106990003
    SEEED(矽递科技)
    LM2596 DC/DC, Step Down 1, Non-Isolated Output Evaluation Board
106990003 数据手册
LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 LM2596 SIMPLE SWITCHER® Power Converter 150 kHz 3A Step-Down Voltage Regulator Check for Samples: LM2596 FEATURES DESCRIPTION • • The LM2596 series of regulators are monolithic integrated circuits that provide all the active functions for a step-down (buck) switching regulator, capable of driving a 3A load with excellent line and load regulation. These devices are available in fixed output voltages of 3.3V, 5V, 12V, and an adjustable output version. 1 23 • • • • • • • • • • • 3.3V, 5V, 12V, and Adjustable Output Versions Adjustable Version Output Voltage Range, 1.2V to 37V ±4% Max Over Line and Load Conditions Available in TO-220 and TO-263 Packages Ensured 3A Output Load Current Input Voltage Range Up to 40V Requires Only 4 External Components Excellent Line and Load Regulation Specifications 150 kHz Fixed Frequency Internal Oscillator TTL Shutdown Capability Low Power Standby Mode, IQ Typically 80 μA High Efficiency Uses Readily Available Standard Inductors Thermal Shutdown and Current Limit Protection APPLICATIONS • • • Simple High-Efficiency Step-Down (Buck) Regulator On-Card Switching Regulators Positive to Negative Converter Requiring a minimum number of external components, these regulators are simple to use and include internal frequency compensation , and a fixed-frequency oscillator. The LM2596 series operates at a switching frequency of 150 kHz thus allowing smaller sized filter components than what would be needed with lower frequency switching regulators. Available in a standard 5-lead TO-220 package with several different lead bend options, and a 5-lead TO-263 surface mount package. A standard series of inductors are available from several different manufacturers optimized for use with the LM2596 series. This feature greatly simplifies the design of switch-mode power supplies. Other features include a ensured ±4% tolerance on output voltage under specified input voltage and output load conditions, and ±15% on the oscillator frequency. External shutdown is included, featuring typically 80 μA standby current. Self protection features include a two stage frequency reducing current limit for the output switch and an over temperature shutdown for complete protection under fault conditions. (1) (1) † Patent Number 5,382,918. Typical Application (Fixed Output Voltage Versions) 1 2 3 Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. SIMPLE SWITCHER is a registered trademark of Texas Instruments. All other trademarks are the property of their respective owners. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. Copyright © 1999–2013, Texas Instruments Incorporated LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Connection Diagrams Figure 1. 5-Lead Bent and Staggered Leads, Through Hole TO-220 (T) Package See Package Number NDH0005D Figure 2. 5-Lead DDPAK/TO-263 (S) Package See Package Number KTT0005B These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. Absolute Maximum Ratings (1) (2) Maximum Supply Voltage 45V ON /OFF Pin Input Voltage −0.3 ≤ V ≤ +25V Feedback Pin Voltage −0.3 ≤ V ≤+25V −1V Output Voltage to Ground (Steady State) Power Dissipation Internally limited −65°C to +150°C Storage Temperature Range ESD Susceptibility Human Body Model (3) 2 kV Lead Temperature DDPAK/TO-263 Package Vapor Phase (60 sec.) +215°C Infrared (10 sec.) +245°C TO-220 Package (Soldering, 10 sec.) +260°C Maximum Junction Temperature +150°C (1) (2) (3) Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is intended to be functional, but do not ensure specific performance limits. For ensured specifications and test conditions, see the Electrical Characteristics. If Military/Aerospace specified devices are required, please contact the Texas Instruments Sales Office/ Distributors for availability and specifications. The human body model is a 100 pF capacitor discharged through a 1.5k resistor into each pin. Operating Conditions −40°C ≤ TJ ≤ +125°C Temperature Range Supply Voltage 2 4.5V to 40V Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 LM2596-3.3 Electrical Characteristics Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range LM2596-3.3 Symbol Parameter Conditions Typ (1) SYSTEM PARAMETERS VOUT η (1) (2) (3) (3) Limit (2) Units (Limits) 3.168/3.135 V(min) 3.432/3.465 V(max) Test Circuit Figure 20 Output Voltage Efficiency 4.75V ≤ VIN ≤ 40V, 0.2A ≤ ILOAD ≤ 3A VIN = 12V, ILOAD = 3A 3.3 V 73 % Typical numbers are at 25°C and represent the most likely norm. All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are ensured via correlation using standard Statistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). External components such as the catch diode, inductor, input and output capacitors, and voltage programming resistors can affect switching regulator system performance. When the LM2596 is used as shown in the Figure 20 test circuit, system performance will be as shown in system parameters of Electrical Characteristics section. LM2596-5.0 Electrical Characteristics Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range LM2596-5.0 Symbol Parameter Conditions Typ (1) SYSTEM PARAMETERS VOUT η (1) (2) (3) (3) Limit (2) Units (Limits) Test Circuit Figure 20 Output Voltage Efficiency 7V ≤ VIN ≤ 40V, 0.2A ≤ ILOAD ≤ 3A VIN = 12V, ILOAD = 3A 5.0 V 4.800/4.750 V(min) 5.200/5.250 V(max) 80 % Typical numbers are at 25°C and represent the most likely norm. All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are ensured via correlation using standard Statistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). External components such as the catch diode, inductor, input and output capacitors, and voltage programming resistors can affect switching regulator system performance. When the LM2596 is used as shown in the Figure 20 test circuit, system performance will be as shown in system parameters of Electrical Characteristics section. LM2596-12 Electrical Characteristics Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range LM2596-12 Symbol Parameter Conditions Typ (1) SYSTEM PARAMETERS VOUT η (1) (2) (3) (3) (2) Units (Limits) Test Circuit Figure 20 Output Voltage Efficiency Limit 15V ≤ VIN ≤ 40V, 0.2A ≤ ILOAD ≤ 3A VIN = 25V, ILOAD = 3A 12.0 90 V 11.52/11.40 V(min) 12.48/12.60 V(max) % Typical numbers are at 25°C and represent the most likely norm. All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are ensured via correlation using standard Statistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). External components such as the catch diode, inductor, input and output capacitors, and voltage programming resistors can affect switching regulator system performance. When the LM2596 is used as shown in the Figure 20 test circuit, system performance will be as shown in system parameters of Electrical Characteristics section. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 3 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com LM2596-ADJ Electrical Characteristics Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range LM2596-ADJ Symbol Parameter Conditions Typ (1) SYSTEM PARAMETERS VFB (3) 4.5V ≤ VIN ≤ 40V, 0.2A ≤ ILOAD ≤ 3A Efficiency (3) Units (Limits) 1.193/1.180 V(min) 1.267/1.280 V(max) 1.230 V VOUT programmed for 3V. Circuit of Figure 20 (1) (2) (2) Test Circuit Figure 20 Feedback Voltage η Limit VIN = 12V, VOUT = 3V, ILOAD = 3A 73 % Typical numbers are at 25°C and represent the most likely norm. All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are ensured via correlation using standard Statistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). External components such as the catch diode, inductor, input and output capacitors, and voltage programming resistors can affect switching regulator system performance. When the LM2596 is used as shown in the Figure 20 test circuit, system performance will be as shown in system parameters of Electrical Characteristics section. All Output Voltage Versions Electrical Characteristics Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range. Unless otherwise specified, VIN = 12V for the 3.3V, 5V, and Adjustable version and VIN = 24V for the 12V version. ILOAD = 500 mA LM2596-XX Symbol Parameter Conditions Typ (1) Limit (2) Units (Limits) 50/100 nA (max) 127/110 kHz(min) 173/173 kHz(max) 1.4/1.5 V(max) DEVICE PARAMETERS Ib Feedback Bias Current fO Oscillator Frequency VSAT DC ICL IL Saturation Voltage Adjustable Version Only, VFB = 1.3V See (3) IOUT = 3A (4) (5) See (5) 100 Min Duty Cycle (OFF) See (6) 0 Current Limit Peak Current Output = 0V (1) (2) (3) (4) (5) (6) (7) 4 Quiescent Current See (4) (5) (6) V % 4.5 (4) (6) (7) kHz 1.16 Max Duty Cycle (ON) Output Leakage Current nA 150 Output = −1V IQ 10 A 3.6/3.4 A(min) 6.9/7.5 A(max) 50 μA(max) 30 mA(max) 10 mA(max) 2 mA 5 mA Typical numbers are at 25°C and represent the most likely norm. All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are ensured via correlation using standard Statistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). The switching frequency is reduced when the second stage current limit is activated. No diode, inductor or capacitor connected to output pin. Feedback pin removed from output and connected to 0V to force the output transistor switch ON. Feedback pin removed from output and connected to 12V for the 3.3V, 5V, and the ADJ. version, and 15V for the 12V version, to force the output transistor switch OFF. VIN = 40V. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 All Output Voltage Versions Electrical Characteristics (continued) Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range. Unless otherwise specified, VIN = 12V for the 3.3V, 5V, and Adjustable version and VIN = 24V for the 12V version. ILOAD = 500 mA LM2596-XX Symbol Parameter Conditions Typ (1) ISTBY θJC Standby Quiescent Current Thermal Resistance ON/OFF pin = 5V (OFF) (7) Limit (2) Units (Limits) 200/250 μA(max) μA 80 2 °C/W TO-220 Package, Junction to Ambient (8) 50 °C/W θJA TO-263 Package, Junction to Ambient (9) 50 °C/W θJA TO-263 Package, Junction to Ambient (10) 30 °C/W θJA TO-263 Package, Junction to Ambient (11) 20 °C/W θJA TO-220 or TO-263 Package, Junction to Case ON/OFF CONTROL Test Circuit Figure 20 ON /OFF Pin Logic Input VIH Threshold Voltage VIL IH IL 1.3 Low (Regulator ON) High (Regulator OFF) ON /OFF Pin Input Current VLOGIC = 2.5V (Regulator OFF) VLOGIC = 0.5V (Regulator ON) V 0.6 V(max) 2.0 V(min) 15 μA(max) μA 5 μA 0.02 5 μA(max) (8) Junction to ambient thermal resistance (no external heat sink) for the TO-220 package mounted vertically, with the leads soldered to a printed circuit board with (1 oz.) copper area of approximately 1 in2. (9) Junction to ambient thermal resistance with the TO-263 package tab soldered to a single printed circuit board with 0.5 in2 of (1 oz.) copper area. (10) Junction to ambient thermal resistance with the TO-263 package tab soldered to a single sided printed circuit board with 2.5 in2 of (1 oz.) copper area. (11) Junction to ambient thermal resistance with the TO-263 package tab soldered to a double sided printed circuit board with 3 in2 of (1 oz.) copper area on the LM2596S side of the board, and approximately 16 in2 of copper on the other side of the p-c board. See Application Information in this data sheet and the thermal model in Switchers Made Simple™ version 4.3 software. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 5 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Typical Performance Characteristics (Circuit of Figure 20) 6 Normalized Output Voltage Line Regulation Figure 3. Figure 4. Efficiency Switch Saturation Voltage Figure 5. Figure 6. Switch Current Limit Dropout Voltage Figure 7. Figure 8. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 Typical Performance Characteristics (continued) (Circuit of Figure 20) Operating Quiescent Current Shutdown Quiescent Current Figure 9. Figure 10. Minimum Operating Supply Voltage ON /OFF Threshold Voltage Figure 11. Figure 12. ON /OFF Pin Current (Sinking) Switching Frequency Figure 13. Figure 14. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 7 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Typical Performance Characteristics (continued) (Circuit of Figure 20) Continuous Mode Switching Waveforms VIN = 20V, VOUT = 5V, ILOAD = 2A L = 32 μH, COUT = 220 μF, COUT ESR = 50 mΩ Feedback Pin Bias Current A: Output Pin Voltage, 10V/div. B: Inductor Current 1A/div. C: Output Ripple Voltage, 50 mV/div. Figure 16. Horizontal Time Base: 2 μs/div. Figure 15. Discontinuous Mode Switching Waveforms VIN = 20V, VOUT = 5V, ILOAD = 500 mA L = 10 μH, COUT = 330 μF, COUT ESR = 45 mΩ A: Output Pin Voltage, 10V/div. B: Inductor Current 0.5A/div. C: Output Ripple Voltage, 100 mV/div. Figure 17. Horizontal Time Base: 2 μs/div. Load Transient Response for Continuous Mode VIN = 20V, VOUT = 5V, ILOAD = 500 mA to 2A L = 32 μH, COUT = 220 μF, COUT ESR = 50 mΩ A: Output Voltage, 100 mV/div. (AC) B: 500 mA to 2A Load Pulse Figure 18. Horizontal Time Base: 100 μs/div. Load Transient Response for Discontinuous Mode VIN = 20V, VOUT = 5V, ILOAD = 500 mA to 2A L = 10 μH, COUT = 330 μF, COUT ESR = 45 mΩ A: Output Voltage, 100 mV/div. (AC) B: 500 mA to 2A Load Pulse Figure 19. Horizontal Time Base: 200 μs/div. 8 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 Test Circuit and Layout Guidelines Fixed Output Voltage Versions CIN —470 μF, 50V, Aluminum Electrolytic Nichicon “PL Series” COUT —220 μF, 25V Aluminum Electrolytic, Nichicon “PL Series” D1 —5A, 40V Schottky Rectifier, 1N5825 L1 —68 μH, L38 Adjustable Output Voltage Versions where VREF = 1.23V Select R1 to be approximately 1 kΩ, use a 1% resistor for best stability. CIN —470 μF, 50V, Aluminum Electrolytic Nichicon “PL Series” COUT —220 μF, 35V Aluminum Electrolytic, Nichicon “PL Series” D1 —5A, 40V Schottky Rectifier, 1N5825 L1 —68 μH, L38 R1 —1 kΩ, 1% CFF —See Application Information Section Figure 20. Standard Test Circuits and Layout Guides As in any switching regulator, layout is very important. Rapidly switching currents associated with wiring inductance can generate voltage transients which can cause problems. For minimal inductance and ground loops, the wires indicated by heavy lines should be wide printed circuit traces and should be kept as short as possible. For best results, external components should be located as close to the switcher lC as possible using ground plane construction or single point grounding. If open core inductors are used, special care must be taken as to the location and positioning of this type of inductor. Allowing the inductor flux to intersect sensitive feedback, lC groundpath and COUT wiring can cause problems. When using the adjustable version, special care must be taken as to the location of the feedback resistors and the associated wiring. Physically locate both resistors near the IC, and route the wiring away from the inductor, especially an open core type of inductor. (See Application Information section for more information.) Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 9 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com LM2596 Series Buck Regulator Design Procedure (Fixed Output) PROCEDURE (Fixed Output Voltage Version) EXAMPLE (Fixed Output Voltage Version) Given: VOUT = Regulated Output Voltage (3.3V, 5V or 12V) VIN(max) = Maximum DC Input Voltage ILOAD(max) = Maximum Load Current Given: VOUT = 5V VIN(max) = 12V ILOAD(max) = 3A 1. Inductor Selection (L1) A. Select the correct inductor value selection guide from Figures Figure 21, Figure 22, or Figure 23. (Output voltages of 3.3V, 5V, or 12V respectively.) For all other voltages, see the Design Procedure for the adjustable version. B. From the inductor value selection guide, identify the inductance region intersected by the Maximum Input Voltage line and the Maximum Load Current line. Each region is identified by an inductance value and an inductor code (LXX). C. Select an appropriate inductor from the four manufacturer's part numbers listed in Table 3. 1. Inductor Selection (L1) A. Use the inductor selection guide for the 5V version shown in Figure 22. B. From the inductor value selection guide shown in Figure 22, the inductance region intersected by the 12V horizontal line and the 3A vertical line is 33 μH, and the inductor code is L40. C. The inductance value required is 33 μH. From the table in Table 3, go to the L40 line and choose an inductor part number from any of the four manufacturers shown. (In most instance, both through hole and surface mount inductors are available.) 2. Output Capacitor Selection (COUT) A. In the majority of applications, low ESR (Equivalent Series Resistance) electrolytic capacitors between 82 μF and 820 μF and low ESR solid tantalum capacitors between 10 μF and 470 μF provide the best results. This capacitor should be located close to the IC using short capacitor leads and short copper traces. Do not use capacitors larger than 820 μF . For additional information, see section on output capacitors in Application Information section. B. To simplify the capacitor selection procedure, refer to the quick design component selection table shown in Table 1. This table contains different input voltages, output voltages, and load currents, and lists various inductors and output capacitors that will provide the best design solutions. C. The capacitor voltage rating for electrolytic capacitors should be at least 1.5 times greater than the output voltage, and often much higher voltage ratings are needed to satisfy the low ESR requirements for low output ripple voltage. D. For computer aided design software, see Switchers Made Simple™ version 4.3 or later. 2. Output Capacitor Selection (COUT) A. See section on output capacitors in Application Information section. B. From the quick design component selection table shown in Table 1, locate the 5V output voltage section. In the load current column, choose the load current line that is closest to the current needed in your application, for this example, use the 3A line. In the maximum input voltage column, select the line that covers the input voltage needed in your application, in this example, use the 15V line. Continuing on this line are recommended inductors and capacitors that will provide the best overall performance. The capacitor list contains both through hole electrolytic and surface mount tantalum capacitors from four different capacitor manufacturers. It is recommended that both the manufacturers and the manufacturer's series that are listed in the table be used. In this example aluminum electrolytic capacitors from several different manufacturers are available with the range of ESR numbers needed. 330 μF 35V Panasonic HFQ Series 330 μF 35V Nichicon PL Series C. For a 5V output, a capacitor voltage rating at least 7.5V or more is needed. But even a low ESR, switching grade, 220 μF 10V aluminum electrolytic capacitor would exhibit approximately 225 mΩ of ESR (see the curve in Figure 26 for the ESR vs voltage rating). This amount of ESR would result in relatively high output ripple voltage. To reduce the ripple to 1% of the output voltage, or less, a capacitor with a higher value or with a higher voltage rating (lower ESR) should be selected. A 16V or 25V capacitor will reduce the ripple voltage by approximately half. 10 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 PROCEDURE (Fixed Output Voltage Version) EXAMPLE (Fixed Output Voltage Version) 3. Catch Diode Selection (D1) A. The catch diode current rating must be at least 1.3 times greater than the maximum load current. Also, if the power supply design must withstand a continuous output short, the diode should have a current rating equal to the maximum current limit of the LM2596. The most stressful condition for this diode is an overload or shorted output condition. B. The reverse voltage rating of the diode should be at least 1.25 times the maximum input voltage. C. This diode must be fast (short reverse recovery time) and must be located close to the LM2596 using short leads and short printed circuit traces. Because of their fast switching speed and low forward voltage drop, Schottky diodes provide the best performance and efficiency, and should be the first choice, especially in low output voltage applications. Ultra-fast recovery, or High-Efficiency rectifiers also provide good results. Ultra-fast recovery diodes typically have reverse recovery times of 50 ns or less. Rectifiers such as the 1N5400 series are much too slow and should not be used. 3. Catch Diode Selection (D1) A. Refer to the table shown in Table 6. In this example, a 5A, 20V, 1N5823 Schottky diode will provide the best performance, and will not be overstressed even for a shorted output. 4. Input Capacitor (CIN) A low ESR aluminum or tantalum bypass capacitor is needed between the input pin and ground pin to prevent large voltage transients from appearing at the input. This capacitor should be located close to the IC using short leads. In addition, the RMS current rating of the input capacitor should be selected to be at least ½ the DC load current. The capacitor manufacturers data sheet must be checked to assure that this current rating is not exceeded. The curve shown in Figure 25 shows typical RMS current ratings for several different aluminum electrolytic capacitor values. For an aluminum electrolytic, the capacitor voltage rating should be approximately 1.5 times the maximum input voltage. Caution must be exercised if solid tantalum capacitors are used (see Application Information on input capacitor). The tantalum capacitor voltage rating should be 2 times the maximum input voltage and it is recommended that they be surge current tested by the manufacturer. Use caution when using ceramic capacitors for input bypassing, because it may cause severe ringing at the VIN pin. For additional information, see section on input capacitors in Application Information section. 4. Input Capacitor (CIN) The important parameters for the Input capacitor are the input voltage rating and the RMS current rating. With a nominal input voltage of 12V, an aluminum electrolytic capacitor with a voltage rating greater than 18V (1.5 × VIN) would be needed. The next higher capacitor voltage rating is 25V. The RMS current rating requirement for the input capacitor in a buck regulator is approximately ½ the DC load current. In this example, with a 3A load, a capacitor with a RMS current rating of at least 1.5A is needed. The curves shown in Figure 25 can be used to select an appropriate input capacitor. From the curves, locate the 35V line and note which capacitor values have RMS current ratings greater than 1.5A. A 680 μF/35V capacitor could be used. For a through hole design, a 680 μF/35V electrolytic capacitor (Panasonic HFQ series or Nichicon PL series or equivalent) would be adequate. other types or other manufacturers capacitors can be used provided the RMS ripple current ratings are adequate. For surface mount designs, solid tantalum capacitors can be used, but caution must be exercised with regard to the capacitor surge current rating (see Application Information on input capacitors in this data sheet). The TPS series available from AVX, and the 593D series from Sprague are both surge current tested. Table 1. LM2596 Fixed Voltage Quick Design Component Selection Table Conditions Inductor Output Capacitor Through Hole Electrolytic Output Voltage (V) Load Current (A) 3.3 3 2 Max Input Voltage (V) Inductance (μH) Inductor (#) Surface Mount Tantalum Panasonic HFQ Series (μF/V) Nichicon PL Series (μF/V) AVX TPS Series (μF/V) Sprague 595D Series (μF/V) 5 22 L41 470/25 560/16 330/6.3 390/6.3 7 22 L41 560/35 560/35 330/6.3 390/6.3 10 22 L41 680/35 680/35 330/6.3 390/6.3 40 33 L40 560/35 470/35 330/6.3 390/6.3 6 22 L33 470/25 470/35 330/6.3 390/6.3 10 33 L32 330/35 330/35 330/6.3 390/6.3 40 47 L39 330/35 270/50 220/10 330/10 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 11 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Table 1. LM2596 Fixed Voltage Quick Design Component Selection Table (continued) Conditions Inductor Output Capacitor Through Hole Electrolytic Output Voltage (V) Load Current (A) 5 3 2 12 3 2 Max Input Voltage (V) Inductance (μH) Inductor (#) Surface Mount Tantalum Panasonic HFQ Series (μF/V) Nichicon PL Series (μF/V) AVX TPS Series (μF/V) Sprague 595D Series (μF/V) 8 22 L41 470/25 560/16 220/10 330/10 10 22 L41 560/25 560/25 220/10 330/10 15 33 L40 330/35 330/35 220/10 330/10 40 47 L39 330/35 270/35 220/10 330/10 9 22 L33 470/25 560/16 220/10 330/10 20 68 L38 180/35 180/35 100/10 270/10 40 68 L38 180/35 180/35 100/10 270/10 15 22 L41 470/25 470/25 100/16 180/16 18 33 L40 330/25 330/25 100/16 180/16 30 68 L44 180/25 180/25 100/16 120/20 40 68 L44 180/35 180/35 100/16 120/20 15 33 L32 330/25 330/25 100/16 180/16 20 68 L38 180/25 180/25 100/16 120/20 40 150 L42 82/25 82/25 68/20 68/25 LM2596 Series Buck Regulator Design Procedure (Adjustable Output) PROCEDURE (Adjustable Output Voltage Version) EXAMPLE (Adjustable Output Voltage Version) Given: VOUT = Regulated Output Voltage VIN(max) = Maximum Input Voltage ILOAD(max) = Maximum Load Current F = Switching Frequency (Fixed at a nominal 150 kHz). Given: VOUT = 20V VIN(max) = 28V ILOAD(max) = 3A F = Switching Frequency (Fixed at a nominal 150 kHz). 1. Programming Output Voltage (Selecting R1 and R2, as shown in 1. Programming Output Voltage (Selecting R1 and R2, as shown in Figure 20 ) Figure 20 ) Use the following formula to select the appropriate resistor values. Select R1 to be 1 kΩ, 1%. Solve for R2. (3) (1) Select a value for R1 between 240Ω and 1.5 kΩ. The lower resistor R2 = 1k (16.26 − 1) = 15.26k, closest 1% value is 15.4 kΩ. values minimize noise pickup in the sensitive feedback pin. (For the R = 15.4 kΩ. 2 lowest temperature coefficient and the best stability with time, use 1% metal film resistors.) (2) 12 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 PROCEDURE (Adjustable Output Voltage Version) EXAMPLE (Adjustable Output Voltage Version) 2. Inductor Selection (L1) 2. Inductor Selection (L1) A. Calculate the inductor Volt • microsecond constant E • T (V • μs), A. Calculate the inductor Volt • microsecond constant from the following formula: (E • T), where • • (5) VSAT = internal switch saturation voltage = B. E • T = 34.2 (V • μs) 1.16V C. ILOAD(max) = 3A VD = diode forward voltage drop = 0.5V (4) D. From the inductor value selection guide shown in Figure 24, the inductance region intersected by the 34 (V • μs) horizontal line and B. Use the E • T value from the previous formula and match it with the 3A vertical line is 47 μH, and the inductor code is L39. the E • T number on the vertical axis of the Inductor Value Selection E. From the table in Table 3, locate line L39, and select an inductor Guide shown in Figure 24. part number from the list of manufacturers part numbers. C. on the horizontal axis, select the maximum load current. D. Identify the inductance region intersected by the E • T value and the Maximum Load Current value. Each region is identified by an inductance value and an inductor code (LXX). E. Select an appropriate inductor from the four manufacturer's part numbers listed in Table 3. 3. Output Capacitor Selection (COUT) A. In the majority of applications, low ESR electrolytic or solid tantalum capacitors between 82 μF and 820 μF provide the best results. This capacitor should be located close to the IC using short capacitor leads and short copper traces. Do not use capacitors larger than 820 μF. For additional information, see section on output capacitors in Application Information section. B. To simplify the capacitor selection procedure, refer to the quick design table shown in Table 2. This table contains different output voltages, and lists various output capacitors that will provide the best design solutions. C. The capacitor voltage rating should be at least 1.5 times greater than the output voltage, and often much higher voltage ratings are needed to satisfy the low ESR requirements needed for low output ripple voltage. 3. Output Capacitor SeIection (COUT) A. See section on COUT in Application Information section. B. From the quick design table shown in Table 2, locate the output voltage column. From that column, locate the output voltage closest to the output voltage in your application. In this example, select the 24V line. Under the OUTPUT CAPACITOR section, select a capacitor from the list of through hole electrolytic or surface mount tantalum types from four different capacitor manufacturers. It is recommended that both the manufacturers and the manufacturers series that are listed in the table be used. In this example, through hole aluminum electrolytic capacitors from several different manufacturers are available. 220 μF/35V Panasonic HFQ Series 150 μF/35V Nichicon PL Series C. For a 20V output, a capacitor rating of at least 30V or more is needed. In this example, either a 35V or 50V capacitor would work. A 35V rating was chosen, although a 50V rating could also be used if a lower output ripple voltage is needed. Other manufacturers or other types of capacitors may also be used, provided the capacitor specifications (especially the 100 kHz ESR) closely match the types listed in the table. Refer to the capacitor manufacturers data sheet for this information. 4. Feedforward Capacitor (CFF) (See Figure 20) For output voltages greater than approximately 10V, an additional capacitor is required. The compensation capacitor is typically between 100 pF and 33 nF, and is wired in parallel with the output voltage setting resistor, R2. It provides additional stability for high output voltages, low input-output voltages, and/or very low ESR output capacitors, such as solid tantalum capacitors. 4. Feedforward Capacitor (CFF) The table shown in Table 2 contains feed forward capacitor values for various output voltages. In this example, a 560 pF capacitor is needed. (6) This capacitor type can be ceramic, plastic, silver mica, etc. (Because of the unstable characteristics of ceramic capacitors made with Z5U material, they are not recommended.) Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 13 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com PROCEDURE (Adjustable Output Voltage Version) EXAMPLE (Adjustable Output Voltage Version) 5. Catch Diode Selection (D1) A. The catch diode current rating must be at least 1.3 times greater than the maximum load current. Also, if the power supply design must withstand a continuous output short, the diode should have a current rating equal to the maximum current limit of the LM2596. The most stressful condition for this diode is an overload or shorted output condition. B. The reverse voltage rating of the diode should be at least 1.25 times the maximum input voltage. C. This diode must be fast (short reverse recovery time) and must be located close to the LM2596 using short leads and short printed circuit traces. Because of their fast switching speed and low forward voltage drop, Schottky diodes provide the best performance and efficiency, and should be the first choice, especially in low output voltage applications. Ultra-fast recovery, or High-Efficiency rectifiers are also a good choice, but some types with an abrupt turn-off characteristic may cause instability or EMl problems. Ultra-fast recovery diodes typically have reverse recovery times of 50 ns or less. Rectifiers such as the 1N4001 series are much too slow and should not be used. 5. Catch Diode Selection (D1) A. Refer to the table shown in Table 6. Schottky diodes provide the best performance, and in this example a 5A, 40V, 1N5825 Schottky diode would be a good choice. The 5A diode rating is more than adequate and will not be overstressed even for a shorted output. 6. Input Capacitor (CIN) A low ESR aluminum or tantalum bypass capacitor is needed between the input pin and ground to prevent large voltage transients from appearing at the input. In addition, the RMS current rating of the input capacitor should be selected to be at least ½ the DC load current. The capacitor manufacturers data sheet must be checked to assure that this current rating is not exceeded. The curve shown in Figure 25 shows typical RMS current ratings for several different aluminum electrolytic capacitor values. This capacitor should be located close to the IC using short leads and the voltage rating should be approximately 1.5 times the maximum input voltage. If solid tantalum input capacitors are used, it is recomended that they be surge current tested by the manufacturer. Use caution when using a high dielectric constant ceramic capacitor for input bypassing, because it may cause severe ringing at the VIN pin. For additional information, see section on input capacitors in Application Information section. 6. Input Capacitor (CIN) The important parameters for the Input capacitor are the input voltage rating and the RMS current rating. With a nominal input voltage of 28V, an aluminum electrolytic aluminum electrolytic capacitor with a voltage rating greater than 42V (1.5 × VIN) would be needed. Since the the next higher capacitor voltage rating is 50V, a 50V capacitor should be used. The capacitor voltage rating of (1.5 × VIN) is a conservative guideline, and can be modified somewhat if desired. The RMS current rating requirement for the input capacitor of a buck regulator is approximately ½ the DC load current. In this example, with a 3A load, a capacitor with a RMS current rating of at least 1.5A is needed. The curves shown in Figure 25 can be used to select an appropriate input capacitor. From the curves, locate the 50V line and note which capacitor values have RMS current ratings greater than 1.5A. Either a 470 μF or 680 μF, 50V capacitor could be used. For a through hole design, a 680 μF/50V electrolytic capacitor (Panasonic HFQ series or Nichicon PL series or equivalent) would be adequate. Other types or other manufacturers capacitors can be used provided the RMS ripple current ratings are adequate. For surface mount designs, solid tantalum capacitors can be used, but caution must be exercised with regard to the capacitor surge current rting (see Application Information or input capacitors in this data sheet). The TPS series available from AVX, and the 593D series from Sprague are both surge current tested. To further simplify the buck regulator design procedure, Texas Instruments is making available computer design software to be used with the Simple Switcher line ot switching regulators. Switchers Made Simple (version 4.3 or later) is available on a 3½″ diskette for IBM compatible computers. LM2596 Series Buck Regulator Design Procedure (Adjustable Output) Table 2. Output Capacitor and Feedforward Capacitor Selection Table Output Voltage (V) 14 Through Hole Output Capacitor Panasonic HFQ Series (μF/V) Nichicon PL Series (μF/V) 2 820/35 820/35 4 560/35 6 470/25 Surface Mount Output Capacitor Feedforward Capacitor AVX TPS Series (μF/V) Sprague 595D Series (μF/V) Feedforward Capacitor 33 nF 330/6.3 470/4 33 nF 470/35 10 nF 330/6.3 390/6.3 10 nF 470/25 3.3 nF 220/10 330/10 3.3 nF Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 Table 2. Output Capacitor and Feedforward Capacitor Selection Table (continued) Output Voltage (V) Through Hole Output Capacitor Panasonic HFQ Series (μF/V) Nichicon PL Series (μF/V) 9 330/25 330/25 12 330/25 15 220/35 24 28 Surface Mount Output Capacitor Feedforward Capacitor AVX TPS Series (μF/V) Sprague 595D Series (μF/V) Feedforward Capacitor 1.5 nF 100/16 180/16 1.5 nF 330/25 1 nF 100/16 180/16 1 nF 220/35 680 pF 68/20 120/20 680 pF 220/35 150/35 560 pF 33/25 33/25 220 pF 100/50 100/50 390 pF 10/35 15/50 220 pF LM2596 Series Buck Regulator Design Procedure INDUCTOR VALUE SELECTION GUIDES (For Continuous Mode Operation) Figure 21. LM2596-3.3 Figure 22. LM2596-5.0 Figure 23. LM2596-12 Figure 24. LM2596-ADJ Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 15 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Table 3. Inductor Manufacturers Part Numbers Inductance (μH) Current (A) Schott Renco Through Hole Surface Mount Through Hole Pulse Engineering Surface Mount Through Hole Surface Mount Coilcraft Surface Mount L15 22 0.99 67148350 67148460 RL-1284-22-43 RL1500-22 PE-53815 PE-53815-S DO3308-223 L21 68 0.99 67144070 67144450 RL-5471-5 RL1500-68 PE-53821 PE-53821-S DO3316-683 L22 47 1.17 67144080 67144460 RL-5471-6 — PE-53822 PE-53822-S DO3316-473 L23 33 1.40 67144090 67144470 RL-5471-7 — PE-53823 PE-53823-S DO3316-333 L24 22 1.70 67148370 67148480 RL-1283-22-43 — PE-53824 PE-53825-S DO3316-223 L25 15 2.10 67148380 67148490 RL-1283-15-43 — PE-53825 PE-53824-S DO3316-153 L26 330 0.80 67144100 67144480 RL-5471-1 — PE-53826 PE-53826-S DO5022P-334 L27 220 1.00 67144110 67144490 RL-5471-2 — PE-53827 PE-53827-S DO5022P-224 L28 150 1.20 67144120 67144500 RL-5471-3 — PE-53828 PE-53828-S DO5022P-154 L29 100 1.47 67144130 67144510 RL-5471-4 — PE-53829 PE-53829-S DO5022P-104 L30 68 1.78 67144140 67144520 RL-5471-5 — PE-53830 PE-53830-S DO5022P-683 L31 47 2.20 67144150 67144530 RL-5471-6 — PE-53831 PE-53831-S DO5022P-473 L32 33 2.50 67144160 67144540 RL-5471-7 — PE-53932 PE-53932-S DO5022P-333 L33 22 3.10 67148390 67148500 RL-1283-22-43 — PE-53933 PE-53933-S DO5022P-223 L34 15 3.40 67148400 67148790 RL-1283-15-43 — PE-53934 PE-53934-S DO5022P-153 L35 220 1.70 67144170 — RL-5473-1 — L36 150 2.10 67144180 — RL-5473-4 — PE-54036 PE-54036-S — L37 100 2.50 67144190 — RL-5472-1 — PE-54037 PE-54037-S — L38 68 3.10 67144200 — RL-5472-2 — PE-54038 PE-54038-S — L39 47 3.50 67144210 — RL-5472-3 — PE-54039 PE-54039-S — L40 33 3.50 67144220 67148290 RL-5472-4 — PE-54040 PE-54040-S — L41 22 3.50 67144230 67148300 RL-5472-5 — PE-54041 PE-54041-S — L42 150 2.70 67148410 — RL-5473-4 — PE-54042 PE-54042-S — L43 100 3.40 67144240 — RL-5473-2 — PE-54043 — L44 68 3.40 67144250 — RL-5473-3 — PE-54044 — PE-53935 PE-53935-S — Table 4. Inductor Manufacturers Phone Numbers Coilcraft Inc. Coilcraft Inc., Europe Pulse Engineering Inc. Pulse Engineering Inc., Europe Renco Electronics Inc. Schott Corp. Phone (800) 322-2645 FAX (708) 639-1469 Phone +11 1236 730 595 FAX +44 1236 730 627 Phone (619) 674-8100 FAX (619) 674-8262 Phone +353 93 24 107 FAX +353 93 24 459 Phone (800) 645-5828 FAX (516) 586-5562 Phone (612) 475-1173 FAX (612) 475-1786 Table 5. Capacitor Manufacturers Phone Numbers Nichicon Corp. Panasonic 16 Phone (708) 843-7500 FAX (708) 843-2798 Phone (714) 373-7857 FAX (714) 373-7102 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 Table 5. Capacitor Manufacturers Phone Numbers (continued) AVX Corp. Sprague/Vishay Phone (803) 448-9411 FAX (803) 448-1943 Phone (207) 324-4140 FAX (207) 324-7223 Table 6. Diode Selection Table VR 3A Diodes Surface Mount Schottky Ultra Fast 4A–6A Diodes Through Hole Schottky Recovery 20V SK32 30V 30WQ03 SK33 40V or More 1N5820 SR302 MBR320 1N5821 MBR330 Recovery All of these diodes are rated to at least 50V. All of these diodes are rated to at least 50V. 50WQ03 31DQ04 50WQ04 SR502 1N5823 SB520 SR503 MBR350 30WQ05 31DQ05 All of these diodes are rated to at least 50V. SR504 1N5825 MUR320 MURS620 SR305 MBRS360 Ultra Fast Recovery SB530 MBR340 30WF10 Recovery Schottky 1N5824 SR304 SK35 Through Hole Ultra Fast 1N5822 MBRS340 MURS320 Surface Mount Schottky 31DQ03 SK34 30WQ04 50V All of these diodes are rated to at least 50V. Ultra Fast SB540 50WF10 50WQ05 MUR620 HER601 SB550 50SQ080 Block Diagram Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 17 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com APPLICATION INFORMATION Table 7. PIN DESCRIPTIONS Name +VIN Description This is the positive input supply for the IC switching regulator. A suitable input bypass capacitor must be present at this pin to minimize voltage transients and to supply the switching currents needed by the regulator. Ground Circuit ground. Output Internal switch. The voltage at this pin switches between (+VIN − VSAT) and approximately −0.5V, with a duty cycle of approximately VOUT/VIN. To minimize coupling to sensitive circuitry, the PC board copper area connected to this pin should be kept to a minimum. Feedback Senses the regulated output voltage to complete the feedback loop. ON /OFF Allows the switching regulator circuit to be shut down using logic level signals thus dropping the total input supply current to approximately 80 μA. Pulling this pin below a threshold voltage of approximately 1.3V turns the regulator on, and pulling this pin above 1.3V (up to a maximum of 25V) shuts the regulator down. If this shutdown feature is not needed, the ON /OFF pin can be wired to the ground pin or it can be left open, in either case the regulator will be in the ON condition. EXTERNAL COMPONENTS INPUT CAPACITOR CIN — A low ESR aluminum or tantalum bypass capacitor is needed between the input pin and ground pin. It must be located near the regulator using short leads. This capacitor prevents large voltage transients from appearing at the input, and provides the instantaneous current needed each time the switch turns on. The important parameters for the Input capacitor are the voltage rating and the RMS current rating. Because of the relatively high RMS currents flowing in a buck regulator's input capacitor, this capacitor should be chosen for its RMS current rating rather than its capacitance or voltage ratings, although the capacitance value and voltage rating are directly related to the RMS current rating. The RMS current rating of a capacitor could be viewed as a capacitor's power rating. The RMS current flowing through the capacitors internal ESR produces power which causes the internal temperature of the capacitor to rise. The RMS current rating of a capacitor is determined by the amount of current required to raise the internal temperature approximately 10°C above an ambient temperature of 105°C. The ability of the capacitor to dissipate this heat to the surrounding air will determine the amount of current the capacitor can safely sustain. Capacitors that are physically large and have a large surface area will typically have higher RMS current ratings. For a given capacitor value, a higher voltage electrolytic capacitor will be physically larger than a lower voltage capacitor, and thus be able to dissipate more heat to the surrounding air, and therefore will have a higher RMS current rating. The consequences of operating an electrolytic capacitor above the RMS current rating is a shortened operating life. The higher temperature speeds up the evaporation of the capacitor's electrolyte, resulting in eventual failure. Selecting an input capacitor requires consulting the manufacturers data sheet for maximum allowable RMS ripple current. For a maximum ambient temperature of 40°C, a general guideline would be to select a capacitor with a ripple current rating of approximately 50% of the DC load current. For ambient temperatures up to 70°C, a current rating of 75% of the DC load current would be a good choice for a conservative design. The capacitor voltage rating must be at least 1.25 times greater than the maximum input voltage, and often a much higher voltage capacitor is needed to satisfy the RMS current requirements. A graph shown in Figure 25 shows the relationship between an electrolytic capacitor value, its voltage rating, and the RMS current it is rated for. These curves were obtained from the Nichicon “PL” series of low ESR, high reliability electrolytic capacitors designed for switching regulator applications. Other capacitor manufacturers offer similar types of capacitors, but always check the capacitor data sheet. “Standard” electrolytic capacitors typically have much higher ESR numbers, lower RMS current ratings and typically have a shorter operating lifetime. 18 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 Because of their small size and excellent performance, surface mount solid tantalum capacitors are often used for input bypassing, but several precautions must be observed. A small percentage of solid tantalum capacitors can short if the inrush current rating is exceeded. This can happen at turn on when the input voltage is suddenly applied, and of course, higher input voltages produce higher inrush currents. Several capacitor manufacturers do a 100% surge current testing on their products to minimize this potential problem. If high turn on currents are expected, it may be necessary to limit this current by adding either some resistance or inductance before the tantalum capacitor, or select a higher voltage capacitor. As with aluminum electrolytic capacitors, the RMS ripple current rating must be sized to the load current. FEEDFORWARD CAPACITOR (Adjustable Output Voltage Version) CFF — A Feedforward Capacitor CFF, shown across R2 in Figure 20 is used when the ouput voltage is greater than 10V or when COUT has a very low ESR. This capacitor adds lead compensation to the feedback loop and increases the phase margin for better loop stability. For CFF selection, see the Design Procedure section. Figure 25. RMS Current Ratings for Low ESR Electrolytic Capacitors (Typical) OUTPUT CAPACITOR COUT — An output capacitor is required to filter the output and provide regulator loop stability. Low impedance or low ESR Electrolytic or solid tantalum capacitors designed for switching regulator applications must be used. When selecting an output capacitor, the important capacitor parameters are; the 100 kHz Equivalent Series Resistance (ESR), the RMS ripple current rating, voltage rating, and capacitance value. For the output capacitor, the ESR value is the most important parameter. The output capacitor requires an ESR value that has an upper and lower limit. For low output ripple voltage, a low ESR value is needed. This value is determined by the maximum allowable output ripple voltage, typically 1% to 2% of the output voltage. But if the selected capacitor's ESR is extremely low, there is a possibility of an unstable feedback loop, resulting in an oscillation at the output. Using the capacitors listed in the tables, or similar types, will provide design solutions under all conditions. If very low output ripple voltage (less than 15 mV) is required, refer to the section on OUTPUT VOLTAGE RIPPLE AND TRANSIENTS for a post ripple filter. An aluminum electrolytic capacitor's ESR value is related to the capacitance value and its voltage rating. In most cases, higher voltage electrolytic capacitors have lower ESR values (see Figure 26 ). Often, capacitors with much higher voltage ratings may be needed to provide the low ESR values required for low output ripple voltage. The output capacitor for many different switcher designs often can be satisfied with only three or four different capacitor values and several different voltage ratings. See the quick design component selection tables in Table 1 and 4 for typical capacitor values, voltage ratings, and manufacturers capacitor types. Electrolytic capacitors are not recommended for temperatures below −25°C. The ESR rises dramatically at cold temperatures and typically rises 3X @ −25°C and as much as 10X at −40°C. See curve shown in Figure 27. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 19 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Solid tantalum capacitors have a much better ESR spec for cold temperatures and are recommended for temperatures below −25°C. Figure 26. Capacitor ESR vs Capacitor Voltage Rating (Typical Low ESR Electrolytic Capacitor) CATCH DIODE Buck regulators require a diode to provide a return path for the inductor current when the switch turns off. This must be a fast diode and must be located close to the LM2596 using short leads and short printed circuit traces. Because of their very fast switching speed and low forward voltage drop, Schottky diodes provide the best performance, especially in low output voltage applications (5V and lower). Ultra-fast recovery, or High-Efficiency rectifiers are also a good choice, but some types with an abrupt turnoff characteristic may cause instability or EMI problems. Ultra-fast recovery diodes typically have reverse recovery times of 50 ns or less. Rectifiers such as the 1N5400 series are much too slow and should not be used. Figure 27. Capacitor ESR Change vs Temperature INDUCTOR SELECTION All switching regulators have two basic modes of operation; continuous and discontinuous. The difference between the two types relates to the inductor current, whether it is flowing continuously, or if it drops to zero for a period of time in the normal switching cycle. Each mode has distinctively different operating characteristics, which can affect the regulators performance and requirements. Most switcher designs will operate in the discontinuous mode when the load current is low. The LM2596 (or any of the Simple Switcher family) can be used for both continuous or discontinuous modes of operation. 20 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 In many cases the preferred mode of operation is the continuous mode. It offers greater output power, lower peak switch, inductor and diode currents, and can have lower output ripple voltage. But it does require larger inductor values to keep the inductor current flowing continuously, especially at low output load currents and/or high input voltages. To simplify the inductor selection process, an inductor selection guide (nomograph) was designed (see Figure 21 through 8). This guide assumes that the regulator is operating in the continuous mode, and selects an inductor that will allow a peak-to-peak inductor ripple current to be a certain percentage of the maximum design load current. This peak-to-peak inductor ripple current percentage is not fixed, but is allowed to change as different design load currents are selected. (See Figure 28.) Figure 28. (ΔIIND) Peak-to-Peak Inductor Ripple Current (as a Percentage of the Load Current) vs Load Current By allowing the percentage of inductor ripple current to increase for low load currents, the inductor value and size can be kept relatively low. When operating in the continuous mode, the inductor current waveform ranges from a triangular to a sawtooth type of waveform (depending on the input voltage), with the average value of this current waveform equal to the DC output load current. Inductors are available in different styles such as pot core, toroid, E-core, bobbin core, etc., as well as different core materials, such as ferrites and powdered iron. The least expensive, the bobbin, rod or stick core, consists of wire wound on a ferrite bobbin. This type of construction makes for an inexpensive inductor, but since the magnetic flux is not completely contained within the core, it generates more Electro-Magnetic Interference (EMl). This magnetic flux can induce voltages into nearby printed circuit traces, thus causing problems with both the switching regulator operation and nearby sensitive circuitry, and can give incorrect scope readings because of induced voltages in the scope probe. Also see section on OPEN CORE INDUCTORS. When multiple switching regulators are located on the same PC board, open core magnetics can cause interference between two or more of the regulator circuits, especially at high currents. A torroid or E-core inductor (closed magnetic structure) should be used in these situations. The inductors listed in the selection chart include ferrite E-core construction for Schott, ferrite bobbin core for Renco and Coilcraft, and powdered iron toroid for Pulse Engineering. Exceeding an inductor's maximum current rating may cause the inductor to overheat because of the copper wire losses, or the core may saturate. If the inductor begins to saturate, the inductance decreases rapidly and the inductor begins to look mainly resistive (the DC resistance of the winding). This can cause the switch current to rise very rapidly and force the switch into a cycle-by-cycle current limit, thus reducing the DC output load current. This can also result in overheating of the inductor and/or the LM2596. Different inductor types have different saturation characteristics, and this should be kept in mind when selecting an inductor. The inductor manufacturer's data sheets include current and energy limits to avoid inductor saturation. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 21 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com DISCONTINUOUS MODE OPERATION The selection guide chooses inductor values suitable for continuous mode operation, but for low current applications and/or high input voltages, a discontinuous mode design may be a better choice. It would use an inductor that would be physically smaller, and would need only one half to one third the inductance value needed for a continuous mode design. The peak switch and inductor currents will be higher in a discontinuous design, but at these low load currents (1A and below), the maximum switch current will still be less than the switch current limit. Discontinuous operation can have voltage waveforms that are considerable different than a continuous design. The output pin (switch) waveform can have some damped sinusoidal ringing present. (See Typical Performance Characteristics photo titled Discontinuous Mode Switching Waveforms) This ringing is normal for discontinuous operation, and is not caused by feedback loop instabilities. In discontinuous operation, there is a period of time where neither the switch or the diode are conducting, and the inductor current has dropped to zero. During this time, a small amount of energy can circulate between the inductor and the switch/diode parasitic capacitance causing this characteristic ringing. Normally this ringing is not a problem, unless the amplitude becomes great enough to exceed the input voltage, and even then, there is very little energy present to cause damage. Different inductor types and/or core materials produce different amounts of this characteristic ringing. Ferrite core inductors have very little core loss and therefore produce the most ringing. The higher core loss of powdered iron inductors produce less ringing. If desired, a series RC could be placed in parallel with the inductor to dampen the ringing. The computer aided design software Switchers Made Simple (version 4.3) will provide all component values for continuous and discontinuous modes of operation. Figure 29. Post Ripple Filter Waveform OUTPUT VOLTAGE RIPPLE AND TRANSIENTS The output voltage of a switching power supply operating in the continuous mode will contain a sawtooth ripple voltage at the switcher frequency, and may also contain short voltage spikes at the peaks of the sawtooth waveform. The output ripple voltage is a function of the inductor sawtooth ripple current and the ESR of the output capacitor. A typical output ripple voltage can range from approximately 0.5% to 3% of the output voltage. To obtain low ripple voltage, the ESR of the output capacitor must be low, however, caution must be exercised when using extremely low ESR capacitors because they can affect the loop stability, resulting in oscillation problems. If very low output ripple voltage is needed (less than 20 mV), a post ripple filter is recommended. (See Figure 20.) The inductance required is typically between 1 μH and 5 μH, with low DC resistance, to maintain good load regulation. A low ESR output filter capacitor is also required to assure good dynamic load response and ripple reduction. The ESR of this capacitor may be as low as desired, because it is out of the regulator feedback loop. The photo shown in Figure 29 shows a typical output ripple voltage, with and without a post ripple filter. 22 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 When observing output ripple with a scope, it is essential that a short, low inductance scope probe ground connection be used. Most scope probe manufacturers provide a special probe terminator which is soldered onto the regulator board, preferable at the output capacitor. This provides a very short scope ground thus eliminating the problems associated with the 3 inch ground lead normally provided with the probe, and provides a much cleaner and more accurate picture of the ripple voltage waveform. The voltage spikes are caused by the fast switching action of the output switch and the diode, and the parasitic inductance of the output filter capacitor, and its associated wiring. To minimize these voltage spikes, the output capacitor should be designed for switching regulator applications, and the lead lengths must be kept very short. Wiring inductance, stray capacitance, as well as the scope probe used to evaluate these transients, all contribute to the amplitude of these spikes. When a switching regulator is operating in the continuous mode, the inductor current waveform ranges from a triangular to a sawtooth type of waveform (depending on the input voltage). For a given input and output voltage, the peak-to-peak amplitude of this inductor current waveform remains constant. As the load current increases or decreases, the entire sawtooth current waveform also rises and falls. The average value (or the center) of this current waveform is equal to the DC load current. If the load current drops to a low enough level, the bottom of the sawtooth current waveform will reach zero, and the switcher will smoothly change from a continuous to a discontinuous mode of operation. Most switcher designs (irregardless how large the inductor value is) will be forced to run discontinuous if the output is lightly loaded. This is a perfectly acceptable mode of operation. Figure 30. Peak-to-Peak Inductor Ripple Current vs Load Current In a switching regulator design, knowing the value of the peak-to-peak inductor ripple current (ΔIIND) can be useful for determining a number of other circuit parameters. Parameters such as, peak inductor or peak switch current, minimum load current before the circuit becomes discontinuous, output ripple voltage and output capacitor ESR can all be calculated from the peak-to-peak ΔIIND. When the inductor nomographs shown in Figure 21 through 8 are used to select an inductor value, the peak-to-peak inductor ripple current can immediately be determined. The curve shown in Figure 30 shows the range of (ΔIIND) that can be expected for different load currents. The curve also shows how the peak-to-peak inductor ripple current (ΔIIND) changes as you go from the lower border to the upper border (for a given load current) within an inductance region. The upper border represents a higher input voltage, while the lower border represents a lower input voltage (see Inductor Selection Guides section). These curves are only correct for continuous mode operation, and only if the inductor selection guides are used to select the inductor value Consider the following example: VOUT = 5V, maximum load current of 2.5A VIN = 12V, nominal, varying between 10V and 16V. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 23 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com The selection guide in Figure 22 shows that the vertical line for a 2.5A load current, and the horizontal line for the 12V input voltage intersect approximately midway between the upper and lower borders of the 33 μH inductance region. A 33 μH inductor will allow a peak-to-peak inductor current (ΔIIND) to flow that will be a percentage of the maximum load current. Referring to Figure 30, follow the 2.5A line approximately midway into the inductance region, and read the peak-to-peak inductor ripple current (ΔIIND) on the left hand axis (approximately 620 mA pp). As the input voltage increases to 16V, it approaches the upper border of the inductance region, and the inductor ripple current increases. Referring to the curve in Figure 30, it can be seen that for a load current of 2.5A, the peak-to-peak inductor ripple current (ΔIIND) is 620 mA with 12V in, and can range from 740 mA at the upper border (16V in) to 500 mA at the lower border (10V in). Once the ΔIIND value is known, the following formulas can be used to calculate additional information about the switching regulator circuit. 1. Peak Inductor or peak switch current 2. Minimum load current before the circuit becomes discontinuous 3. Output Ripple Voltage = (ΔIIND)×(ESR of COUT) = 0.62A×0.1Ω = 62 mV p-p 4. added for line break OPEN CORE INDUCTORS Another possible source of increased output ripple voltage or unstable operation is from an open core inductor. Ferrite bobbin or stick inductors have magnetic lines of flux flowing through the air from one end of the bobbin to the other end. These magnetic lines of flux will induce a voltage into any wire or PC board copper trace that comes within the inductor's magnetic field. The strength of the magnetic field, the orientation and location of the PC copper trace to the magnetic field, and the distance between the copper trace and the inductor, determine the amount of voltage generated in the copper trace. Another way of looking at this inductive coupling is to consider the PC board copper trace as one turn of a transformer (secondary) with the inductor winding as the primary. Many millivolts can be generated in a copper trace located near an open core inductor which can cause stability problems or high output ripple voltage problems. If unstable operation is seen, and an open core inductor is used, it's possible that the location of the inductor with respect to other PC traces may be the problem. To determine if this is the problem, temporarily raise the inductor away from the board by several inches and then check circuit operation. If the circuit now operates correctly, then the magnetic flux from the open core inductor is causing the problem. Substituting a closed core inductor such as a torroid or E-core will correct the problem, or re-arranging the PC layout may be necessary. Magnetic flux cutting the IC device ground trace, feedback trace, or the positive or negative traces of the output capacitor should be minimized. Sometimes, locating a trace directly beneath a bobbin in- ductor will provide good results, provided it is exactly in the center of the inductor (because the induced voltages cancel themselves out), but if it is off center one direction or the other, then problems could arise. If flux problems are present, even the direction of the inductor winding can make a difference in some circuits. This discussion on open core inductors is not to frighten the user, but to alert the user on what kind of problems to watch out for when using them. Open core bobbin or “stick” inductors are an inexpensive, simple way of making a compact efficient inductor, and they are used by the millions in many different applications. 24 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 THERMAL CONSIDERATIONS The LM2596 is available in two packages, a 5-pin TO-220 (T) and a 5-pin surface mount TO-263 (S). The TO-220 package needs a heat sink under most conditions. The size of the heatsink depends on the input voltage, the output voltage, the load current and the ambient temperature. The curves in Figure 31 show the LM2596T junction temperature rises above ambient temperature for a 3A load and different input and output voltages. The data for these curves was taken with the LM2596T (TO-220 package) operating as a buck switching regulator in an ambient temperature of 25°C (still air). These temperature rise numbers are all approximate and there are many factors that can affect these temperatures. Higher ambient temperatures require more heat sinking. The TO-263 surface mount package tab is designed to be soldered to the copper on a printed circuit board. The copper and the board are the heat sink for this package and the other heat producing components, such as the catch diode and inductor. The PC board copper area that the package is soldered to should be at least 0.4 in2, and ideally should have 2 or more square inches of 2 oz. (0.0028 in.) copper. Additional copper area improves the thermal characteristics, but with copper areas greater than approximately 6 in2, only small improvements in heat dissipation are realized. If further thermal improvements are needed, double sided, multilayer PC board with large copper areas and/or airflow are recommended. The curves shown in Figure 32 show the LM2596S (TO-263 package) junction temperature rise above ambient temperature with a 2A load for various input and output voltages. This data was taken with the circuit operating as a buck switching regulator with all components mounted on a PC board to simulate the junction temperature under actual operating conditions. This curve can be used for a quick check for the approximate junction temperature for various conditions, but be aware that there are many factors that can affect the junction temperature. When load currents higher than 2A are used, double sided or multilayer PC boards with large copper areas and/or airflow might be needed, especially for high ambient temperatures and high output voltages. For the best thermal performance, wide copper traces and generous amounts of printed circuit board copper should be used in the board layout. (One exception to this is the output (switch) pin, which should not have large areas of copper.) Large areas of copper provide the best transfer of heat (lower thermal resistance) to the surrounding air, and moving air lowers the thermal resistance even further. Package thermal resistance and junction temperature rise numbers are all approximate, and there are many factors that will affect these numbers. Some of these factors include board size, shape, thickness, position, location, and even board temperature. Other factors are, trace width, total printed circuit copper area, copper thickness, single- or double-sided, multilayer board and the amount of solder on the board. The effectiveness of the PC board to dissipate heat also depends on the size, quantity and spacing of other components on the board, as well as whether the surrounding air is still or moving. Furthermore, some of these components such as the catch diode will add heat to the PC board and the heat can vary as the input voltage changes. For the inductor, depending on the physical size, type of core material and the DC resistance, it could either act as a heat sink taking heat away from the board, or it could add heat to the board. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 25 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Circuit Data for Temperature Rise Curve TO-220 Package (T) Capacitors Through hole electrolytic Inductor Through hole, Renco Diode Through hole, 5A 40V, Schottky PC board 3 square inches single sided 2 oz. copper (0.0028″) Figure 31. Junction Temperature Rise, TO-220 Circuit Data for Temperature Rise Curve TO-263 Package (S) Capacitors Surface mount tantalum, molded “D” size Inductor Surface mount, Pulse Engineering, 68 μH Diode Surface mount, 5A 40V, Schottky PC board 9 square inches single sided 2 oz. copper (0.0028″) Figure 32. Junction Temperature Rise, TO-263 26 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 Figure 33. Delayed Startup Figure 34. Undervoltage Lockout for Buck Regulator DELAYED STARTUP The circuit in Figure 33 uses the the ON /OFF pin to provide a time delay between the time the input voltage is applied and the time the output voltage comes up (only the circuitry pertaining to the delayed start up is shown). As the input voltage rises, the charging of capacitor C1 pulls the ON /OFF pin high, keeping the regulator off. Once the input voltage reaches its final value and the capacitor stops charging, and resistor R2 pulls the ON /OFF pin low, thus allowing the circuit to start switching. Resistor R1 is included to limit the maximum voltage applied to the ON /OFF pin (maximum of 25V), reduces power supply noise sensitivity, and also limits the capacitor, C1, discharge current. When high input ripple voltage exists, avoid long delay time, because this ripple can be coupled into the ON /OFF pin and cause problems. This delayed startup feature is useful in situations where the input power source is limited in the amount of current it can deliver. It allows the input voltage to rise to a higher voltage before the regulator starts operating. Buck regulators require less input current at higher input voltages. UNDERVOLTAGE LOCKOUT Some applications require the regulator to remain off until the input voltage reaches a predetermined voltage. An undervoltage lockout feature applied to a buck regulator is shown in Figure 34, while Figure 35 and Figure 36 applies the same feature to an inverting circuit. The circuit in Figure 35 features a constant threshold voltage for turn on and turn off (zener voltage plus approximately one volt). If hysteresis is needed, the circuit in Figure 36 has a turn ON voltage which is different than the turn OFF voltage. The amount of hysteresis is approximately equal to the value of the output voltage. If zener voltages greater than 25V are used, an additional 47 kΩ resistor is needed from the ON /OFF pin to the ground pin to stay within the 25V maximum limit of the ON /OFF pin. INVERTING REGULATOR The circuit in Figure 37 converts a positive input voltage to a negative output voltage with a common ground. The circuit operates by bootstrapping the regulator's ground pin to the negative output voltage, then grounding the feedback pin, the regulator senses the inverted output voltage and regulates it. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 27 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com This circuit has an ON/OFF threshold of approximately 13V. Figure 35. Undervoltage Lockout for Inverting Regulator This example uses the LM2596-5.0 to generate a −5V output, but other output voltages are possible by selecting other output voltage versions, including the adjustable version. Since this regulator topology can produce an output voltage that is either greater than or less than the input voltage, the maximum output current greatly depends on both the input and output voltage. The curve shown in Figure 38 provides a guide as to the amount of output load current possible for the different input and output voltage conditions. The maximum voltage appearing across the regulator is the absolute sum of the input and output voltage, and this must be limited to a maximum of 40V. For example, when converting +20V to −12V, the regulator would see 32V between the input pin and ground pin. The LM2596 has a maximum input voltage spec of 40V. Additional diodes are required in this regulator configuration. Diode D1 is used to isolate input voltage ripple or noise from coupling through the CIN capacitor to the output, under light or no load conditions. Also, this diode isolation changes the topology to closley resemble a buck configuration thus providing good closed loop stability. A Schottky diode is recommended for low input voltages, (because of its lower voltage drop) but for higher input voltages, a fast recovery diode could be used. Without diode D3, when the input voltage is first applied, the charging current of CIN can pull the output positive by several volts for a short period of time. Adding D3 prevents the output from going positive by more than a diode voltage. This circuit has hysteresis Regulator starts switching at VIN = 13V Regulator stops switching at VIN = 8V Figure 36. Undervoltage Lockout with Hysteresis for Inverting Regulator 28 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 CIN —68 μF/25V Tant. Sprague 595D 470 μF/50V Elec. Panasonic HFQ COUT —47 μF/20V Tant. Sprague 595D 220 μF/25V Elec. Panasonic HFQ Figure 37. Inverting −5V Regulator with Delayed Startup Figure 38. Inverting Regulator Typical Load Current Because of differences in the operation of the inverting regulator, the standard design procedure is not used to select the inductor value. In the majority of designs, a 33 μH, 3.5A inductor is the best choice. Capacitor selection can also be narrowed down to just a few values. Using the values shown in Figure 37 will provide good results in the majority of inverting designs. This type of inverting regulator can require relatively large amounts of input current when starting up, even with light loads. Input currents as high as the LM2596 current limit (approx 4.5A) are needed for at least 2 ms or more, until the output reaches its nominal output voltage. The actual time depends on the output voltage and the size of the output capacitor. Input power sources that are current limited or sources that can not deliver these currents without getting loaded down, may not work correctly. Because of the relatively high startup currents required by the inverting topology, the delayed startup feature (C1, R1 and R2) shown in Figure 37 is recommended. By delaying the regulator startup, the input capacitor is allowed to charge up to a higher voltage before the switcher begins operating. A portion of the high input current needed for startup is now supplied by the input capacitor (CIN). For severe start up conditions, the input capacitor can be made much larger than normal. INVERTING REGULATOR SHUTDOWN METHODS To use the ON /OFF pin in a standard buck configuration is simple, pull it below 1.3V (@25°C, referenced to ground) to turn regulator ON, pull it above 1.3V to shut the regulator OFF. With the inverting configuration, some level shifting is required, because the ground pin of the regulator is no longer at ground, but is now setting at the negative output voltage level. Two different shutdown methods for inverting regulators are shown in Figure 39 and Figure 40. Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 29 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com Figure 39. Inverting Regulator Ground Referenced Shutdown Figure 40. Inverting Regulator Ground Referenced Shutdown using Opto Device TYPICAL THROUGH HOLE PC BOARD LAYOUT, FIXED OUTPUT (1X SIZE), DOUBLE SIDED CIN—470 μF, 50V, Aluminum Electrolytic Panasonic, “HFQ Series” COUT—330 μF, 35V, Aluminum Electrolytic Panasonic, “HFQ Series” D1—5A, 40V Schottky Rectifier, 1N5825 L1—47 μH, L39, Renco, Through Hole Thermalloy Heat Sink #7020 30 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 LM2596 www.ti.com SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 TYPICAL THROUGH HOLE PC BOARD LAYOUT, ADJUSTABLE OUTPUT (1X SIZE), DOUBLE SIDED CIN—470 μF, 50V, Aluminum Electrolytic Panasonic, “HFQ Series” COUT—220 μF, 35V Aluminum Electrolytic Panasonic, “HFQ Series” D1—5A, 40V Schottky Rectifier, 1N5825 L1—47 μH, L39, Renco, Through Hole R1—1 kΩ, 1% R2—Use formula in Design Procedure CFF—See Table 2. Thermalloy Heat Sink #7020 Figure 41. PC Board Layout Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 31 LM2596 SNVS124C – NOVEMBER 1999 – REVISED APRIL 2013 www.ti.com REVISION HISTORY Changes from Revision B (April 2013) to Revision C • 32 Page Changed layout of National Data Sheet to TI format .......................................................................................................... 31 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LM2596 PACKAGE OPTION ADDENDUM www.ti.com 11-Apr-2013 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish (2) MSL Peak Temp Op Temp (°C) Top-Side Markings (3) (4) LM2596S-12 ACTIVE DDPAK/ TO-263 KTT 5 45 TBD Call TI Call TI LM2596S -12 P+ LM2596S-12/NOPB ACTIVE DDPAK/ TO-263 KTT 5 45 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596S -12 P+ LM2596S-3.3 ACTIVE DDPAK/ TO-263 KTT 5 45 TBD Call TI Call TI LM2596S -3.3 P+ LM2596S-3.3/NOPB ACTIVE DDPAK/ TO-263 KTT 5 45 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596S -3.3 P+ LM2596S-5.0 ACTIVE DDPAK/ TO-263 KTT 5 45 TBD Call TI Call TI LM2596S -5.0 P+ LM2596S-5.0/NOPB ACTIVE DDPAK/ TO-263 KTT 5 45 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596S -5.0 P+ LM2596S-ADJ/NOPB ACTIVE DDPAK/ TO-263 KTT 5 45 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596SX-12 ACTIVE DDPAK/ TO-263 KTT 5 500 TBD Call TI Call TI LM2596S -12 P+ LM2596SX-12/NOPB ACTIVE DDPAK/ TO-263 KTT 5 500 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596S -12 P+ LM2596SX-3.3 ACTIVE DDPAK/ TO-263 KTT 5 500 TBD Call TI Call TI LM2596S -3.3 P+ LM2596SX-3.3/NOPB ACTIVE DDPAK/ TO-263 KTT 5 500 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596S -3.3 P+ LM2596SX-5.0/NOPB ACTIVE DDPAK/ TO-263 KTT 5 500 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR LM2596S -5.0 P+ LM2596SX-ADJ ACTIVE DDPAK/ TO-263 KTT 5 500 TBD Call TI Call TI -40 to 125 LM2596S -ADJ P+ LM2596SX-ADJ/NOPB ACTIVE DDPAK/ TO-263 KTT 5 500 Pb-Free (RoHS Exempt) CU SN Level-3-245C-168 HR -40 to 125 LM2596S -ADJ P+ LM2596T-12 ACTIVE TO-220 NDH 5 45 TBD Call TI Call TI LM2596T -12 P+ LM2596T-12/LF03 ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -12 P+ LM2596T-12/NOPB ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -12 P+ Addendum-Page 1 -40 to 125 LM2596S -ADJ P+ Samples PACKAGE OPTION ADDENDUM www.ti.com 11-Apr-2013 Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish (2) MSL Peak Temp Op Temp (°C) Top-Side Markings (3) (4) LM2596T-3.3 ACTIVE TO-220 NDH 5 45 TBD Call TI Call TI LM2596T -3.3 P+ LM2596T-3.3/LF03 ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -3.3 P+ LM2596T-3.3/NOPB ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -3.3 P+ LM2596T-5.0 ACTIVE TO-220 NDH 5 45 TBD Call TI Call TI LM2596T -5.0 P+ LM2596T-5.0/LF03 ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -5.0 P+ LM2596T-5.0/NOPB ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -5.0 P+ LM2596T-ADJ ACTIVE TO-220 NDH 5 45 TBD Call TI Call TI LM2596T-ADJ/LB05 ACTIVE TO-220 NEB 5 45 TBD Call TI Call TI LM2596T -ADJ P+ LM2596T-ADJ/LF02 ACTIVE TO-220 NEB 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM LM2596T -ADJ P+ LM2596T-ADJ/NOPB ACTIVE TO-220 NDH 5 45 Green (RoHS & no Sb/Br) CU SN Level-1-NA-UNLIM -40 to 125 -40 to 125 LM2596T -ADJ P+ LM2596T -ADJ P+ (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) Addendum-Page 2 Samples PACKAGE OPTION ADDENDUM www.ti.com (3) 11-Apr-2013 MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) Multiple Top-Side Markings will be inside parentheses. Only one Top-Side Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Top-Side Marking for that device. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 3 PACKAGE MATERIALS INFORMATION www.ti.com 8-Apr-2013 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant LM2596SX-12 DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 LM2596SX-12/NOPB DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 LM2596SX-3.3 DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 LM2596SX-3.3/NOPB DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 LM2596SX-5.0/NOPB DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 LM2596SX-ADJ DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 LM2596SX-ADJ/NOPB DDPAK/ TO-263 KTT 5 500 330.0 24.4 10.75 14.85 5.0 16.0 24.0 Q2 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 8-Apr-2013 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) LM2596SX-12 DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 LM2596SX-12/NOPB DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 LM2596SX-3.3 DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 LM2596SX-3.3/NOPB DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 LM2596SX-5.0/NOPB DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 LM2596SX-ADJ DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 LM2596SX-ADJ/NOPB DDPAK/TO-263 KTT 5 500 367.0 367.0 45.0 Pack Materials-Page 2 MECHANICAL DATA NDH0005D www.ti.com MECHANICAL DATA KTT0005B TS5B (Rev D) BOTTOM SIDE OF PACKAGE www.ti.com MECHANICAL DATA NEB0005B www.ti.com MECHANICAL DATA NEB0005E www.ti.com IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2013, Texas Instruments Incorporated
106990003 价格&库存
很抱歉,暂时无法提供与“106990003”相匹配的价格&库存,您可以联系我们找货
