the 'stereo average' output. If you want left or right
channel only, or if you are powering from non-5V power, you may need to experiment
with different resistors to get the desired voltage on SD
Assembly
Page 12 of 46
Cut the strip to length if necessary. It will
be easier to solder if you insert it into a
breadboard - long pins down
Place the breakout board over the pins so
that the short pins poke through the
breakout pads
Page 13 of 46
And Solder!
Be sure to solder all pins for reliable
electrical contact.
(For tips on soldering, be sure to check out
our Guide to Excellent Soldering (https://
adafru.it/aTk)).
Page 14 of 46
You're done! Check your solder joints
visually and continue onto the next steps
If you want to use a terminal block for
connecting a speaker, place the 3.5mm
terminal so the mouthes point out.
Page 15 of 46
Solder in both pins with plenty of solder!
Raspberry Pi Wiring
if you have a Raspberry Pi and you want higher quality audio than the headphone jack
can provide, I2S is a good option! You only use 3 pins, and since its a pure-digital
output, there can be less noise and interference. Of course, you'll need to make sure
that you have a nice strong 5V power supply so make sure to add 500mA or more to
your power supply requirements!
This board also works very well with boards that don't have audio like the Pi Zero
This technique will work with any Raspberry Pi with the 2x20 connector. Older Pi
1's with a 2x13 connector do not bring out the I2S pins as easily
Page 16 of 46
Connect:
• Amp Vin to Raspbery Pi 5V Power
• Amp GND to Raspbery Pi Ground
• Amp DIN to Raspbery Pi GPIO 21
• Amp BCLK to Raspbery Pi GPIO 18
• Amp LRCLK to Raspbery Pi GPIO 19
Check Raspberry Pi documentation for which pins are GPIO 18, 19, 21, 5V and GND (ht
tps://adafru.it/112A)
Raspberry Pi Setup
At this time, Raspbery Pi linux kernel does not support mono audio out of the I2S
interface, you can only play stereo, so any mono audio files may need conversion
to stereo!
2017-11-2 Raspbian PIXEL ('full') has broken something in volume control. I2S
works, but there's no software volume setup, if you need this, try Raspbian Lite will try to fix as soon as we figure out why :)
Page 17 of 46
Fast Install
Luckily its quite easy to install support for I2S DACs on Raspbian.
These instructions are totally cribbed from the PhatDAC instructions at the lovely folks
at Pimoroni! (https://adafru.it/nFy)
Run the following from your Raspberry Pi with Internet connectivity:
curl -sS https://raw.githubusercontent.com/adafruit/Raspberry-PiInstaller-Scripts/master/i2samp.sh | bash
We've added an extra helper systemd script that will play quiet audio when the I2S
peripheral isn't in use. This removes popping when playback starts or stops. It uses a
tiny amount of CPU time (on a Pi Zero, 5%, on a Pi 2 or 3 its negligible). You don't
need this on RetroPie because it never releases the I2S device, but it's great for
Raspbian.
Page 18 of 46
You will need to reboot once installed.
You must reboot to enable the speaker hardware!
After rebooting, log back in and re-run the script again...It will ask you if you want to
test the speaker. Say yes and listen for audio to come out of your speakers...
If it sounds really distorted, it could be the volume is too high. However, in order to
have volume control appear in Raspbian desktop or Retropie you must reboot a
second time after doing the speaker test, with sudo reboot
You must reboot *twice* to enable alsamixer volume (really!)
Once rebooted, try running alsamixer and use arrow keys to lower the volume, 50% is
a good place to start.
If you're still having audio problems, try re-running the script and saying N (disable)
the /dev/zero playback service .
You can then go to the next page on testing and optimizing your setup. Skip the rest
of this page on Detailed Installation if the script worked for you!
Page 19 of 46
Detailed Install
If, for some reason, you can't just run the script and you want to go through the install
by hand - here's all the steps!
Log into your Pi and get into a serial console (either via a console cable, the TV
console, RXVT, or what have you)
Edit the raspi blacklist with
sudo nano /etc/modprobe.d/raspi-blacklist.conf
If the file is empty, just skip this step
However, if you see the following lines:
blacklist i2c-bcm2708
blacklist snd-soc-pcm512x
blacklist snd-soc-wm8804
Update the lines by putting a # before each line
Page 20 of 46
Save by typing Control-X Y
Edit the raspi modules list with
sudo nano /etc/modules
However, if you see the following line:
snd_bcm2835
Put a # in front of it
Page 21 of 46
and save with Control-X Y
sudo nano /etc/asound.conf
This file ought to be blank!
Copy and paste the following text into the file
pcm.speakerbonnet {
type hw card 0
pcm.dmixer {
type dmix
ipc_key 1024
ipc_perm 0666
slave {
pcm "speakerbonnet"
period_time 0
period_size 1024
buffer_size 8192
rate 44100
channels 2
ctl.dmixer {
Page 22 of 46
type hw card 0
pcm.softvol {
type softvol
slave.pcm "dmixer"
control.name "PCM"
control.card 0
ctl.softvol {
type hw card 0
pcm.!default {
type
slave.pcm
plug
"softvol"
Save the file as usual
Edit your Pi configuration file with
sudo nano /boot/config.txt
And scroll down to the bottom. If you see a line that says: dtparam=audio=on
Page 23 of 46
Disable it by putting a # in front.
Then add:
dtoverlay=hifiberry-dac
dtoverlay=i2s-mmap
on the next line. Save the file.
Reboot your Pi with sudo reboot
Page 24 of 46
Raspberry Pi Test
Speaker Tests!
OK you can use whatever software you like to play audio but if you'd like to test the
speaker output, here's some quick commands that will let you verify your amp and
speaker are working as they should!
Run speaker-test -c2 to generate white noise out of the speaker, alternating left
and right.
If you have a mono output amplifier, the I2S amp merges left and right channels, so
you'll hear continuous white noise
Once you've got something coming out, try to play an audio file with speaker-test (for
WAV files, not MP3)
speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/
Front_Center.wav
You'll hear audio coming from left and right alternating speakers
If you want to play a stream of music, you can try
sudo apt-get install -y mpg123
mpg123 http://ice1.somafm.com/u80s-128-mp3
If you want to play MP3's on command, check out this tutorial which covers how to set
that up (https://adafru.it/aTD)
Page 25 of 46
At this time, Jessie Raspbery Pi kernel does not support mono audio out of the I2S
interface, you can only play stereo, so any mono audio files may need conversion to
stereo!
omxplayer does not seem use the I2S interface for audio - only HDMI - so you
won't be able to use it
Volume adjustment
Many programs like PyGame and Sonic Pi have volume control within the application.
For other programs you can set the volume using the command line tool called alsami
xer. Just type alsamixer in and then use the up/down arrows to set the volume. Press
Escape once its set
In Raspbian PIXEL you can set the volume using the menu item control. If it has an X
through it, try restarting the Pi (you have to restart twice after install to get PIXEL to
recognize the volume control
Page 26 of 46
Pi I2S Tweaks
This page is deprecated, our installer already performs these steps for you, but
we'll keep them here for archival use!
Reducing popping
For people who followed our original installation instructions with the simple alsa
config, they may find that the I2S audio pops when playing new audio.
The workaround is to use a software mixer to output a fixed sample rate to the I2S
device so the bit clock does not change. I use ALSA so I configured dmixer and I no
longer have any pops or clicks. Note that the RaspPi I2S driver does not support dmix
er by default and you must follow these instructions provided (https://adafru.it/sHF) to
add it. Continue on for step-by-step on how to enable it!
Step 1
Start by modify /boot/config.txt to add dtoverlay=i2s-mmap
Run sudo nano /boot/config.txt and add the text to the bottom like so:
Page 27 of 46
Save and exit.
Then change /etc/asound.conf to:
pcm.speakerbonnet {
type hw card 0
pcm.!default {
type plug
slave.pcm "dmixer"
pcm.dmixer {
type dmix
ipc_key 1024
ipc_perm 0666
slave {
pcm "speakerbonnet"
period_time 0
period_size 1024
buffer_size 8192
rate 44100
channels 2
ctl.dmixer {
type hw card 0
By running sudo nano /etc/asound.conf
This creates a PCM device called speakerbonnet which is connected to the hardware
I2S device. Then we make a new 'dmix' device ( type dmix ) called pcm.dmixer . We
give it a unique Inter Process Communication key ( ipc_key 1024 ) and permissions
that are world-read-writeable (ipc_perm 0666 ) The mixer will control the hardware
pcm device speakerbonnet (pcm "speakerbonnet") and has a buffer set up so its nice
and fast. The communication buffer is set up so there's no delays ( period_time 0 ,
period_size 1024 and buffer_size 8192 work well). The default mixed rate is
44.1khz stereo ( rate 44100 channels 2 )
Page 28 of 46
Finally we set up a control interface but it ended up working best to just put in the
hardware device here - ctl.dmixer { type hw card 0 }
Save and exit. Then reboot the Pi to enable the mixer. Also, while it will greatly reduce
popping, you still may get one once in a while - especially when first playing audio!
The basic I2S chipset used here does not have software control built in. So we have
to 'trick' the Pi into creating a software volume control. Luckily, its not hard once you
know how to do it (https://adafru.it/ydQ).
Create a new audio config file in ~/.asoundrc with nano ~/.asoundrc and inside put
the following text:
pcm.speakerbonnet {
type hw card 0
pcm.dmixer {
type dmix
ipc_key 1024
ipc_perm 0666
slave {
pcm "speakerbonnet"
period_time 0
period_size 1024
buffer_size 8192
rate 44100
channels 2
Page 29 of 46
ctl.dmixer {
type hw card 0
pcm.softvol {
type softvol
slave.pcm "dmixer"
control.name "PCM"
control.card 0
ctl.softvol {
type hw card 0
pcm.!default {
type
slave.pcm
plug
"softvol"
This assumes you set up the dmixer for no-popping above!
Save and exit
Now, here's the trick, you have to reboot, then play some audio through alsa, then
reboot to get the alsamixer to sync up right:
Front_Center.wav
Then you can type alsamixer to control the volume with the 'classic' alsa mixing
interface
Page 30 of 46
Just press the up and down arrows to set the volume, and ESC to quit
You can use mpg123 for basic testing but it's a little clumsy for use where you want to
dynamically change the volume or have an interactive program. For more powerful
audio playback we suggest using PyGame to playback a variety of audio formats (MP3
included!)
Install PyGame
Start by installing pygame support, you'll need to open up a console on your Pi with
network access and run:
sudo apt-get install python-pygame
Next, download this pygame example zip to your Pi
Click to download PyGame example
code & sample mp3s
https://adafru.it/wbp
On the command line, run
wget https://cdn-learn.adafruit.com/assets/assets/000/041/506/
original/pygame_example.zip (https://adafru.it/wbq)
Page 31 of 46
unzip pygame_example.zip (https://adafru.it/wbq)
Run Demo
Inside the zip is an example called pygameMP3.py
This example will playback all MP3's within the script's folder. To demonstrate that you
can also adjust the volume within pygame, the second argument is the volume for
playback. Specify a volume to playback with a command line argument between 0.0
and 1.0
For example here is how to play at 75% volume:
python pygameMP3.py 0.75
Here's the code if you have your own mp3s!
''' pg_midi_sound101.py
play midi music files (also mp3 files) using pygame
tested with Python273/331 and pygame192 by vegaseat
#code modified by James DeVito from here: https://www.daniweb.com/programming/
software-development/code/454835/let-pygame-play-your-midi-or-mp3-files
#!/usr/bin/python
import
import
import
import
sys
pygame as pg
os
time
def play_music(music_file):
stream music with mixer.music module in blocking manner
this will stream the sound from disk while playing
clock = pg.time.Clock()
try:
pg.mixer.music.load(music_file)
print("Music file {} loaded!".format(music_file))
except pygame.error:
print("File {} not found! {}".format(music_file, pg.get_error()))
return
pg.mixer.music.play()
# If you want to fade in the audio...
# for x in range(0,100):
pg.mixer.music.set_volume(float(x)/100.0)
time.sleep(.0075)
# # check if playback has finished
while pg.mixer.music.get_busy():
clock.tick(30)
Page 32 of 46
freq = 44100
# audio CD quality
bitsize = -16
# unsigned 16 bit
channels = 2
# 1 is mono, 2 is stereo
buffer = 2048
# number of samples (experiment to get right sound)
pg.mixer.init(freq, bitsize, channels, buffer)
if len(sys.argv) > 1:
try:
user_volume = float(sys.argv[1])
except ValueError:
print "Volume argument invalid. Please use a float (0.0 - 1.0)"
pg.mixer.music.fadeout(1000)
pg.mixer.music.stop()
raise SystemExit
print("Playing at volume: " + str(user_volume)+ "\n")
pg.mixer.music.set_volume(user_volume)
mp3s = []
for file in os.listdir("."):
if file.endswith(".mp3"):
mp3s.append(file)
print mp3s
for x in mp3s:
try:
play_music(x)
time.sleep(.25)
except KeyboardInterrupt:
# if user hits Ctrl/C then exit
# (works only in console mode)
raise SystemExit
else:
print("Please specify volume as a float! (0.0 - 1.0)")
The classic ATmega328P-based Arduino's like the UNO and Metro 328 don't have I2S
interfaces, so you can't use this breakout with them
But the newer ATSAMD21-based boards like the Zero, Metro M0, Feather M0 can!
(Note, Gemma M0 & Trinket M0 do not have I2S pins available). And so can the even
newer ATSAMD51-based boards like the Metro M4 and Feather M4.
To use I2S with M0 or M4 boards, you'll need to install the Adafruit Zero I2S library (ht
tps://adafru.it/DHD). It is available through the Library Manager. You can search for
(see below) and then just click the install button.
Page 33 of 46
Wiring
Wiring connections are the same as those used for CircuitPython. So go to the Circuit
Python Wiring & Test page to see how to wire the breakout for your specific board.
Basic Test
To test things out, try running the demo below. It comes with the library installation, so
you can find it by going to:
File -> Examples -> Adafruit Zero I2S Library -> basic
Be sure to change this line:
Adafruit_ZeroI2S i2s(0, 1, 9, 2);
to match the pins used for your setup. If you've wired as shown in this guide, then you
can try using the default pins by changing that line to this:
Adafruit_ZeroI2S i2s;
#include
#include
#include
/* max volume for 32 bit data */
#define VOLUME ( (1UL dma
#include
#include
#include
#include
"utility/dma.h"
