TDHBG2500P100-KIT
TDHBG2500P100-KIT
    TRANSPHORM
    2.5KWHB,BUCKORBOOSTEVALKIT
TDHBG2500P100-KIT 数据手册
User Guide TDHBG2500P100: 2.5kW Half-bridge Evaluation Board Introduction The TDHBG2500P100 half-bridge evaluation board provides the elements of a simple buck or boost converter for basic study of switching characteristics and efficiency achievable with Transphorm’s 650V GaN FETs. In either buck or boost mode the circuit can be configured for synchronous rectification. Jumpers allow use of a single logic input or separate hi/lo inputs. The highvoltage input and output can operate at up to 400Vdc, with a power output of up to 2.5kW. The inductor provided is intended for efficient operation at 100kHz, although other inductors and other frequencies may be easily used. The TDHBG2500P100-KIT is for evaluation purposes only. Figure 1. TDHBG2500P100 half-bridge evaluation board December 6, 2017 © 2017 Transphorm Inc. Subject to change without notice. TDHBG2500P100 User Guide Warnings TDHGB2500P100 input/output specifications High-voltage input/output: 400Vdc max Auxiliary supply (J1): 10V min, 18V max Logic inputs: nominal 0V-5V Pulse-generation circuit: Vlo < 1.5V, Vhi > 3.0V Direct connection to gate driver: Vlo < 0.8V, Vhi > 2.0V SMA coaxial connectors Switching frequency: configuration-dependent Lower limit determined by peak inductor current Upper limit determined by desired dead-time and power dissipation Power dissipation in the GaN FET is limited by the maximum junction temperature. Refer to the TPH3212PS datasheet. Circuit description The circuit comprises a simple half-bridge featuring two TPH3212PS GaN FETs, as indicated in the block diagram of Figure 2. Two high-voltage ports are provided which can serve as either input or output, depending on the configuration—boost or buck. In either case one FET acts as the active power switch while the other carries the freewheeling current. The latter device may be enhanced, as a synchronous rectifier, or not. With GaN FETs the reverse recovery charge is low and there is no need for additional freewheeling diodes. Two input connectors are provided which can be connected to sources of logic-level command signals for the hi/lo gate driver. Both inputs may be driven by off-board signal sources; or alternatively, a single signal source may be connected to an on-board pulse-generator circuit which generates the two non-overlapping pulses. Jumpers determine how the input signals are used. An inductor is provided as a starting point for investigation. This is a 440µH toroid intended to demonstrate a reasonable compromise between size and efficiency for power up to 2.5kW at a switching frequency of 100kHz. TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide TPH3212PS TPH3212PS Figure 2. Functional block diagram Using the board The board can be used for evaluation of basic switching functionality in a variety of circuit configurations. It is not a complete circuit, but rather a building block. It can be used in steady-state DC/DC converter mode with output power up to 2.5kW. When operating the board at high power (>1000W), an external fan should be used to cool the heatsink. Configurations Figure 3 shows the basic power connections for buck and boost modes. For buck mode, the HVdc input (terminals J2, J3) is connected to the high-voltage supply and the output is taken from terminals J5 and J7. For boost mode, the connections are reversed. Note that in boost mode a load must be connected. The load current affects the output voltage up to the transition from DCM to CCM. In buck mode the load may be an open circuit. TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide TPH3212PS TPH3212PS (a) Buck mode TPH3212PS TPH3212PS (b) Boost mode Figure 3. Supply and load connections for buck (a) and boost (b) configurations Figure 4 shows possible configurations for the gate-drive signals. In Figure 4(a), a single input from an external signal source is used together with the on-board pulse generation circuit. J4 is used, J6 is left open circuit. Jumpers JP1 and JP2 are in the top position, as shown. If the high-side transistor is to be the active switch (e.g. buck mode), then the duty cycle of the input source should simply be set to the desired duty cycle (D). If the low-side transistor is to be the active switch (e.g. boost mode) the duty cycle of the input source should be set to (1-D), where D is the desired duty cycle of the low-side switch. This configuration results in synchronous rectification. If it is desired to let the device carrying the freewheeling current act as a diode, then the appropriate jumper should be placed so that the pull-down resistor is connected to the driver. Figure 4(b) shows a buck-mode TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide configuration where the low-side device is not enhanced. Finally, Figure 4(c) shows use of two external signal sources as inputs to the gate driver. For any configuration, an auxiliary supply voltage of 10V-18V must be supplied at connector J1. Pull-down resistors R5 and R6 have a value of 4.99k. If a 50Ω signal source is used and 50Ω termination is desired, then R5 and R6 may be replaced (or paralleled) with 1206 size 50Ω resistors. Boost mode/buck mode operation For buck mode operation, with input voltage of 400V and output voltage of 48V; 50A max output current is achievable at 2500W with duty cycle of 12%. A typical 400Vin - 200Vout buck operation with 50% duty cycle, 6.5A max output current is seen at 2500W. On the other hand, for 200Vin - 400Vout boost mode operation at 2.5kW, 12.5A max output current can be reached with a duty cycle of 50%. Thermal cooling must be enforced for high current switching at all times. TPH3212PS TPH3212PS (a) TPH3212PS TPH3212PS (b) TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide TPH3212PS TPH3212PS (c) Figure 4. Input configurations (a) using a single source for either buck or boost mode (b) buck mode without synchronous rectification (c) using two signal sources Dead time control The required form of the gate-drive signals is shown in Figure 5. The times marked A are the dead times when neither transistor is driven on. The dead time must be greater than zero to avoid shoot-through currents. The Si8230BB gate drive chip ensures a minimum dead time based on the value of resistor R7, connected to the DT input. The dead time in ns is equal to the resistance in kΩ x 10, so the default value of 12k corresponds to 120ns. This will add to any dead time already present in the input signals. The on-board pulse generator circuit; for example, creates dead times of about 60ns. The resulting dead time at the gate pins of Q1 and Q2 is about 240ns. Either shorting or removing R7 will reduce the dead time to 60ns. Figure 5. Non-overlapping gate pulses Design details See Figure 6 for a detailed circuit schematic and Figure 7 for the PCB layers (also included in the design files). The parts list can be found in Table 1. Table 1. TDHBG2500P100 half-bridge evaluation board bill of materials (BOM) Designator Qty U3 1 D1, D4, D5 FB1, FB2 FB3, FB4, FB5, FB6 JP1, JP2 3 2 2 2 TDHBG2500P100_0v6 Value 300Ω 30Ω Description Package Part Number Manufacturer 74LVC1G17DBV SOT23-5 SN74LVC1G17DBVR DIODE-DO-214AC FB0603 FB0805 DO-214AC 603 805 ES1J MMZ1608S301ATA00 BLM21SN300SZ1D Texas Instruments Fairchild TDK Murata JP2E JP2 68001-403HLF FCI December 6, 2017 TDHBG2500P100 User Guide Designator Qty J2, J3, J5, J7 LED1, LED2, LED3 U1 Description Package Part Number Manufacturer 4 KEYSTONE_7691 KEYSTONE_7691 7691 Keystone 3 LEDCHIP-LED0805 CHIP-LED0805 SML-211UTT86 Rohm 1 LT3082 SOT223-3 LT3082EST#PBF J1 LDS, LGS C7 C10, C11, C12, C14, C20, C21, C22 C8, C16, C17 R15 R16, R23 R9, R12 R4 R14 C19, C23 R3 R7, R11 C13, C15 R8, R10 C2 C3 C1 R13 C4, C5, C6, C24 R1, R5, R6 R17, R18, R19, R20, R21, R22 R2 C9, C18 U4, U5 1 2 1 7 0.1µF 0.1µF PJ-002AH TEKTRONIX-PCB C-EUC1812 C-USC0603 PJ-002AH TEKTRONIX-PCB C1812 C0603 PJ-002AH 131-4353-00 C1812V104KDRACTU 06033C104JAT2A Linear Technology CUI Tektronix Kemet AVX 3 0.1µF C-USC2225K C2225K VJ2225Y104KXGAT Vishay 1 2 2 1 1 2 1 2 2 2 1 1 1 1 4 0Ω 20Ω 0Ω 10Ω 100kΩ 100pF 10MΩ 10kΩ 10µF 1kΩ 1µF 2.2µF 22µF 2kΩ 4.7nF R-US_R0603 R-US_R1206 R-US_R1206 R-US_R0805 R-US_R0603 C-USC0603 R-US_R1206 R-US_R0603 C-EUC0805 R-US_R0603 C-EUC0805 C-EUC0805 C-USC1206 R-US_R0805 C-EUC1206 R0603 R1206 R1206 R0805 R0603 C0603 R1206 R0603 C0805 R0603 C0805 C0805 C1206 R0805 C1206 RC0603FR-070RL RNCP1206FTD20R0 ERJ-8GEY0R00V ERJ-P06J100V ESR03EZPJ104 06035A101FAT2A HVC1206T1005JET ERJ-3GEYJ103V C0805C106M4PACTU RC0603FR-071KL CC0805ZRY5V8BB105 C2012X5R1E225K125AC CL31A226MOCLNNC RC0805FR-072KL C1206C472KDRACTU Yageo Stackpole Panasonic Panasonic Rohm AVX Stackpole Panasonic Kemet Yageo Yageo TDK Samsung Yageo Kemet 6 6 4.99kΩ 560kΩ R-US_R1206 R-US_R0805 R1206 R0805 RMCF1206FT4K99 ESR10EZPJ564 Stackpole Rohm 1 2 2 499kΩ 10µH R-US_R1206 10uH 74AHC1G86DBV R1206 EPCOS_B32674 SOT23-5 RMCF1206FT499K B32794D2106K SN74AHC1G86DBVR D2, D3 J4, J6 U$3 HS1 2 2 1 1 SOT23 BU-SMA-G BAT54W 5-1814832-1 CWS-1MP-12640 C220-050-2AE U2 Q1, Q2 1 2 2 BAT54 BU-SMA-G Inductor HEATSINKC220-0502AE SI8230 TPH_TO220VERT_TRI Thermal pad between TPH3212 and heatsink 4-40 screw Nylon washer shoulder Adaptor Stackpole Epcos Texas Instruments NXP TE Connectivity CWS Ohmite SOIC16N TO-220 SI8230BB-D-IS TPH3212PS SP2000-0.015-00-54 SiLabs Transphorm Bergquist 9900 3049 TRG10R120-11E03Level-VI SJ61A1 Keystone Keystone Cincon 2 2 1 4 TDHBG2500P100_0v6 Value 460µH 72mΩ 12V Bumper cylin 0.312" dia blk 3M December 6, 2017 TDHBG2500P100 User Guide Figure 6. Detailed circuit schematic TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide (a) PCB top layer (b) PCB bottom layer TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide (c) PCB inner layer 2 (ground plane) + inner layer 3 (power plane) Figure 7. PCB layers Probing Plated through-holes labeled test points (LGS and LDS) are provided for probing the low-side gate pulse and half-bridge switching node waveform. In order to minimize inductance during measurement, the tip and the ground of the probe should be directly attached to the sensing points to minimize the sensing loop. For safe, reliable and accurate measurement, a scope probe tip may be directly soldered to the low-side FET drain and a short ground wire soldered to the low-side FET source. See Figure 8 for an alternative that does not require soldering the probe tip. WARNINGS: There is no specific protection against over-current or over-voltage on this board. If the on-board pulse generation circuit is used in boost mode, a zero input corresponds to 100% duty cycle for the active lowside switch. TDHBG2500P100_0v6 December 6, 2017 TDHBG2500P100 User Guide Figure 8. Low-inductance probing of fast, high-voltage signals Efficiency has been measured for this circuit in boost mode with 200Vdc in and 400Vdc out, switching at 50kHz and 100kHz (Figure 9). Figure 9. Efficiency for a boost 200V:400V converter TDHBG2500P100_0v6 December 6, 2017
TDHBG2500P100-KIT 价格&库存
很抱歉,暂时无法提供与“TDHBG2500P100-KIT”相匹配的价格&库存,您可以联系我们找货
